    4. iob node fix - Skript
      Thomas Braun Most Active @Meister Mopper last edited by
      @meister-mopper
      Zieh nochmal rein. Aber ich glaube da ist noch ein Fehler drin...
      Meister Mopper F 2 Replies Last reply Reply Quote 1
      • Meister Mopper
        Meister Mopper @Thomas Braun last edited by Meister Mopper
        Spaey
        ioBroker nodejs fixer 2023-09-05
        Could not detect recommended nodejs-version. Setting up the nodejs 18 tree now.
        Your current setup is:
        /usr/bin/nodejs         v20.5.1
        /usr/bin/node           v20.5.1
        /usr/bin/npm            9.8.0
        /usr/bin/npx            9.8.0
        /usr/bin/corepack       0.19.0
        I found these versions available for installation:
        nodejs:
          Installed: 20.5.1-deb-1nodesource1
          Candidate: 20.5.1-deb-1nodesource1
          Version table:
         *** 20.5.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        Nothing to do, your installation is using the correct paths.
        ./iob_node_update: line 302: unexpected EOF while looking for matching `''
        ./iob_node_update: line 316: syntax error: unexpected end of file
        thomas@rpizigbee:~ $ nodejs -v
        v20.5.1
          fastfoot @Thomas Braun last edited by fastfoot
          @thomas-braun sagte in iob node fix - Skript:
          hinter dem -print) muss noch ein Anführungszeichen -print)";
          und die vielen Semikolon kannste dir auch sparen 🙂
            Homoran Global Moderator Administrators @fastfoot last edited by
            @fastfoot sagte in iob node fix - Skript:
            ein Ausrufezeichen
              Thomas Braun Most Active @fastfoot last edited by
              Ich find die schön. Und meine IDE auch.
                @meister-mopper
                Magst du noch mal schauen?
                Meister Mopper 1 Reply Last reply Reply Quote 1
                • Meister Mopper
                  @meister-mopper
                  Sorry, musste in die Heia und heute war ich auf Dienstreise.
                  Es hat mit dem aktuellen Skript (wahrscheinlich) funktioniert.
                  ioBroker nodejs fixer 2023-09-06
                  No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                  /usr/bin/npm            9.8.0
                  /usr/bin/npx            9.8.0
                  I found these nodejs versions available for installation:
                  nodejs:
                    Version table:
                  You are running nodejs v20.5.1. Do you want to install recommended version ?
                  Press <y> to continue or any other key to quit
                  Trying to fix your installation now. Please be patient.
                  Waiting for ioBroker to shut down - Give me a minute...
                  *** These repos are active on your system:
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Reading package lists... Done
                  *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                  Building dependency tree... Done
                  ca-certificates is already the newest version (20210119).
                  curl is already the newest version (7.74.0-1.3+deb11u7).
                  gnupg is already the newest version (2.2.27-2+deb11u2).
                  0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                  *** Creating new /etc/apt/sources.list.d/nodesource.list
                  deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                  *** These repos are active after the adjustments:
                  Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                  Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5161 B]
                  Fetched 17.3 kB in 1s (16.9 kB/s)
                  Installing the recommended nodejs version now!
                  Exact recommended version unknown, installing a fallback!
                  The following packages will be DOWNGRADED:
                    nodejs
                  0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 2 not upgraded.
                  Need to get 26.7 MB of archives.
                  After this operation, 6614 kB disk space will be freed.
                  Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.0-1nodesource1 [26.7 MB]
                  Fetched 26.7 MB in 5s (5830 kB/s)
                  dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
                  (Reading database ... 123973 files and directories currently installed.)
                  Preparing to unpack .../nodejs_18.17.0-1nodesource1_armhf.deb ...
                  Detected old npm client, removing...
                  Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
                  Setting up nodejs (18.17.0-1nodesource1) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Updating fallback to latest nodejs v18 release
                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Calculating upgrade... Done
                  The following packages have been kept back:
                    libudev1 udev
                  The following packages will be upgraded:
                    nodejs
                  1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                  After this operation, 7168 B of additional disk space will be used.
                  Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.1-1nodesource1 [26.7 MB]
                  Fetched 26.7 MB in 3s (8606 kB/s)
                  apt-listchanges: Changelogs werden gelesen...
                  (Reading database ... 124040 files and directories currently installed.)
                  Preparing to unpack .../nodejs_18.17.1-1nodesource1_armhf.deb ...
                  Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
                  Setting up nodejs (18.17.1-1nodesource1) ...
                  We tried our best to fix your nodejs. Please run iob diag again to verify.
                  *** RESTARTING ioBroker NOW! ***
                   Please refresh or restart your browser in a few moments.
                  v18.17.1
                    @meister-mopper
                    Prima! So soll es aussehen! Ich denke der Code ist dann soweit gediehen für ein Release.
                    Mag noch jemand mit einem LXC herumtesten?
                      MCU @Thomas Braun last edited by
                      @thomas-braun LXC-Container
                      Recommended nodejs-version is: 18.17.1
                      Checking your installation now. Please be patient!
                      /usr/bin/nodejs         v18.17.1
                      /usr/bin/node           v18.17.1
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      /usr/bin/corepack       0.18.0
                      nodejs:
                        Installed: 18.17.1-1nodesource1
                        Candidate: 18.17.1-1nodesource1
                        Version table:
                       *** 18.17.1-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           18.13.0+dfsg1-1 500
                              500 http://ftp.debian.org/debian bookworm/main amd64 Packages
                      Nothing to do, your installed version is the recommended one.
                        Thomas Braun Most Active @MCU last edited by
                        @mcu sagte in iob node fix - Skript:
                        Nothing to do
                        Hm. Der Codepart war einfach... 😉 Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
                        M M 2 Replies Last reply Reply Quote 1
                          mrjeschke @Thomas Braun last edited by
                          nodejs 20 sieht bei mir im LXC-Container so aus.
                          /usr/bin/npm            9.8.0
                          /usr/bin/npx            9.8.0
                          nodejs:
                            Version table:
                           *** 20.5.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                               18.13.0+dfsg1-1 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                          You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
                          find: '/lost+found': Permission denied
                          lxc
                          Hit:2 http://security.debian.org bookworm-security InRelease
                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                          ca-certificates is already the newest version (20230311).
                          curl is already the newest version (7.88.1-10+deb12u1).
                          gnupg is already the newest version (2.2.40-1.1).
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Hit:1 http://security.debian.org bookworm-security InRelease
                          Hit:2 http://deb.debian.org/debian bookworm InRelease
                          Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                          Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
                          Fetched 17.3 kB in 0s (38.4 kB/s)
                          ./iob_node_update: line 275: [: : integer expression expected
                            nodejs
                          0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                          Need to get 29.4 MB of archives.
                          After this operation, 5249 kB disk space will be freed.
                          Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
                          Fetched 29.4 MB in 2s (13.2 MB/s)
                          (Reading database ... 37746 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
                          Processing triggers for man-db (2.11.2-2) ...
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            nodejs
                          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
                          Fetched 29.4 MB in 1s (43.5 MB/s)
                          apt-listchanges: Reading changelogs...
                          (Reading database ... 37813 files and directories currently installed.)
                          Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
                          ./iob_node_update: line 300: [: : integer expression expected
                          *** You need to manually restart your container now! ***
                          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                          maik@iobtest:~$
                            @thomas-braun Frisch aufgesetzter LXC mit nodejs 16 ohne ioBroker.
                            /usr/bin/nodejs         v16.20.2
                            /usr/bin/node           v16.20.2
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
                            /usr/bin/corepack       0.17.0
                            nodejs:
                              Installed: 16.20.2-deb-1nodesource1
                              Candidate: 16.20.2-deb-1nodesource1
                              Version table:
                             *** 16.20.2-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                    500 http://security.debian.org bullseye-security/main amd64 Packages
                                 12.22.12~dfsg-1~deb11u3 500
                                    500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                            You are running nodejs v16.20.2. Do you want to install recommended version ?
                            [sudo] password for prox:
                            lxc
                            ./iob_node_update: line 248: iob: command not found
                            Hit:1 http://ftp.debian.org/debian bullseye InRelease
                            Hit:2 http://security.debian.org bullseye-security InRelease
                            Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                            Hit:1 http://security.debian.org bullseye-security InRelease
                            Hit:2 http://ftp.debian.org/debian bullseye InRelease
                            Fetched 17.3 kB in 0s (57.5 kB/s)
                              nodejs
                            After this operation, 60.4 MB of additional disk space will be used.
                            Fetched 29.4 MB in 1s (21.7 MB/s)
                            (Reading database ... 22654 files and directories currently installed.)
                            Unpacking nodejs (18.17.0-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                              nodejs
                            Fetched 29.4 MB in 1s (41.9 MB/s)
                            (Reading database ... 25141 files and directories currently installed.)
                            nodejs is already the newest version (18.17.1-1nodesource1).
                              Homoran Global Moderator Administrators @MCU last edited by
                              ohne ioBroker.
                              dann kennt er natürlich (?) die empfohlene Version nicht
                              @Thomas-Braun
                              was tut er dann?
                              M Thomas Braun 2 Replies Last reply Reply Quote 1
                                Thomas Braun Most Active @mrjeschke last edited by
                                @mrjeschke sagte in iob node fix - Skript:
                                Gut, der muss auch noch geprunt werden.
                                Nanu?
                                Muss ich schauen.
                                Thx! Ich verzieh mich in die Code-Küche und brutzel noch was...
                                  MCU @Homoran last edited by
                                  @homoran Ich hab dann mit y bestätigt und er hat dann die v18 installiert.
                                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                    @homoran sagte in iob node fix - Skript:
                                    was tut er dann?
                                    Dann geht es auf die neueste Version aus dem 18er-Zweig. Oder welcher nodejs-Entwicklungszweig auch immer gerade empfohlen wird. Der muss allerdings immer händisch im skript gesetzt werden, wenn sich die generelle Empfehlung ändert.
                                    NODE_MAJOR=18           #recommended major nodejs version for ioBroker, please adjust if the recommendation changes
                                      Homoran Global Moderator Administrators @MCU last edited by Homoran
                                      hab ich auch gesehen, aber wieso?
                                      hier
                                      gibt er die recommended version komplett an.
                                      bei dir steht da (erwartungsgemäß) nichts
                                      edit: Hat sich mit Thomas' Antwort geklärt
                                        bei dir steht da nichts
                                        Bei @mrjeschke konnte die empfohlene Version auch direkt aus den iob-States gelesen werden.
                                        Wenn es aber ein slave ist oder die Datenbank (noch) nicht geladen ist, dann greift der Fallback-Code.
                                        So oder so soll am Ende immer die aktuellste Version aus dem empfohlenen Zweig installiert sein (inkl. aktuellem Schlüssel und aktueller, unverfrickelter nodesource.list)
                                        Ich hatte überlegt, die Version auswählbar zu machen, hab mich aber dann dagegen entschieden.
                                          @thomas-braun alles gut!
                                          Damit hast du jetzt auch den Fallback verifiziert.
                                          ich hatte mich nur gefragt woher bei nicht vorhandener Empfehlung jetztcdue v18 kam.
                                          Aber du denkst anscheinend an allem!
                                            Den konnte ich hier lokal schon ausgiebig testen. Hab mein Test-System mit diversen krummen Konstellationen malträtiert und das skript immer aufräumen lassen. 🙂
                                            Intern nenne ich es auch 'die nodejs-Putze'. 😄
                                            198
                                            37919
