Hmip-broll in Iobroker einpflegen
@infinity-0 es fehlen noch die Einstellungen der hm-rpc Instanzen.
Das log bitte als Text in code-tags posten.
und mehr als paar abgeschnittene Zeilen
https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1@infinity-0 sagte in Hmip-broll in Iobroker einpflegen:
Muss ich Port 2010 im PI irgendwo freigeben?
was ist Pi?
@homoran raspberry pi wo iobroker drauf läuft.
2023-09-12 18:53:06.357 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true) 2023-09-12 18:53:06.364 - info: hm-rpc.1 (20202) Got terminate signal TERMINATE_YOURSELF 2023-09-12 18:53:06.370 - info: hm-rpc.1 (20202) xmlrpc -> 192.168.178.31:2010/ init ["http://192.168.178.64:2010",""] 2023-09-12 18:53:06.409 - info: hm-rpc.1 (20202) Disconnected 2023-09-12 18:53:06.412 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal 2023-09-12 18:53:06.411 - info: hm-rpc.1 (20202) terminating 2023-09-12 18:53:06.413 - info: hm-rpc.1 (20202) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-09-12 18:53:07.017 - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-12 18:53:09.968 - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 20346 2023-09-12 18:53:12.266 - info: hm-rpc.1 (20346) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.1, js-controller: 4.0.24 2023-09-12 18:53:12.468 - info: hm-rpc.1 (20346) xmlrpc server is trying to listen on 192.168.178.64:2010 2023-09-12 18:53:12.469 - info: hm-rpc.1 (20346) xmlrpc client is trying to connect to 192.168.178.31:2010/ with ["http://192.168.178.64:2010","iobroker:hm-rpc.1:1bbb6f167671f49033eef98deb0e3d33"] 2023-09-12 18:53:12.532 - info: hm-rpc.1 (20346) Connected 2023-09-12 18:53:12.579 - info: hm-rpc.1 (20346) xmlrpc <- listDevices ["iobroker:hm-rpc.1:1bbb6f167671f49033eef98deb0e3d33"] 2023-09-12 18:53:12.652 - info: hm-rpc.1 (20346) xmlrpc -> 0 devices 2023-09-12 18:53:13.653 - info: hm-rpc.1 (20346) xmlrpc <- newDevices 295 2023-09-12 18:53:13.724 - info: hm-rpc.1 (20346) new HMIP devices/channels after filter: 0MOD-EDIT: Code in code-tags gesetzt!
nee, da nicht, aber in der Firewall der ccu.
letztes Bild ist nach dem Start. Error ist dann weg.
was bedeutet das jetzt in Klartext?
@homoran in der ccu3 sind die ports freigegeben.
Zu dem error. Der war in der historie. Aber nach dem Löschen und Neustart der hm-rpc war er nicht mehr da.
@infinity-0 und jetzt ist der broll da?
@homoran der broll ist schon immer da. Nur sind die order leer. Und ich kann keine datenpunke auswählen um diese zum Beispiel in die iot clout einzufügen um den broll mit alexa zu steuern. Sorry Wenn ich mich hier evtl unverständlich ausdrücke. Ich bin schon froh überhaupt soweit gekommen zu sein.
Vllt hilft das noch weiter. Das sind die objektdaten vom broll
{ "_id": "hm-rpc.1.001118A9AC07E1", "type": "device", "common": { "name": "Rollladen Küche", "icon": "/icons/PushButton-2ch-wm_thumb.png" }, "native": { "TYPE": "HmIP-BROLL", "SUBTYPE": "BROLL", "ADDRESS": "001118A9AC07E1", "RF_ADDRESS": 6407650, "CHILDREN": [ "001118A9AC07E1:0", "001118A9AC07E1:1", "001118A9AC07E1:2", "001118A9AC07E1:3", "001118A9AC07E1:4", "001118A9AC07E1:5", "001118A9AC07E1:6", "001118A9AC07E1:7" ], "PARENT": "", "PARENT_TYPE": "", "INDEX": 0, "AES_ACTIVE": 1, "PARAMSETS": [ "MASTER", "SERVICE" ], "FIRMWARE": "1.10.16", "AVAILABLE_FIRMWARE": "1.10.16", "UPDATABLE": true, "FIRMWARE_UPDATE_STATE": "UP_TO_DATE", "VERSION": 5, "FLAGS": 1, "LINK_SOURCE_ROLES": "", "LINK_TARGET_ROLES": "", "DIRECTION": 0, "GROUP": "", "TEAM": "", "TEAM_TAG": "", "TEAM_CHANNELS": [], "INTERFACE": "", "ROAMING": 0, "RX_MODE": 0 }, "from": "system.adapter.hm-rega.0", "user": "system.user.admin", "ts": 1694450490948, "acl": { "object": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }MOD-EDIT: Code in code-tags gesetzt!
also ist der Fehler noch da!
@homoran sagte in Hmip-broll in Iobroker einpflegen:
nein, das hilft nicht.
und bitte niemals in früheren Posts Informationen hinzufügen!
https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1 -
@homoran ok nochmal sorry hierfür. Also ich bin mit dem Latein am Ende. Es kann ja nicht allzu viel falsch sein, ich sehe ja alle anderen Teilnehmer und deren Ordner sind mit Daten gefüllt. Nur eben bei den broll's nicht, dort sind die Ordner leer.
dazu brauche ich die Konfigurationen der hm-rpc Instanzen!
bitte liefere die doch endlich -
war hier
leider nicht zu sehen!
ich musste davon ausgehen dass die alle leer sind -
@homoran ich habe dir doch oben den Screenshot geschickt. Oder meinst du etwas anderes? Einstellungen von hm-rpc 1 habe ich gesendet. Das ist ja die für die homematic ip Geräte
nur eine von 2 Seiten, und rpc.0 gar nicht.
hattest du das log vom Neustart der rpc.1 gepostet?
am besten nach anhaken von "...neu einlesen" -
2023-09-12 18:53:06.357 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true) 2023-09-12 18:53:06.364 - info: hm-rpc.1 (20202) Got terminate signal TERMINATE_YOURSELF 2023-09-12 18:53:06.370 - info: hm-rpc.1 (20202) xmlrpc -> 192.168.178.31:2010/ init ["http://192.168.178.64:2010",""] 2023-09-12 18:53:06.409 - info: hm-rpc.1 (20202) Disconnected 2023-09-12 18:53:06.412 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal 2023-09-12 18:53:06.411 - info: hm-rpc.1 (20202) terminating 2023-09-12 18:53:06.413 - info: hm-rpc.1 (20202) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-09-12 18:53:07.017 - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-12 18:53:09.968 - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 20346 2023-09-12 18:53:12.266 - info: hm-rpc.1 (20346) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.1, js-controller: 4.0.24 2023-09-12 18:53:12.468 - info: hm-rpc.1 (20346) xmlrpc server is trying to listen on 192.168.178.64:2010 2023-09-12 18:53:12.469 - info: hm-rpc.1 (20346) xmlrpc client is trying to connect to 192.168.178.31:2010/ with ["http://192.168.178.64:2010","iobroker:hm-rpc.1:1bbb6f167671f49033eef98deb0e3d33"] 2023-09-12 18:53:12.532 - info: hm-rpc.1 (20346) Connected 2023-09-12 18:53:12.579 - info: hm-rpc.1 (20346) xmlrpc <- listDevices ["iobroker:hm-rpc.1:1bbb6f167671f49033eef98deb0e3d33"] 2023-09-12 18:53:12.652 - info: hm-rpc.1 (20346) xmlrpc -> 0 devices 2023-09-12 18:53:13.653 - info: hm-rpc.1 (20346) xmlrpc <- newDevices 295 2023-09-12 18:53:13.724 - info: hm-rpc.1 (20346) new HMIP devices/channels after filter: 0 2023-09-12 19:07:21.358 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:07:27.123 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:07:30.658 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:07:38.908 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:11:23.575 - info: host.iobroker stopInstance system.adapter.hm-rega.0 (force=false, process=true) 2023-09-12 19:11:23.582 - info: hm-rega.0 (6049) Got terminate signal TERMINATE_YOURSELF 2023-09-12 19:11:23.609 - info: hm-rega.0 (6049) terminating 2023-09-12 19:11:23.611 - info: hm-rega.0 (6049) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-09-12 19:11:23.629 - info: host.iobroker stopInstance system.adapter.hm-rega.0 send kill signal 2023-09-12 19:11:24.167 - info: host.iobroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-09-12 19:11:26.719 - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 20423 2023-09-12 19:11:29.128 - info: hm-rega.0 (20423) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.16.1, js-controller: 4.0.24 2023-09-12 19:11:29.265 - info: hm-rega.0 (20423) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT 2023-09-12 19:11:29.351 - info: hm-rega.0 (20423) ReGaHSS 192.168.178.31 up 2023-09-12 19:11:29.506 - info: hm-rega.0 (20423) time difference local-ccu 1s 2023-09-12 19:11:30.762 - info: hm-rega.0 (20423) request state values 2023-09-12 19:11:31.847 - info: hm-rega.0 (20423) Updated all datapoints 2023-09-12 19:11:31.861 - info: hm-rega.0 (20423) got 9 variables 2023-09-12 19:11:31.971 - info: hm-rega.0 (20423) added/updated 9 variables 2023-09-12 19:11:31.972 - info: hm-rega.0 (20423) deleted 0 variables 2023-09-12 19:11:31.987 - info: hm-rega.0 (20423) got 13 programs 2023-09-12 19:11:32.305 - info: hm-rega.0 (20423) added/updated 13 programs 2023-09-12 19:11:32.307 - info: hm-rega.0 (20423) deleted 0 programs 2023-09-12 19:11:32.327 - info: hm-rega.0 (20423) update rooms to enum.rooms 2023-09-12 19:11:32.366 - info: hm-rega.0 (20423) update functions to enum.functions 2023-09-12 19:11:32.404 - info: hm-rega.0 (20423) update favorites to enum.favorites 2023-09-12 19:18:23.768 - info: worx.0 (2670) Refresh token for MQTT-Connection 2023-09-12 19:18:23.771 - info: worx.0 (2670) Disconnected 2023-09-12 19:18:24.214 - info: worx.0 (2670) MQTT connected to: iot.eu-west-1.worxlandroid.com 2023-09-12 19:20:18.518 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20 admin 2023-09-12 19:21:18.980 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:21:30.013 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:23:21.661 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:26:49.389 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20 2023-09-12 19:26:58.740 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20!MOD-EDIT: Code in code-tags gesetzt!
MOD-EDIT: formatiert
@infinity-0 trag mal die Callback Adressen ein.
hattest du den Haken gesetzt?
@homoran was ist die callback Adresse? Die Adresse vom raspberry pi mit iobroker drauf. Ja Haken hatte ich schon gesetzt.
ja
und der ist jetzt weg?
dann bitte den leeren Ordner vom hmbroll in den Objekten löschen, den Haken erneut setzen und speichern und schließen -
Ja mega. Es hat geklappt. Ich musste noch die IP Adresse umstellen. Ich danke die so sehr für deine Mühe.
wieso?
auf 0.0.0.0?wie kommst du darauf?
Das gab es noch zur Auswahl. Nur nur damit hat es letztendlich geklappt.
