      losossos @Kuckuckmann last edited by
      @kuckuckmann said in SONOFF NSPanel mit Lovelace UI:
      Du kannst das XML vom Blockly (Export Button nutzen) hier als Spoiler rein packen, dann kann man es sich ziehen und importieren. Wärst Du so nett es zu posten?
      Klar, Kein Problem:
        <variables>
          <variable type="cron" id="Stati_an_HMIs_senden">Stati_an_HMIs_senden</variable>
          <variable id="VZf%pEO,fVtNN`Z2zJ~Q">Durchlauf</variable>
          <variable id="zDH?_%C!d6OI,`P[a.i:">Status-Titel</variable>
          <variable id="aejf`L;)M:EGo;7S=Yg@">Statuswert</variable>
        </variables>
        <block type="schedule_create" id="JT7YLb+qLp]Av_U(n_sm" x="-212" y="113">
          <field name="NAME">Stati_an_HMIs_senden</field>
          <value name="SCHEDULE">
            <shadow type="field_cron" id="z4AXT)EPB_%+`_i|lb_)">
              <field name="CRON">*/5 * * * * *</field>
            <block type="controls_if" id="KTxid8XGHV?yfYM4)66x">
                <block type="logic_operation" id="K01G.jX4yT8RfQH;(L!Z">
                  <field name="OP">OR</field>
                    <block type="logic_compare" id="]=HQeG:Q?%^IkxN-%EOE">
                      <field name="OP">LT</field>
                        <block type="variables_get" id="{?mCnQFVOQ]:%?=;(dID">
                          <field name="VAR" id="VZf%pEO,fVtNN`Z2zJ~Q">Durchlauf</field>
                        <block type="math_number" id="HT.?.ev3MTsBdE[q%ib]">
                          <field name="NUM">1</field>
                    <block type="logic_compare" id="NK{dd=F*Mb1mu!$NG^N#">
                      <field name="OP">GT</field>
                        <block type="variables_get" id="ai3[c7[P|Q1ZP2r/QeES">
                        <block type="math_number" id="#CbZ|4;Yj,J:G$4,hu,`">
                          <field name="NUM">9</field>
                <block type="variables_set" id="^]C~v5iN9fk:?)3(IIds">
                    <block type="math_number" id="Z4c,tsp7!4BQ8^#c_K;M">
                <block type="controls_if" id="PBcQM|-DnHh2[60%rHhE">
                  <mutation elseif="8"></mutation>
                    <block type="logic_compare" id="=b*EBBUD#/.Nlc!wlvDH">
                      <field name="OP">EQ</field>
                        <block type="variables_get" id="3rseBxJA|-wlMT:NWHUU">
                        <block type="math_number" id="jHAoug%0vO-0CJRGMqGp">
                    <block type="variables_set" id="_On3pRA6n14yQt?aP.UA">
                      <field name="VAR" id="zDH?_%C!d6OI,`P[a.i:">Status-Titel</field>
                        <block type="text_join" id="~w5S_B+FtE5fIrvtkBb@">
                          <value name="ADD0">
                            <block type="text" id="$j`[iq.om4CKEd5ds*GA">
                              <field name="TEXT">PV-Erzeugung </field>
                        <block type="variables_set" id="IbcZWB!1-aGApG9Z_+ca">
                          <field name="VAR" id="aejf`L;)M:EGo;7S=Yg@">Statuswert</field>
                            <block type="text_join" id="B$47Csi$.MY$RY?1oN+}">
                              <value name="ADD0">
                                <block type="math_rndfixed" id="d+s@(OZ2NR;lw+k4Iyh2">
                                  <field name="n">1</field>
                                  <value name="x">
                                    <shadow type="math_number" id="5T})[LLnr?wd4k@Ve37|">
                                      <field name="NUM">3.1234</field>
                                    <block type="math_arithmetic" id="u$)sV#x#+8,3k9c7g=i)">
                                      <field name="OP">DIVIDE</field>
                                        <shadow type="math_number" id="VFWt$_F.c7h6d83Nt9)W">
                                        <block type="get_value" id="U(!!K!IsSNK|,v(@08Q6">
                                          <field name="OID">senec.0.ENERGY.GUI_INVERTER_POWER</field>
                                        <shadow type="math_number" id="SQ@tUwJQJ*_@:8r9m.~1">
                                          <field name="NUM">1000</field>
                            <block type="text_append" id=":#[5;c]wS=jqt#~0!`LQ">
                              <value name="TEXT">
                                <shadow type="text" id="5dd1zABKhh7=b9gG1C;S">
                                  <field name="TEXT">kW</field>
                  <value name="IF1">
                    <block type="logic_compare" id="i]Afh#J;~El$~X9JN*{(">
                        <block type="variables_get" id="89yIzTa/8%R{=bMqnr{5">
                        <block type="math_number" id=":$VYU-!c|y!V*=f-IH.M">
                          <field name="NUM">2</field>
                  <statement name="DO1">
                    <block type="variables_set" id="Nx{;%ltCObET/!_R$Qm$">
                        <block type="text_join" id="26^gc[2P=9)-F0KqNipP">
                          <value name="ADD0">
                            <block type="text" id="w5jvxWxdhCD1BzRV8%Z9">
                              <field name="TEXT">Akkustand-PV </field>
                        <block type="variables_set" id="-:q}rVgJUI2`v2a:%YrW">
                            <block type="text_join" id="BQy%E6pOyeF.2UjJbs=8">
                              <value name="ADD0">
                                <block type="math_rndfixed" id="p}7hX#;E8hG/K#!3LY(S">
                                  <field name="n">2</field>
                                  <value name="x">
                                    <shadow type="math_number" id="go[g-6|bz/*9?BxnWpy2">
                                    <block type="get_value" id="7GdI6n`.G-/_*U+uLC[3">
                                      <field name="OID">senec.0.ENERGY.GUI_BAT_DATA_FUEL_CHARGE</field>
                            <block type="text_append" id="@=K?[PzFeDsA{rsyqc${">
                              <value name="TEXT">
                                <shadow type="text" id=";(]WuCkOVTcMy$uiR$1X">
                                  <field name="TEXT">%</field>
                  <value name="IF2">
                    <block type="logic_compare" id="y=/|SN[.]+mz@{481*,+">
                        <block type="variables_get" id="fO4X3V{kn8y}a?y6Es|r">
                        <block type="math_number" id="o}N__hy{OR=]*oUqOqTM">
                          <field name="NUM">3</field>
                  <statement name="DO2">
                    <block type="variables_set" id="sH?jUA(BV+1){Togfe*5">
                        <block type="text_join" id="M]d6l:a*CxY3))[ZOkp[">
                          <value name="ADD0">
                            <block type="text" id="s[]G8?Nq|[`lU%5T)a%s">
                              <field name="TEXT">Haus-Verbrauch  </field>
                        <block type="variables_set" id="xF40V(@.b+li5n;lMq{3">
                            <block type="text_join" id="B#;=tW,kcj1A[w@aI6jh">
                              <value name="ADD0">
                                <block type="math_rndfixed" id="W|yg:x}-=MXt|]+|kTo5">
                                  <value name="x">
                                    <shadow type="math_number" id="=$c3X]Nm_Iw3ux#|vQQ[">
                                    <block type="math_arithmetic" id="cV?I~JN{?v4,/8?A1FgF">
                                        <shadow type="math_number" id="`w9q:;NA3o+@WF6{HT-E">
                                        <block type="get_value" id="Qp$mB+Q,+NBtTh-R#PdV">
                                          <field name="OID">senec.0.ENERGY.GUI_HOUSE_POW</field>
                                        <shadow type="math_number" id="p@Bh$5ywBO(9X;;6r3%E">
                            <block type="text_append" id="2._aTohPPu{+W~62wxiH">
                              <value name="TEXT">
                                <shadow type="text" id="AJ:c/C5*O`Au|t^__*AX">
                  <value name="IF3">
                    <block type="logic_compare" id="o2mfy*P1/MlRnSDQ+YMC">
                        <block type="variables_get" id="6i+_eG8RXsV3R:W7mbx=">
                        <block type="math_number" id="mC,cEID3xK4!.pc8Qp#P">
                          <field name="NUM">4</field>
                  <statement name="DO3">
                    <block type="variables_set" id="xBxMgH+!C),,b8~Q}f9q">
                        <block type="text_join" id="=G93BQ]rz*EgCR!7.{Xy">
                          <value name="ADD0">
                            <block type="text" id="W#nrR[cm}u;x#^ZzTkJq">
                              <field name="TEXT">Tagesertrag PV</field>
                        <block type="variables_set" id="|=mObrPdZ61V*32Se{?B">
                            <block type="text_join" id="8[[u|H{|MSEyyB6VvZTH">
                              <value name="ADD0">
                                <block type="get_value" id="#{-xZl`gOmOv`~yo)|_+">
                                  <field name="OID">senec.0._calc.LIVE_PV_GEN.today</field>
                            <block type="text_append" id=",(cdqdCG-EybVa{ri^tm">
                              <value name="TEXT">
                                <shadow type="text" id="|Yt6lrfJ^,HVlldv/:b1">
                                  <field name="TEXT">kWh</field>
                  <value name="IF4">
                    <block type="logic_compare" id="nKB)ra-O:%Yq$3k$nCCM">
                        <block type="variables_get" id="~?N*x:wL:464eTsNC=hC">
                        <block type="math_number" id="$jnU2.2M:ug5|]y6W^4L">
                          <field name="NUM">5</field>
                  <statement name="DO4">
                    <block type="variables_set" id="0brZY,==?7ex|03dQ5AL">
                        <block type="text_join" id="|vq/}||Nxm2^hI)/*EaZ">
                          <value name="ADD0">
                            <block type="text" id="V$DF2CVVtM3eUvX*[l5v">
                              <field name="TEXT">Tagesverbrauch</field>
                        <block type="variables_set" id="z(}s9ED(cYn0EvIOe+KT">
                            <block type="text_join" id="9/(4#7~w9sxj.ghD)_X[">
                              <value name="ADD0">
                                <block type="get_value" id="e%iE^)Wp8)CwI/Z.X^^.">
                                  <field name="OID">senec.0._calc.LIVE_HOUSE_CONS.today</field>
                            <block type="text_append" id="Uj]N*yCow]sScbxt)|y}">
                              <value name="TEXT">
                                <shadow type="text" id="QKl=/%H;_@~F7@?;I0NS">
                  <value name="IF5">
                    <block type="logic_compare" id="Lp`swqg||PRyxr;];8t6">
                        <block type="variables_get" id="lzaePeg5`YX$r6.QjMi(">
                        <block type="math_number" id="1zgi,S[PmV-E?92`N0|I">
                          <field name="NUM">6</field>
                  <statement name="DO5">
                    <block type="variables_set" id="OH:GCngQ%/G4?XNx5]N|">
                        <block type="text_join" id="aS=hdi}xFZg3%o:lN]x;">
                          <value name="ADD0">
                            <block type="text" id="joQct8TM-hc)oQP9=!h.">
                              <field name="TEXT">Kamin-Temp.</field>
                        <block type="variables_set" id="v|`C@YP=t,6ZrRA7ErT}">
                            <block type="text_join" id="sM:;%sf}hHp(X`*Zf*,X">
                              <value name="ADD0">
                                <block type="get_value" id="a_^VJZD@D|2;%!:-T)fc">
                                  <field name="OID">openknx.0.Heizen.Temperatur_(IST).IST-Temperatur_Kamin</field>
                            <block type="text_append" id="3z|6EY.B0W/{:}OW,iGu">
                              <value name="TEXT">
                                <shadow type="text" id="JA!rtqU/b6uLS[#(lH-K">
                                  <field name="TEXT">°C</field>
                  <value name="IF6">
                    <block type="logic_compare" id="5yDGXMXds6cpLeEIk-_!">
                        <block type="variables_get" id="nv8G#wdvRJ[]mua-wGYi">
                        <block type="math_number" id="R1CqxD-pgOYZA0_((}o6">
                          <field name="NUM">7</field>
                  <statement name="DO6">
                    <block type="variables_set" id="y3WNRL`{d*1-`jnppaUi">
                        <block type="text_join" id="cAd3)u0hS==M7GTF~Ma,">
                          <value name="ADD0">
                            <block type="text" id="4ar{R{q`lWyd28`ouJn4">
                              <field name="TEXT">Wind</field>
                        <block type="variables_set" id="3ZNi(PfAT,Z[bXzN+,6O">
                            <block type="text_join" id="?RTgg6XOCAs`!!%0u!MW">
                              <value name="ADD0">
                                <block type="get_value" id="e7JEgb7C.9!lLc).gnJp">
                                  <field name="OID">openknx.0.Wetter.Wetterstation_MDT.Windgeschwindigkeit</field>
                            <block type="text_append" id="HgN%kgRMnEHUu|2XgeDM">
                              <value name="TEXT">
                                <shadow type="text" id="=F!1MJotI_w,;!~7RWOg">
                                  <field name="TEXT">m/s</field>
                  <value name="IF7">
                    <block type="logic_compare" id="=0Bc[u9D{gS*P{OMpHHq">
                        <block type="variables_get" id="|6=Wg%CCug0u(Yn~i3v;">
                        <block type="math_number" id=",5T!pS~M6x}Xp*j[)FFq">
                          <field name="NUM">8</field>
                  <statement name="DO7">
                    <block type="variables_set" id="dGlNmN8H/XV{KT+rbj~H">
                        <block type="text_join" id="gvuj0i8v!J(}U`y~4Em+">
                          <value name="ADD0">
                            <block type="text" id="u/zXq1rLKf|iIm3x.ucK">
                              <field name="TEXT">WC-Nebengebäude</field>
                        <block type="variables_set" id="PHo4Slt;z?ZOOd@WrL=+">
                            <block type="text_join" id="*?F}u(Xij,aI;_CcXIW0">
                              <value name="ADD0">
                                <block type="get_value" id="6lI1D`F4!XJH^}SFD[6F">
                                  <field name="OID">openknx.0.Heizen.Temperatur_(IST).ISTwert_Bad_Nebengebäude_HMI_</field>
                            <block type="text_append" id="DnS)+#WMCEbbdtv.Ce2l">
                              <value name="TEXT">
                                <shadow type="text" id="_zkc%$r/oBnM8Sc1@Xna">
                  <value name="IF8">
                    <block type="logic_compare" id="#y,w,$g:7X7=QfP.(%`y">
                        <block type="variables_get" id=":=sIkYqy-$K,wmPZKD%w">
                        <block type="math_number" id="?yhXb0#=?!([D[ks|=@i">
                  <statement name="DO8">
                    <block type="variables_set" id="^MANy4M4yr971nlZ[m-q">
                        <block type="text_join" id="M/WlX%wsjy+[#XS3EG^~">
                          <value name="ADD0">
                            <block type="time_get" id="e^xzBDB`yoJiS+x6L1u_">
                              <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="true"></mutation>
                              <field name="OPTION">wdt</field>
                              <field name="LANGUAGE">de</field>
                        <block type="variables_set" id="pTv)dh4QF4|{NQdGKPp3">
                            <block type="text_join" id="$WM8x76=qJy!HeVCxCD=">
                              <value name="ADD0">
                                <block type="time_get" id="e*@p!mgSlvPF]DFXNwX9">
                                  <field name="OPTION">DD.MM.YYYY</field>
                    <block type="debug" id="i22RchTjK8{cxq[~p*na">
                      <value name="TEXT">
                        <shadow type="text" id="iUQOiWv@^]61($?tb;OK">
                        <block type="text_join" id="^!6s2;sgwFbub2%QmA{8">
                          <mutation items="5"></mutation>
                          <value name="ADD0">
                            <block type="variables_get" id=".A1~gH|Mc-3k5%nNjV,l">
                          <value name="ADD1">
                            <block type="text_newline" id="Rp]o~QpuEJ3Lm-]lU^m@">
                              <field name="Type">\r\n</field>
                          <value name="ADD2">
                            <block type="variables_get" id="^VEF*:?VgSTvj#nwLGbr">
                          <value name="ADD3">
                            <block type="text_newline" id="N:Y72r5PpW]|YF%yNWrh">
                          <value name="ADD4">
                            <block type="variables_get" id="DkZJ8=#*;ak,aR9Gs@c_">
                        <block type="math_change" id="3VRo7GjJdQU67[9R{LtG">
                          <value name="DELTA">
                            <shadow type="math_number" id="E0mu2+{9=QjyK/%naCA/">
                            <block type="control" id="A49|0RH?y:l^3%esr!K[">
                              <field name="OID">openknx.0.Meldung_&amp;_Alarm.Systemstatus.Titel_PV-Anlage</field>
                                <block type="variables_get" id="9oV}d;E^ow+AV7.:)6;P">
                                <block type="control" id="~6W`?QkN~v7EQEdJ02U]">
                                  <field name="OID">openknx.0.Meldung_&amp;_Alarm.Systemstatus.Werte_PV-Anlage</field>
                                    <block type="variables_get" id="Qe?`zF**:J9!*S.Wv#q8">
                                    <block type="controls_if" id="WdvyJ,ex+-zjf]B!1P8=">
                                        <block type="logic_compare" id="={U=:`-X(f,VX*2qGC20">
                                          <field name="OP">LTE</field>
                                            <block type="variables_get" id="u0oHVOtlJt*#cy55|{;M">
                                            <block type="math_number" id="om-vLIj~@vELXmxjdCqA">
                                        <block type="control" id="4oT(9d7C:fwFfUMuz2L}">
                                          <field name="OID">0_userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyHeading</field>
                                            <block type="variables_get" id="E}Tf[xICDI)g04}GLAJ`">
                                            <block type="control" id="yo{axy]AnO=!B=H:.k/[">
                                              <field name="OID">0_userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyText</field>
                                                <block type="variables_get" id="|D)}Wik,BS)8jp[.;3A5">
                                                <block type="control" id="(Lf0f+u^1k.%V`;0cEoG">
                                                  <field name="OID">0_userdata.0.NSPanel.2.ScreensaverInfo.popupNotifyHeading</field>
                                                    <block type="variables_get" id="LBa*gnzvgsdOtmX[=I~~">
                                                    <block type="control" id="%E9e=LQo1/n6P%{-kSv.">
                                                      <field name="OID">0_userdata.0.NSPanel.2.ScreensaverInfo.popupNotifyText</field>
                                                        <block type="variables_get" id="xb*IPlkbdxgN!nB1#=.3">
                                      <statement name="ELSE">
                                        <block type="control" id="Eeq|RjKmNMRhSPpN$Jj1">
                                            <block type="text" id="7CkINKL)^mc(44_?Z=t{">
                                              <field name="TEXT"></field>
                                            <block type="control" id="v%kPPzO9JjaRA!I23P/:">
                                                <block type="text" id="7tkS5]m8gyyYQhS.N{Q|">
                                                <block type="control" id="N#5cn$b--M10TjOZzyPf">
                                                    <block type="text" id=";-5OGzXHT9pIPWal5d^Y">
                                                    <block type="control" id="|I1MPy/hZjW:(V1ZZ{7x">
                                                        <block type="text" id="Bj%]:}y1+yK0!s!2yolH">
      • icebear
        icebear last edited by
        Kurze Frage, hab bei mir im Screensaver jetzt auch eingestellt das unten der Text angezeigt werden soll.
        Allerdings schneidet er bei 11 Zeichen ab (Morgen Restmü), ich hab aber z.B bei anderen Bilder gesehen das da mehr hinpasst, kann man da noch irgendwo was einstellen?
          TT-Tom @icebear last edited by TT-Tom
          @icebear
          aktuell ist das Feld noch auf 10 Zeichen begrenzt. @Gargano hat sein HMI selbst geändert und bekommt dadurch mehr Zeichen rein. Ggf. auf GitHub mal ein Feature Request aufmachen.
          icebear 1 Reply Last reply Reply Quote 0
          • icebear
            icebear @TT-Tom last edited by
            @tt-tom said in SONOFF NSPanel mit Lovelace UI:
            Ah, Danke
            Ich dachte das wäre mittlerweile schon offiziell drin.
              tomsport2022 @losossos last edited by
              @losossos
              Danke dir für die Info, den Code und die Beschreibung!
              Leider ist das nicht ganz das was ich mir vorgestellt habe bzw. es sollen die 4 Entity Werte einfach zyklisch Wechseln.
              Ich hab das jetzt selbst mal Testweise umgesetzt und im Code die Funktion HandleScreensaverUpdate ab der Bedingung if (weatherForecast) mit meinen 4 Zusatzwerten angepasst, damit dort einfach ein payloadString mit den gewünschten Infos aufgebaut wird. Danach hab ich den in den Einstellungen die Wettervorhersage und den Timer aktiviert und den Timer Wert auf 5 Sekunden gesetzt.
              @Kuckuckmann
              Ah das klingt super. Danke für die Info bzw. den Ausblick!
                @icebear
                ich muss mich korrigieren, laut Github sollen es jetzt wirklich schon 16 Zeichen sein.
                https://github.com/joBr99/nspanel-lovelace-ui/issues/831
                habe es getestet und es funktioniert. Hast du die aktuelle TFT Version??
                wie sieht die Config von deinem mrIcon1ScreensaverEntity aus.
                beandi created this issue in joBr99/nspanel-lovelace-ui
                closed [Feature Request] Text bzw String in der untersten Zeile darstellen #831
                • icebear
                  icebear @TT-Tom last edited by icebear
                  Die aktuelle TFT Version hab ich, hab das Panel erst am Samsatg in Betrieb genommen, sollte also alles letzter Stand sein.
                  mrIcon1ScreensaverEntity:
                              ScreensaverEntity: NSPanel_Path + 'Relay.1',
                              ScreensaverEntityIconOn: null,
                              ScreensaverEntityIconOff: null,
                              ScreensaverEntityValue: '0_userdata.0.Abfallkalender.nexttype',
                              ScreensaverEntityValueDecimalPlace : null,
                              ScreensaverEntityValueUnit: null,
                              ScreensaverEntityOnColor: MSRed,
                              ScreensaverEntityOffColor: Yellow
                  • Marc Berg
                    Marc Berg Most Active @icebear last edited by
                    @icebear
                    Aber „Morgen Restmü“ sind doch schon mindestens 13 Zeichen und es sieht nach zwei Leerzeichen aus.
                    icebear 1 Reply Last reply Reply Quote 1
                    • icebear
                      icebear @Marc Berg last edited by
                      @marc-berg said in SONOFF NSPanel mit Lovelace UI:
                      Jepp du hast recht, es sind insgesamt sogar drei Leerzeichen.
                      Komisch, weil ich beim restellen des DP definitiv nur ein Leerzeichen angegeben hab.
                      Ich muß dann wohl nochmal das Script überarbeiten.
                      ich hab mal beim erstelleten Wert händisch die Leerzeichen entfernt und jetzt passt es.
                        TT-Tom last edited by TT-Tom
                        Version 4.2.1.5 ist fertig
                        Der Debug Modus für das Script wurde umgeschrieben und behält jetzt auch beim Neustart des Script seine Einstellung.
                        Die Konfiguration für Rollo / Jalousie / Markise wurde um die Parameter minValueLevel, maxValueLevel, minValueTilt und maxValueTilt erweitert. Damit können jetzt die Standardwerte überschrieben werden.
                        Es muss immer min und max angegeben werden.
                        • minValueLevel -> Postion unten -> Standard 0%
                        • maxValueLevel -> Position oben -> Standard 100%
                        • minValueTilt -> verdrehen der Lamellen linksrum -> Standard 0%
                        • maxValueTilt ->verdrehen der Lamellen rechtsrum -> Standard 100%
                        Beispiel für PageItem
                        <PageItem>{ id: 'alias.0.NSPanel.allgemein.Rollo', name: "Test Rollo", secondRow: "Hier Text für 2. Zeile", minValueLevel: 100, maxValueLevel: 0, minValueTilt: 100, maxValueTilt: 0},
                        Weiterhin viel Spass mit dem Panel
                        Marc Berg 1 Reply Last reply Reply Quote 1
                        • Marc Berg
                          Marc Berg Most Active @TT-Tom last edited by
                          @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                          Ein erster Test war erfolgreich, die Pfeile bleiben jetzt in der korrekten Richtung aktiv. Top!
                          Den "Tilt"-Teil kann ich allerdings nicht testen.
                            Futty last edited by Futty
                            Guten Abend,
                            ich hätte mal wieder ein Problem mit der ThermoCard.
                            Der Alias bzw. Button Power funktioniert nicht so wie erwartet / erhofft.
                            Folgende Objekte habe ich:
                            Der Alias dazu sieht so aus, Power wird mir (warum auch immer) nach dem erstellen nicht mehr angezeigt:
                            Definition NSPanel-Skript:
                            let Thermostat_Wohnzimmer = <PageThermo>
                                    "type": "cardThermo",
                                    "heading": "Thermostat",
                                    "useColor": true,
                                    "subPage": false,
                                    "items": [<PageItem>{ id: AliasPath + 'ThermostatWohnbereich', minValue: 50, maxValue: 300 }]
                            AliasManager:
                            Debug beim Drücken des Powerbuttons links unten im Display:
                            6.9.2023, 00:20:44.967	[info ]: javascript.0 (2440423) script.js.common.NSPanel: HandleButtonEvent übergebene Werte event - buttonPress2 - alias.0.NSPanel.1.ThermostatWohnbereich - hvac_action - POW - PageId: 1
                            6.9.2023, 00:20:44.968	[info ]: javascript.0 (2440423) script.js.common.NSPanel: HandleButtonEvent buttonAction: hvac_action
                            6.9.2023, 00:20:44.979	[info ]: javascript.0 (2440423) script.js.common.NSPanel: GetNavigationString Übergabe pageId: 1
                            6.9.2023, 00:20:44.980	[info ]: javascript.0 (2440423) script.js.common.NSPanel: thermostat - Currently
                            6.9.2023, 00:20:44.985	[info ]: javascript.0 (2440423) script.js.common.NSPanel: thermostat - State
                            6.9.2023, 00:20:44.989	[info ]: javascript.0 (2440423) script.js.common.NSPanel: GenerateThermoPage payload: [object Object],[object Object]
                            6.9.2023, 00:20:44.991	[info ]: javascript.0 (2440423) script.js.common.NSPanel: function SendToPanel payload: pageType~cardThermo
                            6.9.2023, 00:20:44.992	[info ]: javascript.0 (2440423) script.js.common.NSPanel: function SendToPanel payload: entityUpd~Thermostat~button~bPrev~~65535~~~button~bNext~~65535~~~alias.0.NSPanel.1.ThermostatWohnbereich~22.4°C~220~MANU~50~300~5~~2016~1~POW~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Aktuell~Zustand~~°C~~1
                            6.9.2023, 00:20:44.992	[info ]: javascript.0 (2440423) script.js.common.NSPanel: HandleMessage -> buttonPress2 event - buttonPress2 - alias.0.NSPanel.1.ThermostatWohnbereich - hvac_action - POW
                            Der Powerbutton erscheint, allerdings kann ich hiermit bei Betätigung das Objekt nicht steuern, Quasi nur eine Anzeige.
                            Wenn ich das Objekt manuell auf Toogle, verändert sich die Farbe.
                            Drücke ich auf den Button baut sich die Seite erneut auf, sonst passiert nichts.
                            Ich hab testweise mal AUTOMATIC und MANUAL als Alias hinzugefügt, diese Buttons kann ich wie erwartet auch steuern.
                            Ideen? Danke!
                              TT-Tom @Futty last edited by
                              @futty
                              Hast du beim Test den Alias geändert oder den Datenpunkt unter 0_userdata.0 ?
                              D F 2 Replies Last reply Reply Quote 0
                                danny_v1 @TT-Tom last edited by
                                Hi, hab eine kurze Frage, aufgrund der vielen Abstürze von Accuweather wollte ich dasWetter verwenden. Da werden allerdings keine Icons im Screensaver angezeigt (oben das große Icon ist zb ein Ausrufezeichen in einem Kreis).
                                Wie bekomme ich das hin?
                                  lesiflo Most Active last edited by lesiflo
                                  Moin, gibt es die Möglichkeit bei Typ "cardGrid" oder "cardGrid2" das Icon eines PageItems in Abhängigkeit vom Status zu ändern? Im Moment benutze ich dafür 2 Items die ich wechselweise ein und ausschalte.
                                          <PageItem>{ id: "alias.0.Auto.Phasen", icon: 'numeric-1-circle', name: "Phasen", onColor: MSGreen, offColor: Gray},
                                          <PageItem>{ id: "alias.0.Auto.Phasen", icon: 'numeric-3-circle', name: "Phasen", onColor: Gray, offColor: MSGreen},
                                  T D 2 Replies Last reply Reply Quote 0
                                    TT-Tom @danny_v1 last edited by
                                    @danny_v1
                                    im Script richtig angepasst? Du musst auch die bottomScreensaverEntity ggf. anpassen.
                                    const weatherAdapterInstance: string = 'accuweather.0.';    // Möglich 'accuweather.0.' oder 'daswetter.0.'
                                      Futty @TT-Tom last edited by Futty
                                      @tt-tom
                                      Im Test habe ich den Alias geändert. Habe es gerade noch mal mit Datenpunkt 0_userdata.0 geprüft, dort ist das gleiche Verhalten. Die Datenpunkte sind auch verbunden, ändern also unabhängig ob ich im Alias oder im Datenpunkt 0_userdata.0 manuell den Wert über den Objektbaum ändere den Zustand mit.
                                      Es sieht so aus das der Zugriff nur lesend erfolgt bzw. erfolgen kann.
                                      Der angelegte Datenpunkt hat aber auch Schreibberechtigung:
                                        TT-Tom @lesiflo last edited by
                                        @lesiflo
                                        Es gibt mehrere Möglichkeiten, entscheidend ist die Art des Datenpunkt. Der Channel alias.0.Auto.Phasen ist was für ein Typ und welche die Datenpunkte darunter => boolean , number?
                                          @Futty
                                          was ich so am Handy sehen konnte ist vermutlich ein Bug im Script. Sehe ich mir heute Abend genauer an.
                                          • N
                                            niiccooo1 last edited by
                                            Hallo Zusammen,
                                            ich habe eine Frage bezüglich WLED. Auf der UI ist folgender Slider vorhanden:
                                            Bei Änderung des Sliders ändern sich folgende Datenpunkte im WLED-Adapter:
                                            Besteht die Möglichkeit diesen Slider im NSPanel abzubilden? Ich vermute das im NSPanel der Alias Farbtemperatur verwendet wird. Der Datenpunkt TEMPERATURE ist ein Wert zwischen 0 und 255 oder?
                                            Vielen Dank!
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6632572
