    4. Test Adapter Plex v1.1.x
      ticaki Developer @sigi234 last edited by ticaki
      @sigi234 sagte in Test Adapter Plex v1.0.x:
      Versuche nochmal. Mal sehen ob eine der Varianten funktioniert.
      https://github.com/iobroker-community-adapters/ioBroker.plex/tree/forSigi
      Mit beendeter Plexapp sieht das log dann so aus:
      2023-08-31 20:17:42.783  - debug: plex.0 (324488) http://192.168.178.32:32500/player/playback/play?
      2023-08-31 20:17:45.785  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:17:45.785  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with GET.
      2023-08-31 20:17:48.788  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:17:48.788  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with POST and without header.
      2023-08-31 20:17:51.791  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:17:51.792  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with GET and without headers.
      2023-08-31 20:17:54.794  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:17:54.795  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with POST and without REQUEST_OPTIONS.
      2023-08-31 20:17:57.798  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:17:57.798  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with GET and without REQUEST_OPTIONS.
      2023-08-31 20:18:00.800  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:18:00.801  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with POST and without REQUEST_OPTIONS and headers.
      2023-08-31 20:18:03.803  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      2023-08-31 20:18:03.803  - debug: plex.0 (324488) Try to trigger playback action -play- on player 192.168.178.32 with GET and without REQUEST_OPTIONS and headers.
      2023-08-31 20:18:06.806  - warn: plex.0 (324488) Error triggering playback action -play- on player 192.168.178.32! See debug log for details.
      Die einzelnen Aktionen werden durch den Fehler ausgelöst und im 3 Sekundentakt
      in der Wiki steht
      If present, players should verify that X-Plex-Target-Client-Identifier matches its own identifier and return HTTP error 404 if it doesn't
      wenn der nicht dabei ist gehts aber bei dir... dann wird wohl with POST and without header funktionieren... Hoffe ich mal.
        sigi234 Forum Testing Most Active @ticaki last edited by sigi234
        @ticaki
        plex.0
        2023-08-31 20:53:25.314	debug	Incoming data from plex with ip: 192.168.178.20
        plex.0
        2023-08-31 20:52:12.412	debug	plex.0._playing.android-xxxxxxxxxxxxxxx_Controls.playback.play_switch
        plex.0
        2023-08-31 20:52:12.411	debug	Successfully triggered playback action -play_switch- on player 192.168.178.47.
        plex.0
        2023-08-31 20:52:12.384	debug	Try to trigger playback action -play_switch- on player 192.168.178.47 with GET.
        plex.0
        2023-08-31 20:52:12.384	debug	uwebsockets: 19content-length: 13
        plex.0
        2023-08-31 20:52:12.384	debug	404
        plex.0
        2023-08-31 20:52:12.384	debug	404 Not Found
        plex.0
        2023-08-31 20:52:12.384	warn	Error triggering playback action -play_switch- on player 192.168.178.47! See debug log for details.
        plex.0
        2023-08-31 20:52:12.332	debug	http://192.168.178.47:32500/player/playback/play?
        plex.0
        2023-08-31 20:52:12.332	debug	command url: http://192.168.178.47:32500/player/playback/play?xxxxxxxxxxxxxxxxxx
        plex.0
        2023-08-31 20:52:12.332	debug	Triggered action -play_switch- on player 192.168.178.47.
        plex.0
        2023-08-31 20:52:12.332	debug	State of plex.0._playing.android-xxxxxxxxxxxxxx_Controls.playback.play_switch has changed {"val":true,"ack":false,"ts":1693507932330,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1693507925458}.
        plex.0
        2023-08-31 20:52:09.248	debug	plex.0._playing.android-1810d7e1-7f53-4d2e-8a9e-218e85d27f5f._Controls.playback.stop
        plex.0
        2023-08-31 20:52:09.247	debug	Successfully triggered playback action -stop- on player 192.168.178.47.
        plex.0
        2023-08-31 20:52:09.212	debug	Try to trigger playback action -stop- on player 192.168.178.47 with GET.
        plex.0
        2023-08-31 20:52:09.212	debug	uwebsockets: 19content-length: 13
        plex.0
        2023-08-31 20:52:09.212	debug	404
        plex.0
        2023-08-31 20:52:09.211	debug	404 Not Found
        plex.0
        2023-08-31 20:52:09.211	warn	Error triggering playback action -stop- on player 192.168.178.47! See debug log for details.
        plex.0
        2023-08-31 20:52:09.148	debug	http://192.168.178.47:32500/player/playback/stop?
        plex.0
        2023-08-31 20:52:09.147	debug	command url: http://192.168.178.47:32500/player/playback/stop?RCjj11yxZwVXS42Uxy6A
        plex.0
        2023-08-31 20:52:09.147	debug	Triggered action -stop- on player 192.168.178.47.
        plex.0
        2023-08-31 20:52:09.147	debug	State of plex.0._playing.android-xxxxxxxxxxxxxxxxxxx_Controls.playback.stop has changed {"val":true,"ack":false,"ts":1693507929145,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1693507920865}.
        plex.0
        2023-08-31 20:52:05.542	debug	plex.0._playing.android-xxxxxxxxxxxx._Controls.playback.play_switch
        plex.0
        2023-08-31 20:52:05.542	debug	Successfully triggered playback action -play_switch- on player 192.168.178.47.
        plex.0
        2023-08-31 20:52:05.526	debug	Try to trigger playback action -play_switch- on player 192.168.178.47 with GET.
        plex.0
        2023-08-31 20:52:05.526	debug	uwebsockets: 19content-length: 13
        plex.0
        2023-08-31 20:52:05.526	debug	404
        plex.0
        2023-08-31 20:52:05.526	debug	404 Not Found
        plex.0
        2023-08-31 20:52:05.526	warn	Error triggering playback action -play_switch- on player 192.168.178.47! See debug log for details.
        plex.0
        2023-08-31 20:52:05.461	debug	http://192.168.178.47:32500/player/playback/play?
        plex.0
        2023-08-31 20:52:05.460	debug	command url: http://192.168.178.47:32500/player/playback/play?xxxxxxxxxxxxx
        plex.0
        2023-08-31 20:52:05.460	debug	Triggered action -play_switch- on player 192.168.178.47.
        plex.0
        2023-08-31 20:52:05.460	debug	State of plex.0._playing.android-xxxxxxxxxxxxxxxx_Controls.playback.play_switch has changed {"val":true,"ack":false,"ts":1693507925458,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1693507925458}.
        Funktioniert 👍
        Volume geht jetzt auch.
          v.1.0.5
          ist auf dem Weg - hoffe das nächste ist ein Antrag auf stable update 🙂
          @sigi234
          Super dann ändere ich das für die nächste Version auf get, wenn das auch hier funktioniert, ansonsten post dann get dann fehlermeldung.
          Auf meinem IPad funktioniert es mit GET ebenfalls. Dann stoße ich mal ne neue Version an.
          @SidM
          Hast du einen Webhook eingerichtet? Versuchs mal mit der neuen Version die dann demnächst online ist.
          sigi234 1 Reply Last reply Reply Quote 2
            @ticaki sagte in Test Adapter Plex v1.0.x:
            v.1.0.5
            plex.0
            2023-09-01 00:36:10.966	debug	Error: ESOCKETTIMEDOUT
            plex.0
            2023-09-01 00:36:10.966	debug	Could not retrieve items for playlists from Plex!
            plex.0
            plex.0
            plex.0
            2023-09-01 00:36:10.951	debug	Error: ESOCKETTIMEDOUT
            plex.0
            2023-09-01 00:36:10.950	debug	Could not retrieve items for libraries from Plex!
            plex.0
            2023-09-01 00:36:10.726	debug	Plex Media flushed!
            plex.0
            2023-09-01 00:36:10.725	debug	Deleted state _playing with 468 objects.
            plex.0
            2023-09-01 00:36:10.004	debug	Retrieved Watch Statistics for User Sigi2345 from Tautulli.
            plex.0
            2023-09-01 00:36:10.001	debug	Retrieved Watch Statistics for User Guest from Tautulli.
            plex.0
            2023-09-01 00:36:09.999	debug	Retrieved Watch Statistics for Library Musikvideos from Tautulli.
            plex.0
            2023-09-01 00:36:09.996	debug	Retrieved Watch Statistics for Library Music from Tautulli.
            plex.0
            2023-09-01 00:36:09.993	debug	Retrieved Watch Statistics for Library Filme from Tautulli.
            plex.0
            2023-09-01 00:36:09.970	debug	Retrieved Settings from Plex.
            plex.0
            2023-09-01 00:36:09.953	debug	Retrieved Playlists from Plex.
            plex.0
            2023-09-01 00:36:09.953	debug	Retrieved Players from Plex.
            plex.0
            2023-09-01 00:36:09.946	debug	Retrieved Users from Tautulli.
            plex.0
            2023-09-01 00:36:09.927	debug	Retrieved Libraries from Plex.
            plex.0
            2023-09-01 00:36:09.922	debug	Retrieved Servers from Plex.
            plex.0
            2023-09-01 00:36:08.520	info	Establishing insecure connection to Plex Media Server...
            plex.0
            2023-09-01 00:36:08.506	info	starting. Version 1.0.5 (non-npm: iobroker-community-adapters/ioBroker.plex) in C:/ioBroker/_iob_Test/node_modules/iobroker.plex, node: v18.17.1, js-controller: 5.0.12
            2023-09-01 00:36:10.725 debug Deleted state _playing with 468 objects.?
              Plex Media flushed!
              Verstehe die Frage nicht? Der Reset _playing löscht alles unter _playing.
              if (adapter.config.resetMedia)
              				library.del('_playing', true, () => adapter.log.debug('Plex Media flushed!'));
              Jup alles unter _playing wird entfernt.
                Plex Media flushed!
                Nur einmalig?
                Kann nicht weiter testen, da der Router offline ist.
                  @sigi234
                  Bei jedem Start des Adapters
                    @sigi234
                    Ok, wie ist der Stand bei den Liedtexten?
                    Die Live Daten von den Abspielzeiten sind noch verzögert oder hängen.
                    Top Arbeit! Danke dafür.
                    Schläfst du auch mal? 😁
                      @sigi234
                      Das kommt in der 1.1 Stand ist:
                      Die Datenquellen hab ich jetzt zusammen, aber noch nicht die jeweiligen Verknüpfungen zu den gewünschten Datenpunkten. Vielleicht wirds dieses oder nächstes Wochenende.
                      Ich hab eine Link(wobei die Formatierung als letztes kommt) auf einen Songtext, der kann
                      • codec txt enthält xml
                      • codec lrc enthält einen Text mit Zeitstempeln https://github.com/mcanam/liricle
                      Diese Daten werden incl. Link zum Lieddatei in Metadata.Music.Lyric.codec/key/url und Metadata.Music.Media.codec/key/url abgelegt.
                      Abspielzeit hab ich bis her % und millisekunden vorgesehen, mit bis zur sekündlichen Aktualisierung über den Client Das sind <1kb an Daten - da kann ich es dann auch genau machen. Das geht aber nur für Clients die lokal und steuerbar sind. Die Aktualisierung vom Server ist grob drin. Der hängt bis zu 5 Sekunden hinter der Clientversion.
                      In meiner Version ist der Datenpunkt des Clients noch unter Player.Details.Music.time
                      Bei Clientversion werden dann _Controls.playback.seekTo und _Controls.playback.seekToPercent mit aktualisiert.
                      Bei der Serverversion wird es Metadata.viewOffset sein. Der viewOffset kommt so vom server, da muß ich dann nicht alles kreuz und quer aktualisieren.
                      Was noch fehlt ist: Player.Status. Im Moment laufen die ganzen Aktualisierungen ununterbrochen und das ist bei vielen Clients quark.
                      Dann hab ich wirklich alles an Daten in States schreiben lassen... 1000 Datenpunkte da muß ich noch sortieren, was man braucht.
                      Jetzt 🙂
                        ticaki Developer last edited by ticaki
                        Stable ist angefragt release ca. 5-7 Tage wenn keine bösen Probleme auftreten.
                        Wenn ihr Lust habt könnt ihr meine "Entwicklungsversion" testen.
                        würde die aber wenn ihr viele lokale Clients habt, nach dem rumspielen wieder entfernen. Ist noch nichts drin um das aktualisieren für bestimmte Clients zu unterbinden.
                        WORK IN PROGRESS
                        • (ticaki) Added: Retrieve a bit more information about streams
                        • (ticaki) Added: Retrieve status informations from local clients (webhook needed)
                        • (ticaki) Added: Update local client data while not stopped (video/music) every second (webhook needed)
                        • (ticaki) Added: Update metadata on local client playing target change
                        • (ticaki) Added: alot more states
                        todo:
                        • sort alot more states 🙂
                        • Add: admin configuration for refresh of metadata and clientdata
                        • add datapoint to allow/disallow refresh by client
                        • check if all urls are formated as urls
                        Falls euch die Bezeichnung der Datenpunkte nicht überzeugt, weil schlechtes Englisch, oder ihr besser wisst was der bedeutet würde ich mich über eine PR oder ne Liste freuen:
                        https://github.com/iobroker-community-adapters/ioBroker.plex/blob/player_requests/_NODES.js
                        ^da sind die Daten abgelegt das playing. steht für _playing. Das Gerät wird nicht benannt und dann halt z.B. metadata.video: { description:"und hier steht der Text zum datenpunkt"}. Dazu falls ihr Datenpunkte mit "no description" habt die nicht durch Tautulli erzeugt werden, könnt ihr mir gerne einen Namensvorschlag unterbreiten. Tautulli erlaubt benutzerdefinierte Datenpunkte und da bringts nix die zu benennen, hat ja jeder andere.
                        Hier gibts die aktuelle Entwicklungsversion:
                        https://github.com/iobroker-community-adapters/ioBroker.plex/tree/player_requests
                        Zu der Version ist auch anzumerken, das die debugmeldungen noch keinen richtigen Sinn ergeben, daran wo ich arbeite gibts viel zu viele, und der rest ist auskommentiert damit er nicht nervt. 🙂
                          DAS:
                          Installierte Version:1.0.5
                            @sigi234
                            1. sind nicht alle bugfix enthalten habe gerade daran gedacht und zumindest den GET POST übernommen. Die werden beim Zusammenführen einfliessen.
                            2. Die Version sollte 1.0.2 sein, an dem Punkt hab ich diesen Entwicklungszweig abgespalten und will da nicht dran rummachen.
                            Github installation https://github.com/iobroker-community-adapters/ioBroker.plex/tree/player_requests
                            Angezeigte Version ist 1.0.2 einfach per update dann zu entfernen 🙂
                            Solange stable noch nicht durch ist, werde ich das nicht in latest übernehmen, nicht das ich für stable noch nen fix machen muß. Keine Ahnung ob das dann gehen würde.
                              @ticaki
                              Also das als Benutzerdefiniert?
                              Edit:
                                @sigi234
                                Es ist richtig das v.1.0.2 nach erfolgter Installation angezeigt wird, da ändere ich nichts, nur etwas mehr das ich beim Zusammenführen dann beheben müsste.
                                Unter plex.0._playing.ipad-xxx.Player gibts das meiste zu sehen.
                                Ich muß aber mal daran arbeiten das States erstellt werden die nicht existieren, das man immer den ganzen Baum löschen muß nervt.
                                  @ticaki
                                  plex.0
                                  2023-09-02 12:17:35.004	info	State value to set for "plex.0._playing.android-1810d7e1-7f53-4d2e-8a9e-218e85d27f5f.Metadata.Media" has to be type "channel" but received type "string"
                                  plex.0
                                  2023-09-02 12:17:33.659	warn	This object will not be created in future versions. Please report this to the developer.
                                  plex.0
                                  2023-09-02 12:17:33.659	warn	Object plex.0._playing.android-1810d7e1-7f53-4d2e-8a9e-218e85d27f5f.Metadata.Media is invalid: obj.common.type has an invalid value (channel) but has to be one of number, string, boolean, array, object, mixed, file, json
                                  Edit:
                                  Control reagiert nicht mehr!
                                    @sigi234
                                    Jup habe ich auch, hab das jetzt behoben. Aber da funktioniert noch etwas nicht so wie es soll. Hab keine States bekommen, bis ich mal ein paar Minuten gewartet habe. Start ohne States mit aktiviertem Client will nicht so recht scheinbar.
                                    _Control sollte jetzt auch wieder gehen, wenn nicht muß ich noch mehr daran arbeiten, bis ich mir Meinungen einholen kann. Aktuell gehts nur darum ob die Daten so verwertbar sind.
                                      @ticaki
                                      Log läuft voll
                                        @sigi234
                                        Damm lass es erstmal, ich gucke heute abend nochmal das ist wahrscheinlich nur eine Kleinigkeit, die ich übersehen habe.
                                          @sigi234
                                          Ok zurück auf 1.0.5?
                                            @sigi234
                                            Ja.
                                            hast du beim letzten Test States gelöscht ohne Plex Neustarten?
                                            adapter plex tautulli
                                            25621
