    3. Off Topic
    4. Docker buanet startet nicht mehr (Synology NAS)
    • Marc Berg
      Marc Berg Most Active @StefanRS last edited by
      @stefanrs sagte in Docker buanet startet nicht mehr (Synology NAS):
      Seit heute startet plötzlich der Docker vom IOBroker nicht mehr.
      Setze mal die Container-Umgebungvariable "DEBUG" auf "true". Vielleicht sieht man dann mehr. Damit wird auch verhindert, dass der Container neu startet.
        Hab ich gemacht. Hier der LOG Auszug.
        date	stream	content
        2023/09/08 19:03:15	stdout
        2023/09/08 19:03:15	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:03:15	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
        2023/09/08 19:03:15	stdout	Registering maintenance script as command... Done.
        2023/09/08 19:03:12	stdout	Updating Linux packages on first run... Done.
        2023/09/08 19:03:07	stdout
        2023/09/08 19:03:07	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:03:07	stdout	-----                   Step 1 of 5: Preparing container                   -----
        2023/09/08 19:03:07	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023/09/08 19:03:07	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
        2023/09/08 19:03:07	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
        2023/09/08 19:03:07	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
        2023/09/08 19:03:07	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
        2023/09/08 19:03:07	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
        2023/09/08 19:03:07	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
        2023/09/08 19:03:07	stdout	-----                    SETUID:              1000                         -----
        2023/09/08 19:03:07	stdout	-----                    SETGID:              1000                         -----
        2023/09/08 19:03:07	stdout	-----                    DEBUG:               true                         -----
        2023/09/08 19:03:07	stdout	-----                        Environment Variables                         -----
        2023/09/08 19:03:07	stdout	-----        -----
        2023/09/08 19:03:07	stdout	-----                    npm:                 9.6.7                        -----
        2023/09/08 19:03:07	stdout	-----                    node:                v18.17.1                     -----
        2023/09/08 19:03:07	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
        2023/09/08 19:03:07	stdout	-----                    image:               v8.1.0                       -----
        2023/09/08 19:03:07	stdout	-----                          Version Information                         -----
        2023/09/08 19:03:07	stdout	-----                    hostname:            IOBroker                     -----
        2023/09/08 19:03:07	stdout	-----                    arch:                x86_64                       -----
        2023/09/08 19:03:07	stdout	-----                          System Information                          -----
        2023/09/08 19:03:07	stdout	-----                          Please be patient!                          -----
        2023/09/08 19:03:07	stdout	-----                    Startupscript is now running!                     -----
        2023/09/08 19:03:07	stdout	-----              Welcome to your ioBroker Docker container!              -----
        2023/09/08 19:03:07	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
        2023/09/08 19:03:07	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
        2023/09/08 19:03:07	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
        2023/09/08 19:03:07	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
        2023/09/08 19:03:07	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
        2023/09/08 19:03:07	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
        2023/09/08 19:03:07	stdout	-------------------------     2023-09-08 19:03:07      -------------------------
        2023/09/08 19:03:03	stdout	(Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231:   359 Killed                  chown -R "$setuid":"$setgid" /opt/iobroker
        2023/09/08 19:03:02	stdout
        2023/09/08 19:03:02	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:03:02	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
        2023/09/08 19:03:01	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
        2023/09/08 19:03:00	stdout
        2023/09/08 19:03:00	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:03:00	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
        2023/09/08 19:03:00	stdout	Registering maintenance script as command... Done.
        2023/09/08 19:02:57	stdout	Updating Linux packages on first run... Done.
        2023/09/08 19:02:52	stdout
        2023/09/08 19:02:52	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:52	stdout	-----                   Step 1 of 5: Preparing container                   -----
        2023/09/08 19:02:52	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023/09/08 19:02:52	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
        2023/09/08 19:02:52	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
        2023/09/08 19:02:52	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
        2023/09/08 19:02:52	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
        2023/09/08 19:02:52	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
        2023/09/08 19:02:52	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
        2023/09/08 19:02:52	stdout	-----                    SETUID:              1000                         -----
        2023/09/08 19:02:52	stdout	-----                    SETGID:              1000                         -----
        2023/09/08 19:02:52	stdout	-----                    DEBUG:               true                         -----
        2023/09/08 19:02:52	stdout	-----                        Environment Variables                         -----
        2023/09/08 19:02:52	stdout	-----        -----
        2023/09/08 19:02:52	stdout	-----                    npm:                 9.6.7                        -----
        2023/09/08 19:02:51	stdout	-----                    node:                v18.17.1                     -----
        2023/09/08 19:02:51	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
        2023/09/08 19:02:51	stdout	-----                    image:               v8.1.0                       -----
        2023/09/08 19:02:51	stdout	-----                          Version Information                         -----
        2023/09/08 19:02:51	stdout	-----        -----
        2023/09/08 19:02:51	stdout	-----                    hostname:            IOBroker                     -----
        2023/09/08 19:02:51	stdout	-----                    arch:                x86_64                       -----
        2023/09/08 19:02:51	stdout	-----                          System Information                          -----
        2023/09/08 19:02:51	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:51	stdout	-----                          Please be patient!                          -----
        2023/09/08 19:02:51	stdout	-----                    Startupscript is now running!                     -----
        2023/09/08 19:02:51	stdout	-----              Welcome to your ioBroker Docker container!              -----
        2023/09/08 19:02:51	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
        2023/09/08 19:02:51	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
        2023/09/08 19:02:51	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
        2023/09/08 19:02:51	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
        2023/09/08 19:02:51	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
        2023/09/08 19:02:51	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
        2023/09/08 19:02:51	stdout	-------------------------     2023-09-08 19:02:51      -------------------------
        2023/09/08 19:02:47	stdout	(Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231:   359 Killed                  chown -R "$setuid":"$setgid" /opt/iobroker
        2023/09/08 19:02:47	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:47	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
        2023/09/08 19:02:45	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
        2023/09/08 19:02:44	stdout
        2023/09/08 19:02:44	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:44	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
        2023/09/08 19:02:44	stdout	Registering maintenance script as command... Done.
        2023/09/08 19:02:41	stdout	Updating Linux packages on first run... Done.
        2023/09/08 19:02:36	stdout
        2023/09/08 19:02:36	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:36	stdout	-----                   Step 1 of 5: Preparing container                   -----
        2023/09/08 19:02:36	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023/09/08 19:02:36	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
        2023/09/08 19:02:36	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
        2023/09/08 19:02:36	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
        2023/09/08 19:02:36	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
        2023/09/08 19:02:36	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
        2023/09/08 19:02:36	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
        2023/09/08 19:02:36	stdout	-----                    SETUID:              1000                         -----
        2023/09/08 19:02:36	stdout	-----                    SETGID:              1000                         -----
        2023/09/08 19:02:36	stdout	-----                    DEBUG:               true                         -----
        2023/09/08 19:02:36	stdout	-----                        Environment Variables                         -----
        2023/09/08 19:02:36	stdout	-----        -----
        2023/09/08 19:02:36	stdout	-----                    npm:                 9.6.7                        -----
        2023/09/08 19:02:35	stdout	-----                    node:                v18.17.1                     -----
        2023/09/08 19:02:35	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
        2023/09/08 19:02:35	stdout	-----                    image:               v8.1.0                       -----
        2023/09/08 19:02:35	stdout	-----                          Version Information                         -----
        2023/09/08 19:02:35	stdout	-----        -----
        2023/09/08 19:02:35	stdout	-----                    hostname:            IOBroker                     -----
        2023/09/08 19:02:35	stdout	-----                    arch:                x86_64                       -----
        2023/09/08 19:02:35	stdout	-----                          System Information                          -----
        2023/09/08 19:02:35	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:35	stdout	-----                          Please be patient!                          -----
        2023/09/08 19:02:35	stdout	-----                    Startupscript is now running!                     -----
        2023/09/08 19:02:35	stdout	-----              Welcome to your ioBroker Docker container!              -----
        2023/09/08 19:02:35	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
        2023/09/08 19:02:35	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
        2023/09/08 19:02:35	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
        2023/09/08 19:02:35	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
        2023/09/08 19:02:35	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
        2023/09/08 19:02:35	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
        2023/09/08 19:02:35	stdout	-------------------------     2023-09-08 19:02:35      -------------------------
        2023/09/08 19:02:32	stdout	(Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231:   359 Killed                  chown -R "$setuid":"$setgid" /opt/iobroker
        2023/09/08 19:02:30	stdout
        2023/09/08 19:02:30	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:30	stdout	-----             Step 3 of 5: Checking ioBroker installation              -----
        2023/09/08 19:02:30	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
        2023/09/08 19:02:28	stdout
        2023/09/08 19:02:28	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:28	stdout	-----             Step 2 of 5: Detecting ioBroker installation             -----
        2023/09/08 19:02:28	stdout	Registering maintenance script as command... Done.
        2023/09/08 19:02:25	stdout	Updating Linux packages on first run... Done.
        2023/09/08 19:02:20	stdout
        2023/09/08 19:02:20	stdout	--------------------------------------------------------------------------------
        2023/09/08 19:02:20	stdout	-----                   Step 1 of 5: Preparing container                   -----
        2023/09/08 19:02:20	stdout	!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        2023/09/08 19:02:20	stdout	!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
        2023/09/08 19:02:20	stdout	!!!!     For more information see ioBroker Docker image documentation:      !!!!
        2023/09/08 19:02:20	stdout	!!!!          Please make sure to deactivate if no longer needed.           !!!!
        2023/09/08 19:02:20	stdout	!!!! This will extend the logging output and may slow down container start. !!!!
        2023/09/08 19:02:20	stdout	!!!!               Environment variable DEBUG is set to true.               !!!!
        2023/09/08 19:02:20	stdout	!!!!                            DEBUG LOG ACTIVE                            !!!!
        2023/09/08 19:02:20	stdout	-----                    SETUID:              1000                         -----
        2023/09/08 19:02:20	stdout	-----                    SETGID:              1000                         -----
        2023/09/08 19:02:20	stdout	-----                    DEBUG:               true                         -----
        2023/09/08 19:02:20	stdout	-----                        Environment Variables                         -----
        2023/09/08 19:02:20	stdout	-----        -----
        2023/09/08 19:02:20	stdout	-----                    npm:                 9.6.7                        -----
        2023/09/08 19:02:20	stdout	-----                    node:                v18.17.1                     -----
        2023/09/08 19:02:20	stdout	-----                    build:               2023-08-19T23:45:39+00:00    -----
        2023/09/08 19:02:20	stdout	-----                    image:               v8.1.0                       -----
        2023/09/08 19:02:20	stdout	-----                          Version Information                         -----
        2023/09/08 19:02:20	stdout	-----                    hostname:            IOBroker                     -----
        2023/09/08 19:02:20	stdout	-----                    arch:                x86_64                       -----
        2023/09/08 19:02:20	stdout	-----                          System Information                          -----
        2023/09/08 19:02:20	stdout	-----                          Please be patient!                          -----
        2023/09/08 19:02:20	stdout	-----                    Startupscript is now running!                     -----
        2023/09/08 19:02:20	stdout	-----              Welcome to your ioBroker Docker container!              -----
        2023/09/08 19:02:20	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
        2023/09/08 19:02:20	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
        2023/09/08 19:02:20	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
        2023/09/08 19:02:20	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
        2023/09/08 19:02:20	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
        2023/09/08 19:02:20	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
        haselchen Marc Berg Glasfaser 3 Replies Last reply Reply Quote 0
        • haselchen
          haselchen Most Active @StefanRS last edited by
          @stefanrs
          Hast Du Backups gemacht oder machen lassen?
          Aus dem Log kann man nicht viel sehen.
          Aber wenn er permanent startet hast Du keine Chance mal ins Terminal zu kommen.
            StefanRS @haselchen last edited by StefanRS
            @haselchen sagte in Docker buanet startet nicht mehr (Synology NAS):
            @stefanrs
            Ja ich hab ein Backup vor ein paar Monaten gemacht. Aber wenn der Container ja nicht startet, bringt das Backup auch nix oder?
            • Marc Berg
              @stefanrs
              Hast du mal die Logs unter /opt/iobroker/log geschaut? Könnte es sein, dass das Volume, wo der ioBroker liegt, vollgelaufen ist?
                StefanRS @Marc Berg last edited by
                @marc-berg ja unter log sind Daten vorhanden. Die Festplatte ist nicht voll. Sind noch 1,xTB frei.
                • Marc Berg
                  Naja, reinschauen in die aktuelle Log-Datei wäre schon nicht schlecht. Vielleicht gibt's da noch neue Erkenntnisse.
                    @marc-berg : Anbei ein Auszug von den letzten Einträgen
                    (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.033  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.070  - info: host.IOBroker instance system.adapter.mihome-vacuum.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.070  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.436  - info: host.IOBroker instance system.adapter.trashschedule.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.436  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.471  - info: host.IOBroker instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.471  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.472  - info: host.IOBroker instance system.adapter.tankerkoenig.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.472  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.524  - info: host.IOBroker instance system.adapter.denon.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.524  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.524  - info: host.IOBroker instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.556  - info: host.IOBroker instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.556  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.557  - info: host.IOBroker instance system.adapter.reolink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.557  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.582  - info: host.IOBroker instance system.adapter.reolink.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.583  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.761  - warn: host.IOBroker Cannot get view: Connection is closed.
                    2023-09-08 17:56:21.762  - warn: host.IOBroker Cannot get view: Connection is closed.
                    2023-09-08 17:56:21.763  - info: host.IOBroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.763  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.763  - info: host.IOBroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.764  - info: host.IOBroker All instances are stopped.
                    2023-09-08 17:56:21.764  - info: host.IOBroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-09-08 17:56:21.764  - info: host.IOBroker instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    • Marc Berg
                      Hm, da kann ich nichts draus ablesen. Das Log ist auch nicht komplett. Ein vollständiger Durchlauf eines Startversuches wäre sicher besser zu sehen.
                      • Glasfaser
                        Glasfaser @StefanRS last edited by Glasfaser
                        Da stimmt etwas mit den Ordnerrechten nicht ... hast du ein Mount !?
                        EDIT :
                        so sieht es sonst aus ... mit Done :
                        (Re)setting permissions (This might take a while! Please be patient!)... Done.
                        Fixing "sudo-bug" by replacing sudo with gosu... Done.
                          StefanRS @Glasfaser last edited by
                          @glasfaser was genau meinst du mit Mount?
                          Habe die Rechte nochmal überprüft. Steht alles auf lesen/schreiben. Zugriff ist vorhanden.
                            @marc-berg leider sind das die letzten Einträge. Ab dann ging es nicht mehr und er schreibt bzw. legt keinen neuen LOG mehr im Laufwerk ab.
                            • Glasfaser
                              ob der Ordner /opt/iobroker außerhalb vom Container ist
                              schonmal die Synology danach mal neu gestartet !?
                                @glasfaser danke für den Tipp mit dem Neustart von der NAS. Jetzt geht es wieder.
                                Peinlich, das hätte ich auch gleich machen können 🙂
                                • Glasfaser
                                  @stefanrs
                                  Was war jetzt damit !?
                                  @glasfaser sagte in Docker buanet startet nicht mehr (Synology NAS):
                                  So ganz Normal ist das nicht , da muß noch was passiert sein !
                                    @glasfaser
                                    der Ordner liegt genauso wie auf deinem Screenshot zu sehen ist. So sieht es bei mir auch aus (bis auf die Bezeichnung)
                                    • Glasfaser
                                      @stefanrs
                                      OK ... dachte ich mir !
                                      und wie schon geschrieben ... Normal ist das nicht !
                                      Welche DSM Version hast du
                                      und wieviel Container laufen !?
                                        @glasfaser
                                        es läuft nur der eine Container und ich habe Version 7.2-64570 drauf
                                        • Glasfaser
                                          @stefanrs
                                          Top UpToDate 👍
                                          Dann klemmte da etwas .... würde ich aber mal beobachten .. warum !
                                            @glasfaser
                                            Ja werde ich beobachten. Auf jeden Fall danke nochmal für deine Hilfe.
                                            Bin echt froh, dass es wieder geht. Mein ganzes Smart Home etc baut auf IOBroker auf.
                                            Hab schon Panik bekommen. Da sind einige Stunden für ins Lang gegangen 🙂
                                            mcBirne 1 Reply Last reply Reply Quote 0
                                            1891
