    2. English
    3. ioBroker general
    4. Neato Botvac adapter - further development
      Thomas Braun Most Active @csp last edited by
      @csp
      No, I don't own that device, I just checked the adapter installation.
        csp @Thomas Braun last edited by
        @thomas-braun but maybe how I can check nodejs with iob diag?
          @csp sagte in Neato Botvac adapter - further development:
          iob diag
          Just run it in your terminal and copy the output in the forum.
          iob diag
            @thomas-braun I think I'm doing something wrong...
            root@iobroker:/opt/iobroker# iob diag
            iobroker [command]
            Commands:
              iobroker setup                                               Setup ioBroker
              iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
              iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
              iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
              iobroker info                                                Shows the host info
              iobroker logs [<adapter>]                                    Monitor log
              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
              iobroker rebuild [<module>]                                  Rebuild all native modules or path
              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
              iobroker update [<repositoryUrl>]                            Update repository and list adapters
              iobroker upgrade                                             Upgrade management
              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
              iobroker object                                              Object management  [aliases: o]
              iobroker state                                               State management  [aliases: s]
              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
              iobroker list <type> [<filter>]                              List all entries, like objects
              iobroker chmod <mode> <file>                                 Change file rights
              iobroker chown <user> <group> <file>                         Change file ownership
              iobroker touch <file>                                        Touch file
              iobroker rm <file>                                           Remove file
              iobroker file                                                File management
              iobroker user                                                User commands
              iobroker group                                               group management
              iobroker host <hostname>                                     Set host to given hostname
              iobroker set <adapter>.<instance>                            Change settings of adapter config
              iobroker license <license.file or license.text>              Update license by given file
              iobroker cert                                                Certificate management
              iobroker clean <yes>                                         Clears all objects and states
              iobroker backup                                              Create backup
              iobroker restore <backup name or path>                       Restore a specified backup
              iobroker validate <backup name or path>                      Validate a specified backup
              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
              iobroker repo [<name>]                                       Show repo information
              iobroker uuid                                                Show uuid of the installation  [aliases: id]
              iobroker unsetup                                             Reset license, installation secret and language
              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost                                           Multihost management
              iobroker compact                                             compact group management
              iobroker plugin                                              Plugin management
              iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
            Options:
              --help  Show help  [boolean]
              @csp
              iob stop
              iob fix
              iob start
              iob diag
              C 2 Replies Last reply Reply Quote 0
                v.2023-04-16
                Operatingsystem: Debian GNU/Linux 11 (bullseye)
                Kernel: 4.4.180+
                Installation: Docker
                Timezone: Etc/UTC
                User-ID: 0
                X-Server: false
                Pending OS-Updates: 121
                Pending iob updates: 0
                Nodejs-Installation: /usr/bin/nodejs v12.22.7
                /usr/local/bin/node v18.17.1
                /usr/local/bin/npm 9.6.7
                /usr/local/bin/npx 9.6.7
                Recommended versions are nodejs 18.x.y and npm 9.x.y
                *** nodejs is NOT correctly installed ***
                MEMORY:
                total used free shared buff/cache available
                Mem: 9.8G 3.7G 407M 558M 5.6G 5.2G
                Swap: 7.9G 419M 7.5G
                Total: 17G 4.2G 7.9G
                Active iob-Instances: 34
                Active repo(s): default, beta
                ioBroker Core: js-controller 5.0.12
                admin 6.9.1
                ioBroker Status: iobroker is running on this host.
                Objects type: jsonl
                States type: jsonl
                • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects: 20245
                States: 3
                Size of iob-Database:
                25M /opt/iobroker/iobroker-data/objects.jsonl
                13M /opt/iobroker/iobroker-data/objects.json.migrated
                13M /opt/iobroker/iobroker-data/objects.json.bak.migrated
                61M /opt/iobroker/iobroker-data/states.jsonl
                1.9M /opt/iobroker/iobroker-data/states.json.migrated
                1.9M /opt/iobroker/iobroker-data/states.json.bak.migrated
                  @thomas-braun here you go:
                  v.2023-04-16
                  Kernel: 4.4.180+
                  Timezone: Etc/UTC
                  User-ID: 0
                  X-Server: false
                  MEMORY:
                  admin 6.9.1
                  Objects type: jsonl
                  States type: jsonl
                  Objects: 20245
                  States: 3
                    No need to read any further...
                    The correct installation of nodejs as runtime environment ist crucial.
                      @thomas-braun you are faster than I can correct my double post. 🙂
                      Yes, saw that as well. Need to see how I fix it.
                        Thomas Braun Most Active @csp last edited by Thomas Braun
                        @csp
                        This is a Docker?
                        Use the latest Version of Buanet Docker.
                          @thomas-braun yes, Docker. Will most likely use Portainer to recreate and pull latest image.
                            csp @csp last edited by
                            Did everything and node.js seems fine now. So at least this is fixed.
                            BUT: My original problem with the adapter persists. Deleted and re-installed and same issue...
                            Tried npm install --production in adapter directory. - Also not helping...
                            I'm lost 😕
                            root@iobroker:/opt/iobroker/node_modules/iobroker.botvac# npm install --production
                            npm WARN config production Use `--omit=dev` instead.
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            added 53 packages in 35s
                            result:
                            host.iobroker
                            2023-09-01 19:33:28.292	info	iobroker npm-rebuild: Rebuilding native modules ...
                            host.iobroker
                            2023-09-01 19:33:26.133	info	iobroker rebuild
                            host.iobroker
                            2023-09-01 19:33:26.133	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                            host.iobroker
                            2023-09-01 19:33:26.132	info	system.adapter.botvac.0 will be rebuilt
                            host.iobroker
                            2023-09-01 19:33:26.131	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
                            host.iobroker
                            2023-09-01 19:33:26.131	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.iobroker
                            2023-09-01 19:33:26.131	error	Caught by controller[0]: Node.js v18.17.1
                            host.iobroker
                            2023-09-01 19:33:26.131	error	Caught by controller[0]: }
                            host.iobroker
                            2023-09-01 19:33:26.131	error	Caught by controller[0]: ]
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: requireStack: [
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
                            host.iobroker
                            2023-09-01 19:33:26.130	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: Require stack:
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: ^
                            host.iobroker
                            2023-09-01 19:33:26.129	error	Caught by controller[0]: throw err;
                            host.iobroker
                            2023-09-01 19:33:26.128	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
                            host.iobroker
                            2023-09-01 19:33:25.447	info	instance system.adapter.botvac.0 started with pid 816
                            mikeal created this issue in request/request
                            open Request’s Past, Present and Future #3142
                              PeterVoronov @csp last edited by
                              @csp
                              May be it has sence to downgrade the node version? To v16, i.e. version 7 of docker image ?
                                csp @PeterVoronov last edited by
                                @petervoronov : Just tried that as well. - Same story, same error.
                                Now I try to restore my system. Need to see what backups I have...
                                  I'm so glad to have automatic backup enabled on my server... Went back 2 months and it works again. I only moved my most recent objects.jsonl back to the folder. I'm not sure what happened in-between.
                                  Just did diag and it looks good. (Will update adapters one by one...)
                                                       v.2023-04-16
                                  Kernel:                 4.4.180+
                                  Timezone:               Etc/UTC
                                  User-ID:                0
                                  X-Server:               false
                                  Pending OS-Updates:     0
                                  Pending iob updates:    13
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                          /usr/bin/node           v18.17.1
                                                          /usr/bin/npm            9.6.7
                                                          /usr/bin/npx            9.6.7
                                  MEMORY:
                                  Mem:            9.8G        3.5G        555M        565M        5.8G        5.5G
                                  Swap:           7.9G        434M        7.5G
                                  Total:           17G        3.9G        8.1G
                                  Active iob-Instances:   35
                                  ioBroker Core:          js-controller           4.0.24
                                                          admin                   6.5.9
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                16657
                                  States:                 14206
                                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                                  24M     /opt/iobroker/iobroker-data/states.jsonl
                                    @csp
                                    Please setup the time zone and do not mix the repos:
                                      csp @Thomas Braun last edited by csp
                                      @thomas-braun fixed and thanks for the help.
                                      Will now update adapters. I'm curious if js adapter will cause again the issue.
                                      Edit: All adapters updated. No problem.
                                      Now final step: js controller 4.0.24 -> 5.0.12 - let's see 🙂
                                        @thomas-braun so now I found the issue.
                                        js controller update is causing issue.
                                        Maybe the way I'm doing it is not correct.
                                        Here is what I did:
                                        iobroker console:
                                        pkill -u iobroker
                                        iobroker update
                                        iobroker upgrade self
                                        -> js controller gets upgraded, but now I have the old problem.
                                        What am I'm doing wrong?
                                          Nothing. It seems as if the adapter needs to be adjusted to the current js-controller.
                                            @PeterVoronov -> maybe something you could take a look...
                                            Until then I'll stay on 4.0.24
                                            68
                                            9532
