    4. iob node fix - Skript
      Thomas Braun Most Active @Meister Mopper last edited by
      @meister-mopper
      Magst du noch mal schauen?
      Meister Mopper 1 Reply Last reply Reply Quote 1
      • Meister Mopper
        Meister Mopper @Thomas Braun last edited by
        @thomas-braun sagte in iob node fix - Skript:
        @meister-mopper
        Sorry, musste in die Heia und heute war ich auf Dienstreise.
        Es hat mit dem aktuellen Skript (wahrscheinlich) funktioniert.
        ioBroker nodejs fixer 2023-09-06
        No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
        Your current setup is:
        /usr/bin/nodejs         v20.5.1
        /usr/bin/node           v20.5.1
        /usr/bin/npm            9.8.0
        /usr/bin/npx            9.8.0
        /usr/bin/corepack       0.19.0
        I found these nodejs versions available for installation:
        nodejs:
          Installed: 20.5.1-deb-1nodesource1
          Candidate: 20.5.1-deb-1nodesource1
          Version table:
         *** 20.5.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             18.17.1-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        Nothing to do, your installation is using the correct paths.
        You are running nodejs v20.5.1. Do you want to install recommended version ?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        Building dependency tree... Done
        ca-certificates is already the newest version (20210119).
        curl is already the newest version (7.74.0-1.3+deb11u7).
        gnupg is already the newest version (2.2.27-2+deb11u2).
        0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
        *** Creating new /etc/apt/sources.list.d/nodesource.list
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        *** These repos are active after the adjustments:
        Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5161 B]
        Fetched 17.3 kB in 1s (16.9 kB/s)
        Installing the recommended nodejs version now!
        Exact recommended version unknown, installing a fallback!
        The following packages will be DOWNGRADED:
          nodejs
        0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 2 not upgraded.
        Need to get 26.7 MB of archives.
        After this operation, 6614 kB disk space will be freed.
        Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.0-1nodesource1 [26.7 MB]
        Fetched 26.7 MB in 5s (5830 kB/s)
        dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
        (Reading database ... 123973 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.17.0-1nodesource1_armhf.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
        Setting up nodejs (18.17.0-1nodesource1) ...
        Processing triggers for man-db (2.9.4-2) ...
        Updating fallback to latest nodejs v18 release
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Calculating upgrade... Done
        The following packages have been kept back:
          libudev1 udev
        The following packages will be upgraded:
          nodejs
        1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
        After this operation, 7168 B of additional disk space will be used.
        Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.1-1nodesource1 [26.7 MB]
        Fetched 26.7 MB in 3s (8606 kB/s)
        apt-listchanges: Changelogs werden gelesen...
        (Reading database ... 124040 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.17.1-1nodesource1_armhf.deb ...
        Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
        Setting up nodejs (18.17.1-1nodesource1) ...
        We tried our best to fix your nodejs. Please run iob diag again to verify.
        *** RESTARTING ioBroker NOW! ***
         Please refresh or restart your browser in a few moments.
         thomas@rpizigbee:~ $ nodejs -v
        v18.17.1
          @meister-mopper
          Prima! So soll es aussehen! Ich denke der Code ist dann soweit gediehen für ein Release.
          Mag noch jemand mit einem LXC herumtesten?
            MCU @Thomas Braun last edited by
            @thomas-braun LXC-Container
            Recommended nodejs-version is: 18.17.1
            Checking your installation now. Please be patient!
            /usr/bin/nodejs         v18.17.1
            /usr/bin/node           v18.17.1
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            /usr/bin/corepack       0.18.0
            nodejs:
              Installed: 18.17.1-1nodesource1
              Candidate: 18.17.1-1nodesource1
              Version table:
             *** 18.17.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                 18.13.0+dfsg1-1 500
                    500 http://ftp.debian.org/debian bookworm/main amd64 Packages
            Nothing to do, your installed version is the recommended one.
              Thomas Braun Most Active @MCU last edited by
              @mcu sagte in iob node fix - Skript:
              Nothing to do
              Hm. Der Codepart war einfach... 😉 Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
              M M 2 Replies Last reply Reply Quote 1
                mrjeschke @Thomas Braun last edited by
                nodejs 20 sieht bei mir im LXC-Container so aus.
                /usr/bin/npm            9.8.0
                /usr/bin/npx            9.8.0
                nodejs:
                  Version table:
                 *** 20.5.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                     18.13.0+dfsg1-1 500
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
                find: '/lost+found': Permission denied
                lxc
                Hit:2 http://security.debian.org bookworm-security InRelease
                Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                ca-certificates is already the newest version (20230311).
                curl is already the newest version (7.88.1-10+deb12u1).
                gnupg is already the newest version (2.2.40-1.1).
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Hit:1 http://security.debian.org bookworm-security InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
                Fetched 17.3 kB in 0s (38.4 kB/s)
                ./iob_node_update: line 275: [: : integer expression expected
                  nodejs
                0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                Need to get 29.4 MB of archives.
                After this operation, 5249 kB disk space will be freed.
                Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
                Fetched 29.4 MB in 2s (13.2 MB/s)
                (Reading database ... 37746 files and directories currently installed.)
                Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
                Processing triggers for man-db (2.11.2-2) ...
                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  nodejs
                1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
                Fetched 29.4 MB in 1s (43.5 MB/s)
                apt-listchanges: Reading changelogs...
                (Reading database ... 37813 files and directories currently installed.)
                Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
                ./iob_node_update: line 300: [: : integer expression expected
                *** You need to manually restart your container now! ***
                We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                maik@iobtest:~$
                  @thomas-braun Frisch aufgesetzter LXC mit nodejs 16 ohne ioBroker.
                  /usr/bin/nodejs         v16.20.2
                  /usr/bin/node           v16.20.2
                  /usr/bin/npm            8.19.4
                  /usr/bin/npx            8.19.4
                  /usr/bin/corepack       0.17.0
                  nodejs:
                    Installed: 16.20.2-deb-1nodesource1
                    Candidate: 16.20.2-deb-1nodesource1
                    Version table:
                   *** 16.20.2-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                          500 http://security.debian.org bullseye-security/main amd64 Packages
                       12.22.12~dfsg-1~deb11u3 500
                          500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                  You are running nodejs v16.20.2. Do you want to install recommended version ?
                  [sudo] password for prox:
                  lxc
                  ./iob_node_update: line 248: iob: command not found
                  Hit:1 http://ftp.debian.org/debian bullseye InRelease
                  Hit:2 http://security.debian.org bullseye-security InRelease
                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                  Hit:1 http://security.debian.org bullseye-security InRelease
                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                  Fetched 17.3 kB in 0s (57.5 kB/s)
                    nodejs
                  After this operation, 60.4 MB of additional disk space will be used.
                  Fetched 29.4 MB in 1s (21.7 MB/s)
                  (Reading database ... 22654 files and directories currently installed.)
                  Unpacking nodejs (18.17.0-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                    nodejs
                  Fetched 29.4 MB in 1s (41.9 MB/s)
                  (Reading database ... 25141 files and directories currently installed.)
                  nodejs is already the newest version (18.17.1-1nodesource1).
                    Homoran Global Moderator Administrators @MCU last edited by
                    ohne ioBroker.
                    dann kennt er natürlich (?) die empfohlene Version nicht
                    @Thomas-Braun
                    was tut er dann?
                    M Thomas Braun 2 Replies Last reply Reply Quote 1
                      Thomas Braun Most Active @mrjeschke last edited by
                      @mrjeschke sagte in iob node fix - Skript:
                      Gut, der muss auch noch geprunt werden.
                      Nanu?
                      Muss ich schauen.
                      Thx! Ich verzieh mich in die Code-Küche und brutzel noch was...
                        MCU @Homoran last edited by
                        @homoran Ich hab dann mit y bestätigt und er hat dann die v18 installiert.
                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                          @homoran sagte in iob node fix - Skript:
                          was tut er dann?
                          Dann geht es auf die neueste Version aus dem 18er-Zweig. Oder welcher nodejs-Entwicklungszweig auch immer gerade empfohlen wird. Der muss allerdings immer händisch im skript gesetzt werden, wenn sich die generelle Empfehlung ändert.
                          NODE_MAJOR=18           #recommended major nodejs version for ioBroker, please adjust if the recommendation changes
                            Homoran Global Moderator Administrators @MCU last edited by Homoran
                            hab ich auch gesehen, aber wieso?
                            hier
                            gibt er die recommended version komplett an.
                            bei dir steht da (erwartungsgemäß) nichts
                            edit: Hat sich mit Thomas' Antwort geklärt
                              bei dir steht da nichts
                              Bei @mrjeschke konnte die empfohlene Version auch direkt aus den iob-States gelesen werden.
                              Wenn es aber ein slave ist oder die Datenbank (noch) nicht geladen ist, dann greift der Fallback-Code.
                              So oder so soll am Ende immer die aktuellste Version aus dem empfohlenen Zweig installiert sein (inkl. aktuellem Schlüssel und aktueller, unverfrickelter nodesource.list)
                              Ich hatte überlegt, die Version auswählbar zu machen, hab mich aber dann dagegen entschieden.
                                @thomas-braun alles gut!
                                Damit hast du jetzt auch den Fallback verifiziert.
                                ich hatte mich nur gefragt woher bei nicht vorhandener Empfehlung jetztcdue v18 kam.
                                Aber du denkst anscheinend an allem!
                                  Den konnte ich hier lokal schon ausgiebig testen. Hab mein Test-System mit diversen krummen Konstellationen malträtiert und das skript immer aufräumen lassen. 🙂
                                  Intern nenne ich es auch 'die nodejs-Putze'. 😄
                                    @mrjeschke
                                    Bitte nochmal von einer nodejs@20 aus mit frischem Skript aufräumen lassen.
                                      ioBroker nodejs fixer 2023-09-07
                                      /usr/bin/nodejs         v20.6.0
                                      /usr/bin/node           v20.6.0
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      nodejs:
                                        Installed: 20.6.0-1nodesource1
                                        Candidate: 20.6.0-1nodesource1
                                        Version table:
                                       *** 20.6.0-1nodesource1 500
                                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                           20.5.1-1nodesource1 500
                                           20.5.0-1nodesource1 500
                                           20.4.0-1nodesource1 500
                                           20.3.1-1nodesource1 500
                                           20.3.0-1nodesource1 500
                                           20.2.0-1nodesource1 500
                                           20.1.0-1nodesource1 500
                                           20.0.0-1nodesource1 500
                                           18.13.0+dfsg1-1 500
                                      The following packages were automatically installed and are no longer required:
                                        libc-ares2 node-busboy node-cjs-module-lexer node-undici node-xtend
                                      Use 'sudo apt autoremove' to remove them.
                                      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:3 http://security.debian.org bookworm-security InRelease
                                      Fetched 17.3 kB in 1s (27.1 kB/s)
                                        nodejs
                                      Need to get 0 B/29.4 MB of archives.
                                      After this operation, 5746 kB disk space will be freed.
                                      dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
                                      (Reading database ... 38007 files and directories currently installed.)
                                      Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
                                      maik@iobtest:~$
                                        Da hast du aber mal die dfsg-Version von nodejs installiert gehabt... Die kommt nämlich mit diesen jetzt obsoleten Paketen angeschleppt.
                                        Aber das Skript selber schaut jetzt gut aus.
                                          Hier noch die Version mit einer ganz frischen Installation.
                                          Habe ich Gestern nicht mehr geschafft, da ich Nachtschicht hatte.
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          You are running nodejs v20.6.0. Do you want to install recommended version 18.17.1?
                                          lxc
                                          Fetched 17.3 kB in 1s (27.3 kB/s)
                                            nodejs
                                          Fetched 29.4 MB in 1s (31.3 MB/s)
                                          (Reading database ... 37784 files and directories currently installed.)
                                          maik@iobtest2:~$
                                            Vielen Dank für das Beta-Testing!
                                            Habe jetzt gestern noch ein pinning auf das nodesoure-Repo gelegt, das muss aber nicht getestet werden.
                                            PR gegen den ioBroker ist gestellt. Mal schauen wie schnell das im upstream landet.
                                            M 1 Reply Last reply Reply Quote 3
                                            198
                                            37919
