    4. [Neuer Adapter] mediola-gateway
      line @oelison last edited by Homoran
      @oelison anbei der Log. Hoffe es passt so. Danke
      2023-07-25 22:30:23.503 - info: host.raspberrypi stopInstance system.adapter.mediola-gateway.0 (force=false, process=true)
      2023-07-25 22:30:23.512 - info: mediola-gateway.0 (37773) Got terminate signal TERMINATE_YOURSELF
      2023-07-25 22:30:23.517 - info: mediola-gateway.0 (37773) terminating
      2023-07-25 22:30:23.519 - info: mediola-gateway.0 (37773) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-25 22:30:23.597 - info: host.raspberrypi stopInstance system.adapter.mediola-gateway.0 send kill signal
      2023-07-25 22:30:24.172 - info: host.raspberrypi instance system.adapter.mediola-gateway.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-25 22:30:26.790 - info: host.raspberrypi instance system.adapter.mediola-gateway.0 started with pid 37803
      2023-07-25 22:30:30.540 - debug: mediola-gateway.0 (37803) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-07-25 22:30:30.636 - debug: mediola-gateway.0 (37803) Objects client ready ... initialize now
      2023-07-25 22:30:30.644 - debug: mediola-gateway.0 (37803) Objects create System PubSub Client
      2023-07-25 22:30:30.648 - debug: mediola-gateway.0 (37803) Objects create User PubSub Client
      2023-07-25 22:30:30.780 - debug: mediola-gateway.0 (37803) Objects client initialize lua scripts
      2023-07-25 22:30:30.797 - debug: mediola-gateway.0 (37803) Objects connected to redis: 127.0.0.1:9001
      2023-07-25 22:30:30.843 - debug: mediola-gateway.0 (37803) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-07-25 22:30:30.866 - debug: mediola-gateway.0 (37803) States create System PubSub Client
      2023-07-25 22:30:30.869 - debug: mediola-gateway.0 (37803) States create User PubSub Client
      2023-07-25 22:30:30.953 - debug: mediola-gateway.0 (37803) States connected to redis: 127.0.0.1:9000
      2023-07-25 22:30:31.424 - info: mediola-gateway.0 (37803) starting. Version 0.1.4 (non-npm: oelison/ioBroker.mediola-gateway#more_info) in /opt/iobroker/node_modules/iobroker.mediola-gateway, node: v18.16.1, js-controller: 4.0.24
      2023-07-25 22:30:31.528 - info: mediola-gateway.0 (37803) auto detection: true
      2023-07-25 22:30:31.549 - debug: mediola-gateway.0 (37803) UDP socket listening on 0.0.0.0:1902
      2023-07-25 22:30:31.624 - debug: mediola-gateway.0 (37803) out RECEIVED: 192.168.178.53:1901 - DHCP:TRUE
      HWV:C3
      VER:1.24.0
      VID:FFFF
      IP:192.168.178.53
      SN:255.255.255.0
      GW:192.168.178.1
      DNS:192.168.178.1
      MAC:40-66-7a-00-89-2c
      |end
      2023-07-25 22:30:31.629 - info: mediola-gateway.0 (37803) DHCP:TRUE
      2023-07-25 22:30:31.630 - info: mediola-gateway.0 (37803) HWV:C3
      2023-07-25 22:30:31.631 - info: mediola-gateway.0 (37803) VER:1.24.0
      2023-07-25 22:30:31.632 - info: mediola-gateway.0 (37803) VID:FFFF
      2023-07-25 22:30:31.632 - info: mediola-gateway.0 (37803) IP:192.168.178.53
      2023-07-25 22:30:31.633 - info: mediola-gateway.0 (37803) SN:255.255.255.0
      2023-07-25 22:30:31.635 - info: mediola-gateway.0 (37803) GW:192.168.178.1
      2023-07-25 22:30:31.637 - info: mediola-gateway.0 (37803) DNS:192.168.178.1
      2023-07-25 22:30:31.638 - info: mediola-gateway.0 (37803) MAC:40-66-7a-00-89-2c
      2023-07-25 22:30:31.639 - info: mediola-gateway.0 (37803) NAME:AIO GATEWAY
      2023-07-25 22:30:31.640 - info: mediola-gateway.0 (37803)
      2023-07-25 22:30:31.641 - info: mediola-gateway.0 (37803) Mediola connected with ip:192.168.178.53 and mac:40-66-7a-00-89-2c
      2023-07-25 22:30:31.642 - debug: mediola-gateway.0 (37803) url request to mediola: http://192.168.178.53/command?XC_USER=xxx@xxx.de&XC_PASS=xxx&XC_FNC=getstates
      2023-07-25 22:30:31.887 - debug: mediola-gateway.0 (37803) {XC_SUC}[{"type":"BK","sid":"01","adr":"032753","config":"","state":""},{"type":"BK","sid":"02","adr":"032750","config":"","state":""},{"type":"BK","sid":"03","adr":"032752","config":"","state":""},{"type":"BK","sid":"04","adr":"032754","config":"","state":""}]
      2023-07-25 22:30:31.888 - debug: mediola-gateway.0 (37803) mediola device found data: {XC_SUC}[{"type":"BK","sid":"01","adr":"032753","config":"","state":""},{"type":"BK","sid":"02","adr":"032750","config":"","state":""},{"type":"BK","sid":"03","adr":"032752","config":"","state":""},{"type":"BK","sid":"04","adr":"032754","config":"","state":""}]
      2023-07-25 22:30:31.890 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"01","adr":"032753","config":"","state":""}
      2023-07-25 22:30:31.905 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"02","adr":"032750","config":"","state":""}
      2023-07-25 22:30:31.908 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"03","adr":"032752","config":"","state":""}
      2023-07-25 22:30:31.912 - debug: mediola-gateway.0 (37803) {"type":"BK","sid":"04","adr":"032754","config":"","state":""}
      oelison 2 Replies Last reply Reply Quote 0
      • oelison
        oelison @line last edited by
        @line said in [Neuer Adapter] mediola-gateway:
        anbei der Log.
        Perfekt. Habe den Adapter erweitert. Jetzt sollten die Objekte auftauchen.
        Steuern geht dann aber noch nicht. Hier nochmal der Link:
        https://github.com/oelison/ioBroker.mediola-gateway/tree/more_info
        • oelison
          @line Bitte eine PM an die Mailadresse vom Readme.md des Adapters. Dann können wir die Steuerbefehle vieleicht generieren.
          • oelison
            Hallo Mediola Nutzer, nach einiger arbeit mit KeuleHD (github user) und Line (in diesem Forum). Habe ich eine Version 1.0.0 herausgegeben. Die ersten RF Aktoren sind damit ansteuerbar. Das sind WIR (WR), Roto (BK) und Nobily (NY). Die WIR sind richtig gut. Die werden automatisch erkannt und können auch teil angesteuert werden (in 10% Schritten). Die BK werden automatisch erkannt, aber geht nur rauf, runter und stop. Die Nobily zicken noch etwas herum, da ist manuelle arbeit notwendig. Im Readme steht mehr dazu. Bitte mal testen, wenn noch jemand sowas hat. Oder andere, dann werde ich die Rollos gerne hinzufügen.
              rofo1968 @oelison last edited by
              @oelison Hallo, ich bin noch ein sehr neuer und daher unerfahrener iobrocker-nutzer. Derzeit habe ich drei Rolläden von Roto, die ich über das Mediola-Gateway bediene. Nach der Installation werden die Geräte ausgelesen und die Statuspunkte angelegt
              Wenn ich die Beschreibung richtig verstehe, sollte ein action Ordner vorhanden sein, dieser fehlt bei mir.
              oelison 1 Reply Last reply Reply Quote 0
              • oelison
                oelison @rofo1968 last edited by
                @rofo1968 Hallo. Sieht nach einem alten Stand aus. Ich habe vor kurzem die Version 1.0.1 released. Diese ist noch nicht in der Stable-liste. Bitte diese installieren.
                Wenn es dann noch nicht geht, bitte die Instanz auf Debug stellen und im log nach der Instanz filtern und hier posten.
                  @oelison Hallo, sieht jetzt perfekt aus, funktioniert auch alles!
                  Super Arbeit, vielen Dank!
                  oelison B 2 Replies Last reply Reply Quote 1
                  • oelison
                    @rofo1968 Super, das freut mich.
                    Ezifox 1 Reply Last reply Reply Quote 0
                    • Ezifox
                      Ezifox @oelison last edited by
                      @oelison
                      Hallo ich bin Neu hier und Anfänger im Iobroker.
                      Ich habe schon alles mögliche versucht,aber ich bekomme den Mediola Adapter nicht zum laufen.Hier die Logdatei ich hoffe Sie können mir auf den richtigen Weg führen.iobroker.2023-09-08.log
                      Danke Im Voraus
                      • oelison
                        oelison @Ezifox last edited by
                        Hallo @ezifox,
                        In dem log ist schön zu sehen, dass die Version 1.0.1 startet im Auto Mode. Anscheinend wird aber kein Mediola Gatway gefunden. Was für ein Gateway haben Sie denn? Kennen Sie die IP Adresse? Dann einfach mal diese eintragen und den Auto Mode abschalten. Bisher hat der Adapter aber das Gateway automatisch gefunden. Gruß Christian
                        • Ezifox
                          @oelison
                          Danke für die rasche Antwort.
                          Habe einen AIO GATEWAY V6 version: C3 (1.24.0)
                          Ich habe es mit der IP Adresse des Gateways 10.0.0.1 und der MAC Adresse versucht. Leider das selbe Ergebnis.
                          • oelison
                            @ezifox
                            Bitte mal im WebBrowser folgendes aufrufen:
                            http://10.0.0.1/command?XC_FNC=getstates
                            Da sollte dann sowas wie
                            {XC_SUC}[...]
                            Rauskommen.
                            • Ezifox
                              @oelison
                              Das ist die Antwort
                              {"XC_ERR":{"code":"000007","msg":"access denied"}}
                              • oelison
                                oelison @Ezifox last edited by oelison
                                @ezifox
                                Okay, dann musst Du einen Usernamen und ein Passwort vergeben haben. Dann wieder alles auf Auto und die anderen Hacken weg und Name und Passwort setzen.
                                Hiermit kann Name und Passwort getestet werden:
                                http://ip-of-mediola/command?XC_USER=username&XC_PASS=password&XC_FNC=getstates
                                ip-of-mediola ist ja klar und username und password ersetzen.
                                • Ezifox
                                  @oelison
                                  {XC_ERR}{"code":"010000"}
                                  Ich habe im Mediola Configtool nur ein Passwort vergeben, keinen Nutzernamen.
                                  • oelison
                                    @ezifox
                                    Versuchs mal mit admin als user. Das sollte der default user sein. Ich habe aber nur eine V4, da könnte das anders sein.
                                    Ezifox 1 Reply Last reply Reply Quote -1
                                    • Ezifox
                                      @oelison
                                      Ich hatte zuvor schon sämtliche User probiert.
                                      Admin,Admin,Root,email,etc… auch lehr gelassen, leider ohne Erfolg.
                                      Mit der App IQONTROL NEO komme ich auf den Gateway.
                                      • oelison
                                        @ezifox
                                        Bei meiner V4 ist die api immer ohne name und passwort, egal ob ich ein config passwort gesetzt habe oder nicht. Ist es möglich einen User anzulegen?
                                        • Ezifox
                                          @oelison
                                          Bin noch Anfänger. Brauche ich eine api für meinen Gateway und wo bekomme ich die?
                                          User finde ich nichts um einen anzulegen.
                                          • oelison
                                            @ezifox
                                            Mit dem Webaufruf hast Du die API ja schon verwendet. Das ist die Verbindung die mein Adapter verwendet.
                                            Weiter oben in diesem Thread sind ja die Erfolgsmeldungen von line, hier wurde name und passwort gesetzt und es war auch ein V6 (keine + soweit ich weiß).
                                            Wenn wir das debuggen wollen, dann solltest Du mir eine Mail schreiben. (siehe readme).
                                            Alternativ kannst Du das Passwort löschen, aber dann verlierst Du Deinen Cloud zugriff.
                                            133
                                            20109
