    2. English
    3. ioBroker general
    4. Neato Botvac adapter - further development
      csp @PeterVoronov last edited by
      @petervoronov I tried that already. It is a bit difficult, as I'm running it on Synology server in docker.
      It did run through though, but not worked at the end.
      Any idea on how to wipe the adapter fully? (Not all of course, just this one)
      Happy to follow instructions.
      Thomas
        csp @csp last edited by
        @csp I just did it again, no success.
        So I deinstalled the adapter and manually deleted the module folder.
        Reboot ioBroker.
        Reinstall bot vac adapter -> OK
        Putting credentials in and restart... -> same issue. ioBroker tries 3 times to rebuild and fails...
        host.iobroker
        2023-09-01 09:37:08.038	info	iobroker npm-rebuild: Rebuilding native modules ...
        host.iobroker
        2023-09-01 09:37:06.088	info	iobroker rebuild
        host.iobroker
        2023-09-01 09:37:06.088	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        host.iobroker
        2023-09-01 09:37:06.087	info	system.adapter.botvac.0 will be rebuilt
        host.iobroker
        2023-09-01 09:37:06.087	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
        host.iobroker
        2023-09-01 09:37:06.086	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        2023-09-01 09:37:06.086	error	Caught by controller[0]: Node.js v18.17.1
        host.iobroker
        2023-09-01 09:37:06.086	error	Caught by controller[0]: }
        host.iobroker
        2023-09-01 09:37:06.086	error	Caught by controller[0]: ]
        host.iobroker
        2023-09-01 09:37:06.086	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
        host.iobroker
        2023-09-01 09:37:06.086	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
        host.iobroker
        2023-09-01 09:37:06.086	error	Caught by controller[0]: requireStack: [
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        host.iobroker
        2023-09-01 09:37:06.085	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: Require stack:
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        host.iobroker
        2023-09-01 09:37:06.079	error	Caught by controller[0]: ^
        host.iobroker
        2023-09-01 09:37:06.078	error	Caught by controller[0]: throw err;
        host.iobroker
        2023-09-01 09:37:06.078	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
        host.iobroker
        2023-09-01 09:37:02.812	info	instance system.adapter.botvac.0 started with pid 912
        host.iobroker
        2023-09-01 09:36:57.818	info	iobroker exit 0
        host.iobroker
        2023-09-01 09:36:56.009	info	iobroker host.iobroker object system.adapter.botvac.0 created
        host.iobroker
        2023-09-01 09:36:54.323	info	iobroker host.iobroker object system.adapter.botvac.0.logLevel created
        host.iobroker
        2023-09-01 09:36:53.946	info	iobroker host.iobroker object system.adapter.botvac.0.sigKill created
        host.iobroker
        2023-09-01 09:36:53.779	info	iobroker host.iobroker object system.adapter.botvac.0.eventLoopLag created
        host.iobroker
        2023-09-01 09:36:53.594	info	iobroker host.iobroker object system.adapter.botvac.0.outputCount created
        host.iobroker
        2023-09-01 09:36:53.420	info	iobroker host.iobroker object system.adapter.botvac.0.inputCount created
        host.iobroker
        2023-09-01 09:36:53.287	info	iobroker host.iobroker object system.adapter.botvac.0.uptime created
        host.iobroker
        2023-09-01 09:36:53.061	info	iobroker host.iobroker object system.adapter.botvac.0.memRss created
        host.iobroker
        2023-09-01 09:36:52.850	info	iobroker host.iobroker object system.adapter.botvac.0.memHeapTotal created
        host.iobroker
        2023-09-01 09:36:52.603	info	iobroker host.iobroker object system.adapter.botvac.0.memHeapUsed created
        host.iobroker
        2023-09-01 09:36:51.671	info	iobroker host.iobroker object system.adapter.botvac.0.cputime created
        host.iobroker
        2023-09-01 09:36:48.434	info	iobroker host.iobroker object system.adapter.botvac.0.cpu created
        host.iobroker
        2023-09-01 09:36:48.027	info	iobroker host.iobroker object system.adapter.botvac.0.compactMode created
        host.iobroker
        2023-09-01 09:36:47.669	info	iobroker host.iobroker object system.adapter.botvac.0.connected created
        host.iobroker
        2023-09-01 09:36:47.477	info	iobroker host.iobroker object system.adapter.botvac.0.alive created
        host.iobroker
        2023-09-01 09:36:47.342	info	iobroker host.iobroker create instance botvac
        host.iobroker
        2023-09-01 09:36:46.191	info	iobroker host.iobroker object system.adapter.botvac created/updated
          Thomas Braun Most Active @csp last edited by
          @csp
          I just did a crosscheck on my setup.
          The adapter installs without issues here.
          Check your setup, especially the nodejs install.
          iob diag
          may be helpfull.
            csp @Thomas Braun last edited by
            @thomas-braun Installation works fine on my end as well. But as soon as I want to log in, it doesn't work.
            What do I need to do exactly? Can you help?
              @csp
              No, I don't own that device, I just checked the adapter installation.
                @thomas-braun but maybe how I can check nodejs with iob diag?
                  @csp sagte in Neato Botvac adapter - further development:
                  iob diag
                  Just run it in your terminal and copy the output in the forum.
                  iob diag
                    @thomas-braun I think I'm doing something wrong...
                    root@iobroker:/opt/iobroker# iob diag
                    iobroker [command]
                    Commands:
                      iobroker setup                                               Setup ioBroker
                      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                      iobroker info                                                Shows the host info
                      iobroker logs [<adapter>]                                    Monitor log
                      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                      iobroker rebuild [<module>]                                  Rebuild all native modules or path
                      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                      iobroker update [<repositoryUrl>]                            Update repository and list adapters
                      iobroker upgrade                                             Upgrade management
                      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                      iobroker object                                              Object management  [aliases: o]
                      iobroker state                                               State management  [aliases: s]
                      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                      iobroker list <type> [<filter>]                              List all entries, like objects
                      iobroker chmod <mode> <file>                                 Change file rights
                      iobroker chown <user> <group> <file>                         Change file ownership
                      iobroker touch <file>                                        Touch file
                      iobroker rm <file>                                           Remove file
                      iobroker file                                                File management
                      iobroker user                                                User commands
                      iobroker group                                               group management
                      iobroker host <hostname>                                     Set host to given hostname
                      iobroker set <adapter>.<instance>                            Change settings of adapter config
                      iobroker license <license.file or license.text>              Update license by given file
                      iobroker cert                                                Certificate management
                      iobroker clean <yes>                                         Clears all objects and states
                      iobroker backup                                              Create backup
                      iobroker restore <backup name or path>                       Restore a specified backup
                      iobroker validate <backup name or path>                      Validate a specified backup
                      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                      iobroker repo [<name>]                                       Show repo information
                      iobroker uuid                                                Show uuid of the installation  [aliases: id]
                      iobroker unsetup                                             Reset license, installation secret and language
                      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                      iobroker multihost                                           Multihost management
                      iobroker compact                                             compact group management
                      iobroker plugin                                              Plugin management
                      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                    Options:
                      --help  Show help  [boolean]
                      @csp
                      iob stop
                      iob fix
                      iob start
                      iob diag
                      C 2 Replies Last reply Reply Quote 0
                        v.2023-04-16
                        Operatingsystem: Debian GNU/Linux 11 (bullseye)
                        Kernel: 4.4.180+
                        Installation: Docker
                        Timezone: Etc/UTC
                        User-ID: 0
                        X-Server: false
                        Pending OS-Updates: 121
                        Pending iob updates: 0
                        Nodejs-Installation: /usr/bin/nodejs v12.22.7
                        /usr/local/bin/node v18.17.1
                        /usr/local/bin/npm 9.6.7
                        /usr/local/bin/npx 9.6.7
                        Recommended versions are nodejs 18.x.y and npm 9.x.y
                        *** nodejs is NOT correctly installed ***
                        MEMORY:
                        total used free shared buff/cache available
                        Mem: 9.8G 3.7G 407M 558M 5.6G 5.2G
                        Swap: 7.9G 419M 7.5G
                        Total: 17G 4.2G 7.9G
                        Active iob-Instances: 34
                        Active repo(s): default, beta
                        ioBroker Core: js-controller 5.0.12
                        admin 6.9.1
                        ioBroker Status: iobroker is running on this host.
                        Objects type: jsonl
                        States type: jsonl
                        • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects: 20245
                        States: 3
                        Size of iob-Database:
                        25M /opt/iobroker/iobroker-data/objects.jsonl
                        13M /opt/iobroker/iobroker-data/objects.json.migrated
                        13M /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        61M /opt/iobroker/iobroker-data/states.jsonl
                        1.9M /opt/iobroker/iobroker-data/states.json.migrated
                        1.9M /opt/iobroker/iobroker-data/states.json.bak.migrated
                          @thomas-braun here you go:
                          v.2023-04-16
                          Kernel: 4.4.180+
                          Timezone: Etc/UTC
                          User-ID: 0
                          X-Server: false
                          MEMORY:
                          admin 6.9.1
                          Objects type: jsonl
                          States type: jsonl
                          Objects: 20245
                          States: 3
                            No need to read any further...
                            The correct installation of nodejs as runtime environment ist crucial.
                              @thomas-braun you are faster than I can correct my double post. 🙂
                              Yes, saw that as well. Need to see how I fix it.
                                Thomas Braun Most Active @csp last edited by Thomas Braun
                                @csp
                                This is a Docker?
                                Use the latest Version of Buanet Docker.
                                  @thomas-braun yes, Docker. Will most likely use Portainer to recreate and pull latest image.
                                    Did everything and node.js seems fine now. So at least this is fixed.
                                    BUT: My original problem with the adapter persists. Deleted and re-installed and same issue...
                                    Tried npm install --production in adapter directory. - Also not helping...
                                    I'm lost 😕
                                    root@iobroker:/opt/iobroker/node_modules/iobroker.botvac# npm install --production
                                    npm WARN config production Use `--omit=dev` instead.
                                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                    added 53 packages in 35s
                                    result:
                                    host.iobroker
                                    2023-09-01 19:33:28.292	info	iobroker npm-rebuild: Rebuilding native modules ...
                                    host.iobroker
                                    2023-09-01 19:33:26.133	info	iobroker rebuild
                                    host.iobroker
                                    2023-09-01 19:33:26.133	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                    host.iobroker
                                    2023-09-01 19:33:26.132	info	system.adapter.botvac.0 will be rebuilt
                                    host.iobroker
                                    2023-09-01 19:33:26.131	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
                                    host.iobroker
                                    2023-09-01 19:33:26.131	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.iobroker
                                    2023-09-01 19:33:26.131	error	Caught by controller[0]: Node.js v18.17.1
                                    host.iobroker
                                    2023-09-01 19:33:26.131	error	Caught by controller[0]: }
                                    host.iobroker
                                    2023-09-01 19:33:26.131	error	Caught by controller[0]: ]
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: requireStack: [
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                                    host.iobroker
                                    2023-09-01 19:33:26.130	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: Require stack:
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: ^
                                    host.iobroker
                                    2023-09-01 19:33:26.129	error	Caught by controller[0]: throw err;
                                    host.iobroker
                                    2023-09-01 19:33:26.128	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                                    host.iobroker
                                    2023-09-01 19:33:25.447	info	instance system.adapter.botvac.0 started with pid 816
                                      PeterVoronov @csp last edited by
                                      @csp
                                      May be it has sence to downgrade the node version? To v16, i.e. version 7 of docker image ?
                                        @petervoronov : Just tried that as well. - Same story, same error.
                                        Now I try to restore my system. Need to see what backups I have...
                                          I'm so glad to have automatic backup enabled on my server... Went back 2 months and it works again. I only moved my most recent objects.jsonl back to the folder. I'm not sure what happened in-between.
                                          Just did diag and it looks good. (Will update adapters one by one...)
                                                               v.2023-04-16
                                          Kernel:                 4.4.180+
                                          Timezone:               Etc/UTC
                                          User-ID:                0
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Pending iob updates:    13
                                          Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
                                          MEMORY:
                                          Mem:            9.8G        3.5G        555M        565M        5.8G        5.5G
                                          Swap:           7.9G        434M        7.5G
                                          Total:           17G        3.9G        8.1G
                                          Active iob-Instances:   35
                                          ioBroker Core:          js-controller           4.0.24
        admin                   6.5.9
                                          Objects type: jsonl
                                          States  type: jsonl
                                          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          Objects:                16657
                                          States:                 14206
                                          26M     /opt/iobroker/iobroker-data/objects.jsonl
                                          24M     /opt/iobroker/iobroker-data/states.jsonl
                                            @csp
                                            Please setup the time zone and do not mix the repos:
                                            68
                                            9540
