    4. Test Adapter Plex v1.1.x
      ticaki Developer @SidM last edited by ticaki
      @sidm
      Die Version die ich vor 10 Minuten hochgeladen habe. Du musst immer diese 5 Punkte eintragen/kontrollieren bzw. die 2 wenn sie falsch sind. Bis es dann geht 🙂
      plex.0._playing.mac-mini-home-3.x.Player.controllable
      ist der 5. der muß true sein.
        SidM @ticaki last edited by
        @ticaki
        Ist installiert + Instanz neu gestartet
        • plex.0._playing.mac-mini-home-3.x.Player.controllable ist true
        Steuerung nicht möglich
        warn	Error triggering playback action -skipNext- on player iPad-xxxxxxx with ip:192.168.178.37.! See debug log for details! Action not supported!
        plex.0
        2023-09-10 23:44:40.009	debug	State of plex.0._playing.ipad-xxxxxxx._Controls.playback.skipNext has changed {"val":false,"ack":false,"ts":1694382280007,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1694382280007}.
        plex.0
        2023-09-10 23:44:33.810	warn	Error triggering playback action -skipNext- on player iPad-xxxxxxx with ip:192.168.178.37.! See debug log for details! Action not supported!
        plex.0
        2023-09-10 23:44:33.809	debug	State of plex.0._playing.ipad-xxxxxxx._Controls.playback.skipNext has changed {"val":true,"ack":false,"ts":1694382273808,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1694382273808}.
        plex.0
        2023-09-10 23:44:20.554	warn	Error triggering playback action -pause- on player iPad-xxxxxxx with ip:192.168.178.37.! See debug log for details! Action not supported!
        plex.0
        2023-09-10 23:44:20.553	debug	State of plex.0._playing.ipad-xxxxxxx._Controls.playback.pause has changed {"val":true,"ack":false,"ts":1694382260552,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1694382260552}.
        plex.0
        2023-09-10 23:44:14.915	warn	Error triggering playback action -pause- on player iPad-xxxxxxx with ip:192.168.178.37.! See debug log for details! Action not supported!
          @sidm sagte in Test Adapter Plex v1.0.x:
          Das sieht nach der falschen Adapterversion aus. Installiere bitte mal per benutzerdefiniertem Githublink:
          In meinem Code gibts 3 Meldung wenn dort ein Fehler entsteht und du hast nur 2. von denen eine ganz woanders im Code ist..
            @ticaki
            Habe ich gemacht. Eben nochmal.
            warn	Error triggering playback action -play- on player iPad-xxxxxx  with ip:192.168.178.37.! See debug log for details! Action not supported!
            plex.0
            2023-09-11 00:13:28.843	debug	State of plex.0._playing.ipad-xxxxxx ._Controls.playback.play has changed {"val":true,"ack":false,"ts":1694384008841,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1694379607661}.
            plex.0
            2023-09-11 00:12:30.021	warn	Error triggering playback action -pause- on player iPad-xxxxxx with ip:192.168.178.37.! See debug log for details! Action not supported!
            plex.0
            2023-09-11 00:12:30.020	debug	State of plex.0._playing.ipad-xxxxxx ._Controls.playback.pause has changed {"val":true,"ack":false,"ts":1694383950018,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1694382260552}.
              @sidm
              Bin zu müde, hast recht. 🙂
              schaue ich mir morgen abend an. Die heißt das entweder der Port oder die Adresse 0 sind. Muß mal schauen ob die intern richtig vom state übernommen wird.
                @ticaki
                Kein Problem, ich hau mich jetzt auch hin. Schadet manchmal nicht.🤙
                Erhol dich erst einmal und mach dir kein Stress.
                In dem Sinne: Gute Nacht😴
                  ticaki Developer last edited by ticaki
                  v.1.1.0
                  ist auf dem Weg ins latest
                  Ich benenne den Topic um
                  @SidM
                  Dein Problem sollte mit der Version behebbar sein.
                  plex.0._playing.ipad-x.Player.port
                  müssen wie besprochen verändert werden, die restlichen Daten sind schon da.
                  hab bei mir einfach die Abfrage "Retrieve players..." deaktiviert und den Fehler in 1 Minute gefunden 🙂
                    sigi234 Forum Testing Most Active @ticaki last edited by sigi234
                    @ticaki sagte in Test Adapter Plex v1.0.x:
                    v.1.1.0
                    Ok,
                    mal Plex auf LG TV getestet, keine Reaktion auf button controls und keine Daten xxxseek
                    plex.0
                    2023-09-11 13:02:59.147	warn	Error triggering playback action -skipNext- on player LG 43UK6300LLB-966gg2cnfsu7sc84e95hupho with ip:192.168.178.20.! See debug log for details.
                    plex.0
                    2023-09-11 13:02:59.135	info	Triggered action -skipNext- on player LG 43UK6300LLB-966gg2cnfsu7sc84e95hupho with ip:192.168.178.20.
                    Edit:
                    Android Handy ist alles Ok!
                      ticaki Developer @sigi234 last edited by
                      @sigi234
                      bitte mit debug
                        @sigi234
                        bitte mit debug
                        plex.0
                        2023-09-11 13:16:10.408	debug	url: http://192.168.178.20:32400/player/playback/skipNext?
                        plex.0
                        2023-09-11 13:16:10.408	debug	catch() 133: Request failed with status code 400
                        plex.0
                        2023-09-11 13:16:10.408	warn	Error triggering playback action -skipNext- on player LG 43UK6300LLB-966gg2cnfsu7sc84e95hupho with ip:192.168.178.20.! See debug log for details.
                        plex.0
                        2023-09-11 13:16:10.398	info	Triggered action -skipNext- on player LG 43UK6300LLB-966gg2cnfsu7sc84e95hupho with ip:192.168.178.20.
                        plex.0
                        2023-09-11 13:16:10.398	debug	State of plex.0._playing.lg 43uk6300llb-966gg2cnfsu7sc84e95hupho._Controls.playback.skipNext has changed {"val":true,"ack":false,"ts":1694430970396,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1694430970396}.
                        Edit2:
                        plex.0
                        2023-09-11 13:18:37.005	debug	Stop getting client details _playing.lg 43uk6300llb-966gg2cnfsu7sc84e95hupho - timeline,playback,navigation,playqueues,provider-playback - 192.168.178.20 - 32400
                        plex.0
                        2023-09-11 13:18:34.318	debug	Received events playload - media.play - from tautulli: {"event":"media.play","user":"undefined","owner":"undefined","Account":{"userId":"19689043","id":"undefined","thumb":"undefined","title":"Sigi2345"},"Server":{"title":"PLEX","uuid":"xxxxxxxxx"},"Player":{"local":"1","localAddress":"192.168.178.41","publicAddress":"undefined","title":"LG 43UK6300LLB","uuid":"966gg2cnfsu7sc84e95hupho"},"Metadata":{"librarySectionType":"track","ratingKey":"31915","parentRatingKey":"31914","grandparentRatingKey":"21488","key":"/library/metadata/31915","guid":"com.plexapp.agents.imdb://?lang=en","librarySectionTitle":"Music","librarySectionID":"6","librarySectionKey":"/library/sections/6","studio":"","type":"track","title":"Never Gonna Give You Up - Rick Astley","grandparentTitle":"","parentTitle":"","titleSort":"undefined","contentRating":"","summary":"","rating":"","viewOffset":"undefined","lastViewedAt":"2023-09-04","year":"1987","tagline":"","thumb":"/library/metadata/21488/thumb/1694139088","parentThumb":"/library/metadata/31914/thumb/1692900097","grandparentThumb":"/library/metadata/21488/thumb/1694139088","posterThumb":"/library/metadata/31914/thumb/1692900097","art":"undefined","duration":"4","originallyAvailableAt":"","addedAt":"2023-08-24","updatedAt":"","chapterSource":"undefined","primaryExtraKey":"undefined","ratingImage":"imdb://image.rating","Genre":"Folk","Director":"","Writer":"","Country":"undefined","Producer":"undefined","Collection":"","Role":"","Similar":"undefined","tautulli":{"Player":"LG 43UK6300LLB","LibraryTyp":"Music","Filmstudio":"","Titel":"Never Gonna Give You Up - Rick Astley","Originaltitel":"","SerienName":"Rick Astley","FolgeName":"Never Gonna Give You Up","Status":"play","Beschreibung":"","Bewertung":"","Jahr":"1987","Genre":"Folk","Hintergrund":"/library/metadata/21488/art/1694139088","SerienBanner":"","Cover":"/library/metadata/21488/thumb/1694139088","DauerMinuten":"4","DauerSekunden":"212","VerbleibendMinuten":"4","VerbleibendSekunden":"212","VerbleibendZeit":"00:03","FortschrittMinuten":"0","FortschrittSekunden":"0 sek","FortschrittZeit":"00:00","FortschrittProzent":"0","Veroeffentlichung":"","UploadDatum":"2023-08-24","AbspielDatum":"2023-09-04","Kategorie":"Folk","Regisseur":"","Drehbuch":"","Kollektion":"","Darsteller":"","Folge":"0","Staffel":"1"},"video":{"container":"mp3","bitrate":"128","aspect_ratio":"","video_codec":"","video_codec_level":"","video_bitrate":"","video_bit_depth":"","video_framerate":"","video_ref_frames":"","video_resolution":"","video_height":"","video_width":"","video_language":"","video_language_code":""},"audio":{"audio_bitrate":"128","audio_bitrate_mode":"","audio_codec":"mp3","audio_channels":"2","audio_channel_layout":"stereo","audio_sample_rate":"44100","audio_language":"","audio_language_code":""},"subtitles":{"subtitle_codec":"","subtitle_container":"","subtitle_format":"","subtitle_forced":"0","subtitle_location":"","subtitle_language":"","subtitle_language_code":""},"file":{"path":"F:\\Music\\Rick Astley\\Rick Astley\\Rick Astley - Never Gonna Give You Up.mp3","name":"Rick Astley - Never Gonna Give You Up.mp3","size":"3.29 MB"},"transcoding":{"transcode_decision":"Direct Play","video_decision":"direct play","audio_decision":"direct play","subtitle_decision":"","transcode_container":"","transcode_video_codec":"","transcode_video_width":"","transcode_video_height":"","transcode_audio_codec":"","transcode_audio_channels":"","transcode_hw_requested":"0","transcode_hw_decoding":"0","transcode_hw_decode":"","transcode_hw_decode_title":"","transcode_hw_encoding":"0","transcode_hw_encode":"","transcode_hw_encode_title":""},"stream":{"user":{"streams":"1","user_streams":"1","name":"Sigi2345","user":"Sigi2345","email":"xxxxxxxxx"},"player":{"device":"webOS 4.4.0","platform":"webOS","product":"Plex for LG","player":"LG 43UK6300LLB","ip_address":"192.168.178.41"},"quality_profile":"128 kbps","optimized_version":"0","optimized_version_profile":"","synced_version":"0","live":"0","stream_local":"1","stream_location":"lan","stream_bandwidth":"132","stream_container":"mp3","stream_bitrate":"128","stream_aspect_ratio":"","stream_duration":"0","stream_time":"00:00","remaining_duration":"4","remaining_time":"00:03","progress_duration":"0","progress_time":"00:00","progress_percent":"0","stream_video":{"stream_video_codec":"","stream_video_codec_level":"","stream_video_bitrate":"","stream_video_bit_depth":"","stream_video_framerate":"","stream_video_ref_frames":"","stream_video_resolution":"","stream_video_height":"","stream_video_width":"","stream_video_language":"","stream_video_language_code":""},"stream_audio":{"stream_audio_bitrate":"128","stream_audio_bitrate_mode":"","stream_audio_codec":"mp3","stream_audio_channels":"2","stream_audio_channel_layout":"stereo","stream_audio_sample_rate":"44100","stream_audio_language":"","stream_audio_language_code":""},"stream_subtitle":{"stream_subtitle_codec":"","stream_subtitle_container":"","stream_subtitle_format":"","stream_subtitle_forced":"0","stream_subtitle_language":"","stream_subtitle_language_code":"","stream_subtitle_location":""}}},"media":"track","player":"LG 43UK6300LLB","account":"Sigi2345","source":"tautulli","timestamp":1694431114,"datetime":"11.09.2023 13:18:34","playing":true}
                        plex.0
                        2023-09-11 13:18:34.310	debug	Running Garbage Collector for _playing._recent-player...
                        plex.0
                        2023-09-11 13:18:34.299	debug	Received _playing playload - media.play - from tautulli: {"event":"media.play","user":"undefined","owner":"undefined","Account":{"userId":"19689043","id":"undefined","thumb":"undefined","title":"Sigi2345"},"Server":{"title":"PLEX","uuid":"xxxxxxxxx"},"Player":{"title":"_recent","uuid":"player"},"Metadata":{"librarySectionType":"track","ratingKey":"31915","parentRatingKey":"31914","grandparentRatingKey":"21488","key":"/library/metadata/31915","guid":"com.plexapp.agents.imdb://?lang=en","librarySectionTitle":"Music","librarySectionID":"6","librarySectionKey":"/library/sections/6","studio":"","type":"track","title":"Never Gonna Give You Up - Rick Astley","grandparentTitle":"","parentTitle":"","titleSort":"undefined","contentRating":"","summary":"","rating":"","viewOffset":"undefined","lastViewedAt":"2023-09-04","year":"1987","tagline":"","thumb":"/library/metadata/21488/thumb/1694139088","parentThumb":"/library/metadata/31914/thumb/1692900097","grandparentThumb":"/library/metadata/21488/thumb/1694139088","posterThumb":"/library/metadata/31914/thumb/1692900097","art":"undefined","duration":"4","originallyAvailableAt":"","addedAt":"2023-08-24","updatedAt":"","chapterSource":"undefined","primaryExtraKey":"undefined","ratingImage":"imdb://image.rating","Genre":"Folk","Director":"","Writer":"","Country":"undefined","Producer":"undefined","Collection":"","Role":"","Similar":"undefined","tautulli":{"Player":"LG 43UK6300LLB","LibraryTyp":"Music","Filmstudio":"","Titel":"Never Gonna Give You Up - Rick Astley","Originaltitel":"","SerienName":"Rick Astley","FolgeName":"Never Gonna Give You Up","Status":"play","Beschreibung":"","Bewertung":"","Jahr":"1987","Genre":"Folk","Hintergrund":"/library/metadata/21488/art/1694139088","SerienBanner":"","Cover":"/library/metadata/21488/thumb/1694139088","DauerMinuten":"4","DauerSekunden":"212","VerbleibendMinuten":"4","VerbleibendSekunden":"212","VerbleibendZeit":"00:03","FortschrittMinuten":"0","FortschrittSekunden":"0 sek","FortschrittZeit":"00:00","FortschrittProzent":"0","Veroeffentlichung":"","UploadDatum":"2023-08-24","AbspielDatum":"2023-09-04","Kategorie":"Folk","Regisseur":"","Drehbuch":"","Kollektion":"","Darsteller":"","Folge":"0","Staffel":"1"},"video":{"container":"mp3","bitrate":"128","aspect_ratio":"","video_codec":"","video_codec_level":"","video_bitrate":"","video_bit_depth":"","video_framerate":"","video_ref_frames":"","video_resolution":"","video_height":"","video_width":"","video_language":"","video_language_code":""},"audio":{"audio_bitrate":"128","audio_bitrate_mode":"","audio_codec":"mp3","audio_channels":"2","audio_channel_layout":"stereo","audio_sample_rate":"44100","audio_language":"","audio_language_code":""},"subtitles":{"subtitle_codec":"","subtitle_container":"","subtitle_format":"","subtitle_forced":"0","subtitle_location":"","subtitle_language":"","subtitle_language_code":""},"file":{"path":"F:\\Music\\Rick Astley\\Rick Astley\\Rick Astley - Never Gonna Give You Up.mp3","name":"Rick Astley - Never Gonna Give You Up.mp3","size":"3.29 MB"},"transcoding":{"transcode_decision":"Direct Play","video_decision":"direct play","audio_decision":"direct play","subtitle_decision":"","transcode_container":"","transcode_video_codec":"","transcode_video_width":"","transcode_video_height":"","transcode_audio_codec":"","transcode_audio_channels":"","transcode_hw_requested":"0","transcode_hw_decoding":"0","transcode_hw_decode":"","transcode_hw_decode_title":"","transcode_hw_encoding":"0","transcode_hw_encode":"","transcode_hw_encode_title":""},"stream":{"user":{"streams":"1","user_streams":"1","name":"Sigi2345","user":"Sigi2345","email":"xxxxxxxxx"},"player":{"device":"webOS 4.4.0","platform":"webOS","product":"Plex for LG","player":"LG 43UK6300LLB","ip_address":"192.168.178.41"},"quality_profile":"128 kbps","optimized_version":"0","optimized_version_profile":"","synced_version":"0","live":"0","stream_local":"1","stream_location":"lan","stream_bandwidth":"132","stream_container":"mp3","stream_bitrate":"128","stream_aspect_ratio":"","stream_duration":"0","stream_time":"00:00","remaining_duration":"4","remaining_time":"00:03","progress_duration":"0","progress_time":"00:00","progress_percent":"0","stream_video":{"stream_video_codec":"","stream_video_codec_level":"","stream_video_bitrate":"","stream_video_bit_depth":"","stream_video_framerate":"","stream_video_ref_frames":"","stream_video_resolution":"","stream_video_height":"","stream_video_width":"","stream_video_language":"","stream_video_language_code":""},"stream_audio":{"stream_audio_bitrate":"128","stream_audio_bitrate_mode":"","stream_audio_codec":"mp3","stream_audio_channels":"2","stream_audio_channel_layout":"stereo","stream_audio_sample_rate":"44100","stream_audio_language":"","stream_audio_language_code":""},"stream_subtitle":{"stream_subtitle_codec":"","stream_subtitle_container":"","stream_subtitle_format":"","stream_subtitle_forced":"0","stream_subtitle_language":"","stream_subtitle_language_code":"","stream_subtitle_location":""}}},"media":"track","player":"LG 43UK6300LLB","account":"Sigi2345","source":"tautulli","timestamp":1694431114,"datetime":"11.09.2023 13:18:34","playing":true}
                          @sigi234 bitte mal debug an, Fernseh irgendwas bei Plex laufen lassen, Adapter neustarten und die Logzeile die mit:
                          Retrieved Players from Plex:
                          beginnt posten.
                            gelöscht
                              @sigi234
                              ok, danke.
                              Hab die Woche nicht soviel Zeit, aber das wird wohl wieder auf eine Testversion rauslaufen um zu versuchen mit unterschiedlichen Optionen und Zugriffen ans Ziel zu kommen.
                                SidM last edited by
                                @ticaki said in Test Adapter Plex v1.1.x:
                                v.1.1.0
                                @SidM
                                Suppi! Die Controls funktionieren jetzt, ebenso viewOffset und viewOffsetSeconds👍 Vielen vielen Dank.
                                Was mich aber verwundert: Es gibt jetzt 2 mal den Ordner Player.
                                • plex.0._playing.ipad-xxxxx.Metadata.Player
                                • plex.0._playing.ipad-xxxxx.Player
                                ist das so beabsichtigt?
                                Denn es gibt bei beiden den state:
                                • plex.0._playing.ipad-xxxxx.Metadata.Player.state (dieser bleibt auf playing stehen)
                                • plex.0._playing.ipad-xxxxx.Player.details.state (nur dieser funktioniert und zeigt richtig playing, paused, buffering)
                                  @sigi234
                                  ok, danke.
                                  Ok, ich lösche das Log wieder wegen der Daten
                                    @sidm
                                    Ausschnitt aus der Tautullikonfiguration
                                           "Player":{
                                    		"local":"{stream_local}",
                                    		"localAddress":"{ip_address}",
                                    		"title":"{player}",
                                    		"uuid":"{machine_id}"
                                    Ansonsten muß ich mit den States noch etwas aufräumen, da der aber jetzt "fertig" ist, kann ich auf Nutzerfeedbackbasis, da aufräumen.
                                    Die States (abgesehen von den tautulli) sollte da aber nicht sein, da bin ich wohl irgendwo mit den Player durcheinander gekommen 🙂
                                      @ticaki
                                      Also bei mir funktioniert soweit alles was ich brauche.
                                      Wenn ich aber noch irgend etwas testen soll, sag bescheid.
                                        @sidm sagte in Test Adapter Plex v1.1.x:
                                        Das Metadata.Player.state ist ein dump von "playing now" wird durch den Client ausgelöst, aber die Daten stammen vom Server. Da wird immer playing stehen. Wenn nicht playing ist, ist es nicht in playing now 🙂
                                        Kann das aber raus nehmen da ich die Daten für die Lyric brauche hab ich sie auch gleich schreiben lassen.
                                        plex.0._playing.ipad-xxxxx.Player.details kommen vom Player
                                        plex.0._playing.ipad-xxxxx.Metadata kommen vom Server (abgesehen viewOffset)
                                        EDIT:
                                        Ich werde in Zukunft Metadata.Player.state löschen und die Bezeichnung von Metadata.Player ist Player Information vom Server (nicht live)
                                          @sigi234 sagte in Test Adapter Plex v1.1.x:
                                          v.1.1.0
                                          Ok,
                                          plex.0
                                          plex.0
                                          Hast du mal probiert ob das per Link im Browser geht? Hat der Fernseher ne Firewall?
                                            @ticaki sagte in Test Adapter Plex v1.1.x:
                                            400 Bad Request
                                            Nein
                                            Cover wird aber angezeigt via Browser:
                                            http://192.168.178.20:32400/library/metadata/25163/art/1694049681?X-Plex-Token=xxxxxxxxxxxxxx
                                            Edit:
                                            Daten kommen ja alle rein, aber nicht raus. Der TV hat ja eine andere IP und ist via LAN verbunden.
                                            Ich habe auch den LG Adapter installiert und da musste man den TV mit dem Adapter einmalig ein Pairing ausführen.
                                            adapter plex tautulli
                                            25698
