    4. Adapter "smartmeter"
      michihorn @Thomas Braun last edited by
      @thomas-braun Ich habe meine Hausaufgaben gemacht:
      cas@raspberrypi:~ $ find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
      ls -lAh /dev/serial/by-id
      apt policy udev
      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D201033S-if00-port0
      insgesamt 0
      lrwxrwxrwx 1 root root 13  8. Sep 20:00 usb-FTDI_FT230X_Basic_UART_D201033S-if00-port0 -> ../../ttyUSB0
      udev:
        Installiert:           247.3-7+deb11u4
        Installationskandidat: 247.3-7+deb11u4
        Versionstabelle:
       *** 247.3-7+deb11u4 500
              500 http://deb.debian.org/debian bullseye-updates/main arm64 Packages
              100 /var/lib/dpkg/status
           247.3-7+deb11u2 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      cas@raspberrypi:~ $
      Leider verbindet sich der Adapter trotzdem nicht
        Homoran Global Moderator Administrators @michihorn last edited by Homoran
        @michihorn dann bitte ein debug-log vom Adapterstart und die Konfiguration
          michihorn @Homoran last edited by michihorn
          smartmeter.0
          2023-09-08 20:22:46.712	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"D201033S","pnpId":"usb-FTDI_FT230X_Basic_UART_D201033S-if00-port0","vendorId":"0403","productId":"6015"}]
          smartmeter.0
          2023-09-08 20:22:20.029	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:22:20.026	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:20:11.513	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:20:11.510	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:18:41.370	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:18:41.368	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:17:11.285	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:17:11.254	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:15:41.131	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:15:41.107	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:14:10.553	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:14:10.460	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:13:39.990	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
          smartmeter.0
          2023-09-08 20:12:43.158	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          smartmeter.0
          2023-09-08 20:12:43.146	error	smartmeter.0 already running
          smartmeter.0
          2023-09-08 20:11:13.717	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:11:13.296	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:09:42.368	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:09:42.342	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:08:12.042	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:08:12.019	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:06:41.896	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:06:41.890	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2023-09-08 20:06:11.738	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
          smartmeter.0
          2023-09-08 20:06:02.604	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            Thomas Braun Most Active @michihorn last edited by
            @michihorn sagte in Adapter "smartmeter":
            Du hast gleich das Betriebssystem neuinstalliert?
            Ober warst du doch auf 32bit-armhf unterwegs und jetzt mit 64bit-arm64.
            Kommt da überhaupt ein Signal über die LED an?
              @michihorn lass mal alle sonstigen Einstellungen auf default, insbes. keine signon message, das macht der Adapter schon selbst.
              sollte in etwa so aussehen
                michihorn @Thomas Braun last edited by michihorn
                @thomas-braun ich hatte eh nur auf dieser installation den smartmeter-adapter und habe tatsächlich eine neue installation erstellt. Die LED am IR-Kopf blinkt unregelmäßig
                  @homoran Danke für den Screenshoot.
                  Super Danke der Adapter liefert nun Daten, ich könnte Dich knutschen... Grins
                  Kannst Du mir jetzt noch einen Screenshot der Objekte zeigen, damit ich sehe, was ankommen sollte ?
                    Das war nicht die dümmste Entscheidung.
                      jetzigen Konfiguration für die Nachwelt posten.
                      was kommt denn bei dir?
                      Dann kann man darauf aufbauen
                        @thomas-braun die neue installation hat die selbe Hardware, damit auch die selbe IP. Leider mag Putty damit nicht umgehen
                        Haste nen Tip
                            ssh freigeschaltet?
                            selber user?
                            selbes passwort? (default bei Installation geändert?)
                              @michihorn dann hast du die PIN nicht drin und INF nicht auf ON
                                @michihorn
                                Ich mag mit puTTY auch nicht umgehen. ssh keys erneuert?
                                  @homoran sagte in Adapter "smartmeter":
                                  PIN war definitiv drin und inf auf ON, kurze Zeit später war davon aber nichts mehr zu sehen
                                    @homoran Ja SSH habe ich bewusst eingeschaltet
                                    Habs gerade lösen können, ich habe per Konsole SSH aktiviert. Habe es nun per Externen Screen und UI-Desktop kontrolliert, da war SSH nicht aktiviert, aber jetzt geht auch Putty.
                                      dann hattest du es nicht bestätigt (langer Blink!)
                                      und die anderen Parameter?
                                        @homoran ich habe den PIN gerade nochmal eingegeben und nach fertigstellung lange geleuchtet, aktuell steht der Zähler auf On
                                          und deine Objekte sehen jetzt wie aus?
                                            Nur die Momentanlast ist nun neu...was sollte sonst noch zu sehen sein?
                                            3625
                                            2286751
