    4. Test Adapter Rain Bird v0.1.x GitHub
      myssv @StrathCole last edited by
      @strathcole Ich fürchte damit bin ich dann doch raus ...
      • Jörg Heilig
        Jörg Heilig last edited by
        @strathcole
        Leider bekomme ich immer wieder den gleichen JS Fehler. Ich habe das log Rainbird_log.txt angehangen. Vielleicht kann mir jemand einen Tip geben, was falsch läuft?
          tobitobsta last edited by tobitobsta
          hallo zusammen,
          hatte jemand von euch schonmal folgendes Problem?
          rainbird.0 2021-08-31 10:11:39.960	warn	Error in request from client for CurrentStationsActive: {"code":"ESOCKETTIMEDOUT","connect":false}
          rainbird.0 2021-08-31 10:11:39.958	warn	Request reply error: [{"code":"ESOCKETTIMEDOUT","connect":false},null,null]
          rainbird.0 2021-08-31 10:11:35.782	info	Not inserting command into queue, it already exists on earlier position: ["CurrentRainSensorState",null]
          rainbird.0 2021-08-31 10:11:35.782	info	Not inserting command into queue, it already exists on earlier position: ["WaterBudget",[0]]
          rainbird.0 2021-08-31 10:11:35.781	info	Not inserting command into queue, it already exists on earlier position: ["RainDelayGet",null]
          rainbird.0 2021-08-31 10:11:35.781	info	Not inserting command into queue, it already exists on earlier position: ["CurrentIrrigationState",null]
          rainbird.0 2021-08-31 10:11:19.952	warn	Error in request from client for CurrentRainSensorState: {"code":"ESOCKETTIMEDOUT","connect":false}
          rainbird.0 2021-08-31 10:11:19.952	warn	Request reply error: [{"code":"ESOCKETTIMEDOUT","connect":false},null,null]
          rainbird.0 2021-08-31 10:11:15.780	info	Not inserting command into queue, it already exists on earlier position: ["CurrentStationsActive",[0]]
          rainbird.0 2021-08-31 10:11:15.780	info	Not inserting command into queue, it already exists on earlier position: ["WaterBudget",[0]]
          rainbird.0 2021-08-31 10:11:15.780	info	Not inserting command into queue, it already exists on earlier position: ["RainDelayGet",null]
          rainbird.0 2021-08-31 10:11:15.779	info	Not inserting command into queue, it already exists on earlier position: ["CurrentIrrigationState",null]
          rainbird.0 2021-08-31 10:10:59.941	warn	Error in request from client for CurrentIrrigationState: {"code":"ESOCKETTIMEDOUT","connect":false}
          rainbird.0 2021-08-31 10:10:59.940	warn	Request reply error: [{"code":"ESOCKETTIMEDOUT","connect":false},null,null]
          rainbird.0 2021-08-31 10:10:55.779	info	Not inserting command into queue, it already exists on earlier position: ["CurrentRainSensorState",null]
          rainbird.0 2021-08-31 10:10:55.779	info	Not inserting command into queue, it already exists on earlier position: ["CurrentStationsActive",[0]]
          rainbird.0 2021-08-31 10:10:55.778	info	Not inserting command into queue, it already exists on earlier position: ["WaterBudget",[0]]
          rainbird.0 2021-08-31 10:10:55.778	info	Not inserting command into queue, it already exists on earlier position: ["RainDelayGet",null]
          kommt durchgängig alle 15 Sekunden. Ein Instanz-Restart behebt das Problem nicht. Irgendwelche Ideen oder Erfahrungen damit hier?
          VG
          Tobi
          edit:
          Problem saß wieder sehr eindeutig vor dem Bildschirm - habe in meinen Skripten irgendwo eine Dauerschleife generiert und scheinbar den Regenvogel dauerhaft befeuert....
            emeins last edited by
            Hallo, Ich habe gerade die Version 0.2.3 zusammen mit dem LNK2 Stick an ESP-RZXe 6 Stationen von Rainbird getestet. Läuft soweit, Vielen Dank für die Implementierung!
            Das Einzige, was ich momentan auch bekomme, sind Warnungen im Log (jeweils zum Polling, default alle 20 Sekunden):
            Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
            M werner2000x 2 Replies Last reply Reply Quote 0
              mr-suw @emeins last edited by
              @emeins sagte in Test Adapter Rain Bird v0.1.x GitHub:
              Hi, ich habe gerade das Plugin an eine ESP-RZXe 4 mit LNK-Stick angebunden. Zwei Dinge sind mir aufgefallen:
              a) Status request failed. Requested B0 but got 00 (wie bei dir)
              b) Das State Polling wird nur nach Start des Adapters mit "Full Polling" ausgeführt. Laut main.js (Zeile 147) sollte das "Full Polling" alle 10 Minuten durchgeführt werden. In der Debug-Log Ausgabe steht nur: "Starting state polling with full=false"
              Ansonsten scheint der Adapter zu funktionieren 🙂
                Kaiman @StrathCole last edited by
                @strathcole Bei mir steht die Anschaffung einer Rainbird Bewässerung an. Weisst du, ob es der Adapter auch mit dem LNK2 Wlan Modul tut?
                S NWH 2 Replies Last reply Reply Quote 0
                  schmidti @Kaiman last edited by schmidti
                  Hat jemand das ganze in YAHKA eingebunden? Komme irgendwie nicht so richtig weiter.....
                  Die Restdaueranzeige und das Stoppen bekomme ich nicht so richtig hin.
                    schmidti @schmidti last edited by
                    @schmidti said in Test Adapter Rain Bird v0.1.x GitHub:
                    So, habe es jetz so gut wie hinbekommen.
                    • NWH
                      NWH @Kaiman last edited by
                      @kaiman
                      Servus,
                      Hast du inzwischen schon deine Anlage in betrieb?
                      Mich würde auch interessieren ob der Adapter mit mit dem LNK2 WIFI Modul funktioniert.
                      Oder weiß das scho wer?
                        Kaiman @NWH last edited by
                        @nwh Aktuell warten wir noch auf die Genehmigung zum Brunnenbau - danach kommt dann erst die Bewässerung. Das wird wohl realistisch diese Saison nichts mehr 😞
                        Ich hoffe dran zu denken, nächste Saison hier dann zu berichten.
                        NWH 1 Reply Last reply Reply Quote 0
                        • NWH
                          @kaiman
                          Ok
                          Danke für die Antwort.
                          • Feuersturm
                            Feuersturm last edited by
                            Hat jemand von euch den Adapter mit dem Rainbird Steuergerät ST8-2.0 Series in Betrieb? Das ST8 2.0 (https://wifi.rainbird.com/) hat wohl ein eingebautes WIFI Modul und nicht den Wifi Stick wie beim ESP-Me.
                            • Feuersturm
                              Hier geht es mit den Tests für Rainbird 1.x.x weiter https://forum.iobroker.net/topic/75150/test-adapte-rainbird-1-x-x
                              @mcm1957 @Homoran Mein Vorschlag wäre hier den Testing Thread zu schließen, um im neuen Thread dann weiter zu machen.
                              • mcm1957
                                mcm1957 @Feuersturm last edited by
                                @feuersturm said in Test Adapter Rain Bird v0.1.x GitHub:
                                @Homoran
                                Ja, bin auch dafür hier mal zu schließen.
                                31.7k
                                79.8k
                                bewässerung rain bird
                                21
                                215
                                23979
