    3. Einsteigerfragen
    4. Installation
    5. Sonoff Zigbee Dongle - keine Verbindung zu Gerät oder Dienst
      richi1230 last edited by richi1230
      Hab das gleiche Problem sowohl mit dem Zigbee Dongle 3.0 als auch mit der ZigBee Brigde (Tasmota geflasht).:
      Hier die Probleme beim Dongle
      Den Adapter habe ich nach der Anleitung von Matthias Klein eingerichtet:
      Im Log steht folgendes:
      2023-09-07 15:05:29.666 - info: zigbee.0 (275450) starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 4.0.24
      2023-09-07 15:05:29.914 - info: zigbee.0 (275450) delete old Backup files. keep only last 10
      2023-09-07 15:05:29.917 - info: zigbee.0 (275450) Starting Zigbee npm ...
      2023-09-07 15:05:31.670 - info: zigbee.0 (275450) Installed Version: iobroker.zigbee@1.8.23
      2023-09-07 15:05:51.919 - error: zigbee.0 (275450) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2023-09-07 15:05:51.920 - error: zigbee.0 (275450) Failed to start Zigbee
      2023-09-07 15:05:51.921 - error: zigbee.0 (275450) Error herdsman start
      2023-09-07 15:06:01.927 - info: zigbee.0 (275450) Try to reconnect. 1 attempts left
      2023-09-07 15:06:01.929 - info: zigbee.0 (275450) Starting Zigbee npm ...
      2023-09-07 15:06:01.969 - info: zigbee.0 (275450) Installed Version: iobroker.zigbee@1.8.23
      2023-09-07 15:06:02.439 - error: zigbee.0 (275450) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2023-09-07 15:06:02.441 - error: zigbee.0 (275450) Failed to start Zigbee
      2023-09-07 15:06:02.442 - error: zigbee.0 (275450) Error herdsman start
      2023-09-07 15:08:33.974 - error: zigbee.0 (275450) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2023-09-07 15:08:34.389 - info: zigbee.0 (275450) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20230325080218","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230325080218-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA0"}]
      Komme da alleine nicht weiter. Hat jemand einen Tipp für mich?
      geschild 1 Reply Last reply Reply Quote 0
      • geschild
        geschild @richi1230 last edited by
        @richi1230 said in Sonoff Zigbee Dongle - keine Verbindung zu Gerät oder Dienst:
        Zigbee Dongle 3.0
        Ich verwende auch die Bridge mit tasmota. Diese zeigt sich nicht im zigbee.0-adapter, sondern im sonoff.0-adapter.
          richi1230 @geschild last edited by
          @geschild
          das hab ich gerade ausprobiert nur sehe ich da keine ZB Devices (bei mir hauptsächlich Thermometer)
          Wo kann ich im Sonoff Adapter die Geräte koppeln?
          • geschild
            @richi1230 https://www.google.com/search?q=zigbee+bridge+tasmota&rlz=1C1ONGR_deDE980DE980&oq=zigbee+bridge+tasmota&aqs=chrome..69i57.5135j0j1&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:d9016846,vid:FH2KL-5riRQ,st:205
            ab Minute 8:00
              @geschild Danke für den Link, das Video kannte ich bereits und das Koppeln in Tasmota funktioniert ja, allerdings hätte ich eine Kopplung gerne im IOBroker Adapter gemacht.
              Mein Hauptproblem bleibt aber, dass ich auch im Sonoff Adapter keine Objekte für die bereits gekoppelten Geräte finde.
              Das sehe ich in Tasmota:
              Hab den Sonoff Port 1877 in den MQTT settings eingegeben:
              ... im IOBroker wird aber nur ein Objekt für die Bridge angelegt, die Datenpunkte für die Sensoren kommen nicht:
                richi1230 @richi1230 last edited by
                Außerdem soll ja auch die Bridge mit dem Zigbee Adapter funktionieren, soferne man den Com Port mit tcp://192.168.1.xxx:8888 anlegt.
                Hat bei mir leider auch nicht geklappt.
                • geschild
                  geschild @richi1230 last edited by geschild
                  @richi1230 Ist dein SonOff Adapter im iobroker auch auf Port 1877 und nicht wie im Standard auf 1883? Also mqtt-Port in Tasmota wie im iobroker einstellen!
                  Hier wird das Thema anbinden an Zigbee-Adapter besprochen: https://forum.iobroker.net/topic/43446/zigbee-adapter-mit-sonoff-zigbee-bridge hab es aber nur überflogen, da das Schöne an der Bridge doch ist, dass man die Reichweite vom WLAN nutzen kann und nicht an die spärlichere Reichweite von Zigbee gebunden ist.
                    @geschild said in Sonoff Zigbee Dongle - keine Verbindung zu Gerät oder Dienst:
                    Ja, hab zusätzlich auch den Port 1883 für den MQTT Adapter am laufen, drum den vom Sonoff auf 1877 verlegt.
                    Den zitierten Beitrag kenne ich, nur löst er mein Problem leider auch nicht. Die Bridge wir leider nicht erkannt.
