    3. Einsteigerfragen
    4. Kein Start nach Backup möglich / Unraid Docker
    • Marc Berg
      Marc Berg Most Active @Bass-Ti last edited by
      @bass-ti sagte in Kein Start nach Backup möglich / Unraid Docker:
      Wenn der Docker gestartet wird, läuft alles laut Log sauber durch.
      Die Oberfläche startet jedoch nicht.
      Versuche mal ein
      iob host this
      Es könnte sein, dass es ein Problem mit dem Hostnamen gibt, wenn der Name im Backup vom jetzigen Hostnamen abweicht.
        Bass-Ti @Guest last edited by
        @dp20eic
        root@fa845846d6ac:/opt/iobroker# iob diag
        root@fa845846d6ac:/opt/iobroker# netstat -tulpe
        tcp        0      0 127.0.0.11:37859        0.0.0.0:*               LISTEN      root       15054605   -
        tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      iobroker   15063313   -
        tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      iobroker   15063306   -
        udp        0      0 127.0.0.11:41409        0.0.0.0:*                           root       15054604   -
        root@fa845846d6ac:/opt/iobroker# iob host this
        Cannot execute changes on running system. Stop iobroker first.
        root@fa845846d6ac:/opt/iobroker# iobroker stop
        iobroker controller daemon is not running
        root@fa845846d6ac:/opt/iobroker# iobroker stop all
        The adapter "admin.0" was stopped.
        The adapter "backitup.0" was stopped.
        leider keinen erfolg
        • Marc Berg
          Marc Berg Most Active @Bass-Ti last edited by Marc Berg
          m on
          iob host this
          m off
          iob start all
          https://github.com/buanet/ioBroker.docker/issues/188
          buanet created this issue in buanet/ioBroker.docker
          closed After restore in container with new hostname - ioBroker not running/ admin not accessible #188
            Bass-Ti @Marc Berg last edited by
            @marc-berg danke, da hat sich zumindest etwas getan.
            ----- Step 3 of 5: Checking ioBroker installation -----
            (Re)setting permissions (This might take a while! Please be patient!)... Done.
            Fixing "sudo-bug" by replacing sudo with gosu... Done.
            Checking Database connection... Done.
            /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
            Error: Connection is closed.
            at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
            at Readable.read (node:internal/streams/readable:496:12)
            at resume_ (node:internal/streams/readable:999:12)
            at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            Emitted 'error' event on ScanStream instance at:
            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            Node.js v18.17.1
            throw e;
            Node.js v18.17.1
            There was a problem detecting the admin instance of your iobroker.
            Make sure the ioBroker installation you use has an admin instance or try again with a fresh installation and restore your configuration.
            For more details see https://docs.buanet.de/iobroker-docker-image/docs/#restore
            This Script will exit now.
              Bass-Ti @Bass-Ti last edited by
              @bass-ti ich habe den docker noch einmal neugestartet und zumindest scheint die oberfläche vom admin zu laufen. Muss erst einmal los und prüfe dann noch einmal später nach, danke erst einmal.
                @bass-ti
                Danke! iobroker ist jetzt wieder gestartet, leider hat die VIS wohl ein großes Problem.
                Marc Berg B 2 Replies Last reply Reply Quote 0
                • Marc Berg
                  Ja, ist ein bekanntes VIS Problem nach dem Restore. Suche mal hier im Forum, da wirst du schnell fündig.
                    @bass-ti
                    da stelle ich mich wohl etwas dümmlich an, beiträge finde ich einige. jedoch nur viel bla bla und keine lösung.
                    • Marc Berg
                      @bass-ti
                      https://forum.iobroker.net/topic/67945/restore-auf-bookworm-vis-ohne-funktion/3?_=1694324500620
                        warp735 last edited by
                        Erst den vis Adapter manuell installieren und ERST DANN das Backup starten. Hat mich damals auch einige Nerven gekostet 🙂
                          Danke euch! So hat jetzt auch alles wieder funktioniert.
                          333
