    4. [gelöst] ioBroker / Docker Desktop Mac / CCU3
      Schroeder0815 @Marc Berg last edited by Schroeder0815
      @marc-berg
      Ich hoffen du meinst diesen:
      # telnet 192.168.111.100 2001
      Trying 192.168.111.100...
      telnet: Unable to connect to remote host: No route to host
      # telnet 192.168.111.100 80
      # telnet 192.168.111.1 80
      Trying 192.168.111.1...
      Connected to 192.168.111.1.
      Escape character is '^]'.
      EDIT:
      hier der Pingversuch:
      # ping 192.168.111.100
      PING 192.168.111.100 (192.168.111.100) 56(84) bytes of data.
      From 192.168.111.2 icmp_seq=1 Destination Host Unreachable
      From 192.168.111.2 icmp_seq=2 Destination Host Unreachable
      From 192.168.111.2 icmp_seq=3 Destination Host Unreachable
      From 192.168.111.2 icmp_seq=4 Destination Host Unreachable
      From 192.168.111.2 icmp_seq=5 Destination Host Unreachable
      From 192.168.111.2 icmp_seq=6 Destination Host Unreachable
      192.168.111.2 ist eigentlich eine 2te FB die per Kabel (D-Lan) mit der 1ten Verbunden ist und die CCU3 hängt per Kabel an der 2ten.
      PING 192.168.111.1 (192.168.111.1) 56(84) bytes of data.
      64 bytes from 192.168.111.1: icmp_seq=1 ttl=62 time=4.21 ms
      64 bytes from 192.168.111.1: icmp_seq=2 ttl=62 time=6.98 ms
      64 bytes from 192.168.111.1: icmp_seq=3 ttl=62 time=0.566 ms
      64 bytes from 192.168.111.1: icmp_seq=4 ttl=62 time=0.711 ms
      ^C
      --- 192.168.111.1 ping statistics ---
      4 packets transmitted, 4 received, 0% packet loss, time 3034ms
      rtt min/avg/max/mdev = 0.566/3.115/6.980/2.664 ms
      # ping 192.168.111.2
      PING 192.168.111.2 (192.168.111.2) 56(84) bytes of data.
      64 bytes from 192.168.111.2: icmp_seq=1 ttl=63 time=0.225 ms
      64 bytes from 192.168.111.2: icmp_seq=2 ttl=63 time=0.114 ms
      64 bytes from 192.168.111.2: icmp_seq=3 ttl=63 time=0.119 ms
      ^C
      --- 192.168.111.2 ping statistics ---
      3 packets transmitted, 3 received, 0% packet loss, time 2034ms
      rtt min/avg/max/mdev = 0.114/0.152/0.225/0.051 ms
      Denke und Gruß,
      Der Schroeder
      • Marc Berg
        Marc Berg Most Active @Schroeder0815 last edited by Marc Berg
        @schroeder0815 sagte in ioBroker / Docker / CCU3:
        Ja, das meinte ich. Das ist jetzt natürlich nicht normal, und du schreibst ja auch, dass der Ping schon mal funktionierte.
        Da scheint das Routing schief zu sein, wenn die zweite FB die CCU nicht mehr erreicht. Welchen Weg gehen die Geräte, bei denen der Ping funktioniert? Auch 1. FB-->2. FB-->CCU?
          @marc-berg
          hier der funktionierende output vom Pi:
          pi@Pi-hole:~ $ telnet 192.168.111.100 2001
          Connected to 192.168.111.100.
          der Pi hat im Prinzip den gleichen Weg, da er per Kabel an der 1ten FB hängt.
          also Pi -> FB1 -> FB2 -> CCU3
          ioBroker-Container -> Host -> FB1 -> FB2 -> CCU3
          Einziger unterschied ist eben der Docker Container un, dass der Docker HOST per WLAN / WiFi verbunden ist.
          EDIT:
          Bin jetzt LEIDER mal ne zeitlang offline, da ich wo anders ein IT Problem lösen muss...:-)
          Trotzdem schonmal danke und Gruß,
          Der Schroeder
          Marc Berg Glasfaser 2 Replies Last reply Reply Quote 0
          • Marc Berg
            Wow, das ist ja mal ein Weg ...
            Container --> Docker --> Mac OS --> WLAN --> Fritzbox 1 ---> Powerline --> Fritzbox 2 --> CCU (und zurück)
            Sollte aber trotzdem funktionieren, wenn es nicht grob verkonfiguriert ist. Habe aber keine Idee mehr, außer einen Reboot aller Komponenten.
            Edit:
            Na dann hoffe ich für dich, dass "wo anders" die Welt einfacher aussieht ... 😉
              @marc-berg
              Den werde ich später mal versuchen, wenn die Frau und kinder mal nicht den Hals umdrehen, weil das Netzt währenddessen ausfällt.
              Der Weg ist nicht ganz so kompliziert da der Mac im WLAN der FB2 hängt.
              Container --> Docker --> Mac OS --> WLAN --> Fritzbox 2 --> CCU (und zurück)
              Aber alles andere funktioniert im Netz.....
              Gruß!
                ich hab da dunkel etwas im Hinterkopf bei kaskadierten Fritzboxen
                vereinfacht
                WAN - FB1 - FB2
                dann könnenGeräte an der FB2 auf Geräte der FB1 zugreifen, aber nicht umgekehrt.
                • Marc Berg
                  Hm ...
                  Hier: https://forum.iobroker.net/post/1041914
                  schreibst du aber, dass der Host (ich dachte, das wäre der Mac!?), an FB1 hängt. Kann aber sein, dass ich deinen Aufbau falsch verstanden habe.
                  • Glasfaser
                    Glasfaser @Schroeder0815 last edited by Glasfaser
                    pi@ Pi-hole
                    Schalte den mal aus oder wofür ist der !
                    Als erstes vorweg, ich bin neu in ioBroker & Docker,
                    ich lese jetzt nicht alles durch , denn der Aufbau ist recht komplex bei dir !
                      @marc-berg said in ioBroker / Docker / CCU3:
                      Hm ...
                      Das ist richtig… mein Fehler…. War auch mein Gedanke, da beide im gleichen Stockwerk sind (Keller), der Mac hat sich aber trotzdem mit FB2 im EG verbunden.
                      Jetzt bin ich aber weg… 🙂
                      Danke und Gruß,
                      Der Schroeder
                        Homoran Global Moderator Administrators @Glasfaser last edited by
                        @glasfaser sagte in ioBroker / Docker / CCU3:
                        Pi-hole
                        ADLERAUGE!!
                        Da sind wir wieder beim Thema alle relevanten Dinge in einer Installation und deren Umgebung im Eröffnungspost zu nennen.
                        @Schroeder0815
                        das hier hast du doch sicher schon gelesen
                          Schroeder0815 @Homoran last edited by
                          @homoran said in ioBroker / Docker / CCU3:
                          Pi-hole
                          ADLERAUGE!!
                          @Schroeder0815
                          Der Pi-hole ist aus der FB raus genommen (also DNS auf Standard zurück gesetzt), habe ihn nur reaktiviert um eine Alternative zum testen zu haben…..
                          • Glasfaser
                            Du hast was beigefügt
                            Bitte nicht den bestehenden Post verändern .
                            Dann eher mit einem
                            EDIT : !!!
                            • Glasfaser
                              in Docker auf einem MacBookPro (HOST-IP. 192.168.111.101 / Container 172.17.0.4
                              Womit hast du diesen Container erstellt , nutzt du Portainer.
                              Hast du MACVLAN oder ... Bridge ... oder ...
                              Hier mal ein Hinweis :
                              https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2259
                              Kannst du das nicht einstellen :
                                Schroeder0815 @Glasfaser last edited by Schroeder0815
                                @glasfaser
                                Hi Leute,
                                Bin wieder zurück und war „woanders“ erfolgreicher als zuhause… 😂
                                Komme heute leider nicht mehr dazu eure Ideen und Tipps zu probieren, da mich Frau und Kinder um die Ecke bringen wenn ich jetzt am Netzwerk basteln würde.
                                Werde mir aber alles anschauen, testen und mich wieder melden.
                                Gelobe auch Besserung mit dem EDIT.
                                Danke nochmal für eure Unterstützung und hoffe es bleibt so, wenn weiter testen kann.
                                Gruß,
                                Der Schroeder
                                  @glasfaser
                                  Ich habe den Docker Desktop auf dem Mac installiert und den Container per Terminal mit folgendem Befehl gestartet:
                                  docker run -it -p 8081:8081 -p 2001:2001 -p 2010:2010 -p 9292:9292 -p 8701:8701 -p 23:23 --name ioBroker --privileged --restart=unless-stopped -v iobroker:/opt/iobroker -h iobroker buanet/iobroker
                                  Weiter nutze ich ebenfalls Portainer, aber MACVLAN oder Bridge sagt mir garnix.
                                  Die Umstellung auf
                                  Hat leider keinen Erfolg gebracht.
                                  Danke und Gruß,
                                  Der Schroeder
                                    Schroeder0815 @Schroeder0815 last edited by Schroeder0815
                                    @schroeder0815
                                    Ok, so wie ich das sehe, verwende ich Bridge, die vom Docker selbstständig erstellt wurde.
                                    Aber ist es nicht so, dass dies zur Kommunikation der Container untereinander dient?
                                    Danke und Gruß,
                                    Der Schroeder
                                    EDIT
                                    Der NodeRed Container bekommt auch keine Verbindung zur CCU3, wäre aber eine Baustelle, nachdem der ioBroker läuft.
                                    Hat aber auch noch keine Ports weitergeleitet bekommen.
                                    EDIT2
                                    oder ist es ggf. sinnvoller Node red innerhalb von ioBroker laufen zu lassen
                                      vereinfacht
                                      WAN - FB1 - FB2
                                      Bist du sicher?
                                      Dachte das wäre über mesh nicht so, konnte von der CCU3 mit RedMatic (node red) auch auf Endgeräte zugreifen, die per WLAN an der FB1 hängen
                                        Homoran Global Moderator Administrators @Schroeder0815 last edited by
                                        weiss ich denn wie du das verdrahtet hast?
                                          Da ich offensichtlich zu wenig über den Aufbau meines Netzwerks geschrieben habe, möchte ich dies jetzt nachholen….
                                          Ich betreibe 3 FRITZ!Boxen in meinem Netzwerk
                                          FB1 (7530 AX - Keller) Kommunikation zum Internet (Glasfaseranschluss über ein Modem des Netzanbieters)
                                          FB2 (7530 - EG)
                                          FB3 (7569 - 2OG)
                                          Alle drei sind per Powerlan (TP-Link TL-P4010P) in einem Mesh Netzwerk.
                                          Der ioBroker läuft in einem Docker auf einem Mac welcher über Docker Desktop per Terminal gestartet wurde.
                                          Der Mac ist per WLAN verbunden meist mit FB2 (obwohl er im Keller ist) wird sich aber immer das beste Signal greifen.
                                          Die CCU3 ist per weiterem Switch mit einem Kabel mit der FB2 verbunden.
                                          Bisherige Nutzung war CCU3 mit RaspberryMatic und Redmatic (Node Red Add-on) ohne Probleme.
                                          Diverse Homematic (inkl. IP) Geräte, sowie Zigbee (Redmatic Zigbee2mqtt) als auch WiFi Steckdosen und andere Geräte (wahllos im WLAN aller FRITZ!Boxen Verteilt).
                                          Da RedMatic veraltet ist und nicht weiter Supported wird, kam der Wunsch nach einer anderen Lösung.
                                          Mit dem ioBroker habe ich schon lange geliebäugelt, wollte aber eigentlich kein weiteres Gerät nutzen.
                                          Nun bin ich umsonst an das MacBookPro rangekommen und dachte ich teste mal.
                                          Das MAcBookPro wurde dank OpenCore Lagacy Patcher auf MacOS Ventura gebracht und läuft einwandfrei.
                                          Alle Geräte (FB/CCU/Endgeräte) laufen mit aktuellster Firm- bzw- Software.
                                          Hoffe ich habe es ausführlich genug beschrieben, falls nicht bitte melden und ich ergänze was ich kann.
                                          Gruß,
                                          Der Schroeder
                                            Da bin ich mir aktuell leider auch nicht mehr so sicher....
                                            Hatte soooooo viele verschiedene Terminal btw. Komandozeilenfenster offene......
                                            Was ich jetzt jedoch sicher sagen kann ist, dass sowohl Telnet als auch PING vom Container-HOST (also dem Mac) zur CCU3 funktionieren.
                                            XXXXXXXXXX@Schroeders-MacBookPro ~ % telnet 192.168.111.100 2001
                                            Connected to schroedersccu3.fritz.box.
                                            XXXXXXXXXX@Schroeders-MacBookPro ~ % ping 192.168.111.100
                                            PING 192.168.111.100 (192.168.111.100): 56 data bytes
                                            64 bytes from 192.168.111.100: icmp_seq=0 ttl=64 time=12.742 ms
                                            64 bytes from 192.168.111.100: icmp_seq=1 ttl=64 time=5.104 ms
                                            64 bytes from 192.168.111.100: icmp_seq=2 ttl=64 time=4.462 ms
                                            64 bytes from 192.168.111.100: icmp_seq=3 ttl=64 time=5.804 ms
                                            Und vom ioBroker Container funktioniert jedes nicht:
                                            From 192.168.111.2 icmp_seq=10 Destination Host Unreachable
                                            Jetzt liegt doch nahe, dass was an dem PORT-Mapping bzw. Weiterleitung oder wie auch immer man es nennen möchte nicht stimmt, richtig?
                                            Welche Infos braucht ihr um hierzu was sagen bzw. helfen zu können/wollen?
                                            Danke und Gruß,
                                            Der Schroeder!
                                            1190
