    3. Entwicklung
    4. Re-New DoorBird Adapter v1.0.x
    • Negalein
      Negalein Global Moderator @Schmakus last edited by
      @schmakus sagte in Re-New DoorBird Adapter v1.0.x:
      Hi, zeig mal einen Debug-Log, wenn geklingelt wird.
      hat etwas gedauert 😉
      doorbird.0
      2023-08-22 20:43:44.382	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:44.329	debug	Received Ring-alert (ID: 102) from Doorbird!
      doorbird.0
      2023-08-22 20:43:44.322	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:44.289	debug	Received Ring-alert (ID: 102) from Doorbird!
      doorbird.0
      2023-08-22 20:43:44.283	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:44.256	debug	Received Ring-alert (ID: 102) from Doorbird!
      doorbird.0
      2023-08-22 20:43:44.247	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:44.213	debug	Received Ring-alert (ID: 102) from Doorbird!
      doorbird.0
      2023-08-22 20:43:43.719	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:43.696	debug	Received Ring-alert (ID: 102) from Doorbird!
      doorbird.0
      2023-08-22 20:43:42.994	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:42.975	debug	Received Motion-alert from Doorbird!
      doorbird.0
      2023-08-22 20:43:42.974	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:42.942	debug	Received Motion-alert from Doorbird!
      doorbird.0
      2023-08-22 20:43:42.867	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:42.823	debug	Snapshot saved successfully!
      doorbird.0
      2023-08-22 20:43:42.661	warn	Error in downloading file: Error: Request failed with status code 404
      doorbird.0
      2023-08-22 20:43:42.568	debug	Received Motion-alert from Doorbird!
      doorbird.0
      2023-08-22 20:43:42.564	debug	Received Motion-alert from Doorbird!
      doorbird.0
      2023-08-22 20:43:42.562	debug	Received Motion-alert from Doorbird!
      doorbird.0
      2023-08-22 20:43:23.607	debug	Server gestartet auf Port 8100 und IP 10.0.1.202
      doorbird.0
      2023-08-22 20:43:23.536	debug	Okay we dont need to create any Doorbell-Schedules..
      doorbird.0
      doorbird.0
      2023-08-22 20:43:23.536	debug	Checking if we need to create Schedules on DoorBird Device..
      doorbird.0
      2023-08-22 20:43:23.536	debug	Favorites checked successfully. No actions needed!
      doorbird.0
      2023-08-22 20:43:23.536	debug	Checking if we need to create any favorites..
      doorbird.0
      2023-08-22 20:43:23.536	debug	Favorite for Doorbell ID 101 exists!
      doorbird.0
      2023-08-22 20:43:23.536	debug	Cheking if Favorite for Doorbell ID 101 exists.
      doorbird.0
      doorbird.0
      2023-08-22 20:43:23.536	debug	Favorite for Doorbell ID 102 exists!
      doorbird.0
      2023-08-22 20:43:23.536	debug	Cheking if Favorite for Doorbell ID 102 exists.
      doorbird.0
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "5" is: {"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "4" is: {"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "3" is: {"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "2" is: {"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "1" is: {"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "0" is: {"event":"notify","param":"","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	The Output contains 6 entries!
      doorbird.0
      2023-08-22 20:43:23.535	debug	Detected Motion Schedule!
      doorbird.0
      2023-08-22 20:43:23.535	debug	Counted 2 Doorbells.
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "5" is: {"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "4" is: {"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "3" is: {"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.535	debug	Entry "2" is: {"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "1" is: {"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "0" is: {"event":"notify","param":"","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	The Output contains 6 entries!
      doorbird.0
      2023-08-22 20:43:23.534	debug	The Param of the actual Schedule is: 101
      doorbird.0
      2023-08-22 20:43:23.534	debug	Detected a Doorbell Schedule!
      doorbird.0
      2023-08-22 20:43:23.534	debug	Counted 1 Doorbells.
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "5" is: {"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "4" is: {"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "3" is: {"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "2" is: {"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      2023-08-22 20:43:23.534	debug	Entry "1" is: {"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}
      doorbird.0
      doorbird.0
      doorbird.0
      2023-08-22 20:43:23.533	debug	The Param of the actual Schedule is: 102
      doorbird.0
      2023-08-22 20:43:23.533	debug	Detected a Doorbell Schedule!
      doorbird.0
      2023-08-22 20:43:23.533	debug	Looping through the Schedules..
      doorbird.0
      2023-08-22 20:43:23.533	debug	Following schedules found: [{"input":"doorbell","param":"102","output":[{"event":"notify","param":"","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}},{"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}]},{"input":"doorbell","param":"101","output":[{"event":"notify","param":"","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}},{"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}]},{"input":"motion","param":"","output":[{"event":"notify","param":"","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}},{"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}},{"event":"http","param":"2","enabled":"1","schedule":{"weekdays":[{"from":"79200","to":"79199"}]}}]},{"output":[{"schedule":{"weekdays":[{"from":"79200","to":"79199"}]},"param":"1","event":"relay"},{"schedule":{"weekdays":[{"from":"75600","to":"75599"}]},"param":"5","event":"http"}],"input":"rfid","param":"180,19463"},{"output":[{"schedule":{"weekdays":[{"from":"75600","to":"75599"}]},"param":"1","event":"relay"},{"event":"http","param":"7","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}],"input":"rfid","param":"184,63861"},{"output":[{"event":"relay","param":"1","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}},{"event":"http","param":"4","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}],"input":"rfid","param":"162,45091"},{"output":[{"schedule":{"weekdays":[{"from":"75600","to":"75599"}]},"param":"1","event":"relay"},{"event":"http","param":"6","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}],"input":"rfid","param":"162,62522"},{"output":[{"schedule":{"weekdays":[{"from":"75600","to":"75599"}]},"param":"1","event":"relay"},{"event":"http","param":"3","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}],"input":"rfid","param":"184,36797"},{"input":"relay","param":"1","output":[]}]
      doorbird.0
      2023-08-22 20:43:23.491	debug	Result of Favorites: {"101":{"ID":"1","URL":"http://10.0.1.202:8100/ring?101"},"102":{"ID":"0","URL":"http://10.0.1.202:8100/ring?102"},"Motion":{"ID":"2","URL":"http://10.0.1.202:8100/motion"}}
      doorbird.0
      2023-08-22 20:43:23.491	debug	Found a Favorite that belongs to me.. (ID: '2') ('ioBroker doorbird.0 Motion': 'http://10.0.1.202:8100/motion')
      doorbird.0
      2023-08-22 20:43:23.490	debug	Found a Favorite that belongs to me.. (ID: '1') ('ioBroker doorbird.0 101 Ring': 'http://10.0.1.202:8100/ring?101')
      doorbird.0
      2023-08-22 20:43:23.490	debug	Found a Favorite that belongs to me.. (ID: '0') ('ioBroker doorbird.0 102 Ring': 'http://10.0.1.202:8100/ring?102')
      doorbird.0
      2023-08-22 20:43:23.471	debug	Checking favorites on DoorBird Device..
      doorbird.0
      2023-08-22 20:43:23.099	debug	Authorization with User gheetq0002 successful!
      doorbird.0
      2023-08-22 20:43:22.865	info	starting. Version 1.2.3 (non-npm: iobroker-community-adapters/ioBroker.doorbird) in /opt/iobroker/node_modules/iobroker.doorbird, node: v18.17.1, js-controller: 4.0.24
      Schmakus 1 Reply Last reply Reply Quote 0
      • Schmakus
        Schmakus Developer @Negalein last edited by
        @negalein sagte in Re-New DoorBird Adapter v1.0.x:
        Mir fällt auf, dass du für jede Klinkel und motion jeweils 5 identische Zeitpläne hast! Bedeutet, bei jedem Klingeln werden 5 Snapshots erstellt. Da dies nahezu gleichzeitig passiert, kann es schnell zu einem Fehler 404 kommen. Gleiches beim Motion.
        Es geht um die HTTP Zeitpläne. Bitte bei dir in der Doorbird App prüfen und die nicht benötigten Zeitpläne löschen.
        • Negalein
          An das dachte ich auch gleich, aber das ist ja das komische.
          Die sind nur 1x vorhanden. Das passt.
          131ccf96-2f90-4d5e-ae1f-23c3e39b18e1-WhatsApp Bild 2023-08-23 um 09.26.04.jpg
          • Schmakus
            Das sind nicht die Zeitpläne! Das sind nur die Favoriten, also die HTTP Befehle! Die Zeitpläne findest du unter "Zeitplan für Türklingel"
            • Negalein
              ah, die meintest du.
              ist auch nur pro Klingel 1 Http Zeitplan vorhanden.
              6e7b31de-c7f6-422c-9ba3-08a731b87e8d-WhatsApp Bild 2023-08-23 um 10.09.08.jpg
              8a2e88a7-abfc-4b0a-8672-2f114b3b6697-WhatsApp Bild 2023-08-23 um 10.03.25.jpg
              • Schmakus
                Irgendetwas stimmt nicht..... Die API gibt 5 Zeitpläne für ein und denselben Favorite aus.....Aber deine App zeigt jeweils nur einen Zeitplan.
                Eventuell hängt es mit deinen RFID Zeitplänen zusammen?!
                Normal wäre:
                Doorbell => Zeitplan für HTTP, Notify und evtl. SIP
                Motion => Zeitplan für HTTP, Notify
                doorbird.0
                doorbird.0
                doorbird.0
                doorbird.0
                doorbird.0
                doorbird.0
                doorbird.0
                doorbird.0
                Negalein 2 Replies Last reply Reply Quote 0
                • Negalein
                  die hab ich schon von Anfang an.
                  Ich teste jetzt mal ein paar ältere Versionen.
                  • Negalein
                    Normal wäre:
                    hab jetzt alles mögliche probiert.
                    Zeitpläne gelöscht, neu angelegt, usw.
                    Keine Änderung
                    • Schmakus
                      Normal wäre:
                      Keine Änderung
                      Interessant für mich wäre, ob mit es mit der letzten 0.2.0 Version funktionieren würde. Da war der Code noch mit request und nicht axios.
                      Da an der eigentlichen Logik des Adapters nichts geändert wurde.
                      • Negalein
                        Hmmm, wie lautet nochmal der Befehl um die 0.2.0 zu installieren?
                        Über Admin gehts nur bis 1.?.x
                        • Schmakus
                          Schmakus Developer last edited by
                          @negalein sagte
                          npm install ioBroker.doorbird@0.2.0
                          • Negalein
                            funktioniert leider nicht
                            nega@ioBroker:/opt/iobroker$ npm install ioBroker.doorbird@0.2.0
                            [sudo] password for nega:
                            npm ERR! code E404
                            npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.doorbird - Not found
                            npm ERR! 404
                            npm ERR! 404  'ioBroker.doorbird@0.2.0' is not in this registry.
                            npm ERR! 404 This package name is not valid, because
                            npm ERR! 404  1. name can no longer contain capital letters
                            npm ERR! 404
                            npm ERR! 404 Note that you can also install from a
                            npm ERR! 404 tarball, folder, http url, or git url.
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-01T18_13_52_342Z-debug-0.log
                            • DJMarc75
                              DJMarc75 @Negalein last edited by
                              capital letters
                              Keine Grossbuchstaben verwenden, also
                              npm install iobroker.doorbird@0.2.0
                              Schmakus 1 Reply Last reply Reply Quote 1
                              • Schmakus
                                Schmakus Developer @DJMarc75 last edited by
                                @djmarc75 sagte in Re-New DoorBird Adapter v1.0.x:
                                capital letters
                                mein Fehler! Sorry.
                                  Ritschy2000 last edited by Ritschy2000
                                  2 kurze Fragen:
                                  1. habe die aktuelle 1.2.3 installiert, habe aber leider immer noch das Maximum Call Stack Problem, alle 3 Minuten... kann ich dagegen irgendetwas tun?
                                  Error in Parsing Schedules: RangeError: Maximum call stack size exceeded
                                  1. gibt es einen Trick, wie ich die erstellten Bilder in VIS darstellen kann,
                                    habe es mit /opt/iobroker/iobroker-data/files/doorbird.0/Doorbell1_1.jpg probiert,
                                    funktioniert leider nicht, Bild wird nicht angezeigt.
                                    Der Pfad ist korrekt und das Bild ist auch vorhanden/ wurde erstellt.
                                    Wenn ich mich recht erinnere, gab es doch Probleme, Bilder in VIS darzustellen, welche nicht
                                    im VIS Ordner liegen, oder?
                                    Mit der ursprünglichen Adapter-Version hat es noch funktioniert.
                                  Vielen Dank.
                                  Negalein Schmakus 2 Replies Last reply Reply Quote 0
                                    TeraX last edited by
                                    Hallo alle zusammen,
                                    ich habe seit gestern auch nun diese Fehlermeldungen im Log.
                                    Ich habe leider noch keine Zeit zum debuggen gehabt, muss ich am Wochenende mir anschauen.
                                    Ich habe eine D2101V und weiß, das gestern eine neue Firmware installiert wurde (000142).
                                    Ich möchte daher nicht ausschließen, dass es evtl damit etwas zu tun hat.
                                    RELEASE NOTES
                                    Firmware version 000142
                                    Release type:      Production
                                    Release date:      2023-08-16
                                    Products affected: DoorBird D10x, DoorBird D20x, DoorBird D21x, BirdGuard B10x
                                    Preceding version: 000141
                                    Corrections:       Improved communication via cloud, optimize connection to hardware modules (very rare cases)
                                    New Features:      n/a
                                    Known Bugs/Limitations: n/a
                                    Roll-out status:   Rolling out
                                    Ich schaue mir das ganze jedoch am Wochenede mal genauer an.
                                    Viele Grüße
                                    • Negalein
                                      Negalein Global Moderator @Ritschy2000 last edited by
                                      @ritschy2000 sagte in Re-New DoorBird Adapter v1.0.x:
                                      schau dir mein Widget an.
                                      Du darfst nicht /opt/....... schreiben.
                                      Bei mit steht im Bildpfad /doorbird.0/Motion_1.jpg
                                      [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"4400","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/doorbird.0/Motion_1.jpg","stretch":true,"refreshOnWakeUp":true,"refreshOnViewChange":true},"style":{"left":"1837px","top":"493px","width":"193px","height":"109px","z-index":"29"},"widgetSet":"basic"}]
                                        Ritschy2000 @Negalein last edited by
                                        @negalein vielen dank für die Info. Schaue ich mir mal an.
                                        Habe den Adapter aber aktuell erstmal wieder deaktiviert, da ich auch ständig die Fehlermeldung habe.
                                        @TeraX habe auch das Update auf 000142 bekommen, die Fehlermeldung war aber vor dem Update da und ist auch danach noch da.
                                        • Schmakus
                                          Schmakus Developer @Ritschy2000 last edited by
                                          2 kurze Fragen:
                                          Hi, hast du zufällig eine Doorbird mit Keypad?
                                          Kannst du mal einen Debug-log posten?
                                            Ritschy2000 @Schmakus last edited by
                                            @schmakus Hi, ja, habe ein Doorbird mit Keypad. Habe den Adapter jetzt wieder gestartet und auf Debug gestellt, wenn der Fehler wieder auftaucht gebe ich eine Info, dauert aber meistens ein paar Stunden.
                                            Adapter ist auch mittlerweile auf Version 1.2.4 aktualisiert, Fehler kommt aber trotzdem noch.
                                            135
                                            21128
