    4. [How-to] Node.js für ioBroker richtig updaten
      m0uh @Thomas Braun last edited by
      @thomas-braun Selber Fehler
      pi@iobroker:~ $ sudo -H -u iobroker npm cache clean --force
      /usr/lib/node_modules/npm/lib/cli.js:35
          throw err
      TypeError: Class extends value undefined is not a constructor or null
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          at Module.load (node:internal/modules/cjs/loader:1119:32)
          at Module._load (node:internal/modules/cjs/loader:960:12)
          at Module.require (node:internal/modules/cjs/loader:1143:19)
          at require (node:internal/modules/cjs/helpers:121:18)
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
      Node.js v18.17.1
        Thomas Braun Most Active @m0uh last edited by
        @m0uh sagte in [How-to] Node.js für ioBroker richtig updaten:
        Mach einen eigenen Thread auf und gib da mal die Ausgabe von
        iob diag
        rein. Dürfte zwar sehr zerfetzt aussehen, aber sei's drum.
        M M 2 Replies Last reply Reply Quote 0
          @thomas-braun Erledigt. Siehe:
          https://forum.iobroker.net/topic/67912/nodejs-update-von-16-x-auf-18-x-nicht-möglich-npm-fehler
            MCU @Thomas Braun last edited by MCU
            @thomas-braun Installation-Setup wird als veraltet angemerkt. Gibt es da was Neues?
            Hab es in Deiner Signatur nachvollzogen. ok.
            prox@jarvisV313:~$ curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                       SCRIPT DEPRECATION WARNING
              This script, located at https://deb.nodesource.com/setup_X, used to
              install Node.js is deprecated now and will eventually be made inactive.
              Please visit the NodeSource distributions Github and follow the
              instructions to migrate your repo.
              https://github.com/nodesource/distributions
              The NodeSource Node.js Linux distributions GitHub repository contains
              information about which versions of Node.js and which Linux distributions
              are supported and how to install it.
            TO AVOID THIS WAIT MIGRATE THE SCRIPT
            Continuing in 60 seconds (press Ctrl-C to abort) ...
              Thomas Braun Most Active @MCU last edited by
              @mcu sagte in [How-to] Node.js für ioBroker richtig updaten:
              Ja, da hab ich es schon drin. Und im 'Beta-iob-diag' ist es auch drin.
              Ich wollte mir die Tage dann vielleicht auch den iob installer mal anschauen und einen PR schreiben.
                @thomas-braun Wie kann man denn z.B. nodejs 20 sperren?
                Achtung, wenn das Repo mit einer höheren Version nicht deaktiviert wird kommt beim nächsten apt update / apt upgrade natürlich die höhere Version mit.
                  Thomas Braun Most Active @MCU last edited by Thomas Braun
                  @mcu
                  Einfach keine Zeile für nodejs@20 anlegen.
                  Die Versionszweige kommen immer noch aus separaten Einträgen.
                  ODER man pinnt ein nodejs@18 fest. Ging per 'apt pinning'
                  • PLCHome 0
                    PLCHome 0 Developer last edited by Homoran
                    Also das Installieren hat sich geändert.
                    Man soll das Script nicht mehr benutzen:
                    Alt:
                    curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                    sudo apt-get install -y nodejs
                    Neu
                    sudo apt install -y ca-certificates curl gnupg
                    curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                    NODE_MAJOR=18
                    echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
                    sudo apt-get update && sudo apt-get install nodejs -y
                    MOD-EDIT: Code korrigiert!
                    quelle: https://deb.nodesource.com/
                    mit NODE_MAJOR=18 kann man die Version bestimmen.
                    Das hier ist aber nur mit Bookworm getestet. NPM wird nur mit Version 20 mitinstalliert. Unter Buster ist bei mir eine 12 statt der 18 installiert worden.
                    Thomas Braun oberfragger F 3 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @PLCHome 0 last edited by
                      @plchome-0 sagte in [How-to] Node.js für ioBroker richtig updaten:
                      Man muss nun das "Key verfahren "benutzen:
                      Nee, das ist nicht die Änderung, das wurde 'schon immer' verwendet.
                      Die Änderung ist im wesentlichen, das nicht mehr für jedes Distributions-Release ein deb gebaut wird sondern ein generisches, das auf alles passt, was die grundlegendsten Bedingungen erfüllt.
                      Gilt analog für yum / rpm-basierte Paketmanagementsysteme.
                      • oberfragger
                        oberfragger @PLCHome 0 last edited by oberfragger
                        Neu
                        NODE_MAJOR=18
                        sudo apt-get install nodejs npm -y
                        Das hat bei mir nicht funktioniert.
                        The following packages have unmet dependencies:
                         libnode72 : Conflicts: nodejs-legacy
                         nodejs : Conflicts: npm
                        E: Unable to correct problems, you have held broken packages.
                        root@iobroker:/opt/iobroker#
                        Muss ich irgendwas deinstallieren?
                        Habe zwischenzeitlich diesen Link gefunden.
                        https://github.com/Chia-Network/chia-blockchain/discussions/9673
                        Nach iobroekr start habe ich aber plötzlich die aktuelle 18.17.1 Seltsam.
                          Thomas Braun Most Active @oberfragger last edited by Thomas Braun
                          @oberfragger sagte in [How-to] Node.js für ioBroker richtig updaten:
                          Ja.
                          sudo apt remove libnode72 npm nodejs-legacy
                          Und hampel da nicht als root herum.
                            fastfoot @PLCHome 0 last edited by
                            da steht aber NICHTS von npm installieren so wie du es da stehen hast. Die Installation von nodejs beinhaltet bereits npm. Bitte ändere das ab damit sich dieser Unsinn nicht verbreitet
                            PLCHome 0 1 Reply Last reply Reply Quote 0
                            • PLCHome 0
                              PLCHome 0 Developer @fastfoot last edited by
                              @fastfoot ich setze jedes Mal einen Docker neu auf. NPM fehlte jedes Mal wenn ich nur NODEJS im apt hatte.
                              Thomas Braun F 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @PLCHome 0 last edited by Thomas Braun
                                Das kann nicht sein, npm ist Bestandteil des nodejs-Pakets (Jedenfalls so wie es von nodesource zusammengebaut wird).
                                Das nodejs in der dfsg-Version kommt allerdings ohne npm mit. Streng nach der Debian-Herangehensweise, Pakete möglichst modular und schlank aufzubauen.
                                Und weil das so ist knallt das auch oben bei dir.
                                Edit... War ja gar nicht bei dir, wo das knallt...
                                  @plchome-0 ich setze ständig neue Container auf und installiere node, hundert mal in den letzten Wochen ist nicht übertrieben, und npm hat da nie gefehlt. es ging mir auch darum dass wenn du schon eine quelle nennst du sie nicht einfach abändern kannst!
                                    @oberfragger
                                    Prüfe ob das jetzt da alles senkrecht ist bei dir.
                                    Das schaut irgendwie schräg aus.
                                    iob diag
                                    oder damit:
                                    https://forum.iobroker.net/topic/68035/iob-node-fix-skript
                                    • PLCHome 0
                                      @fastfoot sagte in [How-to] Node.js für ioBroker richtig updaten:
                                      Ich brauche keine Hundert container: Also neuer Container unter Bookworm, mit genau dem was oben steht und nix npm.
                                      Wenn man die 20 installiert, ist npm es drauf.
                                      Meines Wissens nach soll der ioB aber unter 18 laufen.
                                      Es gibt auch noch weitere Problemen unter bullseye kommt, wenn man die 18 einträgt eine 12.
                                      Ist wohl alles nicht so ausgereift.
                                      Thomas Braun Homoran F 4 Replies Last reply Reply Quote 0
                                        @plchome-0
                                        nodejs v18.13.0 ist die dfsg-Variante aus dem Debian-Repository.
                                        Die will man nicht verwenden, weswegen der Installer eigentlich auch da schon das nodesource-Repo (in obsoleter Form) reinholt.
                                        Aus Screenshots kann man nicht kopieren, stell Text aus der Konsole auch als Text in CodeTags rein. Danke.
                                          Naja, du installierst die falschen Pakete.
                                            Homoran Global Moderator Administrators @PLCHome 0 last edited by
                                            ehrlich!??
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            734910
