    4. [gelöst] ioBroker / Docker Desktop Mac / CCU3
      Schroeder0815 @Homoran last edited by
      Hi und danke für Eure Unterstützung.
      Bin mir da leider nicht ganz sicher, habe es andersrum gelesen (wie @Codierknecht scheinbar auch).
      Wenn ich mir die logs anschaue, habe ich auch das Gefühl, dass die HOST-Adresse rein muss:
      Mit Container Adresse:
      host.iobroker
      2023-09-10 10:01:33.973	info	Restart adapter system.adapter.hm-rpc.0 because enabled
      host.iobroker
      2023-09-10 10:01:33.973	info	instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      hm-rpc.0
      2023-09-10 10:01:33.445	info	Terminated (NO_ERROR): Without reason
      hm-rpc.0
      2023-09-10 10:01:33.444	info	terminating
      hm-rpc.0
      2023-09-10 10:01:33.439	error	Cannot call init: [http://172.17.0.4:2001, ""] connect EHOSTUNREACH 192.168.111.100:2001
      hm-rpc.0
      2023-09-10 10:01:33.438	error	Init not possible, going to stop: connect EHOSTUNREACH 192.168.111.100:2001
      hm-rpc.0
      2023-09-10 10:01:33.427	info	xmlrpc -> 192.168.111.100:2001/ init ["http://172.17.0.4:2001",""]
      hm-rpc.0
      2023-09-10 10:01:03.427	error	Init not possible, going to stop: connect EHOSTUNREACH 192.168.111.100:2001
      hm-rpc.0
      2023-09-10 10:01:00.356	info	xmlrpc client is trying to connect to 192.168.111.100:2001/ with ["http://172.17.0.4:2001","iobroker:hm-rpc.0:ed30ea53223ef071e7ab3cabfea10f05"]
      hm-rpc.0
      2023-09-10 10:01:00.355	info	xmlrpc server is trying to listen on 172.17.0.4:2001
      hm-rpc.0
      2023-09-10 10:01:00.284	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 4.0.24
      host.iobroker
      2023-09-10 10:00:59.325	info	instance system.adapter.hm-rpc.0 started with pid 39962
      host.iobroker
      2023-09-10 10:00:59.204	info	"system.adapter.hm-rpc.0" enabled
      Mit HOST-Adresse:
      hm-rpc.0
      2023-09-10 10:05:00.026	error	Init not possible, going to stop: connect EHOSTUNREACH 192.168.111.100:2001
      hm-rpc.0
      2023-09-10 10:04:56.930	info	xmlrpc client is trying to connect to 192.168.111.100:2001/ with ["http://192.168.111.101:2001","iobroker:hm-rpc.0:cdd4f889935e7530fe64216777cecdab"]
      hm-rpc.0
      2023-09-10 10:04:56.929	info	xmlrpc server is trying to listen on 172.17.0.4:2001
      hm-rpc.0
      2023-09-10 10:04:56.865	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.1, js-controller: 4.0.24
      host.iobroker
      2023-09-10 10:04:55.998	info	instance system.adapter.hm-rpc.0 started with pid 40216
      host.iobroker
      2023-09-10 10:04:55.949	info	"system.adapter.hm-rpc.0" enabled
      admin.0
      2023-09-10 10:04:42.743	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1
      admin.0
      2023-09-10 10:04:22.651	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      host.iobroker
      2023-09-10 10:04:21.906	info	instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.iobroker
      2023-09-10 10:04:21.627	info	stopInstance system.adapter.hm-rpc.0 killing pid 40165
      hm-rpc.0
      2023-09-10 10:04:21.370	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      hm-rpc.0
      2023-09-10 10:04:21.369	info	terminating
      Es bleibt aber nach wie vor so, dass scheinbar die Zieladresse, also die CCU3 nich5 erreichbar scheint.
      Bisher habe ich nur mit Node red als addon (Redmatic) auf der CCU3 gearbeitet, also beides auf gleichem HOST-System ohne übers Netz zu gehen.
      Irgend ne Idee wie testen kann ob die Ports auf der CCU3 erreichbar sind und wie ich es ggf. gangbar machen kann, falls es so wäre?
      Danke und Gruß,
      Der Schroeder
      • Marc Berg
        Marc Berg Most Active @Schroeder0815 last edited by Marc Berg
        @schroeder0815 sagte in ioBroker / Docker / CCU3:
        Eine Möglichkeit wäre, telnet in den ioBroker Container zu installieren und damit zu testen:
        apt update
        apt install telnet
        telnet 192.168.111.100 2001
        Achtung, kein Doppelpunkt vor "2001"!
        Wenn der Port nicht erreichbar ist, bekommst du eine "Connection refused" Meldung.
        Edit: das funktioniert nur, wenn über TCP (nicht UDP) kommuniziert wird, davon gehe ich aber mal aus.
          Schroeder0815 @Marc Berg last edited by Schroeder0815
          @marc-berg
          So jetzt bin ich komplett verwirrt…..
          Komme scheinbar nicht vom Container auf die CCU3…
          bekomme als Rückmeldung: no Route to host
          Und zwar egal mit welchem Port ich es versuche…
          Versuche ich über Telnet Port 80 meine FritzBox zu erreichen, funktioniert es.
          Auch mit einem Ping komme ich vom Container nicht mehr an die CCU3.
          Nutze ich Telnet von einem RasPi zur CCU3, wird eine Verbindung hergestellt. Scheint also doch nicht an der CCU3 zu liegen sondern doch am Docker….
          Habe den Container num mit folgendem Port-mapping neu erstellt:
          172.17.0.4 8701:87019292:92922001:20012010:201023:238081:8081
          Die 23 hab ich nur drin weil Telnet den standardmäßig nutzt
          Leider weiterhin ohne Erfolg
          Keine Ahnung woran das liegt.
          Der Schroeder
          • Marc Berg
            Marc Berg Most Active last edited by Marc Berg
            Bitte den kompletten In- und Output zeigen.
              @marc-berg
              Ich hoffen du meinst diesen:
              # telnet 192.168.111.100 2001
              Trying 192.168.111.100...
              telnet: Unable to connect to remote host: No route to host
              # telnet 192.168.111.100 80
              # telnet 192.168.111.1 80
              Trying 192.168.111.1...
              Connected to 192.168.111.1.
              Escape character is '^]'.
              EDIT:
              hier der Pingversuch:
              # ping 192.168.111.100
              PING 192.168.111.100 (192.168.111.100) 56(84) bytes of data.
              From 192.168.111.2 icmp_seq=1 Destination Host Unreachable
              From 192.168.111.2 icmp_seq=2 Destination Host Unreachable
              From 192.168.111.2 icmp_seq=3 Destination Host Unreachable
              From 192.168.111.2 icmp_seq=4 Destination Host Unreachable
              From 192.168.111.2 icmp_seq=5 Destination Host Unreachable
              From 192.168.111.2 icmp_seq=6 Destination Host Unreachable
              192.168.111.2 ist eigentlich eine 2te FB die per Kabel (D-Lan) mit der 1ten Verbunden ist und die CCU3 hängt per Kabel an der 2ten.
              PING 192.168.111.1 (192.168.111.1) 56(84) bytes of data.
              64 bytes from 192.168.111.1: icmp_seq=1 ttl=62 time=4.21 ms
              64 bytes from 192.168.111.1: icmp_seq=2 ttl=62 time=6.98 ms
              64 bytes from 192.168.111.1: icmp_seq=3 ttl=62 time=0.566 ms
              64 bytes from 192.168.111.1: icmp_seq=4 ttl=62 time=0.711 ms
              ^C
              --- 192.168.111.1 ping statistics ---
              4 packets transmitted, 4 received, 0% packet loss, time 3034ms
              rtt min/avg/max/mdev = 0.566/3.115/6.980/2.664 ms
              # ping 192.168.111.2
              PING 192.168.111.2 (192.168.111.2) 56(84) bytes of data.
              64 bytes from 192.168.111.2: icmp_seq=1 ttl=63 time=0.225 ms
              64 bytes from 192.168.111.2: icmp_seq=2 ttl=63 time=0.114 ms
              64 bytes from 192.168.111.2: icmp_seq=3 ttl=63 time=0.119 ms
              ^C
              --- 192.168.111.2 ping statistics ---
              3 packets transmitted, 3 received, 0% packet loss, time 2034ms
              rtt min/avg/max/mdev = 0.114/0.152/0.225/0.051 ms
              Denke und Gruß,
              Der Schroeder
              • Marc Berg
                Ja, das meinte ich. Das ist jetzt natürlich nicht normal, und du schreibst ja auch, dass der Ping schon mal funktionierte.
                Da scheint das Routing schief zu sein, wenn die zweite FB die CCU nicht mehr erreicht. Welchen Weg gehen die Geräte, bei denen der Ping funktioniert? Auch 1. FB-->2. FB-->CCU?
                  @marc-berg
                  hier der funktionierende output vom Pi:
                  pi@Pi-hole:~ $ telnet 192.168.111.100 2001
                  Connected to 192.168.111.100.
                  der Pi hat im Prinzip den gleichen Weg, da er per Kabel an der 1ten FB hängt.
                  also Pi -> FB1 -> FB2 -> CCU3
                  ioBroker-Container -> Host -> FB1 -> FB2 -> CCU3
                  Einziger unterschied ist eben der Docker Container un, dass der Docker HOST per WLAN / WiFi verbunden ist.
                  EDIT:
                  Bin jetzt LEIDER mal ne zeitlang offline, da ich wo anders ein IT Problem lösen muss...:-)
                  Trotzdem schonmal danke und Gruß,
                  Der Schroeder
                  Marc Berg Glasfaser 2 Replies Last reply Reply Quote 0
                  • Marc Berg
                    Wow, das ist ja mal ein Weg ...
                    Container --> Docker --> Mac OS --> WLAN --> Fritzbox 1 ---> Powerline --> Fritzbox 2 --> CCU (und zurück)
                    Sollte aber trotzdem funktionieren, wenn es nicht grob verkonfiguriert ist. Habe aber keine Idee mehr, außer einen Reboot aller Komponenten.
                    Edit:
                    Na dann hoffe ich für dich, dass "wo anders" die Welt einfacher aussieht ... 😉
                      @marc-berg
                      Den werde ich später mal versuchen, wenn die Frau und kinder mal nicht den Hals umdrehen, weil das Netzt währenddessen ausfällt.
                      Der Weg ist nicht ganz so kompliziert da der Mac im WLAN der FB2 hängt.
                      Container --> Docker --> Mac OS --> WLAN --> Fritzbox 2 --> CCU (und zurück)
                      Aber alles andere funktioniert im Netz.....
                      Gruß!
                        ich hab da dunkel etwas im Hinterkopf bei kaskadierten Fritzboxen
                        vereinfacht
                        WAN - FB1 - FB2
                        dann könnenGeräte an der FB2 auf Geräte der FB1 zugreifen, aber nicht umgekehrt.
                        • Marc Berg
                          Hm ...
                          Hier: https://forum.iobroker.net/post/1041914
                          schreibst du aber, dass der Host (ich dachte, das wäre der Mac!?), an FB1 hängt. Kann aber sein, dass ich deinen Aufbau falsch verstanden habe.
                          • Glasfaser
                            Glasfaser @Schroeder0815 last edited by Glasfaser
                            pi@ Pi-hole
                            Schalte den mal aus oder wofür ist der !
                            Als erstes vorweg, ich bin neu in ioBroker & Docker,
                            ich lese jetzt nicht alles durch , denn der Aufbau ist recht komplex bei dir !
                              @marc-berg said in ioBroker / Docker / CCU3:
                              Hm ...
                              Das ist richtig… mein Fehler…. War auch mein Gedanke, da beide im gleichen Stockwerk sind (Keller), der Mac hat sich aber trotzdem mit FB2 im EG verbunden.
                              Jetzt bin ich aber weg… 🙂
                              Danke und Gruß,
                              Der Schroeder
                                Homoran Global Moderator Administrators @Glasfaser last edited by
                                @glasfaser sagte in ioBroker / Docker / CCU3:
                                Pi-hole
                                ADLERAUGE!!
                                Da sind wir wieder beim Thema alle relevanten Dinge in einer Installation und deren Umgebung im Eröffnungspost zu nennen.
                                @Schroeder0815
                                das hier hast du doch sicher schon gelesen
                                  @homoran said in ioBroker / Docker / CCU3:
                                  Pi-hole
                                  ADLERAUGE!!
                                  @Schroeder0815
                                  Der Pi-hole ist aus der FB raus genommen (also DNS auf Standard zurück gesetzt), habe ihn nur reaktiviert um eine Alternative zum testen zu haben…..
                                  • Glasfaser
                                    Du hast was beigefügt
                                    Bitte nicht den bestehenden Post verändern .
                                    Dann eher mit einem
                                    EDIT : !!!
                                    • Glasfaser
                                      in Docker auf einem MacBookPro (HOST-IP. 192.168.111.101 / Container 172.17.0.4
                                      Womit hast du diesen Container erstellt , nutzt du Portainer.
                                      Hast du MACVLAN oder ... Bridge ... oder ...
                                      Hier mal ein Hinweis :
                                      https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2259
                                      Kannst du das nicht einstellen :
                                        Schroeder0815 @Glasfaser last edited by Schroeder0815
                                        @glasfaser
                                        Hi Leute,
                                        Bin wieder zurück und war „woanders“ erfolgreicher als zuhause… 😂
                                        Komme heute leider nicht mehr dazu eure Ideen und Tipps zu probieren, da mich Frau und Kinder um die Ecke bringen wenn ich jetzt am Netzwerk basteln würde.
                                        Werde mir aber alles anschauen, testen und mich wieder melden.
                                        Gelobe auch Besserung mit dem EDIT.
                                        Danke nochmal für eure Unterstützung und hoffe es bleibt so, wenn weiter testen kann.
                                        Gruß,
                                        Der Schroeder
                                          @glasfaser
                                          Ich habe den Docker Desktop auf dem Mac installiert und den Container per Terminal mit folgendem Befehl gestartet:
                                          docker run -it -p 8081:8081 -p 2001:2001 -p 2010:2010 -p 9292:9292 -p 8701:8701 -p 23:23 --name ioBroker --privileged --restart=unless-stopped -v iobroker:/opt/iobroker -h iobroker buanet/iobroker
                                          Weiter nutze ich ebenfalls Portainer, aber MACVLAN oder Bridge sagt mir garnix.
                                          Die Umstellung auf
                                          Hat leider keinen Erfolg gebracht.
                                          Danke und Gruß,
                                          Der Schroeder
                                            Schroeder0815 @Schroeder0815 last edited by Schroeder0815
                                            @schroeder0815
                                            Ok, so wie ich das sehe, verwende ich Bridge, die vom Docker selbstständig erstellt wurde.
                                            Aber ist es nicht so, dass dies zur Kommunikation der Container untereinander dient?
                                            Danke und Gruß,
                                            Der Schroeder
                                            EDIT
                                            Der NodeRed Container bekommt auch keine Verbindung zur CCU3, wäre aber eine Baustelle, nachdem der ioBroker läuft.
                                            Hat aber auch noch keine Ports weitergeleitet bekommen.
                                            EDIT2
                                            oder ist es ggf. sinnvoller Node red innerhalb von ioBroker laufen zu lassen
                                            1190
