    4. iob node fix - Skript
      Thomas Braun Most Active @MCU last edited by
      @mcu sagte in iob node fix - Skript:
      Nothing to do
      Hm. Der Codepart war einfach... 😉 Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
      M M 2 Replies Last reply Reply Quote 1
        mrjeschke @Thomas Braun last edited by
        nodejs 20 sieht bei mir im LXC-Container so aus.
        ioBroker nodejs fixer 2023-09-06
        Recommended nodejs-version is: 18.17.1
        Checking your installation now. Please be patient!
        Your current setup is:
        /usr/bin/node           v20.5.1
        /usr/bin/npm            9.8.0
        /usr/bin/npx            9.8.0
        /usr/bin/corepack       0.19.0
        I found these nodejs versions available for installation:
        nodejs:
          Installed: 20.5.1-deb-1nodesource1
          Candidate: 20.5.1-deb-1nodesource1
          Version table:
         *** 20.5.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                100 /var/lib/dpkg/status
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
        Nothing to do, your installation is using the correct paths.
        You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        find: '/lost+found': Permission denied
        lxc
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        Building dependency tree... Done
        ca-certificates is already the newest version (20230311).
        curl is already the newest version (7.88.1-10+deb12u1).
        gnupg is already the newest version (2.2.40-1.1).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        *** Creating new /etc/apt/sources.list.d/nodesource.list
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        *** These repos are active after the adjustments:
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
        Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
        Fetched 17.3 kB in 0s (38.4 kB/s)
        Installing the recommended nodejs version now!
        ./iob_node_update: line 275: [: : integer expression expected
        Exact recommended version unknown, installing a fallback!
        The following packages will be DOWNGRADED:
          nodejs
        0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
        Need to get 29.4 MB of archives.
        After this operation, 5249 kB disk space will be freed.
        Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
        Fetched 29.4 MB in 2s (13.2 MB/s)
        dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
        (Reading database ... 37746 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
        Setting up nodejs (18.17.0-1nodesource1) ...
        Processing triggers for man-db (2.11.2-2) ...
        Updating fallback to latest nodejs v18 release
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Calculating upgrade... Done
        The following packages will be upgraded:
          nodejs
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        After this operation, 7168 B of additional disk space will be used.
        Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
        Fetched 29.4 MB in 1s (43.5 MB/s)
        apt-listchanges: Reading changelogs...
        (Reading database ... 37813 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
        Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
        Setting up nodejs (18.17.1-1nodesource1) ...
        ./iob_node_update: line 300: [: : integer expression expected
        *** You need to manually restart your container now! ***
        We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        maik@iobtest:~$
          MCU @Thomas Braun last edited by
          @thomas-braun Frisch aufgesetzter LXC mit nodejs 16 ohne ioBroker.
          No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
          /usr/bin/nodejs         v16.20.2
          /usr/bin/node           v16.20.2
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          /usr/bin/corepack       0.17.0
          nodejs:
            Installed: 16.20.2-deb-1nodesource1
            Candidate: 16.20.2-deb-1nodesource1
            Version table:
           *** 16.20.2-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org bullseye-security/main amd64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
          You are running nodejs v16.20.2. Do you want to install recommended version ?
          [sudo] password for prox:
          lxc
          ./iob_node_update: line 248: iob: command not found
          Hit:1 http://ftp.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org bullseye-security InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
          ca-certificates is already the newest version (20210119).
          curl is already the newest version (7.74.0-1.3+deb11u7).
          gnupg is already the newest version (2.2.27-2+deb11u2).
          Hit:1 http://security.debian.org bullseye-security InRelease
          Hit:2 http://ftp.debian.org/debian bullseye InRelease
          Fetched 17.3 kB in 0s (57.5 kB/s)
            nodejs
          After this operation, 60.4 MB of additional disk space will be used.
          Fetched 29.4 MB in 1s (21.7 MB/s)
          (Reading database ... 22654 files and directories currently installed.)
          Unpacking nodejs (18.17.0-1nodesource1) over (16.20.2-deb-1nodesource1) ...
          Processing triggers for man-db (2.9.4-2) ...
            nodejs
          Fetched 29.4 MB in 1s (41.9 MB/s)
          (Reading database ... 25141 files and directories currently installed.)
          nodejs is already the newest version (18.17.1-1nodesource1).
            Homoran Global Moderator Administrators @MCU last edited by
            ohne ioBroker.
            dann kennt er natürlich (?) die empfohlene Version nicht
            @Thomas-Braun
            was tut er dann?
            M Thomas Braun 2 Replies Last reply Reply Quote 1
              Thomas Braun Most Active @mrjeschke last edited by
              @mrjeschke sagte in iob node fix - Skript:
              Gut, der muss auch noch geprunt werden.
              Nanu?
              Muss ich schauen.
              Thx! Ich verzieh mich in die Code-Küche und brutzel noch was...
                MCU @Homoran last edited by
                @homoran Ich hab dann mit y bestätigt und er hat dann die v18 installiert.
                  Thomas Braun Most Active @Homoran last edited by Thomas Braun
                  @homoran sagte in iob node fix - Skript:
                  was tut er dann?
                  Dann geht es auf die neueste Version aus dem 18er-Zweig. Oder welcher nodejs-Entwicklungszweig auch immer gerade empfohlen wird. Der muss allerdings immer händisch im skript gesetzt werden, wenn sich die generelle Empfehlung ändert.
                  NODE_MAJOR=18           #recommended major nodejs version for ioBroker, please adjust if the recommendation changes
                    Homoran Global Moderator Administrators @MCU last edited by Homoran
                    hab ich auch gesehen, aber wieso?
                    hier
                    gibt er die recommended version komplett an.
                    bei dir steht da (erwartungsgemäß) nichts
                    edit: Hat sich mit Thomas' Antwort geklärt
                      bei dir steht da nichts
                      Bei @mrjeschke konnte die empfohlene Version auch direkt aus den iob-States gelesen werden.
                      Wenn es aber ein slave ist oder die Datenbank (noch) nicht geladen ist, dann greift der Fallback-Code.
                      So oder so soll am Ende immer die aktuellste Version aus dem empfohlenen Zweig installiert sein (inkl. aktuellem Schlüssel und aktueller, unverfrickelter nodesource.list)
                      Ich hatte überlegt, die Version auswählbar zu machen, hab mich aber dann dagegen entschieden.
                        @thomas-braun alles gut!
                        Damit hast du jetzt auch den Fallback verifiziert.
                        ich hatte mich nur gefragt woher bei nicht vorhandener Empfehlung jetztcdue v18 kam.
                        Aber du denkst anscheinend an allem!
                          Den konnte ich hier lokal schon ausgiebig testen. Hab mein Test-System mit diversen krummen Konstellationen malträtiert und das skript immer aufräumen lassen. 🙂
                          Intern nenne ich es auch 'die nodejs-Putze'. 😄
                            @mrjeschke
                            Bitte nochmal von einer nodejs@20 aus mit frischem Skript aufräumen lassen.
                              ioBroker nodejs fixer 2023-09-07
                              /usr/bin/nodejs         v20.6.0
                              /usr/bin/node           v20.6.0
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Installed: 20.6.0-1nodesource1
                                Candidate: 20.6.0-1nodesource1
                                Version table:
                               *** 20.6.0-1nodesource1 500
                                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                   20.5.1-1nodesource1 500
                                   20.5.0-1nodesource1 500
                                   20.4.0-1nodesource1 500
                                   20.3.1-1nodesource1 500
                                   20.3.0-1nodesource1 500
                                   20.2.0-1nodesource1 500
                                   20.1.0-1nodesource1 500
                                   20.0.0-1nodesource1 500
                                   18.13.0+dfsg1-1 500
                              The following packages were automatically installed and are no longer required:
                                libc-ares2 node-busboy node-cjs-module-lexer node-undici node-xtend
                              Use 'sudo apt autoremove' to remove them.
                              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:3 http://security.debian.org bookworm-security InRelease
                              Fetched 17.3 kB in 1s (27.1 kB/s)
                                nodejs
                              Need to get 0 B/29.4 MB of archives.
                              After this operation, 5746 kB disk space will be freed.
                              dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
                              (Reading database ... 38007 files and directories currently installed.)
                              Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
                              maik@iobtest:~$
                                Da hast du aber mal die dfsg-Version von nodejs installiert gehabt... Die kommt nämlich mit diesen jetzt obsoleten Paketen angeschleppt.
                                Aber das Skript selber schaut jetzt gut aus.
                                  Hier noch die Version mit einer ganz frischen Installation.
                                  Habe ich Gestern nicht mehr geschafft, da ich Nachtschicht hatte.
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  You are running nodejs v20.6.0. Do you want to install recommended version 18.17.1?
                                  lxc
                                  Fetched 17.3 kB in 1s (27.3 kB/s)
                                    nodejs
                                  Fetched 29.4 MB in 1s (31.3 MB/s)
                                  (Reading database ... 37784 files and directories currently installed.)
                                  maik@iobtest2:~$
                                    Vielen Dank für das Beta-Testing!
                                    Habe jetzt gestern noch ein pinning auf das nodesoure-Repo gelegt, das muss aber nicht getestet werden.
                                    PR gegen den ioBroker ist gestellt. Mal schauen wie schnell das im upstream landet.
                                    M 1 Reply Last reply Reply Quote 3
                                      @thomas-braun Wenn irgendwann die empfohlene Version die 20 wäre, dann brauch ich nur
                                      NODE_MAJOR=20
                                      zu setzen und lasse dann
                                      iob_node_update
                                      laufen?
                                        Thomas Braun Most Active @MCU last edited by Thomas Braun
                                        @mcu
                                        Ja.
                                        Das muss dann natürlich, wenn das Skript in den iob Installer integriert wurde dann auch dort zentral einmal geändert werden.
                                        Oder ich schau mal ob man das nicht aus der Installer Library auslesen kann. Dann wäre es nur einmal dort zu ändern.
                                        Irgendwie/wo muss die recommended version ja auch dort drin sein.
                                        Edith: In meinem ähnlich gelagerten PR zum Installer wird das natürlich auch mit einer Variablen gesetzt, im alten war ja der Link zum obsoleten nodejs-Installerskript drin.
                                        Edit2: Wobei die Varible NODE_MAJOR auch nur dann als 'FallBack' zum tragen kommt, wenn aus den iob-States nichts ausgelesen werden kann.
                                        G 1 Reply Last reply Reply Quote 2
                                          guitardoc @Thomas Braun last edited by
                                          @thomas-braun Kurze Frage dazu: wenn man gleichzeitig noch die Homebridge auf dem System hat, dann hat man zwei Installationen von Node drauf - Homebridge installiert Node in abweichenden Pfaden. Das können sogar unterschiedliche Versionen sein, es funktioniert trotzdem beides - ioB und Homebridge - einwandfrei. Kann der Node fixer das berücksichtigen, damit die Homebridge Installation nicht zerschossen wird oder interessiert das den Fixer gar nicht dass da noch eine zweite Installation drauf ist?
                                            Thomas Braun Most Active @guitardoc last edited by Thomas Braun
                                            @guitardoc
                                            Der Fixer haut alles weg, was nicht in den Installationspfaden des nodesource-Paketes, aber im $PATH liegt.
                                            Wo liegt denn die Installation der Homebridge?
                                            Hab ich mangels Homebridge nicht getestet.
                                            Edit:
                                            Hab gerade mal geschaut. Deren nodejs wohnt in
                                            Node Path /opt/homebridge/bin/node
                                            Das dürfte vom iob-Skript nicht tangiert werden, liegt es doch nicht im Standard $PATH. Außer sie verändern die Einträge dort.
                                            Kannst es ja testen ...
                                            198
                                            38028
