    3. Einsteigerfragen
    4. Kein Start nach Backup möglich / Unraid Docker
      Bass-Ti @Bass-Ti last edited by
      Danke für Eure Rückmeldungen.
      den Befehl habe ich ausgeführt, es kommt jedoch keinerlei Rückmeldung dazu.
      Wenn der Docker gestartet wird, läuft alles laut Log sauber durch.
      Die Oberfläche startet jedoch nicht.
      ----- Step 5 of 5: ioBroker startup -----
      Starting ioBroker...
      ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
      host.fea5d32f5dbd check instance "system.adapter.admin.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.influxdb.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.javascript.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.node-red.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.telegram.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.alexa2.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.alexa2.1" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.cul.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.hm-rega.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.hm-rpc.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.hm-rpc.1" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.hmip.0" for host "fa845846d6ac"
      host.fea5d32f5dbd check instance "system.adapter.ical.0" for host "fa845846d6ac"
      usw.....
      root@fa845846d6ac:/opt/iobroker# iobroker status
      Objects type: jsonl
      States  type: jsonl
      root@fa845846d6ac:/opt/iobroker# npm -v
      9.6.7
      root@fa845846d6ac:/opt/iobroker# iobroker upgrade self
      Host    "fea5d32f5dbd"   is up to date.
      root@fa845846d6ac:/opt/iobroker# iobroker update
      Used repository: stable
      Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
      Adapter    "backitup"     : 2.6.23   , installed 2.4.10 [Updatable]
      Controller "js-controller": 4.0.24   , installed 4.0.24
        A Former User last edited by
        @bass-ti sagte in Kein Start nach Backup möglich / Unraid Docker:
        Moin,
        welche Version des Docker Images setzt Du ein?
        Das iob diag nichts zurückgibt ist aber nicht normal, ich glaube Dir schon, aber kannst Du bitte immer zeigen, mit Eingabezeile, bis neuen Prompt?
        Was gibt den netstat aus?
        # netstat -tulpe
        VG
        Bernd
        • Marc Berg
          Marc Berg Most Active @Bass-Ti last edited by
          Versuche mal ein
          iob host this
          Es könnte sein, dass es ein Problem mit dem Hostnamen gibt, wenn der Name im Backup vom jetzigen Hostnamen abweicht.
            Bass-Ti @Guest last edited by
            @dp20eic
            root@fa845846d6ac:/opt/iobroker# iob diag
            root@fa845846d6ac:/opt/iobroker# netstat -tulpe
            tcp        0      0 127.0.0.11:37859        0.0.0.0:*               LISTEN      root       15054605   -
            tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      iobroker   15063313   -
            tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      iobroker   15063306   -
            udp        0      0 127.0.0.11:41409        0.0.0.0:*                           root       15054604   -
            root@fa845846d6ac:/opt/iobroker# iob host this
            Cannot execute changes on running system. Stop iobroker first.
            root@fa845846d6ac:/opt/iobroker# iobroker stop
            iobroker controller daemon is not running
            root@fa845846d6ac:/opt/iobroker# iobroker stop all
            The adapter "admin.0" was stopped.
            The adapter "backitup.0" was stopped.
            leider keinen erfolg
            • Marc Berg
              Marc Berg Most Active @Bass-Ti last edited by Marc Berg
              m on
              iob host this
              m off
              iob start all
              https://github.com/buanet/ioBroker.docker/issues/188
              buanet created this issue in buanet/ioBroker.docker
              closed After restore in container with new hostname - ioBroker not running/ admin not accessible #188
                Bass-Ti @Marc Berg last edited by
                @marc-berg danke, da hat sich zumindest etwas getan.
                ----- Step 3 of 5: Checking ioBroker installation -----
                (Re)setting permissions (This might take a while! Please be patient!)... Done.
                Fixing "sudo-bug" by replacing sudo with gosu... Done.
                Checking Database connection... Done.
                /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                throw e;
                Error: Connection is closed.
                at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
                at Readable.read (node:internal/streams/readable:496:12)
                at resume_ (node:internal/streams/readable:999:12)
                at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                Emitted 'error' event on ScanStream instance at:
                at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                Node.js v18.17.1
                throw e;
                Node.js v18.17.1
                There was a problem detecting the admin instance of your iobroker.
                Make sure the ioBroker installation you use has an admin instance or try again with a fresh installation and restore your configuration.
                For more details see https://docs.buanet.de/iobroker-docker-image/docs/#restore
                This Script will exit now.
                  @bass-ti ich habe den docker noch einmal neugestartet und zumindest scheint die oberfläche vom admin zu laufen. Muss erst einmal los und prüfe dann noch einmal später nach, danke erst einmal.
                    @bass-ti
                    Danke! iobroker ist jetzt wieder gestartet, leider hat die VIS wohl ein großes Problem.
                    Marc Berg B 2 Replies Last reply Reply Quote 0
                    • Marc Berg
                      Ja, ist ein bekanntes VIS Problem nach dem Restore. Suche mal hier im Forum, da wirst du schnell fündig.
                        @bass-ti
                        da stelle ich mich wohl etwas dümmlich an, beiträge finde ich einige. jedoch nur viel bla bla und keine lösung.
                        • Marc Berg
                          @bass-ti
                          https://forum.iobroker.net/topic/67945/restore-auf-bookworm-vis-ohne-funktion/3?_=1694324500620
                            warp735 last edited by
                            Erst den vis Adapter manuell installieren und ERST DANN das Backup starten. Hat mich damals auch einige Nerven gekostet 🙂
                              Danke euch! So hat jetzt auch alles wieder funktioniert.
                              333
