    3. Off Topic
    4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
    • wcag22
      wcag22 @Thomas Braun last edited by
      @thomas-braun Moin Allerseits,
      ich häng mich mal an den Thread ran:
      Nach dem erfolgreichen Upgrade auf bookworm am 21.07.23 hatte ich heute wieder einmal routinemäßig ein OS-Update angestoßen. Nun schien da irgendwas schief gelaufen zu sein. Hat das damit zu tun, dass bookworm noch nicht vollständig für pi bereitsteht?
      pi@raspberrypi:~ $ sudo apt-get update && sudo apt-get upgrade -y
      Ign:1 http://raspbian.raspberrypi.org/raspbian booworm InRelease
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm InRelease
      Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
      Err:6 http://raspbian.raspberrypi.org/raspbian booworm Release
        404  Not Found [IP: 93.93.128.193 80]
      Hit:7 https://deb.nodesource.com/node_18.x bookworm InRelease
      Reading package lists... Done
      E: The repository 'http://raspbian.raspberrypi.org/raspbian booworm Release' does not have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      W: http://security.debian.org/debian-security/dists/bookworm-security/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      W: http://deb.debian.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      W: http://archive.raspberrypi.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      pi@raspberrypi:~ $
      Oder liegt der Fehler bei mir?
      Danke für Aufklärung, schönes WE.
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @wcag22 last edited by
        @pi-ter sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
        da fehlt ein k
        wcag22 1 Reply Last reply Reply Quote 0
          Thomas Braun Most Active @wcag22 last edited by Thomas Braun
          @pi-ter
          booworm
          Da fehlt ein k ...
          Das nodesource Repo muss aber auch umgestellt werden. Der letzte Stand ist im howto aus meiner Signatur zu finden.
          Und schieb die keys woanders hin:
          sudo cp /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
          wcag22 3 Replies Last reply Reply Quote 0
          • wcag22
            wcag22 @DJMarc75 last edited by
            @djmarc75 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
            da fehlt ein k
            Ja, sehe ich jetzt auch. Danke.
            Merkwürdig: In meiner "Kopiervorlage" für die sources.list gibt es diesen Tipper nicht.
            Egal, aber hätte es nicht dann auch schon beim Upgrade Probleme geben müssen?
            Wie dem auch sei... Update läuft jetzt erst einmal. Und wie es bislang aussieht wohl ohne Fehler. Schaun wir mal...
            • wcag22
              Ah ok ..., 31.08.23 - na da bin ich ja dann noch zeitnah dran.
              Da das Update noch läuft, werde ich es danach gleich mal angehen.
              Danke für den Hinweis.
              Schönes WE
                @pi-ter
                Warum nimmst du nicht diese Befehle?
                Da ist kein Tippfehler drin:
                sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
                sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list.d/*
                • wcag22
                  Hm.. die stehen auch in meiner "Kopiervorlage" und ich denke, dass ich die auch verwendet habe. Eigentlich habe ich die Anleitung punktuell abgearbeitet.
                  Vlt. ist da schon was quer gelaufen. Weiß ich nun nicht mehr. Letztlich hatte im Juli das erfolgreiche Upgrade gezählt.
                  Andere Frage zu dieser Änderung per 31. August:
                  Habe ich diese Info im abonnierten feed übersehen oder war das eher Insiderwissen?
                  • wcag22
                    @thomas-braun sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                    @pi-ter
                    pi@raspberrypi:~ $ sudo rm `sudo find / -name nodesource.gpg`
                    pi@raspberrypi:~ $ sudo rm `sudo find / -name nodesource.key`
                    rm: missing operand
                    Try 'rm --help' for more information.
                    pi@raspberrypi:~ $
                    Blöd gelaufen?
                      Welcher abonnierte Feed?
                        @pi-ter
                        Nein, nicht blödgelaufen, es gibt die Datei nur nicht.
                        Man könnte die Meldung unterdrücken, hab ich aber in dem Fall drauf verzichtet.
                        • wcag22
                          Der zum Beispiel:
                          https://forum.iobroker.net/recentposts.rss
                          • wcag22
                            Stunden später:
                            • Die Aufgaben bezüglich 31.08. abgearbeitet,
                            • restliche Adapter aktualisiert
                            • OS- Update
                            Magst Du bitte mal schauen, ob nun alles passt oder ob es noch Handlungsbedarf gibt:
                                                 v.2023-04-16
                            Operatingsystem:        Raspbian GNU/Linux 12 (bookworm)
                            Kernel:                 6.1.21-v8+
                            Installation:           Native
                            Timezone:               Europe/Berlin (CEST, +0200)
                            User-ID:                1000
                            X-Server:               false
                            Boot Target:            graphical.target
                            Pending OS-Updates:     0
                            Pending iob updates:    1
                            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                    /usr/bin/node           v18.17.1
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                            MEMORY:
                            Mem:            4.0G        906M        2.6G        503K        522M        3.1G
                            Swap:           104M          0B        104M
                            Total:          4.1G        906M        2.7G
                            Active iob-Instances:   19
                            Active repo(s): Stable (default)
                            ioBroker Core:          js-controller           4.0.24
                                                    admin                   6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                4721
                            States:                 4005
                            Size of iob-Database:
                            11M     /opt/iobroker/iobroker-data/objects.jsonl
                            4.2M    /opt/iobroker/iobroker-data/objects.json.migrated
                            4.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            3.5M    /opt/iobroker/iobroker-data/states.jsonl
                            500K    /opt/iobroker/iobroker-data/states.json.migrated
                            500K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            Danke...
                              Würde ich auf multi-user.taget bringen.
                              Geht in raspi-config:
                              1, S5, B1
                              • wcag22
                                Done!
                                                     v.2023-04-16
                                Kernel:                 6.1.21-v8+
                                User-ID:                1000
                                X-Server:               false
                                Boot Target:            multi-user.target
                                Danke...
                                  @pi-ter
                                  Gib mal die Langfassung zum Besten.
                                  wcag22 2 Replies Last reply Reply Quote 0
                                  • wcag22
                                    @thomas-braun ,
                                    Gern:
                                                         v.2023-04-16
                                    Kernel:                 6.1.21-v8+
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            9.6.7
                                                            /usr/bin/npx            9.6.7
                                    MEMORY:
                                    Mem:            4.0G        1.2G        2.3G        503K        648M        2.8G
                                    Swap:           104M          0B        104M
                                    Total:          4.1G        1.2G        2.4G
                                                            admin                   6.8.0
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                4721
                                    States:                 3990
                                    20M     /opt/iobroker/iobroker-data/objects.jsonl
                                    2.6M    /opt/iobroker/iobroker-data/states.jsonl
                                    • DJMarc75
                                      Gern:
                                      Das ist die Kurzfassung 😉
                                      • wcag22
                                        Moin,
                                        da ich betreffs multi-user.taget gestern nur einen Schnipsel aus diag gepostet hatte, nahm ich an, dass Du die komplette Zusammenfassung wolltest.
                                        Aber bevor ich die tatsächliche Langfassung bringe, noch eine Frage:
                                        Was triggert, ob bei neofetch die Beere oder der Bookworm als Logo ausgegeben wird. Ist zwar nicht wirklich wichtig, interessiert mich nur halt. Auf dem Raspi 3 mit pihole mit bookworm wird der Wurm angezeigt, auf dem Raspi 4 mit iobroker die Beere. Beide laufen auf 64bit...
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Model           : Raspberry Pi 4 Model B Rev 1.1
                                        Architecture    : aarch64
                                        Docker          : false
                                        Virtualization  : none
                                        Distributor ID: Raspbian
                                        Description:    Raspbian GNU/Linux 12 (bookworm)
                                        Release:        12
                                        Codename:       bookworm
                                        PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
                                        NAME="Raspbian GNU/Linux"
                                        VERSION_ID="12"
                                        VERSION="12 (bookworm)"
                                        VERSION_CODENAME=bookworm
                                        ID=raspbian
                                        ID_LIKE=debian
                                        HOME_URL="http://www.raspbian.org/"
                                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                        Systemuptime and Load:
                                         08:39:38 up 15 min,  2 users,  load average: 1.77, 1.53, 0.87
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        Other values than 0x0 hint to temperature/voltage problems
                                        temp=55.5'C
                                        volt=0.8688V
                                        *** Time and Time Zones ***
                                                       Local time: Sun 2023-09-03 08:39:38 CEST
                                                   Universal time: Sun 2023-09-03 06:39:38 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            4.0G        938M        2.6G        499K        546M        3.0G
                                        Swap:           104M          0B        104M
                                        Total:          4.1G        938M        2.7G
                                                 3794 M total memory
                                                  894 M used memory
                                                  858 M active memory
                                                  339 M inactive memory
                                                 2454 M free memory
                                                   83 M buffer memory
                                                  437 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  7.2G   21G  26% /
                                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                        tmpfs          tmpfs     759M  484K  759M   1% /run
                                        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
                                        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                        /dev/sda1      ext4       14G  1.3G   12G  10% /media/USBintern
                                        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                        [Sun Sep  3 08:24:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:2D:5B:0D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=83dc1cec-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                        [Sun Sep  3 08:24:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Sun Sep  3 08:24:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Sun Sep  3 08:24:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        [Sun Sep  3 08:24:36 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                        Show mounted filesystems (real ones only):
                                        TARGET             SOURCE         FSTYPE OPTIONS
                                        /                  /dev/mmcblk0p2 ext4   rw,noatime
                                        |-/boot            /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                        `-/media/USBintern /dev/sda1      ext4   rw,relatime
                                        /var:
                                        1.9G    /var/
                                        1.2G    /var/cache/apt
                                        1.2G    /var/cache
                                        1.1G    /var/cache/apt/archives
                                        528M    /var/log
                                        Archived and active journals take up 524.2M in the file system.
                                        /opt/iobroker/backups:
                                        4.0K    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        437M    /opt/iobroker/iobroker-data/
                                        300M    /opt/iobroker/iobroker-data/files
                                        88M     /opt/iobroker/iobroker-data/files/echarts.admin
                                        88M     /opt/iobroker/iobroker-data/backup-objects
                                        57M     /opt/iobroker/iobroker-data/files/echarts
                                        31M     /opt/iobroker/iobroker-data/objects.jsonl
                                        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                                        23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Installed: 18.17.1-1nodesource1
                                          Candidate: 18.17.1-1nodesource1
                                          Version table:
                                         *** 18.17.1-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                                100 /var/lib/dpkg/status
                                             18.17.0-1nodesource1 500
                                             18.16.1-1nodesource1 500
                                             18.16.0-1nodesource1 500
                                             18.15.0-1nodesource1 500
                                             18.14.2-1nodesource1 500
                                             18.14.1-1nodesource1 500
                                             18.14.0-1nodesource1 500
                                             18.13.0+dfsg1-1+rpi1 500
                                                500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                             18.13.0-1nodesource1 500
                                             18.12.0-1nodesource1 500
                                             18.11.0-1nodesource1 500
                                             18.10.0-1nodesource1 500
                                             18.9.1-1nodesource1 500
                                             18.9.0-1nodesource1 500
                                             18.8.0-1nodesource1 500
                                             18.7.0-1nodesource1 500
                                             18.6.0-1nodesource1 500
                                             18.5.0-1nodesource1 500
                                             18.4.0-1nodesource1 500
                                             18.3.0-1nodesource1 500
                                             18.2.0-1nodesource1 500
                                             18.1.0-1nodesource1 500
                                             18.0.0-1nodesource1 500
                                        No problems detected
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        MULTIHOSTSERVICE/enabled: false
                                        Core adapters versions
                                        js-controller:  4.0.24
                                        admin:          6.8.0
                                        javascript:     7.0.3
                                        Adapters from github:   0
                                        Adapter State
                                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                        + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                          system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
                                        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                          system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
                                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                        + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
                                        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                        + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                                          system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Stable (default): http://download.iobroker.net/sources-dist.json
                                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                        Installed ioBroker-Instances
                                        Used repository: Stable (default)
                                        Adapter    "admin"        : 6.8.0    , installed 6.8.0
                                        Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
                                        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                        Adapter    "deyeidc"      : 0.0.11   , installed 0.0.11
                                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                        Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                        Adapter    "email"        : 1.2.0    , installed 1.2.0
                                        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                        Adapter    "ham"          : 5.3.1    , installed 4.0.2  [Updatable]
                                        Adapter    "history"      : 2.2.6    , installed 2.2.6
                                        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                                        Adapter    "info"         : 1.9.26   , installed 1.9.26
                                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                                        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                                        Controller "js-controller": 4.0.24   , installed 4.0.24
                                        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                        Adapter    "socketio"     : 6.5.2    , installed 6.5.2
                                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
                                        Adapter    "web"          : 6.1.0    , installed 6.1.0
                                        Adapter    "ws"           : 2.5.3    , installed 2.5.3
                                        Objects and States
                                        Objects:        4721
                                        States:         4005
                                        Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                                        Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                                        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14093      733/io.sonoff.0
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15571      518/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12781      518/iobroker.js-con
                                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       16353      1341/io.jarvis.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15517      581/sshd: /usr/sbin
                                        tcp6       0      0 :::8091                 :::*                    LISTEN      1001       18051      1561/io.lovelace.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12863      634/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15931      969/io.web.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          15519      581/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14173      787/io.shelly.0
                                        udp        0      0 0.0.0.0:42766           0.0.0.0:*                           108        13606      369/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12172      650/dhcpcd
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13604      369/avahi-daemon: r
                                        udp6       0      0 :::51524                :::*                                108        13607      369/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        13605      369/avahi-daemon: r
                                        2023-09-03 08:40:38.898  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.name changed: FRITZ!DECT 400 #3 (ack = true)
                                        2023-09-03 08:40:38.902  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.battery changed: 50 (ack = true)
                                        2023-09-03 08:40:38.905  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.batterylow changed: false (ack = true)
                                        2023-09-03 08:40:38.909  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-0.id changed: 5000 (ack = true)
                                        2023-09-03 08:40:38.913  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-0.name changed: FRITZ!DECT 400 #3: kurz (ack = true)
                                        2023-09-03 08:40:38.916  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-0.lastpressedtimestamp changed: Sat Aug 26 2023 12:51:16 GMT+0200 (Central European Summer Time) (ack = true)
                                        2023-09-03 08:40:38.920  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-9.id changed: 5001 (ack = true)
                                        2023-09-03 08:40:38.923  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_130960001449.button.130960001449-9.name changed: FRITZ!DECT 400 #3: lang (ack = true)
                                        2023-09-03 08:40:38.928  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.synchronized changed: false (ack = true)
                                        2023-09-03 08:40:38.939  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.id changed: 900 (ack = true)
                                        2023-09-03 08:40:38.943  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.fwversion changed: 1.0 (ack = true)
                                        2023-09-03 08:40:38.946  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.manufacturer changed: AVM (ack = true)
                                        2023-09-03 08:40:38.949  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.present changed: true (ack = true)
                                        2023-09-03 08:40:38.952  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.txbusy changed: false (ack = true)
                                        2023-09-03 08:40:38.955  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.name changed: Außenbereich (ack = true)
                                        2023-09-03 08:40:38.958  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.state changed: false (ack = true)
                                        2023-09-03 08:40:38.962  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.mode changed: auto (ack = true)
                                        2023-09-03 08:40:38.964  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.lock changed: false (ack = true)
                                        2023-09-03 08:40:38.967  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.devicelock changed: false (ack = true)
                                        2023-09-03 08:40:38.970  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.state changed: false (ack = true)
                                        2023-09-03 08:40:38.974  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.voltage changed: 234.211 (ack = true)
                                        2023-09-03 08:40:38.977  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.power changed: 0 (ack = true)
                                        2023-09-03 08:40:38.980  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.energy changed: 38558 (ack = true)
                                        2023-09-03 08:40:38.984  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.masterdeviceid changed: 0 (ack = true)
                                        2023-09-03 08:40:38.987  - debug: fritzdect.0 (1520) onStateChange => state fritzdect.0.DECT_grp6A507B-3D1EBDFC6.members changed: 17 (ack = true)
                                        Schönen Sonntag zunächst...
                                        crunchip Thomas Braun ? 3 Replies Last reply Reply Quote 0
                                          crunchip Forum Testing Most Active @wcag22 last edited by
                                          debug: fritzdect.0
                                          dein loglevel steht auf debug, stell das mal zurück auf z.b. info
                                            @pi-ter
                                            Passt.
                                            Zu neofetch: Keine Ahnung.
                                            upgrade bullseye bookworm
                                            51
                                            351
                                            88765
