    4. [gelöst] ioBroker / Docker Desktop Mac / CCU3
    • Marc Berg
      Marc Berg Most Active last edited by Marc Berg
      @schroeder0815 sagte in ioBroker / Docker / CCU3:
      Komme scheinbar nicht vom Container auf die CCU3…
      bekomme als Rückmeldung: no Route to host
      Bitte den kompletten In- und Output zeigen.
        Schroeder0815 @Marc Berg last edited by Schroeder0815
        @marc-berg
        Ich hoffen du meinst diesen:
        # telnet 192.168.111.100 2001
        Trying 192.168.111.100...
        telnet: Unable to connect to remote host: No route to host
        # telnet 192.168.111.100 80
        # telnet 192.168.111.1 80
        Trying 192.168.111.1...
        Connected to 192.168.111.1.
        Escape character is '^]'.
        EDIT:
        hier der Pingversuch:
        # ping 192.168.111.100
        PING 192.168.111.100 (192.168.111.100) 56(84) bytes of data.
        From 192.168.111.2 icmp_seq=1 Destination Host Unreachable
        From 192.168.111.2 icmp_seq=2 Destination Host Unreachable
        From 192.168.111.2 icmp_seq=3 Destination Host Unreachable
        From 192.168.111.2 icmp_seq=4 Destination Host Unreachable
        From 192.168.111.2 icmp_seq=5 Destination Host Unreachable
        From 192.168.111.2 icmp_seq=6 Destination Host Unreachable
        192.168.111.2 ist eigentlich eine 2te FB die per Kabel (D-Lan) mit der 1ten Verbunden ist und die CCU3 hängt per Kabel an der 2ten.
        PING 192.168.111.1 (192.168.111.1) 56(84) bytes of data.
        64 bytes from 192.168.111.1: icmp_seq=1 ttl=62 time=4.21 ms
        64 bytes from 192.168.111.1: icmp_seq=2 ttl=62 time=6.98 ms
        64 bytes from 192.168.111.1: icmp_seq=3 ttl=62 time=0.566 ms
        64 bytes from 192.168.111.1: icmp_seq=4 ttl=62 time=0.711 ms
        ^C
        --- 192.168.111.1 ping statistics ---
        4 packets transmitted, 4 received, 0% packet loss, time 3034ms
        rtt min/avg/max/mdev = 0.566/3.115/6.980/2.664 ms
        # ping 192.168.111.2
        PING 192.168.111.2 (192.168.111.2) 56(84) bytes of data.
        64 bytes from 192.168.111.2: icmp_seq=1 ttl=63 time=0.225 ms
        64 bytes from 192.168.111.2: icmp_seq=2 ttl=63 time=0.114 ms
        64 bytes from 192.168.111.2: icmp_seq=3 ttl=63 time=0.119 ms
        ^C
        --- 192.168.111.2 ping statistics ---
        3 packets transmitted, 3 received, 0% packet loss, time 2034ms
        rtt min/avg/max/mdev = 0.114/0.152/0.225/0.051 ms
        Denke und Gruß,
        Der Schroeder
        • Marc Berg
          Marc Berg Most Active @Schroeder0815 last edited by Marc Berg
          Ja, das meinte ich. Das ist jetzt natürlich nicht normal, und du schreibst ja auch, dass der Ping schon mal funktionierte.
          Da scheint das Routing schief zu sein, wenn die zweite FB die CCU nicht mehr erreicht. Welchen Weg gehen die Geräte, bei denen der Ping funktioniert? Auch 1. FB-->2. FB-->CCU?
            @marc-berg
            hier der funktionierende output vom Pi:
            pi@Pi-hole:~ $ telnet 192.168.111.100 2001
            Connected to 192.168.111.100.
            der Pi hat im Prinzip den gleichen Weg, da er per Kabel an der 1ten FB hängt.
            also Pi -> FB1 -> FB2 -> CCU3
            ioBroker-Container -> Host -> FB1 -> FB2 -> CCU3
            Einziger unterschied ist eben der Docker Container un, dass der Docker HOST per WLAN / WiFi verbunden ist.
            EDIT:
            Bin jetzt LEIDER mal ne zeitlang offline, da ich wo anders ein IT Problem lösen muss...:-)
            Trotzdem schonmal danke und Gruß,
            Der Schroeder
            Marc Berg Glasfaser 2 Replies Last reply Reply Quote 0
            • Marc Berg
              Wow, das ist ja mal ein Weg ...
              Container --> Docker --> Mac OS --> WLAN --> Fritzbox 1 ---> Powerline --> Fritzbox 2 --> CCU (und zurück)
              Sollte aber trotzdem funktionieren, wenn es nicht grob verkonfiguriert ist. Habe aber keine Idee mehr, außer einen Reboot aller Komponenten.
              Edit:
              Na dann hoffe ich für dich, dass "wo anders" die Welt einfacher aussieht ... 😉
                @marc-berg
                Den werde ich später mal versuchen, wenn die Frau und kinder mal nicht den Hals umdrehen, weil das Netzt währenddessen ausfällt.
                Der Weg ist nicht ganz so kompliziert da der Mac im WLAN der FB2 hängt.
                Container --> Docker --> Mac OS --> WLAN --> Fritzbox 2 --> CCU (und zurück)
                Aber alles andere funktioniert im Netz.....
                Gruß!
                  ich hab da dunkel etwas im Hinterkopf bei kaskadierten Fritzboxen
                  vereinfacht
                  WAN - FB1 - FB2
                  dann könnenGeräte an der FB2 auf Geräte der FB1 zugreifen, aber nicht umgekehrt.
                  • Marc Berg
                    Hm ...
                    Hier: https://forum.iobroker.net/post/1041914
                    schreibst du aber, dass der Host (ich dachte, das wäre der Mac!?), an FB1 hängt. Kann aber sein, dass ich deinen Aufbau falsch verstanden habe.
                    • Glasfaser
                      Glasfaser @Schroeder0815 last edited by Glasfaser
                      pi@ Pi-hole
                      Schalte den mal aus oder wofür ist der !
                      Als erstes vorweg, ich bin neu in ioBroker & Docker,
                      ich lese jetzt nicht alles durch , denn der Aufbau ist recht komplex bei dir !
                        @marc-berg said in ioBroker / Docker / CCU3:
                        Hm ...
                        Das ist richtig… mein Fehler…. War auch mein Gedanke, da beide im gleichen Stockwerk sind (Keller), der Mac hat sich aber trotzdem mit FB2 im EG verbunden.
                        Jetzt bin ich aber weg… 🙂
                        Danke und Gruß,
                        Der Schroeder
                          Homoran Global Moderator Administrators @Glasfaser last edited by
                          @glasfaser sagte in ioBroker / Docker / CCU3:
                          Pi-hole
                          ADLERAUGE!!
                          Da sind wir wieder beim Thema alle relevanten Dinge in einer Installation und deren Umgebung im Eröffnungspost zu nennen.
                          @Schroeder0815
                          das hier hast du doch sicher schon gelesen
                            Schroeder0815 @Homoran last edited by
                            @homoran said in ioBroker / Docker / CCU3:
                            Pi-hole
                            ADLERAUGE!!
                            @Schroeder0815
                            Der Pi-hole ist aus der FB raus genommen (also DNS auf Standard zurück gesetzt), habe ihn nur reaktiviert um eine Alternative zum testen zu haben…..
                            • Glasfaser
                              Du hast was beigefügt
                              Bitte nicht den bestehenden Post verändern .
                              Dann eher mit einem
                              EDIT : !!!
                              • Glasfaser
                                in Docker auf einem MacBookPro (HOST-IP. 192.168.111.101 / Container 172.17.0.4
                                Womit hast du diesen Container erstellt , nutzt du Portainer.
                                Hast du MACVLAN oder ... Bridge ... oder ...
                                Hier mal ein Hinweis :
                                https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2259
                                Kannst du das nicht einstellen :
                                  Schroeder0815 @Glasfaser last edited by Schroeder0815
                                  @glasfaser
                                  Hi Leute,
                                  Bin wieder zurück und war „woanders“ erfolgreicher als zuhause… 😂
                                  Komme heute leider nicht mehr dazu eure Ideen und Tipps zu probieren, da mich Frau und Kinder um die Ecke bringen wenn ich jetzt am Netzwerk basteln würde.
                                  Werde mir aber alles anschauen, testen und mich wieder melden.
                                  Gelobe auch Besserung mit dem EDIT.
                                  Danke nochmal für eure Unterstützung und hoffe es bleibt so, wenn weiter testen kann.
                                  Gruß,
                                  Der Schroeder
                                    @glasfaser
                                    Ich habe den Docker Desktop auf dem Mac installiert und den Container per Terminal mit folgendem Befehl gestartet:
                                    docker run -it -p 8081:8081 -p 2001:2001 -p 2010:2010 -p 9292:9292 -p 8701:8701 -p 23:23 --name ioBroker --privileged --restart=unless-stopped -v iobroker:/opt/iobroker -h iobroker buanet/iobroker
                                    Weiter nutze ich ebenfalls Portainer, aber MACVLAN oder Bridge sagt mir garnix.
                                    Die Umstellung auf
                                    Hat leider keinen Erfolg gebracht.
                                    Danke und Gruß,
                                    Der Schroeder
                                      Schroeder0815 @Schroeder0815 last edited by Schroeder0815
                                      @schroeder0815
                                      Ok, so wie ich das sehe, verwende ich Bridge, die vom Docker selbstständig erstellt wurde.
                                      Aber ist es nicht so, dass dies zur Kommunikation der Container untereinander dient?
                                      Danke und Gruß,
                                      Der Schroeder
                                      EDIT
                                      Der NodeRed Container bekommt auch keine Verbindung zur CCU3, wäre aber eine Baustelle, nachdem der ioBroker läuft.
                                      Hat aber auch noch keine Ports weitergeleitet bekommen.
                                      EDIT2
                                      oder ist es ggf. sinnvoller Node red innerhalb von ioBroker laufen zu lassen
                                        vereinfacht
                                        WAN - FB1 - FB2
                                        Bist du sicher?
                                        Dachte das wäre über mesh nicht so, konnte von der CCU3 mit RedMatic (node red) auch auf Endgeräte zugreifen, die per WLAN an der FB1 hängen
                                          Homoran Global Moderator Administrators @Schroeder0815 last edited by
                                          weiss ich denn wie du das verdrahtet hast?
                                            Da ich offensichtlich zu wenig über den Aufbau meines Netzwerks geschrieben habe, möchte ich dies jetzt nachholen….
                                            Ich betreibe 3 FRITZ!Boxen in meinem Netzwerk
                                            FB1 (7530 AX - Keller) Kommunikation zum Internet (Glasfaseranschluss über ein Modem des Netzanbieters)
                                            FB2 (7530 - EG)
                                            FB3 (7569 - 2OG)
                                            Alle drei sind per Powerlan (TP-Link TL-P4010P) in einem Mesh Netzwerk.
                                            Der ioBroker läuft in einem Docker auf einem Mac welcher über Docker Desktop per Terminal gestartet wurde.
                                            Der Mac ist per WLAN verbunden meist mit FB2 (obwohl er im Keller ist) wird sich aber immer das beste Signal greifen.
                                            Die CCU3 ist per weiterem Switch mit einem Kabel mit der FB2 verbunden.
                                            Bisherige Nutzung war CCU3 mit RaspberryMatic und Redmatic (Node Red Add-on) ohne Probleme.
                                            Diverse Homematic (inkl. IP) Geräte, sowie Zigbee (Redmatic Zigbee2mqtt) als auch WiFi Steckdosen und andere Geräte (wahllos im WLAN aller FRITZ!Boxen Verteilt).
                                            Da RedMatic veraltet ist und nicht weiter Supported wird, kam der Wunsch nach einer anderen Lösung.
                                            Mit dem ioBroker habe ich schon lange geliebäugelt, wollte aber eigentlich kein weiteres Gerät nutzen.
                                            Nun bin ich umsonst an das MacBookPro rangekommen und dachte ich teste mal.
                                            Das MAcBookPro wurde dank OpenCore Lagacy Patcher auf MacOS Ventura gebracht und läuft einwandfrei.
                                            Alle Geräte (FB/CCU/Endgeräte) laufen mit aktuellster Firm- bzw- Software.
                                            Hoffe ich habe es ausführlich genug beschrieben, falls nicht bitte melden und ich ergänze was ich kann.
                                            Gruß,
                                            Der Schroeder
                                            1190
