    5. [gelöst] Lampe nach Zeit ein /ausschalten
      Alero @DJMarc75 last edited by Alero
      @djmarc75
      Fenstergriff
        "type": "state",
        "common": {
          "def": "CLOSED",
          "type": "number",
          "read": true,
          "write": false,
          "min": 0,
          "max": 2,
          "states": {
            "0": "CLOSED",
            "1": "TILTED",
            "2": "OPEN"
          "role": "state",
          "name": "RHS_Wohnzimmer:1.STATE"
        "native": {
          "MIN": "CLOSED",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID ": "STATE",
          "TYPE": "ENUM",
          "DEFAULT": "CLOSED",
          "VALUE_LIST": [
            "CLOSED",
            "TILTED",
            "OPEN"
          "CONTROL": "RHS.STATE",
          "ID": "STATE"
        "from": "system.adapter.hm-rega.0",
        "user": "system.user.admin",
        "ts": 1606565663365,
        "_id": "hm-rpc.1.0007DA4989ADED.1.STATE",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Fensterkontakt
        "type": "state",
        "common": {
          "def": 0,
          "type": "number",
          "read": true,
          "write": false,
          "min": 0,
          "max": 1,
          "states": {
            "0": "CLOSED",
            "1": "OPEN"
          "unit": "\"\"",
          "role": "value.window",
          "name": "TFK_Terrassentuer:1.STATE"
        "native": {
          "MIN": "CLOSED",
          "UNIT": "\"\"",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID": "STATE",
          "TAB_ORDER": 0,
          "TYPE": "ENUM",
          "VALUE_LIST": [
            "CLOSED",
            "OPEN"
          "CONTROL": "DOOR_SENSOR.STATE"
        "ts": 1683371744664,
        "_id": "hm-rpc.1.0000D8A99E5B80.1.STATE",
        "acl": {
          "object": 1636,
          "state": 1636,
      Schalter licht
        "type": "state",
        "common": {
          "def": false,
          "type": "boolean",
          "read": true,
          "write": true,
          "role": "switch",
          "name": "FS_Garage_Gartenlicht_1_bis_4:1.STATE"
        "native": {
          "CONTROL": "SWITCH.STATE",
          "DEFAULT": false,
          "FLAGS": 1,
          "ID": "STATE",
          "MAX": true,
          "MIN": false,
          "OPERATIONS": 7,
          "TAB_ORDER": 0,
          "TYPE": "BOOL",
          "UNIT": ""
        "ts": 1561403105982,
        "_id": "hm-rpc.0.IEQ0023606.1.STATE",
        "acl": {
          "object": 1636,
          "state": 1636,
      Homoran DJMarc75 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Alero last edited by
        @alero sagte in Lampe nach Zeit ein /ausschalten:
        Fenstergriff
        ist der channel, nicht der state!
        Fensterkontakt
        ist wie erwartet Werteliste mit 0 und 1, weder bool, noch text
        Schalter licht
        ist bool
        • DJMarc75
          DJMarc75 @Alero last edited by
          @alero Dann eben so:
          A Newpicsel 2 Replies Last reply Reply Quote 0
            @djmarc75
            hi,
            vielen dank, ich werde es ausprobieren und bescheid geben.
            Vielen vielen Dank an euch alle.
            • Codierknecht
              Codierknecht Developer Most Active @Homoran last edited by
              @homoran sagte in Lampe nach Zeit ein /ausschalten:
              DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Codierknecht last edited by
                @codierknecht er hat es editiert und steht nun korrekt drin 😉
                  Homoran Global Moderator Administrators @Codierknecht last edited by
                  @codierknecht sagte in Lampe nach Zeit ein /ausschalten:
                  enäää
                  nachträglich editiert ohne Kennzeichnung 😡
                  Strafmaß wird später bekannt gegeben 😂
                  crunchip 1 Reply Last reply Reply Quote 1
                    crunchip Forum Testing Most Active @Homoran last edited by
                    @homoran is der Vorteil wenn man nachgucken kann😜
                      Homoran Global Moderator Administrators @DJMarc75 last edited by
                      @djmarc75 sagte in Lampe nach Zeit ein /ausschalten:
                      @Alero
                      und genau deswegen müssen Edits gekennzeichnet werden, weil sonst die folgenden Posts sinnentstellt werden
                        Alero @Homoran last edited by
                        hi,
                        habe jetzt mal das script gestestet.
                        Die Lampe geht an aber leider nicht wieder aus nach 3 min.
                        • DJMarc75
                          @alero
                          Verschiebe das obere "stop ausschalten" unter Deinen gelben KommentarBaustein.
                            @djmarc75
                            danke
                            werde es testen
                              Alero @Alero last edited by
                              Leider funzt es immer noch nicht
                              • DJMarc75
                                Blockly zeigen bitte
                                  @djmarc75
                                  HI,
                                  hier das script. Das licht geht zwar an aber nicht wieder aus.
                                  • DJMarc75
                                    @alero kann es sein dass der BWM ständig eine Bewegung registriert ?
                                    Bau mal ein Debug ganz oben ein und beobachte das LOG
                                      @djmarc75
                                        @alero was willst du damit zeigen?
                                        • DJMarc75
                                          @alero stell mal von debug auf error oder warn um
                                            @djmarc75
                                            hi, habe ich . zusätzlich habe ich noch im iobroker im objekt nachgeschaut. er steht die ganze zeit auf false
                                            Bei Error kommt auch nix.
                                            DJMarc75 Codierknecht 2 Replies Last reply Reply Quote 0
                                            3055
