    4. Prüfen ob Wechselrichter verbunden
    • Stefan Falt
      Stefan Falt @Codierknecht last edited by
      @codierknecht Das ist ein SolPlanet ASW3000S-S
      Das ist mein Code, der auch funktioniert. Lediglich die Fehlermeldungen nerven, wenn Nachts keine Verbindung vorhanden.
      Homoran Samson71 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Stefan Falt last edited by
        @stefan-falt was kommt nachts beim request zurück?
        Stefan Falt 1 Reply Last reply Reply Quote 0
        • Stefan Falt
          Stefan Falt @Homoran last edited by Stefan Falt
          influxdb.0
             2023-09-04 20:09:00.779	info	Do not store value "{"ack":true}" for 0_userdata.0.SolPlanet.VAR_ElectricalOfTotal because no number
          javascript.0
             2023-09-04 20:09:00.763	info	State value to set for "0_userdata.0.SolPlanet.VAR_ElectricalOfToday" has to be type "number" but received type "object"
          javascript.0
             2023-09-04 20:09:00.762	info	State value to set for "0_userdata.0.SolPlanet.VAR_ElectricalOfTotal" has to be type "number" but received type "object"
          javascript.0
             2023-09-04 20:09:00.759	info	State value to set for "0_userdata.0.SolPlanet.VAR_PowerOfAC" has to be type "number" but received type "object"
          smartmeter.0
             2023-09-04 20:09:00.396	info	Received 10 values, 3 updated
          javascript.0
             2023-09-04 20:08:58.412	warn	at processTicksAndRejections (node:internal/process/task_queues:82:21)
          javascript.0
             2023-09-04 20:08:58.411	warn	at endReadableNT (node:internal/streams/readable:1359:12)
          javascript.0
             2023-09-04 20:08:58.411	warn	at IncomingMessage.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.411	warn	at IncomingMessage.emit (node:events:526:35)
          javascript.0
             2023-09-04 20:08:58.411	warn	at Object.onceWrapper (node:events:628:28)
          javascript.0
             2023-09-04 20:08:58.411	warn	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          javascript.0
             2023-09-04 20:08:58.410	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.410	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:58.410	warn	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          javascript.0
          javascript.0
          javascript.0
             2023-09-04 20:08:58.410	warn	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          javascript.0
             2023-09-04 20:08:58.409	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
          javascript.0
             2023-09-04 20:08:58.409	warn	at script.js.SolPlanet.VAR_Erzeugung:13:5
          javascript.0
             2023-09-04 20:08:58.408	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:58.403	warn	State "0_userdata.0.VAR_Solplanet.VAR_ElectricalOfToday" not found
          javascript.0
             2023-09-04 20:08:58.403	warn	at processTicksAndRejections (node:internal/process/task_queues:82:21)
          javascript.0
             2023-09-04 20:08:58.403	warn	at endReadableNT (node:internal/streams/readable:1359:12)
          javascript.0
             2023-09-04 20:08:58.403	warn	at IncomingMessage.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.402	warn	at IncomingMessage.emit (node:events:526:35)
          javascript.0
             2023-09-04 20:08:58.402	warn	at Object.onceWrapper (node:events:628:28)
          javascript.0
             2023-09-04 20:08:58.402	warn	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          javascript.0
             2023-09-04 20:08:58.402	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.402	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:58.402	warn	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          javascript.0
             2023-09-04 20:08:58.401	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.401	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:58.401	warn	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          javascript.0
             2023-09-04 20:08:58.401	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
          javascript.0
             2023-09-04 20:08:58.400	warn	at script.js.SolPlanet.VAR_Erzeugung:12:5
          javascript.0
             2023-09-04 20:08:58.400	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:58.397	warn	State "0_userdata.0.VAR_Solplanet.VAR_ElectricalOfTotal" not found
          javascript.0
             2023-09-04 20:08:58.397	warn	at processTicksAndRejections (node:internal/process/task_queues:82:21)
          javascript.0
             2023-09-04 20:08:58.396	warn	at endReadableNT (node:internal/streams/readable:1359:12)
          javascript.0
             2023-09-04 20:08:58.396	warn	at IncomingMessage.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.396	warn	at IncomingMessage.emit (node:events:526:35)
          javascript.0
             2023-09-04 20:08:58.396	warn	at Object.onceWrapper (node:events:628:28)
          javascript.0
             2023-09-04 20:08:58.396	warn	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          javascript.0
             2023-09-04 20:08:58.395	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:58.395	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:58.395	warn	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          javascript.0
          javascript.0
          javascript.0
             2023-09-04 20:08:58.395	warn	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          javascript.0
             2023-09-04 20:08:58.394	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
          javascript.0
             2023-09-04 20:08:58.394	warn	at script.js.SolPlanet.VAR_Erzeugung:11:7
          javascript.0
             2023-09-04 20:08:58.394	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:58.390	warn	State "0_userdata.0.VAR_Solplanet.VAR_PowerOfAC" not found
          javascript.0
             2023-09-04 20:08:58.175	info	script.js.SolPlanet.VAR_Erzeugung: request: http://192.168.178.24:8484/getdevdata.cgi?device=2&sn=MA30006012260056
          javascript.0
             2023-09-04 20:08:58.174	warn	at processTimers (node:internal/timers:512:7)
          javascript.0
             2023-09-04 20:08:58.174	warn	at listOnTimeout (node:internal/timers:569:17)
          javascript.0
             2023-09-04 20:08:58.174	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
          javascript.0
             2023-09-04 20:08:58.173	warn	at Object.<anonymous> (script.js.SolPlanet.VAR_Erzeugung:8:3)
          javascript.0
             2023-09-04 20:08:58.173	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:58.171	warn	State "0_userdata.0.VAR_Solplanet.VAR_PowerOfAC" not found
          javascript.0
             2023-09-04 20:08:58.171	warn	at processTimers (node:internal/timers:512:7)
          javascript.0
             2023-09-04 20:08:58.171	warn	at listOnTimeout (node:internal/timers:569:17)
          javascript.0
             2023-09-04 20:08:58.170	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
          javascript.0
             2023-09-04 20:08:58.170	warn	at Object.<anonymous> (script.js.SolPlanet.VAR_Erzeugung:7:3)
          javascript.0
             2023-09-04 20:08:58.170	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:58.168	warn	State "0_userdata.0.VAR_Solplanet.VAR_PowerOfAC" not found
          javascript.0
             2023-09-04 20:08:58.165	warn	at processTimers (node:internal/timers:512:7)
          javascript.0
             2023-09-04 20:08:58.165	warn	at listOnTimeout (node:internal/timers:569:17)
          javascript.0
             2023-09-04 20:08:58.165	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
          javascript.0
             2023-09-04 20:08:58.164	warn	at Object.<anonymous> (script.js.SolPlanet.VAR_Erzeugung:6:3)
          javascript.0
             2023-09-04 20:08:58.164	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:58.162	warn	State "0_userdata.0.VAR_Solplanet.VAR_PowerOfAC" not found
          influxdb.0
             2023-09-04 20:08:50.778	info	Do not store value "{"ack":true}" for 0_userdata.0.SolPlanet.VAR_ElectricalOfTotal because no number
          javascript.0
             2023-09-04 20:08:50.766	info	State value to set for "0_userdata.0.SolPlanet.VAR_ElectricalOfToday" has to be type "number" but received type "object"
          javascript.0
             2023-09-04 20:08:50.765	info	State value to set for "0_userdata.0.SolPlanet.VAR_ElectricalOfTotal" has to be type "number" but received type "object"
          javascript.0
             2023-09-04 20:08:50.763	info	State value to set for "0_userdata.0.SolPlanet.VAR_PowerOfAC" has to be type "number" but received type "object"
          smartmeter.0
             2023-09-04 20:08:48.939	info	Received 10 values, 1 updated
          javascript.0
             2023-09-04 20:08:48.370	warn	at processTicksAndRejections (node:internal/process/task_queues:82:21)
          javascript.0
             2023-09-04 20:08:48.370	warn	at endReadableNT (node:internal/streams/readable:1359:12)
          javascript.0
             2023-09-04 20:08:48.369	warn	at IncomingMessage.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.369	warn	at IncomingMessage.emit (node:events:526:35)
          javascript.0
             2023-09-04 20:08:48.369	warn	at Object.onceWrapper (node:events:628:28)
          javascript.0
             2023-09-04 20:08:48.369	warn	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          javascript.0
             2023-09-04 20:08:48.369	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.368	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:48.368	warn	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          javascript.0
             2023-09-04 20:08:48.368	warn	at Request.emit (node:domain:489:12)
          javascript.0
          javascript.0
             2023-09-04 20:08:48.368	warn	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          javascript.0
             2023-09-04 20:08:48.368	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
          javascript.0
             2023-09-04 20:08:48.367	warn	at script.js.SolPlanet.VAR_Erzeugung:13:5
          javascript.0
             2023-09-04 20:08:48.367	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:48.364	warn	State "0_userdata.0.VAR_Solplanet.VAR_ElectricalOfToday" not found
          javascript.0
             2023-09-04 20:08:48.363	warn	at processTicksAndRejections (node:internal/process/task_queues:82:21)
          javascript.0
             2023-09-04 20:08:48.363	warn	at endReadableNT (node:internal/streams/readable:1359:12)
          javascript.0
             2023-09-04 20:08:48.363	warn	at IncomingMessage.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.363	warn	at IncomingMessage.emit (node:events:526:35)
          javascript.0
             2023-09-04 20:08:48.363	warn	at Object.onceWrapper (node:events:628:28)
          javascript.0
             2023-09-04 20:08:48.363	warn	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          javascript.0
             2023-09-04 20:08:48.362	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.362	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:48.362	warn	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          javascript.0
          javascript.0
          javascript.0
             2023-09-04 20:08:48.362	warn	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          javascript.0
             2023-09-04 20:08:48.361	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
          javascript.0
             2023-09-04 20:08:48.361	warn	at script.js.SolPlanet.VAR_Erzeugung:12:5
          javascript.0
             2023-09-04 20:08:48.361	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:48.358	warn	State "0_userdata.0.VAR_Solplanet.VAR_ElectricalOfTotal" not found
          javascript.0
             2023-09-04 20:08:48.357	warn	at processTicksAndRejections (node:internal/process/task_queues:82:21)
          javascript.0
             2023-09-04 20:08:48.357	warn	at endReadableNT (node:internal/streams/readable:1359:12)
          javascript.0
             2023-09-04 20:08:48.357	warn	at IncomingMessage.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.356	warn	at IncomingMessage.emit (node:events:526:35)
          javascript.0
             2023-09-04 20:08:48.356	warn	at Object.onceWrapper (node:events:628:28)
          javascript.0
             2023-09-04 20:08:48.356	warn	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          javascript.0
             2023-09-04 20:08:48.356	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.356	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:48.356	warn	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          javascript.0
             2023-09-04 20:08:48.355	warn	at Request.emit (node:domain:489:12)
          javascript.0
             2023-09-04 20:08:48.355	warn	at Request.emit (node:events:514:28)
          javascript.0
             2023-09-04 20:08:48.355	warn	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          javascript.0
             2023-09-04 20:08:48.355	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
          javascript.0
             2023-09-04 20:08:48.355	warn	at script.js.SolPlanet.VAR_Erzeugung:11:7
          javascript.0
             2023-09-04 20:08:48.354	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
             2023-09-04 20:08:48.348	warn	State "0_userdata.0.VAR_Solplanet.VAR_PowerOfAC" not found
          javascript.0
             2023-09-04 20:08:48.172	info	script.js.SolPlanet.VAR_Erzeugung: request: http://192.168.178.24:8484/getdevdata.cgi?device=2&sn=MA30006012260056
            @stefan-falt das ist nicht der result
            • Samson71
              Samson71 Global Moderator @Stefan Falt last edited by
              @stefan-falt
              Bau noch zusätzlich Sonnenauf-/untergang als Start/Stop in Deine Abfrage mit ein. Hatte ich bei meinem ersten Growatt auch mit drin.
              • Stefan Falt
                Kopfkratz, Tja hier hat mein Wissen ein Ende.
                Wie wäre es so?
                  Homoran Global Moderator Administrators @Stefan Falt last edited by Homoran
                  @stefan-falt
                  nein, kein weiterer Trigger, einfach ein debug-baustein davor
                  • Stefan Falt
                    Um zu prüfen was er macht?
                    • Stefan Falt
                      Stefan Falt @Stefan Falt last edited by Stefan Falt
                      @stefan-falt
                      Das scheint zu funktionieren. Ich werde Morgen Berichten 🙂 Danke für den Support.
                        @stefan-falt sagte in Prüfen ob Wechselrichter verbunden:
                        @stefan-falt
                        nein!
                        nach dem request den result im debug, damit wir wissen was zurückkomt, undxes abfangen können
                        • Stefan Falt
                          Ah, verstehe:
                          Stefan Falt Homoran 2 Replies Last reply Reply Quote 0
                          • Stefan Falt
                            @stefan-falt
                            Ich sollte wohl nur auswerten, wenn der Wert NICHT "undefined" ist ...
                              @stefan-falt möglicherweise auf undefined prüfen, und nur dann weitermachen.
                              ich fürchte aber der EHOSTUNREACH kommt trotzdem.
                              Vielleicht hat @paul53 einen weiteren Geistesblitz
                              Stefan Falt paul53 2 Replies Last reply Reply Quote 0
                              • Stefan Falt
                                Augenblicklich schauts so aus. Ich nehme an um auf undefined zu prüfen muss ich solche eine Variable erstellen?
                                Ich bin dann mal im Bett. Muss morgen früh raus.
                                Danke + MfG
                                Stefan
                                  paul53 @Stefan Falt last edited by
                                  @stefan-falt sagte: Ich nehme an um auf undefined zu prüfen muss ich solche eine Variable erstellen?
                                  Nein, einfach püfen: falls result
                                    nee, warte mal bis morgen
                                    @homoran sagte in Prüfen ob Wechselrichter verbunden:
                                    und müllt dir doch das log zu, oder?
                                      @homoran sagte: EHOSTUNREACH kommt trotzdem.
                                      Das müsste sich doch mit Hilfe des Ping-Adapters abfangen lassen?
                                      • Schmakus
                                        Schmakus Developer last edited by Schmakus
                                        Ich würde das mit Javascript machen und ein try/catch drumherum bauen. damit ist das Problem gelöst.
                                        Gleichzeitig würde ich auf Axios umstellen, da request deprecated ist und der Standard beim JS-Adapter Axios wird. (Je nach JS-Adapter Version musst noch axios als Modul in den Instanzeinstellungen des JS-Adapters definieren).
                                        Gleichzeitig ein timeout anstatt ein Intervall. Problem ist, dass Intervalle immer laufen, auch wenn der Code darin noch nicht abgeschlossen ist. Mit einem timeout welches die Funktion selbst nach Ablauf des codes wieder aufruft, passiert das nicht.
                                        Ich habe es natürlich nicht getestet.
                                        const axios = require('axios').default;
                                        axios.defaults.timeout = 1000; // timeout der Anfrage
                                        const timeout = null; // timeout für neue Anfrage
                                        async function getInfo() {
                                            try {
                                                const url = 'http://192.168.178.24:8484/getdevdata.cgi?.....'; // richtige URL eintragen
                                                const response = await axios.get(url);
                                                if (response.status === 200) {
                                                    const result = response.data;
                                                    await setStateAsync('VAR_PowerOfAC', result.pac, true);
                                                    // usw....
                                            } catch (error) {
                                                if (error.code === 'EHOSTUNREACH') {
                                                    log('WR is sleeping...', 'warn');
                                                } else if (error.code === 'ECONNABORTED') {
                                                    log('Request timeout... Error: ${error}'. 'error');
                                                } else {
                                                    log(`Error by request WR. Error: ${error}`, ''error);
                                            if (timeout) clearTimeout(timeout), (timeout = null);
                                            timeout = setTimeout(() => {
                                                getInfo();
                                            }, 10000);
                                        getInfo();
                                        Stefan Falt 1 Reply Last reply Reply Quote 1
                                        • Stefan Falt
                                          Stefan Falt @Schmakus last edited by
                                          @schmakus
                                          Dankeschön ... ich bin schon so von Blockly durchdrungen dass man nicht mehr auf die einfachsten Lösungen kommt ... Danke.
                                          989
