    4. s7 Adapter funktioniert nicht mehr noch node update
      Jacke last edited by
      So sieht das skript aus
      ioBroker nodejs fixer 2023-09-07
      Recommended nodejs-version is: 18.17.1
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/node           v16.18.0
      /usr/bin/npm            8.19.2
      /usr/bin/npx            8.19.2
      /usr/bin/corepack       0.14.1
      I found these nodejs versions available for installation:
      nodejs:
        Installed: 16.18.0-deb-1nodesource1
        Candidate: 16.18.0-deb-1nodesource1
        Version table:
       *** 16.18.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x hirsute/main amd64 Packages
              100 /var/lib/dpkg/status
           12.21.0~dfsg-3ubuntu1 500
              500 http://old-releases.ubuntu.com/ubuntu hirsute/universe amd64 Packages
      Nothing to do, your installation is using the correct paths.
      You are running nodejs v16.18.0. Do you want to install recommended version 18.17.1?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      [sudo] password for nils:
      lxc
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:1 http://old-releases.ubuntu.com/ubuntu hirsute InRelease
      Hit:2 http://old-releases.ubuntu.com/ubuntu hirsute-updates InRelease
      Hit:3 http://old-releases.ubuntu.com/ubuntu hirsute-security InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:1 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Hit:2 http://old-releases.ubuntu.com/ubuntu hirsute InRelease
      Hit:3 http://old-releases.ubuntu.com/ubuntu hirsute-updates InRelease
      Get:4 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
      Hit:5 http://old-releases.ubuntu.com/ubuntu hirsute-security InRelease
      Fetched 17.3 kB in 0s (35.8 kB/s)
      Installing the recommended nodejs version now!
      Exact recommended version unknown, installing a fallback!
      Building dependency tree... Done
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
      Need to get 29.4 MB of archives.
      After this operation, 60.1 MB of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
      Fetched 29.4 MB in 1s (35.4 MB/s)
      (Reading database ... 35480 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.17.0-1nodesource1) over (16.18.0-deb-1nodesource1) ...
      Setting up nodejs (18.17.0-1nodesource1) ...
      Processing triggers for man-db (2.9.4-2) ...
      Updating fallback to latest nodejs v18 release
      Calculating upgrade... Done
      The following packages have been kept back:
        libgl1-mesa-dri libglapi-mesa libglx-mesa0 ubuntu-advantage-tools
        nodejs python3-gdbm
      2 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
      After this operation, 32.8 kB of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
      Get:2 http://old-releases.ubuntu.com/ubuntu hirsute-updates/main amd64 python3-gdbm amd64 3.9.5-0ubuntu3~21.04 [20.1 kB]
      Fetched 29.4 MB in 1s (39.5 MB/s)
      (Reading database ... 37965 files and directories currently installed.)
      Preparing to unpack .../python3-gdbm_3.9.5-0ubuntu3~21.04_amd64.deb ...
      Unpacking python3-gdbm:amd64 (3.9.5-0ubuntu3~21.04) over (3.9.4-0ubuntu1) ...
      Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
      Setting up python3-gdbm:amd64 (3.9.5-0ubuntu3~21.04) ...
      Setting up nodejs (18.17.1-1nodesource1) ...
      *** You need to manually restart your container now! ***
      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
      So sieht danach der Fehler im Log aus
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: Node.js v18.17.1
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: }
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: ]
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node'
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.854	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: tries: [
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) {
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.s7/main.js:9:21)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.IoBrokerLXC
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.853	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: ^
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: throw err;
      host.IoBrokerLXC
      2023-09-11 17:41:24.852	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
      host.IoBrokerLXC
      2023-09-11 17:41:22.039	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: Node.js v18.17.1
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: }
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: ]
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node'
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Release/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.912	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-snap7/build/node_snap7.node',
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: tries: [
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14) {
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.s7/main.js:9:21)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.IoBrokerLXC
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/lib/binding/node-v108-linux-x64/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/default/install-root/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/debug/install-root/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/addon-build/release/install-root/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/compiled/18.17.1/linux/x64/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/default/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Release/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Release/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/Debug/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/out/Debug/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/Debug/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: → /opt/iobroker/node_modules/node-snap7/build/node_snap7.node
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: ^
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: throw err;
      host.IoBrokerLXC
      2023-09-11 17:41:13.911	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
      host.IoBrokerLXC
      2023-09-11 17:41:11.932	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[1]: Node.js v18.17.1
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: }
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.IoBrokerLXC
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: NODE_MODULE_VERSION 93. This version of Node.js requires
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node'
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: ^
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: throw e;
      host.IoBrokerLXC
      2023-09-11 17:41:01.913	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
      host.IoBrokerLXC
      2023-09-11 17:40:59.316	error	iobroker npm-rebuild: Rebuilding native modules failed
      host.IoBrokerLXC
      2023-09-11 17:40:43.510	error	instance system.adapter.s7.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.IoBrokerLXC
      2023-09-11 17:40:43.510	error	Caught by controller[0]: Node.js v18.17.1
      host.IoBrokerLXC
      2023-09-11 17:40:43.510	error	Caught by controller[0]: }
      host.IoBrokerLXC
      2023-09-11 17:40:43.510	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-snap7/lib/node-snap7.js:8:45)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.IoBrokerLXC
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1340:18)
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: NODE_MODULE_VERSION 108. Please try re-compiling or re-installing
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: NODE_MODULE_VERSION 93. This version of Node.js requires
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/node-snap7/build/Release/node_snap7.node'
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: ^
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: throw e;
      host.IoBrokerLXC
      2023-09-11 17:40:43.509	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
        Thomas Braun Most Active @Jacke last edited by Thomas Braun
        @jacke
        hirsute ist steinalt und wird nicht mehr aktiv gepflegt.
        Installier da die aktuelle LTS oder gleich ein Debian. Und dann ohne graphische Oberfläche.
        Hast du den Rat befolgt?
          Jacke @Thomas Braun last edited by Jacke
          @thomas-braun Ich habe den S7 adapter gestoppt und dann gesatrtet gleiches ergebnis.
          dann Habe ich die ganze Maschiene neu gestartet.
          Evtl. setze ich ein neues System auf und spiel dann alles über den Backitup Adapter neu ein
            Thomas Braun Most Active last edited by Thomas Braun
            @jacke
            Das wird dir vermutlich nichts nutzen, bei mir baut das Ding mit aktuellem nodejs auch nicht mehr. Mit nodes@16 funktioniert es allerdings noch.
            https://forum.iobroker.net/topic/60999/simatic-s7-adapter-fehlermeldung
            https://github.com/mathiask88/node-snap7/issues/88
            Grothesk242 created this issue in mathiask88/node-snap7
            closed Won't build with nodejs19 #88
              Das ist natürlich schlecht hoffe da kommt ein update für den Adapter. dann warte ich mal aktuell kann ich nur Ring nicht mehr aktualisieren.
                @jacke sagte in s7 Adapter funktioniert nicht mehr noch node update:
                Das hat mit dem Adapter direkt auch nicht zu tun, das klemmt bei einer Dependency (node-snap7). Und die ist seit Jahren nicht mehr angepackt worden. Das sieht fürchte ich schlecht aus, in der derzeitigen Konstellation.
                  Ich habe gerade den Adapter auf einer frischen Installation gesartet und es funktioniert nun wollte ich ein Backup meiner alten installation auf dem neuen system einspielen hier mecker er mir den JS controller an
                  host.IoBrokerDeb Using backup file 2023_09_12-09_16_32_backupiobroker.tar.gz
                  iobroker controller daemon is not running
                  host.IoBrokerDeb OK.
                  The current version of js-controller differs from the version in the backup.
                  The js-controller version of the backup can not be restored automatically.
                  To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@5.0.12 --production" inside your ioBroker directory
                  If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                  nils@IoBrokerDeb:~$ iobroker update
                  Used repository: stable
                  Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Controller "js-controller": 4.0.24   , installed 4.0.24
                  Adapter    "s7"           : 1.3.15   , installed 1.3.15
                  gestern hat er auf meinem alten system von 4 auf 5 geupgraded
                  • mcm1957
                    mcm1957 @Jacke last edited by mcm1957
                    @jacke
                    Welchen js-controller hat den das Zielsystem?
                    Soweit ich weiß kann ein js-controller 5 backup NUR auf einem js-controller 5 System restauriert werden.
                    https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta
                    ACHTUNG backups inkompatibel bei Downgrades!!
                    Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
                      Jacke @mcm1957 last edited by
                      @mcm57
                      habe einen snapshot von gestern eingespielt mein altes system hat jetzt 4.0.23 das neue 4.0.24
                      npm i iobroker.js-controller@4.0.23 --production
                      mir wurde dieser befehl vorgeschlagen.
                      das IoBroker backup beinhaltet das auch NodeRed zigbee und javascript oder muss ich da noch ein einzelnes Backup einspielen?
                      • mcm1957
                        @jacke
                        Sorry,
                        da kann ich nicht helfen. Mir war nur die js-controller 5 breaking change Info bekannt auf die ich hinweisen wollte.
                        • tugsi
                          tugsi last edited by
                          Da ich den S7-Adapter auch brauche, kurz nachgefragt, ist mir jetzt noch nicht so klar geworden.
                          Läuft der Adapter noch, wenn ich den JS-Controller auf die 5er-Version hochziehe?
                          Liegt es nur daran, wenn ich node auf 18 hochrüste?
                          Gruß Thomas
                          • mcm1957
                            mcm1957 @tugsi last edited by
                            @tugsi
                            Leider kann ich deine Frage nicht beantworten.
                            Aber wenn jemand definitiv ein Problem mit Node 18 dokumentieren kann, dann bitte unbedingt ein passendes Issue incl. aktueller Logs beim Adapter anlegen, da node 16 seit 11.9.2023 EOL ist und in der nächsten Zeit von immer mehr Adaptern nicht mehr unterstützt werden wird. Ein Adapter der nicht mit node 18 läuft, ist daher ein Problemfall...
                            Das oben referenzierte Issue bezieht sich auf node 19 welches einerseits ein (veralteter) Nachfolger von node 18 ist und andrerseits ein unstable release. Dieses Issue wird sicher nicht intensiv beachtet. Relevant sind derzeit node 18 und node 20
                              Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                              @mcm57
                              Die Dependency node-snap7 baut nicht mit nodejs >18, mit 18 rumpelt es ein wenig. Jedenfalls auf meinem Testsystem.
                              Issue ist ja auch aus 12/2022. Damals war das aktuell und nodejs@20 noch nicht released.
                              tugsi 1 Reply Last reply Reply Quote 0
                              • tugsi
                                tugsi @Thomas Braun last edited by
                                @thomas-braun @mcm57
                                Ok, dann heißt es also einfach ausprobieren, in wieweit Probleme mit node18 und/oder JS-Controller 5.x auftreten.
                                Werde ich mal auf meine Agenda legen, wenn ich etwas mehr Zeit habe, widme ich mich dem, denn ich wollte mein System auf den neuesten Stand mal wieder bringen.
                                Danke für die Antworten.
                                827
