    2. English
    3. ioBroker general
    4. Neato Botvac adapter - further development
      csp @csp last edited by
      Did everything and node.js seems fine now. So at least this is fixed.
      BUT: My original problem with the adapter persists. Deleted and re-installed and same issue...
      Tried npm install --production in adapter directory. - Also not helping...
      I'm lost 😕
      root@iobroker:/opt/iobroker/node_modules/iobroker.botvac# npm install --production
      npm WARN config production Use `--omit=dev` instead.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      added 53 packages in 35s
      result:
      host.iobroker
      2023-09-01 19:33:28.292	info	iobroker npm-rebuild: Rebuilding native modules ...
      host.iobroker
      2023-09-01 19:33:26.133	info	iobroker rebuild
      host.iobroker
      2023-09-01 19:33:26.133	warn	adapter "botvac" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.iobroker
      2023-09-01 19:33:26.132	info	system.adapter.botvac.0 will be rebuilt
      host.iobroker
      2023-09-01 19:33:26.131	info	Adapter system.adapter.botvac.0 needs rebuild and will be restarted afterwards.
      host.iobroker
      2023-09-01 19:33:26.131	error	instance system.adapter.botvac.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-09-01 19:33:26.131	error	Caught by controller[0]: Node.js v18.17.1
      host.iobroker
      2023-09-01 19:33:26.131	error	Caught by controller[0]: }
      host.iobroker
      2023-09-01 19:33:26.131	error	Caught by controller[0]: ]
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/main.js'
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js',
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: requireStack: [
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.botvac/lib/utils.js:46:25)
      host.iobroker
      2023-09-01 19:33:26.130	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/main.js
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.botvac/lib/utils.js
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: Require stack:
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: ^
      host.iobroker
      2023-09-01 19:33:26.129	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-09-01 19:33:26.128	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
      host.iobroker
      2023-09-01 19:33:25.447	info	instance system.adapter.botvac.0 started with pid 816
        PeterVoronov @csp last edited by
        @csp
        May be it has sence to downgrade the node version? To v16, i.e. version 7 of docker image ?
          csp @PeterVoronov last edited by
          @petervoronov : Just tried that as well. - Same story, same error.
          Now I try to restore my system. Need to see what backups I have...
            I'm so glad to have automatic backup enabled on my server... Went back 2 months and it works again. I only moved my most recent objects.jsonl back to the folder. I'm not sure what happened in-between.
            Just did diag and it looks good. (Will update adapters one by one...)
                                 v.2023-04-16
            Operatingsystem:        Debian GNU/Linux 11 (bullseye)
            Kernel:                 4.4.180+
            Installation:           Docker
            Timezone:               Etc/UTC
            User-ID:                0
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    13
            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                    /usr/bin/node           v18.17.1
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:            9.8G        3.5G        555M        565M        5.8G        5.5G
            Swap:           7.9G        434M        7.5G
            Total:           17G        3.9G        8.1G
            Active iob-Instances:   35
            Active repo(s): default, beta
            ioBroker Core:          js-controller           4.0.24
                                    admin                   6.5.9
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                16657
            States:                 14206
            Size of iob-Database:
            26M     /opt/iobroker/iobroker-data/objects.jsonl
            13M     /opt/iobroker/iobroker-data/objects.json.migrated
            13M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            24M     /opt/iobroker/iobroker-data/states.jsonl
            1.9M    /opt/iobroker/iobroker-data/states.json.migrated
            1.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
              Thomas Braun Most Active @csp last edited by
              @csp
              Please setup the time zone and do not mix the repos:
              C 2 Replies Last reply Reply Quote 0
                csp @Thomas Braun last edited by csp
                @thomas-braun fixed and thanks for the help.
                Will now update adapters. I'm curious if js adapter will cause again the issue.
                Edit: All adapters updated. No problem.
                Now final step: js controller 4.0.24 -> 5.0.12 - let's see 🙂
                  @thomas-braun so now I found the issue.
                  js controller update is causing issue.
                  Maybe the way I'm doing it is not correct.
                  Here is what I did:
                  iobroker console:
                  pkill -u iobroker
                  iobroker update
                  iobroker upgrade self
                  -> js controller gets upgraded, but now I have the old problem.
                  What am I'm doing wrong?
                    @csp sagte in Neato Botvac adapter - further development:
                    Nothing. It seems as if the adapter needs to be adjusted to the current js-controller.
                      @PeterVoronov -> maybe something you could take a look...
                      Until then I'll stay on 4.0.24
                        @csp
                        Unfortunatelly I can't do a lot, mostly nothing.
                        • I'm not an author of the adapter
                        • Currently I have newsest js-controller installed, but adapter at least started for me. I can't check more, then start of adapter.
                        • And, unfortunately, I have no any Neato device now(it's died year ago). So, I can't check the further steps ...
                          ac369a9a-90fe-429b-83c9-6add8fdb2ca0-image.png .
                          @petervoronov : One thing I see is your version number 1.0.4. I'm using 1.0.0 stable.
                          How to get the 1.0.4? Maybe this already solves the issue.
                          Thomas
                            csp @csp last edited by csp
                            I was able to pull v1.0.4. But it fails as well. There is a difference though. It gets green and crashes afterwards.
                            I'll now stay with my former version of js-controller and hope that the developer can fix it at some point.
                            host.iobroker
                            2023-09-07 17:33:49.629	error	instance system.adapter.botvac.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            botvac.0
                            2023-09-07 17:33:49.510	info	terminating
                            botvac.0
                            2023-09-07 17:33:49.074	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
                            botvac.0
                            2023-09-07 17:33:49.073	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
                            botvac.0
                            2023-09-07 17:33:49.069	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
                            botvac.0
                            2023-09-07 17:33:49.068	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
                            botvac.0
                            2023-09-07 17:33:49.008	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            botvac.0
                            2023-09-07 17:33:49.006	info	terminating
                            botvac.0
                            2023-09-07 17:33:49.003	error	undefined is not a valid state value
                            botvac.0
                            2023-09-07 17:33:49.003	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17 at Robot.<anonymous> (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17) at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17 at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45 at <anonymous> at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                            botvac.0
                            2023-09-07 17:33:49.002	error	unhandled promise rejection: undefined is not a valid state value
                            botvac.0
                            2023-09-07 17:33:49.001	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            botvac.0
                            2023-09-07 17:33:48.994	error	undefined is not a valid state value
                            botvac.0
                            2023-09-07 17:33:48.993	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/iobroker.botvac/main.js:514:17 at Robot.<anonymous> (/opt/iobroker/node_modules/node-botvac/lib/robot.js:77:17) at /opt/iobroker/node_modules/node-botvac/lib/robot.js:610:17 at /opt/iobroker/node_modules/node-botvac/lib/api.js:40:45 at <anonymous> at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                            botvac.0
                            2023-09-07 17:33:48.991	error	unhandled promise rejection: undefined is not a valid state value
                            botvac.0
                            2023-09-07 17:33:48.990	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            botvac.0
                            2023-09-07 17:33:47.677	warn	Device"unten" with id: unten is not exists in cloud any more!
                            botvac.0
                            2023-09-07 17:33:46.740	info	devices found: 2
                            botvac.0
                            2023-09-07 17:33:44.228	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 5.0.12
                              @csp If you have time for it - please try start 1.0.4 version with debug log.
                              Other option - you can share via PM your credentials - and I will try to find a time to look for the solution.
                                @petervoronov
                                this is with JS 4.0.24:
                                Later I can try to upgrade and check again
                                botvac.0
                                2023-09-08 08:30:20.179	debug	get schedule {"enabled":false,"events":[]}
                                botvac.0
                                2023-09-08 08:30:20.174	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:30:20.173	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:30:20.151	info	undefined is not a valid state value for id "botvac.0.unten.status.canPause"
                                botvac.0
                                2023-09-08 08:30:20.150	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"unten","_serial":"OPS39718-F045DA6FF249","_secret":"D0E3BFDA3824F493627EE28D882CE4963BF6A0A112FEF9CB0EDC7C0E7E273ADA74F0D7DFD29510271AA4E69BB72CBA100410604DAEBF66E611D052A75502373BE1A61A12D177E4FE94F8369B63BCF3DA76E2C481D5AC29EBAEC36BB0C9A080E501F23A01A81485F1F59F526ACBCC376FBDDF97F9E23692CF1D9A35D19117F48B","_token":"Token token=77962ed80b7e7e2c9898ea76ad40d9c3","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"isBinFull":false,"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":null,"state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"meta":{"modelName":"BotVacD5Connected","firmware":"4.5.3-189"}}
                                botvac.0
                                2023-09-08 08:30:20.093	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:30:20.091	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:30:20.045	info	undefined is not a valid state value for id "botvac.0.obergeschoss.status.canPause"
                                botvac.0
                                2023-09-08 08:30:20.042	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"obergeschoss","_serial":"OPS36118-F045DA70530D","_secret":"AB23FB0FDE9112F5DA12884631EC2C3A2A89E6F056C9C3E41EF3E616CB0C9747E5DB596626D3BB1581D0F71D6C2058E87D234DACE2485D297F3B8716242BF614D06DB2574BF401C273467B7A45701B91DDE7BEE7444E222AF8337B81214BC0BFF8031D83789CCD1077016184F9EC2D193E9B115D3A89CB0A37AC908498CB0D13","_token":"Token token=77962ed80b7e7e2c9898ea76ad40d9c3","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"isBinFull":true,"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":"dustbin_full","state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"meta":{"modelName":"BotVacD7Connected","firmware":"4.5.3-189"}}
                                botvac.0
                                2023-09-08 08:30:20.012	debug	get schedule {"type":1,"enabled":false,"events":[]}
                                botvac.0
                                2023-09-08 08:30:18.831	warn	Device"unten" with id: unten is not exists in cloud any more!
                                botvac.0
                                2023-09-08 08:30:18.313	info	devices found: 2
                                botvac.0
                                2023-09-08 08:30:15.559	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 4.0.24
                                botvac.0
                                2023-09-08 08:30:10.069	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                botvac.0
                                2023-09-08 08:30:10.068	info	terminating
                                botvac.0
                                2023-09-08 08:30:10.067	info	Got terminate signal TERMINATE_YOURSELF
                                botvac.0
                                2023-09-08 08:29:38.719	warn	State value to set for "botvac.0.obergeschoss.commands.spotHeight" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:29:38.718	warn	State value to set for "botvac.0.obergeschoss.commands.spotWidth" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:29:38.707	info	undefined is not a valid state value for id "botvac.0.obergeschoss.status.canPause"
                                botvac.0
                                2023-09-08 08:29:38.706	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"obergeschoss","_serial":"OPS36118-F045DA70530D","_secret":"AB23FB0FDE9112F5DA12884631EC2C3A2A89E6F056C9C3E41EF3E616CB0C9747E5DB596626D3BB1581D0F71D6C2058E87D234DACE2485D297F3B8716242BF614D06DB2574BF401C273467B7A45701B91DDE7BEE7444E222AF8337B81214BC0BFF8031D83789CCD1077016184F9EC2D193E9B115D3A89CB0A37AC908498CB0D13","_token":"Token token=37c8b0e205312639b061254cedc49131","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"isBinFull":true,"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":"dustbin_full","state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":false,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-4","IECTest":"advanced-1","logCopy":"basic-1","manualCleaning":"basic-1","maps":"basic-2","preferences":"basic-2","schedule":"basic-2","softwareUpdate":"basic-1","spotCleaning":"basic-3","wifi":"basic-1"},"meta":{"modelName":"BotVacD7Connected","firmware":"4.5.3-189"}}
                                botvac.0
                                2023-09-08 08:29:38.649	debug	get schedule {"type":1,"enabled":false,"events":[]}
                                botvac.0
                                2023-09-08 08:29:38.588	debug	get schedule {"enabled":false,"events":[]}
                                botvac.0
                                2023-09-08 08:29:38.570	warn	State value to set for "botvac.0.unten.commands.spotHeight" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:29:38.566	warn	State value to set for "botvac.0.unten.commands.spotWidth" has value "0" less than min "100"
                                botvac.0
                                2023-09-08 08:29:38.541	info	undefined is not a valid state value for id "botvac.0.unten.status.canPause"
                                botvac.0
                                2023-09-08 08:29:38.538	debug	robot: {"_nucleoBaseUrl":"https://nucleo.neatocloud.com:4443/vendors/neato/robots/","_beehiveBaseUrl":"https://beehive.neatocloud.com/users/me/robots/","name":"unten","_serial":"OPS39718-F045DA6FF249","_secret":"D0E3BFDA3824F493627EE28D882CE4963BF6A0A112FEF9CB0EDC7C0E7E273ADA74F0D7DFD29510271AA4E69BB72CBA100410604DAEBF66E611D052A75502373BE1A61A12D177E4FE94F8369B63BCF3DA76E2C481D5AC29EBAEC36BB0C9A080E501F23A01A81485F1F59F526ACBCC376FBDDF97F9E23692CF1D9A35D19117F48B","_token":"Token token=37c8b0e205312639b061254cedc49131","availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"isBinFull":false,"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99,"canStart":false,"canStop":false,"canPause":false,"canResume":false,"canGoToBase":false,"eco":false,"noGoLines":true,"navigationMode":1,"spotWidth":0,"spotHeight":0,"spotRepeat":false} state:{"version":1,"reqId":"77","result":"ok","data":{},"error":"dustbin_full","alert":null,"state":4,"action":11,"cleaning":{"category":4,"mode":2,"modifier":1,"navigationMode":1,"mapId":"","spotWidth":0,"spotHeight":0},"details":{"isCharging":true,"isDocked":true,"isScheduleEnabled":false,"dockHasBeenSeen":false,"charge":99},"availableCommands":{"start":false,"stop":false,"pause":false,"resume":false,"goToBase":false},"availableServices":{"findMe":"basic-1","generalInfo":"basic-1","houseCleaning":"basic-3","IECTest":"advanced-1","logCopy":"basic-1","maps":"macro-1","preferences":"basic-2","schedule":"minimal-1","softwareUpdate":"basic-1","spotCleaning":"minimal-2","wifi":"basic-1"},"meta":{"modelName":"BotVacD5Connected","firmware":"4.5.3-189"}}
                                botvac.0
                                2023-09-08 08:29:37.237	warn	Device"unten" with id: unten is not exists in cloud any more!
                                botvac.0
                                2023-09-08 08:29:36.792	info	devices found: 2
                                botvac.0
                                2023-09-08 08:29:34.330	info	starting. Version 1.0.4 (non-npm: iobroker-community-adapters/ioBroker.botvac) in /opt/iobroker/node_modules/iobroker.botvac, node: v18.17.1, js-controller: 4.0.24
                                  PeterVoronov @csp last edited by PeterVoronov
                                  @csp I made a pull request to fix this exact issue.
                                  I don't know how fast it will be applied ...
                                  You can try to install it from my fork - https://github.com/PeterVoronov/ioBroker.botvac/tree/patch-1
                                  In Adapter tab you have to enble expert mode, select custom install and select install from url
                                  Pedder007 mcm1957 2 Replies Last reply Reply Quote 0
                                  • Pedder007
                                    Pedder007 @PeterVoronov last edited by Pedder007
                                    @petervoronov Hi and thanks!
                                    Had the same problem und fixed it with the patch-link 👍
                                    Edit:
                                    But recognized that it causes some warnings now, recurring in frequence of 1 minute:
                                    botvac.0
                                    2023-09-15 12:46:06.971	warn	State value to set for "botvac.0.Freddi.commands.spotHeight" has value "0" less than min "100"
                                    botvac.0
                                    2023-09-15 12:46:06.970	warn	State value to set for "botvac.0.Freddi.commands.spotWidth" has value "0" less than min "100"
                                    Tried to set the objects manually to '100', but they are overwritten by the machine's data after a minute.
                                    Okay, the minute was my polling intervall 😉
                                    • mcm1957
                                      mcm1957 @PeterVoronov last edited by
                                      @petervoronov said in Neato Botvac adapter - further development:
                                      Thanks for the PR
                                      The adapter has been moved to iobroker-community-adapters recently. I'm currently trying to get it to the ciurrent level of infrastructure (standard github based tests, release and deploy scripts, update dependencies - NO planned code changes).
                                      I've released a alpha version incorporating most changes (2.0.0-alpha.0) installing via github and as npm - but not yet listes at repositories.
                                      I would be glad to get some feedback if I did not break things and the code works like the mentioned branch level above.
                                      mcm1957
                                      P.S: Feel free to open a issue at botvac rep if I miss any answer here
                                      JohGre 1 Reply Last reply Reply Quote 0
                                      • JohGre
                                        JohGre @mcm1957 last edited by
                                        @mcm57 hi, have installed the 2.0 alpha today afternoon and no errors. Only some warnings but as i read i can ignore them.
                                        2023-09-18 18:51:00.735  - warn: botvac.0 (53528) State value to set for "botvac.0.Keller.commands.spotWidth" has value "0" less than min "100"
                                        2023-09-18 18:51:00.736  - warn: botvac.0 (53528) State value to set for "botvac.0.Keller.commands.spotHeight" has value "0" less than min "100"
                                        2023-09-18 18:51:00.738  - warn: botvac.0 (53528) State value to set for "botvac.0.Erdgeschoss.commands.spotWidth" has value "0" less than min "100"
                                        2023-09-18 18:51:00.739  - warn: botvac.0 (53528) State value to set for "botvac.0.Erdgeschoss.commands.spotHeight" has value "0" less than min "100"
                                        2023-09-18 18:51:00.741  - warn: botvac.0 (53528) State value to set for "botvac.0.Obergeschoss.commands.spotWidth" has value "0" less than min "100"
                                        2023-09-18 18:51:00.742  - warn: botvac.0 (53528) State value to set for "botvac.0.Obergeschoss.commands.spotHeight" has value "0" less than min "100"
                                        • mcm1957
                                          mcm1957 @JohGre last edited by mcm1957
                                          @johgre said in Neato Botvac adapter - further development:
                                          Danke für das Feeback.
                                          Ich werde dann mal eine 2.0.0 ins latest schicken.
                                          Bezüglich der Warnings erstell bitte ein issue und falls irgendwelche Infos bekannt wann diese Meldungen auftreten, bitte dazu scheiben. Detto bitte die verwendeten Versionen (Dapter, js-controller, ...)
                                          Aus Zeitgründen kann ich nicht zusagen ob / wann ich was tun kann. Aber wir sollten die Warnings nicht unter den Teppich kehren.
                                          Sorry, I missed that this topic is located at english forum - so english text is delivered lately:
                                          I will release a 2.0.0 for latest
                                          In regard to warnings please create a issue and add infos if some environment is known which causes these warnings. Please add the related versions too (adapter, js-controller)
                                          Du to time limitation I cannot promise any timeframe to check.
                                          • JohGre
                                            @mcm57 zu dem Thema gibts schon ein (älteres) Issue
                                            js-controller 5.0.12
                                            botvac-adapter 2.0 alpha
                                            https://github.com/iobroker-community-adapters/ioBroker.botvac/issues/29
                                            68
                                            9540
