    2. English
    3. ioBroker general
    4. Neato Botvac adapter - further development
      csp @Thomas Braun last edited by
      @thomas-braun Installation works fine on my end as well. But as soon as I want to log in, it doesn't work.
      What do I need to do exactly? Can you help?
        Thomas Braun Most Active @csp last edited by
        @csp
        No, I don't own that device, I just checked the adapter installation.
          @thomas-braun but maybe how I can check nodejs with iob diag?
            @csp sagte in Neato Botvac adapter - further development:
            iob diag
            Just run it in your terminal and copy the output in the forum.
            iob diag
              @thomas-braun I think I'm doing something wrong...
              root@iobroker:/opt/iobroker# iob diag
              iobroker [command]
              Commands:
                iobroker setup                                               Setup ioBroker
                iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                iobroker info                                                Shows the host info
                iobroker logs [<adapter>]                                    Monitor log
                iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                iobroker rebuild [<module>]                                  Rebuild all native modules or path
                iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                iobroker update [<repositoryUrl>]                            Update repository and list adapters
                iobroker upgrade                                             Upgrade management
                iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                iobroker object                                              Object management  [aliases: o]
                iobroker state                                               State management  [aliases: s]
                iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                iobroker list <type> [<filter>]                              List all entries, like objects
                iobroker chmod <mode> <file>                                 Change file rights
                iobroker chown <user> <group> <file>                         Change file ownership
                iobroker touch <file>                                        Touch file
                iobroker rm <file>                                           Remove file
                iobroker file                                                File management
                iobroker user                                                User commands
                iobroker group                                               group management
                iobroker host <hostname>                                     Set host to given hostname
                iobroker set <adapter>.<instance>                            Change settings of adapter config
                iobroker license <license.file or license.text>              Update license by given file
                iobroker cert                                                Certificate management
                iobroker clean <yes>                                         Clears all objects and states
                iobroker backup                                              Create backup
                iobroker restore <backup name or path>                       Restore a specified backup
                iobroker validate <backup name or path>                      Validate a specified backup
                iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                iobroker repo [<name>]                                       Show repo information
                iobroker uuid                                                Show uuid of the installation  [aliases: id]
                iobroker unsetup                                             Reset license, installation secret and language
                iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                iobroker multihost                                           Multihost management
                iobroker compact                                             compact group management
                iobroker plugin                                              Plugin management
                iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
              Options:
                --help  Show help  [boolean]
                @csp
                iob stop
                iob fix
                iob start
                iob diag
                C 2 Replies Last reply Reply Quote 0
                  v.2023-04-16
                  Operatingsystem: Debian GNU/Linux 11 (bullseye)
                  Kernel: 4.4.180+
                  Installation: Docker
                  Timezone: Etc/UTC
                  User-ID: 0
                  X-Server: false
                  Pending OS-Updates: 121
                  Pending iob updates: 0
                  Nodejs-Installation: /usr/bin/nodejs v12.22.7
                  /usr/local/bin/node v18.17.1
                  /usr/local/bin/npm 9.6.7
                  /usr/local/bin/npx 9.6.7
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  *** nodejs is NOT correctly installed ***
                  MEMORY:
                  total used free shared buff/cache available
                  Mem: 9.8G 3.7G 407M 558M 5.6G 5.2G
                  Swap: 7.9G 419M 7.5G
                  Total: 17G 4.2G 7.9G
                  Active iob-Instances: 34
                  Active repo(s): default, beta
                  ioBroker Core: js-controller 5.0.12
                  admin 6.9.1
                  ioBroker Status: iobroker is running on this host.
                  Objects type: jsonl
                  States type: jsonl
                  • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects: 20245
                  States: 3
                  Size of iob-Database:
                  25M /opt/iobroker/iobroker-data/objects.jsonl
                  13M /opt/iobroker/iobroker-data/objects.json.migrated
                  13M /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  61M /opt/iobroker/iobroker-data/states.jsonl
                  1.9M /opt/iobroker/iobroker-data/states.json.migrated
                  1.9M /opt/iobroker/iobroker-data/states.json.bak.migrated
                    @thomas-braun here you go:
                    v.2023-04-16
                    Kernel: 4.4.180+
                    Timezone: Etc/UTC
                    User-ID: 0
                    X-Server: false
                    MEMORY:
                    admin 6.9.1
                    Objects type: jsonl
                    States type: jsonl
                    Objects: 20245
                    States: 3
                      No need to read any further...
                      The correct installation of nodejs as runtime environment ist crucial.
                        @thomas-braun you are faster than I can correct my double post. 🙂
                        Yes, saw that as well. Need to see how I fix it.
                          Thomas Braun Most Active @csp last edited by Thomas Braun
                          @csp
                          This is a Docker?
                          Use the latest Version of Buanet Docker.
                            @thomas-braun yes, Docker. Will most likely use Portainer to recreate and pull latest image.
                              csp @csp last edited by
                              Did everything and node.js seems fine now. So at least this is fixed.
                              BUT: My original problem with the adapter persists. Deleted and re-installed and same issue...
                              Tried npm install --production in adapter directory. - Also not helping...
                              I'm lost 😕
                              root@iobroker:/opt/iobroker/node_modules/iobroker.botvac# npm install --production
                              npm WARN config production Use `--omit=dev` instead.
                              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              added 53 packages in 35s
                              result:
                              host.iobroker
                              2023-09-01 19:33:28.292	info	iobroker npm-rebuild: Rebuilding native modules ...
                              host.iobroker
                              2023-09-01 19:33:26.133	info	iobroker rebuild
                              host.iobroker
                              2023-09-01 19:33:26.133	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                              host.iobroker
                              2023-09-01 19:33:26.132	info	system.adapter.botvac.0 will be rebuilt
                              host.iobroker
                              2023-09-01 19:33:26.131	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
                              host.iobroker
                              2023-09-01 19:33:26.131	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.iobroker
                              2023-09-01 19:33:26.131	error	Caught by controller[0]: Node.js v18.17.1
                              host.iobroker
                              2023-09-01 19:33:26.131	error	Caught by controller[0]: }
                              host.iobroker
                              2023-09-01 19:33:26.131	error	Caught by controller[0]: ]
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: requireStack: [
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                              host.iobroker
                              2023-09-01 19:33:26.130	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: Require stack:
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: ^
                              host.iobroker
                              2023-09-01 19:33:26.129	error	Caught by controller[0]: throw err;
                              host.iobroker
                              2023-09-01 19:33:26.128	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                              host.iobroker
                              2023-09-01 19:33:25.447	info	instance system.adapter.botvac.0 started with pid 816
                              mikeal created this issue in request/request
                              open Request’s Past, Present and Future #3142
                                PeterVoronov @csp last edited by
                                @csp
                                May be it has sence to downgrade the node version? To v16, i.e. version 7 of docker image ?
                                  csp @PeterVoronov last edited by
                                  @petervoronov : Just tried that as well. - Same story, same error.
                                  Now I try to restore my system. Need to see what backups I have...
                                    I'm so glad to have automatic backup enabled on my server... Went back 2 months and it works again. I only moved my most recent objects.jsonl back to the folder. I'm not sure what happened in-between.
                                    Just did diag and it looks good. (Will update adapters one by one...)
                                                         v.2023-04-16
                                    Kernel:                 4.4.180+
                                    Timezone:               Etc/UTC
                                    User-ID:                0
                                    X-Server:               false
                                    Pending OS-Updates:     0
                                    Pending iob updates:    13
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                            /usr/bin/node           v18.17.1
                                                            /usr/bin/npm            9.6.7
                                                            /usr/bin/npx            9.6.7
                                    MEMORY:
                                    Mem:            9.8G        3.5G        555M        565M        5.8G        5.5G
                                    Swap:           7.9G        434M        7.5G
                                    Total:           17G        3.9G        8.1G
                                    Active iob-Instances:   35
                                    ioBroker Core:          js-controller           4.0.24
                                                            admin                   6.5.9
                                    Objects type: jsonl
                                    States  type: jsonl
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    Objects:                16657
                                    States:                 14206
                                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                                    24M     /opt/iobroker/iobroker-data/states.jsonl
                                      @csp
                                      Please setup the time zone and do not mix the repos:
                                        csp @Thomas Braun last edited by csp
                                        @thomas-braun fixed and thanks for the help.
                                        Will now update adapters. I'm curious if js adapter will cause again the issue.
                                        Edit: All adapters updated. No problem.
                                        Now final step: js controller 4.0.24 -> 5.0.12 - let's see 🙂
                                          @thomas-braun so now I found the issue.
                                          js controller update is causing issue.
                                          Maybe the way I'm doing it is not correct.
                                          Here is what I did:
                                          iobroker console:
                                          pkill -u iobroker
                                          iobroker update
                                          iobroker upgrade self
                                          -> js controller gets upgraded, but now I have the old problem.
                                          What am I'm doing wrong?
                                            Nothing. It seems as if the adapter needs to be adjusted to the current js-controller.
                                            68
                                            9553
