    3. Off Topic
    4. Docker buanet startet nicht mehr (Synology NAS)
      StefanRS @Marc Berg last edited by
      @marc-berg ja unter log sind Daten vorhanden. Die Festplatte ist nicht voll. Sind noch 1,xTB frei.
      • Marc Berg
        Marc Berg Most Active @StefanRS last edited by
        @stefanrs sagte in Docker buanet startet nicht mehr (Synology NAS):
        Naja, reinschauen in die aktuelle Log-Datei wäre schon nicht schlecht. Vielleicht gibt's da noch neue Erkenntnisse.
          @marc-berg : Anbei ein Auszug von den letzten Einträgen
          (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.033  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.070  - info: host.IOBroker instance system.adapter.mihome-vacuum.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.070  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.436  - info: host.IOBroker instance system.adapter.trashschedule.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.436  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.471  - info: host.IOBroker instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.471  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.472  - info: host.IOBroker instance system.adapter.tankerkoenig.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.472  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.524  - info: host.IOBroker instance system.adapter.denon.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.524  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.524  - info: host.IOBroker instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.556  - info: host.IOBroker instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.556  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.557  - info: host.IOBroker instance system.adapter.reolink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.557  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.582  - info: host.IOBroker instance system.adapter.reolink.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.583  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.761  - warn: host.IOBroker Cannot get view: Connection is closed.
          2023-09-08 17:56:21.762  - warn: host.IOBroker Cannot get view: Connection is closed.
          2023-09-08 17:56:21.763  - info: host.IOBroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.763  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.763  - info: host.IOBroker instance system.adapter.hue.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.764  - info: host.IOBroker All instances are stopped.
          2023-09-08 17:56:21.764  - info: host.IOBroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-08 17:56:21.764  - info: host.IOBroker instance system.adapter.telegram.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          • Marc Berg
            Hm, da kann ich nichts draus ablesen. Das Log ist auch nicht komplett. Ein vollständiger Durchlauf eines Startversuches wäre sicher besser zu sehen.
            • Glasfaser
              Glasfaser @StefanRS last edited by Glasfaser
              2023/09/08 19:02:30 stdout Existing installation of ioBroker detected in "/opt/iobroker".
              2023/09/08 19:02:32 stdout (Re)setting permissions (This might take a while! Please be patient!)... /opt/scripts/iobroker_startup.sh: line 231: 359 Killed chown -R "$setuid":"$setgid" /opt/iobroker
              Da stimmt etwas mit den Ordnerrechten nicht ... hast du ein Mount !?
              EDIT :
              so sieht es sonst aus ... mit Done :
              (Re)setting permissions (This might take a while! Please be patient!)... Done.
              Fixing "sudo-bug" by replacing sudo with gosu... Done.
                StefanRS @Glasfaser last edited by
                @glasfaser was genau meinst du mit Mount?
                Habe die Rechte nochmal überprüft. Steht alles auf lesen/schreiben. Zugriff ist vorhanden.
                  @marc-berg leider sind das die letzten Einträge. Ab dann ging es nicht mehr und er schreibt bzw. legt keinen neuen LOG mehr im Laufwerk ab.
                  • Glasfaser
                    ob der Ordner /opt/iobroker außerhalb vom Container ist
                    schonmal die Synology danach mal neu gestartet !?
                      @glasfaser danke für den Tipp mit dem Neustart von der NAS. Jetzt geht es wieder.
                      Peinlich, das hätte ich auch gleich machen können 🙂
                      • Glasfaser
                        @stefanrs
                        Was war jetzt damit !?
                        @glasfaser sagte in Docker buanet startet nicht mehr (Synology NAS):
                        So ganz Normal ist das nicht , da muß noch was passiert sein !
                          @glasfaser
                          der Ordner liegt genauso wie auf deinem Screenshot zu sehen ist. So sieht es bei mir auch aus (bis auf die Bezeichnung)
                          • Glasfaser
                            @stefanrs
                            OK ... dachte ich mir !
                            und wie schon geschrieben ... Normal ist das nicht !
                            Welche DSM Version hast du
                            und wieviel Container laufen !?
                              @glasfaser
                              es läuft nur der eine Container und ich habe Version 7.2-64570 drauf
                              • Glasfaser
                                @stefanrs
                                Top UpToDate 👍
                                Dann klemmte da etwas .... würde ich aber mal beobachten .. warum !
                                  @glasfaser
                                  Ja werde ich beobachten. Auf jeden Fall danke nochmal für deine Hilfe.
                                  Bin echt froh, dass es wieder geht. Mein ganzes Smart Home etc baut auf IOBroker auf.
                                  Hab schon Panik bekommen. Da sind einige Stunden für ins Lang gegangen 🙂
                                  mcBirne 1 Reply Last reply Reply Quote 0
                                  1859
