    5. Einschaltwert über Temperatur erfassen
      ticaki Developer @Homoran last edited by
      hehe... Zeiten brauchste dabei aber auch... und das wird imho tatsächlich kompliziert.
        siporax @paul53 last edited by
        @paul53 Kannste mir das script zur verfügung stellen ?
        Das möchte ich fehlerfrei übernehmen,wenn das geht.
          paul53 @siporax last edited by
          @siporax sagte: script zur verfügung stellen ?
           <variables>
             <variable id="Vn6j?jOO?$kDTnqTWGfU">lastTemp</variable>
             <variable id="JV,7/}p(l?3Qii59u`wo">temp</variable>
             <variable id="L:#sVF3F*)ZIZ7+wyOUD">istEin</variable>
           </variables>
           <block type="variables_set" id="]!T`lxoBB4d;Cg!NZ]}|" x="-662" y="-1163">
             <field name="VAR" id="Vn6j?jOO?$kDTnqTWGfU">lastTemp</field>
               <block type="get_value" id="Iz2p*j8Ax;+XzF=rVKhl">
                 <field name="OID">0_userdata.0.Blockly.Temperatur</field>
               <block type="schedule" id="9vy9?l/Ip;~mD-a8NGT4">
                 <field name="SCHEDULE">*/5 * * * *</field>
                   <block type="variables_set" id="U2YZi=*EcWMmgr5TH/5B">
                     <field name="VAR" id="JV,7/}p(l?3Qii59u`wo">temp</field>
                       <block type="get_value" id="N5#;gX!iV_`9;l3@%8cd">
                       <block type="controls_if" id="yoQjZl{f2D5XcmPJfuK!">
                           <block type="logic_compare" id="X9VwCHq$Ikow)bf5R)$P">
                             <field name="OP">GTE</field>
                               <block type="variables_get" id="4pB((16P$wnIiV:_RW{m">
                               <block type="math_arithmetic" id="-ypD2~#RlcvCw8G=N2QT">
                                 <field name="OP">ADD</field>
                                   <shadow type="math_number" id="dDkgt-`Ih))K6]iktTJ$">
                                     <field name="NUM">1</field>
                                   <block type="variables_get" id="eidIUFk]Uy{qD6:s)P7W">
                                   <shadow type="math_number" id="m47!La,.3r!*:kGOG:i_">
                           <block type="variables_set" id="|;r)}t;NdlJK:U%qf@p@">
                             <field name="VAR" id="L:#sVF3F*)ZIZ7+wyOUD">istEin</field>
                               <block type="logic_boolean" id="Lte;~5RI[HxZmV~:9,l?">
                         <value name="IF1">
                           <block type="logic_compare" id="Q8YL?;2opW^@CduOyRkJ">
                             <field name="OP">LTE</field>
                               <block type="variables_get" id="-Z_l4#mR/3NfnymU9R+m">
                               <block type="math_arithmetic" id="egk=Qz=iAzK-r!HiBrNu">
                                   <block type="variables_get" id="TmLPt[P}QkHvB:Lf*dV}">
                                   <shadow type="math_number" id="V;G{]7/Ek0s|@*?,($6q">
                                     <field name="NUM">0.5</field>
                         <statement name="DO1">
                           <block type="variables_set" id=",!.Ij;r44xuub.^h%{pf">
                               <block type="logic_boolean" id="6oVc%{sJAP#|aG2JW;F6">
                           <block type="update" id="LoMN_Gt.CbXa^4?p?vjq">
                             <field name="OID">0_userdata.0.Blockly.WP</field>
                               <block type="variables_get" id="mRHB]k/b2+EI3]6i#%/[">
                               <block type="variables_set" id="q=1q;b5nA-;`bgbI8z/d">
                                   <block type="variables_get" id="U!0X(O3pQvmbqtV:lJ]y">
            @paul53 muss den Ordner erstellen ?
              @siporax sagte: muss den Ordner erstellen ?
              Nein, dort muss die DS18B20-Temperatur zugewiesen werden.
              Für "WP" muss ein eigener Datenpunkt unter "0_userdata.0" vom Typ "Logikwert" vorhanden sein / erstellt werden.
                siporax @paul53 last edited by siporax
                @paul53 Ok Datenpunkt erstellt.
                Was ich noch nicht verstehe wo wird mein Relais nun geschaltet in dem Script.
                Das brauche ich um das im Vis darstellen zu können oder bin ich da falsch?
                Oder kann ich den Datenpunkt direkt dazu verwenden ?
                  @siporax sagte: wo wird mein Relais nun geschaltet in dem Script.
                  Weshalb ein Relais schalten?
                  @siporax sagte in Einschaltwert über Temperatur erfassen:
                  Ja, der eigene Datenpunkt kann in Vis verwendet werden.
                    @paul53 said in Einschaltwert über Temperatur erfassen:
                    Klasse ,Danke ich teste das mal
                      @siporax sagte: ich teste das mal
                      Ich habe das Skript noch um die Initialisierung von istEin bei Skriptstart erweitert:
                        @paul53 Mache ich gleich.
                        Habe mal nachgemessen ich habe in 16 Minuten einen Temperaturabfall von 0,1°C im Speicher.
                        Ist doch lang für das Script.
                        Denke er Vergleich ja nur 1x oder vergleich er immer wieder bis sich das was ändert und die 5 Minuten stoßen das nur wieder von vorne an?
                          @siporax sagte: habe in 16 Minuten einen Temperaturabfall von 0,1°C im Speicher.
                          Dann passen Prüfung alle 5 Minuten und Abfall von 0,5 K nicht.
                          Es wird alle 5 Minuten verglichen.
                            @paul53 habs angepasst von 0,5 auf 0,1°C
                              siporax @siporax last edited by
                                siporax @siporax last edited by siporax
                                @siporax nur nochmal für mein Verständnis:
                                vergleicht er immer wieder alle 5 Minuten
                                und würde dann bei 16 Minuten Wartezeit dennoch Schalten.
                                Oder muss ich 16 Minuten einstellen anstatt die 5 Minuten ?
                                  @siporax sagte: Oder muss ich 16 Minuten einstellen anstatt die 5 Minuten ?
                                  Eher alle 20 Minuten prüfen, ob temp < lastTemp - 0.1 ist, wenn die Auflösung 0,1 K beträgt. Bei Prüfung <= führen auch zufällige Schwankungen zum Ausschalten.
                                    @paul53 ok Verstehe.
                                    Das bedeudet dann aber auch das er solange auch wartet diese 20 Minuten beim Aufheizen oder?
                                    Wenn dem so ist könnte man das nicht trennen das man einen andere Intervall bekommt ?
                                      paul53 @siporax last edited by paul53
                                      @siporax
                                      Steigt die Temperatur nicht ständig solange die WP (Kompressor) läuft? Dann genügt es alle 5 Minuten für das Ausschalten zu prüfen: temp < lastTemp. Das funktioniert unabhängig davon, wie langsam die Temperatur sinkt.
                                      Homoran S 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @paul53 last edited by Homoran
                                        @paul53 ich bleibe hartnäckig dabei es über die Aktualisierungsgeschwindigkeit (Timestamp - last Timestamp) auszuwerten und auf Änderung zu triggern.
                                        Je kürzer der Abstand der Änderungen nach oben desto schneller wird aufgeheizt.
                                        Im Prinzip kann man dann schon an der (deutlichen) Erhöhung der Zeit das Ende des Aufheizens erkennen.
                                        und ja msec/K ist nicht unbedingt eine gewöhnliche Einheit
                                          @paul53 Der Anstieg der Temperatur ist nicht das Zeitliche Problem.
                                          Sondern das erfassen des Ausschalten da braucht es 16 minuten bis der Wert um 0,1°C fällt.
                                          Oder meinst du wenn die Temperratur nicht mehr ansteigt in 5 Minuten dann ist der zustand auch aus.
                                          Habe 40°C Auschalttemperatur die könnten wir auch benutzen das ist genauer und schneller zugleich.
                                            @homoran sagte: über die Aktualisierungsgeschwindigkeit (Timestamp - last Timestamp) auszuwerten
                                            Wenn, dann über die Änderungsgeschwindigkeit (letzte Änderung - vorherige letzte Änderung). Der Zeitstempel kann öfter aktualisiert werden.
                                            1962
