    3. Off Topic
    4. Fehlermeldung bei sudo apt update, was tun? [gelöst]
    • Duffy
      Duffy last edited by Duffy
      Hallo an Alle,
      ich wollte heute mal wieder ein sudo apt update ausfühern um meinen iob auf Stand zu halten.
      Dabei kam folgende Meldung (ab Zeile11):
      pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:6 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:7 https://repos.influxdata.com/debian bullseye InRelease
      Get:8 https://packages.grafana.com/oss/deb stable InRelease [5,983 B]
      Get:9 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
      Err:8 https://packages.grafana.com/oss/deb stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      Fetched 4,586 B in 3s (1,484 B/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      pi@raspberrypi:~ $
      Kann mir bitte jemand sagen wie ich das Problem, sollte es eins sei, beheben kann?
      Wenn ich beine Dashboards in Grafana anschaue scheint alles zu funtionieren.
      Für einen Tip wäre ich sehr dankbar.
      Gruß Duffy
      Thomas Braun falke69 Homoran 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Duffy last edited by
        @duffy
        Da bist du aber seit Monaten nicht mehr tätig geworden. Es gibt einen Thread 'Grafana Repository muss angepasst werden' (oder so ähnlich) dazu.
        • falke69
          falke69 @Duffy last edited by
          @duffy
          versuche mal
          sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 963FA27710458545
          Duffy 1 Reply Last reply Reply Quote 2
            Homoran Global Moderator Administrators @Duffy last edited by
            @duffy sagte in Fehlermeldung bei sudo apt update, was tun?:
            wie du richtig gesehen hast veht es um Grafana, nicht iobroker
            • Duffy
              Duffy @falke69 last edited by
              @falke69
              Vielen Dank, das werde ich gleich einmal versuchen.
              Ich habe in der Tat est vor 14 Tagen ein Sudo apt update durchgeführt aber vermutlich ist es mir dabei nicht aufgefallen.
              Jetzt ist der Fehler aber weg., vielen Dank an alle die geholfen haben.
              Gruß Duffy
