    4. iob node fix - Skript
      emil70 @Thomas Braun last edited by
      update hat auch geklappt
      ioBroker nodejs fixer 2023-09-03
      Recommended nodejs-version is: 18.17.1
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.17.0
      /usr/bin/node           v18.17.0
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      I found these versions available:
      nodejs:
        Installed: 18.17.0-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
           18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
       *** 18.17.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      Nothing to do, your installation seems to be correct
      !!! THIS CODE IS IN BETA STAGE. TRY IT AT YOUR OWN RISK !!!
      You are running nodejs v18.17.0. Do you want to install recommended nodejs v18.17.1?
      *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      find: '/proc/401/map_files': Permission denied
      find: '/proc/462/map_files': Permission denied
      find: '/proc/488/map_files': Permission denied
      find: '/proc/656/map_files': Permission denied
      find: '/proc/713/map_files': Permission denied
      find: '/proc/728/map_files': Permission denied
      find: '/proc/789/map_files': Permission denied
      find: '/proc/846/map_files': Permission denied
      find: '/proc/976/map_files': Permission denied
      find: '/proc/1094/map_files': Permission denied
      find: '/proc/1138/map_files': Permission denied
      find: '/proc/1429/map_files': Permission denied
      find: '/proc/1496/map_files': Permission denied
      find: '/proc/1592/map_files': Permission denied
      find: '/proc/1745/map_files': Permission denied
      find: '/proc/1944/map_files': Permission denied
      find: '/proc/2057/map_files': Permission denied
      find: '/proc/3118/map_files': Permission denied
      find: '/proc/5214/map_files': Permission denied
      find: '/proc/7598/map_files': Permission denied
      find: '/proc/7605/map_files': Permission denied
      find: '/proc/8786/map_files': Permission denied
      find: '/proc/13521/map_files': Permission denied
      find: '/proc/16592/map_files': Permission denied
      find: '/proc/17200/map_files': Permission denied
      find: '/proc/19043/map_files': Permission denied
      find: '/proc/22112/map_files': Permission denied
      find: '/proc/26681/map_files': Permission denied
      find: '/proc/26702/map_files': Permission denied
      find: '/proc/26882/map_files': Permission denied
      find: '/proc/31575/map_files': Permission denied
      iobroker controller daemon is not running
      Waiting for ioBroker to shut down - Give me a minute...
      Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Get:4 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [245 kB]
      Fetched 337 kB in 1s (412 kB/s)
      Reading package lists... Done
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
      Fetched 17.3 kB in 2s (11.1 kB/s)
      DEBUG NODEINSTMAJOR: 18 NODEMAJOR:  NODERECOMNF:
      *** DEBUG *** Installation ohne spez. Version
      Building dependency tree... Done
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
      Need to get 29.4 MB of archives.
      After this operation, 7168 B of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
      Fetched 29.4 MB in 3s (10.7 MB/s)
      (Reading database ... 32259 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-deb-1nodesource1) ...
      Setting up nodejs (18.17.1-1nodesource1) ...
      *** You need to manually restart your container now! ***
      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        Thomas Braun Most Active @emil70 last edited by Thomas Braun
        @emil70 sagte in iob node fix - Skript:
        Lief auf Docker sauber durch
        Auf einem Docker sollte das eigentlich gar nicht laufen.
        Edit: Man sollte den entsprechenden Code auch aktiv setzen...
          Thomas Braun Most Active @fastfoot last edited by
          @fastfoot
          Ist doch...
          Line 230:
          $SUDOX rm "$(sudo find / -name nodesource.key)" &> /dev/null;
            emil70 @Thomas Braun last edited by emil70
            @thomas-braun sagte in iob node fix - Skript:
            wie meinen??
            Mit ```
            systemd-detect-virt 2
            kann Docker nix anfangen
            Dadurch wird doch das ausgelöst oder nicht
             if [ "$SYSTDDVIRT" != "none" ]; then
                                            echo "$SYSTDDVIRT";
                                            #sudo pkill -u iobroker;    #FIX ME! How to shut down iob in LXC without killing the script?
        #Using 'iob stop' in the meantime.
                                            iob stop;
                                    else
                                            iob stop;
                                    fi;
              @emil70
              Dann zieh den Code jetzt nochmal runter.
              Sollte jetzt abgebrochen werden.
                @emil70
                root@iobroker:/opt/iobroker# curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update > iob_node_update
                  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                 Dload  Upload   Total   Spent    Left  Speed
                100 10916  100 10916    0     0  50073      0 --:--:-- --:--:-- --:--:-- 50073
                root@iobroker:/opt/iobroker# ./iob_node_update
                ioBroker node-update v2023-09-03 is starting. Please be patient!
                Fixing Docker is not supported, please update your Docker Container
                  @emil70
                  Ja, so soll das.
                    @Thomas-Braun
                    Was soll das denn sein
                    Das ist doch keine GUI.
                    Da musst du noch mal ran 😂
                    E Thomas Braun 2 Replies Last reply Reply Quote 1
                      emil70 @Homoran last edited by
                      @homoran sagte in iob node fix - Skript:
                      @Thomas-Braun
                      Verstehe ich gerade nicht
                        Thomas Braun Most Active @Homoran last edited by Thomas Braun
                        ncurses kommt noch...
                        Erstmal muss der Code noch rundgelutscht werden.
                        Sollte aber Stand 'gerade jetzt' funktionieren. Werden halt noch ein paar Meldungen ausgespuckt, aber die kann man unterdrücken.
                          fastfoot @Thomas Braun last edited by
                          Ist doch...
                          nicht das $(sudo find.... Mit Fehler meinte ich find: '/proc/976/map_files: Permission denied'
                            @fastfoot sagte in iob node fix - Skript:
                            Ich seh nicht mal wo der herkommt. Landet aber jetzt alles in /dev/null
                              mrjeschke @Thomas Braun last edited by
                              Etwas unschön finde ich es noch wenn der nodejs Softlink fehlt.
                              ./iob_node_update: line 98: nodejs: command not found
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              ./iob_node_update: line 109: nodejs: command not found
                              *** nodejs is NOT correctly installed ***
                              nodejs:
                                Installed: 18.17.1-deb-1nodesource1
                                Version table:
                               *** 18.17.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                                   18.13.0+dfsg1-1 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                              Your nodejs-Installation seems to be not correct. Shall we try to fix it?
                              DO NOT RUN FIX ON NON-LINUX-SYSTEMS!
                              Fixing your nodejs setup
                              *** Deleting  ***
                              rm: cannot remove '': No such file or directory
                              Wrong paths have been fixed. Run 'iob diag' or 'iob node-update' again to check if your installation is fine now
                              maik@iobtest:~$
                                Thomas Braun Most Active @mrjeschke last edited by
                                @mrjeschke sagte in iob node fix - Skript:
                                Das ist bei aktuellen builds von nodesource aus dem 'nodist'-Repo nicht mehr erforderlich. Die bringen den dann wieder mit.
                                  Thomas Braun Most Active @mrjeschke last edited by Thomas Braun
                                  Hab ich jetzt auch drin. Wird nicht mehr angemeckert. Gleiches gilt für ein nicht vorhandenes corepack. Das wurde erst mit nodejs@16.irgendwas eingeführt und ist daher nicht überall vorhanden.
                                  Das Skript sollte jetzt alle möglichen und unmöglichen Konstellationen schlucken.
                                  Da ist nur noch ein Bug drin, das wenn man den Fix abbrechen will wird dennoch eine Installation durchgeführt... Zwangsbeglückung... Muss ich mir die Tage noch mal anschauen. FIXED
                                  Zumindest sollte das skript nix weiter kaputt machen. Fehlermeldungen hab ich nicht unterdrückt, das hat zu komischen Ergebnissen geführt, war mir zu heiß.
                                  Lasst das Skript also mal bitte auf alle erdenklichen Konstellationen los.
                                  Krumme Pfade, steinalte nodejs-Versionen, zu neue Versionen (nodejs 20), fehlende Symlinks usw. Ich hoffe das wird nun alles geschluckt und dann zur aktuell empfohlenen nodejs-Version gebogen.
                                  Hinweis: Der iobroker wird vor einer Installation der richtigen nodejs-Version gestoppt und danach wieder gestartet.
                                    Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                                    Note to myself / ToDo:
                                    1.) Zustand der nodesource.list checken. Wenn schon neues Format, dann nichts tun.
                                    2.) ioBroker Stop und Restart in diesem Fall:
                                    ioBroker nodejs fixer 2023-09-05
                                    /usr/bin/npm 		9.6.7
                                    /usr/bin/npx 		9.6.7
                                    I found these versions to be available for installation:
                                    nodejs:
                                      Version table:
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    Nothing to do, your installation is using the correct paths.
                                    You are running nodejs v18.17.0. Do you want to install recommended nodejs 18.17.1?
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                                    Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                    ca-certificates is already the newest version (20210119).
                                    curl is already the newest version (7.74.0-1.3+deb11u7).
                                    gnupg is already the newest version (2.2.27-2+deb11u2).
                                    gnupg set to manually installed.
                                    0 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
                                    Creating new /etc/apt/sources.list.d/nodesource.list file with this content:
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    Get:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                                    Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                    Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5177 B]
                                    Get:9 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5161 B]
                                    Fetched 22.5 kB in 3s (8008 B/s)
                                      nodejs
                                    1 upgraded, 0 newly installed, 0 to remove and 11 not upgraded.
                                    Need to get 28.7 MB of archives.
                                    After this operation, 3072 B of additional disk space will be used.
                                    Get:1 https://deb.nodesource.com/node_18.x nodistro/main arm64 nodejs arm64 18.17.1-1nodesource1 [28.7 MB]
                                    Fetched 28.7 MB in 2s (17.6 MB/s)
                                    Reading changelogs... Done
                                    (Reading database ... 50413 files and directories currently installed.)
                                    Preparing to unpack .../nodejs_18.17.1-1nodesource1_arm64.deb ...
                                    Processing triggers for man-db (2.9.4-2) ...
                                    Your ioBroker is restarting now. Please refresh the admin page in your browser
                                    pi@iobmaster:~ $
                                    • Meister Mopper
                                      Meister Mopper @Thomas Braun last edited by
                                      Da passiert nur, wenn die empfohlene Version und die installierte Version ungleich sind. Bei einer empfohlenen v18.17.2 würde das z. B. umgestellt. So bist du aber aber ja schon auf der aktuellen Version, wenn auch im Moment noch aus dem alten Repo. Installier mal ein nodejs@16 oder 20. Dann wird ein nodejs@18 installiert werden.
                                      Ich habe das mal nachgestellt. Die Umstellung auf nodejs@16 hat nicht funktioniert aber die auf nodejs@20.
                                      Dann habe ich das Skript gestartet und ich erhielt dies:
                                      /usr/bin/nodejs         v20.5.1
                                      /usr/bin/node           v20.5.1
                                      /usr/bin/npm            9.8.0
                                      /usr/bin/npx            9.8.0
                                      /usr/bin/corepack       0.19.0
                                      I found these versions available for installation:
                                      nodejs:
                                        Installed: 20.5.1-deb-1nodesource1
                                        Candidate: 20.5.1-deb-1nodesource1
                                        Version table:
                                       *** 20.5.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                                           18.13.0+dfsg1-1 500
                                      You are running nodejs v20.5.1. Do you want to install recommended nodejs 18.17.1?
                                      find: '/sys/kernel/debug': Permission denied
                                      find: '/sys/fs/fuse/connections/60': Permission denied
                                      find: '/sys/fs/fuse/connections/55': Permission denied
                                      find: '/dev/.lxc/sys/kernel': Permission denied
                                      find: '/dev/.lxc/sys/power': Permission denied
                                      find: '/dev/.lxc/sys/class': Permission denied
                                      find: '/dev/.lxc/sys/devices': Permission denied
                                      find: '/dev/.lxc/sys/dev': Permission denied
                                      find: '/dev/.lxc/sys/hypervisor': Permission denied
                                      find: '/dev/.lxc/sys/fs': Permission denied
                                      find: '/dev/.lxc/sys/bus': Permission denied
                                      find: '/dev/.lxc/sys/firmware': Permission denied
                                      find: '/dev/.lxc/sys/block': Permission denied
                                      find: '/dev/.lxc/sys/module': Permission denied
                                      find: '/dev/.lxc/proc/fs': Permission denied
                                      find: '/dev/.lxc/proc/bus': Permission denied
                                      find: '/dev/.lxc/proc/irq': Permission denied
                                      find: '/dev/.lxc/proc/spl': Permission denied
                                      find: '/dev/.lxc/proc/sys': Permission denied
                                      find: '/dev/.lxc/proc/tty': Permission denied
                                      find: '/dev/.lxc/proc/acpi': Permission denied
                                      find: '/dev/.lxc/proc/scsi': Permission denied
                                      find: '/dev/.lxc/proc/driver': Permission denied
                                      find: '/dev/.lxc/proc/sysvipc': Permission denied
                                      find: '/dev/.lxc/proc/pressure': Permission denied
                                      find: '/dev/.lxc/proc/dynamic_debug': Permission denied
                                      find: '/dev/.lxc/proc/1': Permission denied
                                      find: '/dev/.lxc/proc/45': Permission denied
                                      find: '/dev/.lxc/proc/82': Permission denied
                                      find: '/dev/.lxc/proc/92': Permission denied
                                      find: '/dev/.lxc/proc/94': Permission denied
                                      find: '/dev/.lxc/proc/95': Permission denied
                                      find: '/dev/.lxc/proc/102': Permission denied
                                      find: '/dev/.lxc/proc/120': Permission denied
                                      find: '/dev/.lxc/proc/124': Permission denied
                                      find: '/dev/.lxc/proc/125': Permission denied
                                      find: '/dev/.lxc/proc/126': Permission denied
                                      find: '/dev/.lxc/proc/128': Permission denied
                                      find: '/dev/.lxc/proc/7214': Permission denied
                                      find: '/dev/.lxc/proc/7217': Permission denied
                                      find: '/dev/.lxc/proc/7218': Permission denied
                                      find: '/dev/.lxc/proc/7237': Permission denied
                                      find: '/dev/.lxc/proc/7238': Permission denied
                                      find: '/dev/.lxc/proc/7772': Permission denied
                                      find: '/dev/.lxc/proc/7946': Permission denied
                                      find: '/dev/.lxc/proc/7947': Permission denied
                                      find: '/dev/.lxc/proc/7950': Permission denied
                                      find: '/dev/.lxc/proc/7951': Permission denied
                                      lxc
                                      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      ca-certificates is already the newest version (20230311).
                                      curl is already the newest version (7.88.1-10+deb12u1).
                                      gnupg is already the newest version (2.2.40-1.1).
                                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      Fetched 17.3 kB in 1s (23.0 kB/s)
                                      The following packages will be DOWNGRADED:
                                        nodejs
                                      0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                                      After this operation, 5242 kB disk space will be freed.
                                      Fetched 29.4 MB in 2s (13.1 MB/s)
                                      dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.1-1nodesource1
                                      (Reading database ... 46250 files and directories currently installed.)
                                      Unpacking nodejs (18.17.1-1nodesource1) over (20.5.1-deb-1nodesource1) ...
                                      Processing triggers for man-db (2.11.2-2) ...
                                      0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                                      Need to get 0 B/29.4 MB of archives.
                                      After this operation, 0 B of additional disk space will be used.
                                      (Reading database ... 46317 files and directories currently installed.)
                                      Unpacking nodejs (18.17.1-1nodesource1) over (18.17.1-1nodesource1) ...
                                      Ein beherztes sudo reboot ergab das erwartete Ergebnis.
                                      thomas@iobroker:~$ nodejs -v
                                      v18.17.1
                                      thomas@iobroker:~$ sudo nano /etc/apt/sources.list.d/nodesource.list
                                      Was bedeutet 'Permission denied'? Die Ausgabe ist mir ein Rätsel.
                                      Thomas Braun F 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @Meister Mopper last edited by
                                        @meister-mopper sagte in iob node fix - Skript:
                                        Da jagt ein 'find' nach den nodesource-Keys durch das System, außer durch /proc.
                                        Aber ich sehe, dass ich da bei LXC auch noch andere Verzeichnisse (/sys und /dev) ausschließen muss.
                                        Kannst du das jetzt nochmal nachstellen? Also nodejs@20 installieren und nochmal vom skript auf 18 bringen lassen. Der erste Block an Meldungen sollte dann nicht mehr auftauchen. Zeilen 38-83.
                                        Den Code für den zweiten Key hab ich noch nicht angepasst. Mache ich, wenn es für den ersten passt.
                                        Meister Mopper 1 Reply Last reply Reply Quote 1
                                          fastfoot @Meister Mopper last edited by
                                          die 16er bekommst du indem du das repo auf 16 umstellst/erweiterst und dann apt update und anschliessend ein apt install nodejs=16.20.2-1nodesource1 ausführst
                                          • Meister Mopper
                                            Meister Mopper @Thomas Braun last edited by Meister Mopper
                                            Neues Skript heruntergeladen - kein reboot nach Installation auf nodejs@20:
                                            /usr/bin/nodejs         v20.6.0
                                            /usr/bin/node           v20.6.0
                                            /usr/bin/npm            9.8.1
                                            /usr/bin/npx            9.8.1
                                            nodejs:
                                              Installed: 20.6.0-1nodesource1
                                              Candidate: 20.6.0-1nodesource1
                                              Version table:
                                             *** 20.6.0-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                                 20.5.1-1nodesource1 500
                                                 20.5.0-1nodesource1 500
                                                 20.4.0-1nodesource1 500
                                                 20.3.1-1nodesource1 500
                                                 20.3.0-1nodesource1 500
                                                 20.2.0-1nodesource1 500
                                                 20.1.0-1nodesource1 500
                                                 20.0.0-1nodesource1 500
                                                 18.13.0+dfsg1-1 500
                                            You are running nodejs v20.6.0. Do you want to install recommended nodejs 18.17.1?
                                            find: '/dev/.lxc/proc/76': Permission denied
                                            find: '/dev/.lxc/proc/93': Permission denied
                                            find: '/dev/.lxc/proc/96': Permission denied
                                            find: '/dev/.lxc/proc/123': Permission denied
                                            find: '/dev/.lxc/proc/127': Permission denied
                                            find: '/dev/.lxc/proc/129': Permission denied
                                            find: '/dev/.lxc/proc/130': Permission denied
                                            find: '/dev/.lxc/proc/19126': Permission denied
                                            find: '/dev/.lxc/proc/19129': Permission denied
                                            find: '/dev/.lxc/proc/19130': Permission denied
                                            find: '/dev/.lxc/proc/19149': Permission denied
                                            find: '/dev/.lxc/proc/19150': Permission denied
                                            find: '/dev/.lxc/proc/20024': Permission denied
                                            find: '/dev/.lxc/proc/20125': Permission denied
                                            find: '/dev/.lxc/proc/20126': Permission denied
                                            find: '/dev/.lxc/proc/20129': Permission denied
                                            find: '/dev/.lxc/proc/20130': Permission denied
                                            lxc
                                            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                            Hit:2 http://deb.debian.org/debian bookworm InRelease
                                            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                            Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                                            Fetched 17.3 kB in 1s (20.9 kB/s)
                                              nodejs
                                            After this operation, 5746 kB disk space will be freed.
                                            dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
                                            (Reading database ... 46293 files and directories currently installed.)
                                            Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
                                            198
                                            37761
