    3. Cloud Dienste
    4. Hmip-broll in Iobroker einpflegen
    • I
      Infinity 0 @Homoran last edited by Homoran
      2023-09-12 18:53:06.357 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
      2023-09-12 18:53:06.364 - info: hm-rpc.1 (20202) Got terminate signal TERMINATE_YOURSELF
      2023-09-12 18:53:06.370 - info: hm-rpc.1 (20202) xmlrpc -> 192.168.178.31:2010/ init ["http://192.168.178.64:2010",""]
      2023-09-12 18:53:06.409 - info: hm-rpc.1 (20202) Disconnected
      2023-09-12 18:53:06.412 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal
      2023-09-12 18:53:06.411 - info: hm-rpc.1 (20202) terminating
      2023-09-12 18:53:06.413 - info: hm-rpc.1 (20202) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-12 18:53:07.017 - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-12 18:53:09.968 - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 20346
      2023-09-12 18:53:12.266 - info: hm-rpc.1 (20346) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.16.1, js-controller: 4.0.24
      2023-09-12 18:53:12.468 - info: hm-rpc.1 (20346) xmlrpc server is trying to listen on 192.168.178.64:2010
      2023-09-12 18:53:12.469 - info: hm-rpc.1 (20346) xmlrpc client is trying to connect to 192.168.178.31:2010/ with ["http://192.168.178.64:2010","iobroker:hm-rpc.1:1bbb6f167671f49033eef98deb0e3d33"]
      2023-09-12 18:53:12.532 - info: hm-rpc.1 (20346) Connected
      2023-09-12 18:53:12.579 - info: hm-rpc.1 (20346) xmlrpc <- listDevices ["iobroker:hm-rpc.1:1bbb6f167671f49033eef98deb0e3d33"]
      2023-09-12 18:53:12.652 - info: hm-rpc.1 (20346) xmlrpc -> 0 devices
      2023-09-12 18:53:13.653 - info: hm-rpc.1 (20346) xmlrpc <- newDevices 295
      2023-09-12 18:53:13.724 - info: hm-rpc.1 (20346) new HMIP devices/channels after filter: 0
      2023-09-12 19:07:21.358 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:07:27.123 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:07:30.658 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:07:38.908 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:11:23.575 - info: host.iobroker stopInstance system.adapter.hm-rega.0 (force=false, process=true)
      2023-09-12 19:11:23.582 - info: hm-rega.0 (6049) Got terminate signal TERMINATE_YOURSELF
      2023-09-12 19:11:23.609 - info: hm-rega.0 (6049) terminating
      2023-09-12 19:11:23.611 - info: hm-rega.0 (6049) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-12 19:11:23.629 - info: host.iobroker stopInstance system.adapter.hm-rega.0 send kill signal
      2023-09-12 19:11:24.167 - info: host.iobroker instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-12 19:11:26.719 - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 20423
      2023-09-12 19:11:29.128 - info: hm-rega.0 (20423) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v18.16.1, js-controller: 4.0.24
      2023-09-12 19:11:29.265 - info: hm-rega.0 (20423) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      2023-09-12 19:11:29.351 - info: hm-rega.0 (20423) ReGaHSS 192.168.178.31 up
      2023-09-12 19:11:29.506 - info: hm-rega.0 (20423) time difference local-ccu 1s
      2023-09-12 19:11:30.762 - info: hm-rega.0 (20423) request state values
      2023-09-12 19:11:31.847 - info: hm-rega.0 (20423) Updated all datapoints
      2023-09-12 19:11:31.861 - info: hm-rega.0 (20423) got 9 variables
      2023-09-12 19:11:31.971 - info: hm-rega.0 (20423) added/updated 9 variables
      2023-09-12 19:11:31.972 - info: hm-rega.0 (20423) deleted 0 variables
      2023-09-12 19:11:31.987 - info: hm-rega.0 (20423) got 13 programs
      2023-09-12 19:11:32.305 - info: hm-rega.0 (20423) added/updated 13 programs
      2023-09-12 19:11:32.307 - info: hm-rega.0 (20423) deleted 0 programs
      2023-09-12 19:11:32.327 - info: hm-rega.0 (20423) update rooms to enum.rooms
      2023-09-12 19:11:32.366 - info: hm-rega.0 (20423) update functions to enum.functions
      2023-09-12 19:11:32.404 - info: hm-rega.0 (20423) update favorites to enum.favorites
      2023-09-12 19:18:23.768 - info: worx.0 (2670) Refresh token for MQTT-Connection
      2023-09-12 19:18:23.771 - info: worx.0 (2670) Disconnected
      2023-09-12 19:18:24.214 - info: worx.0 (2670) MQTT connected to: iot.eu-west-1.worxlandroid.com
      2023-09-12 19:20:18.518 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20 admin
      2023-09-12 19:21:18.980 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:21:30.013 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:23:21.661 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:26:49.389 - info: admin.0 (2373) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2023-09-12 19:26:58.740 - info: admin.0 (2373) <== Disconnect system.user.admin from ::ffff:192.168.178.20!
      MOD-EDIT: formatiert
        Homoran Global Moderator Administrators @Infinity 0 last edited by
        @infinity-0 trag mal die Callback Adressen ein.
        @infinity-0 sagte in Hmip-broll in Iobroker einpflegen:
        hattest du den Haken gesetzt?
        • I
          @homoran was ist die callback Adresse? Die Adresse vom raspberry pi mit iobroker drauf. Ja Haken hatte ich schon gesetzt.
            ja
            und der ist jetzt weg?
            dann bitte den leeren Ordner vom hmbroll in den Objekten löschen, den Haken erneut setzen und speichern und schließen
            • I
              Ja mega. Es hat geklappt. Ich musste noch die IP Adresse umstellen. Ich danke die so sehr für deine Mühe. Screenshot_2023-09-12-20-46-21-565_com.android.chrome-edit.jpg
                Homoran Global Moderator Administrators @Infinity 0 last edited by Homoran
                wieso?
                auf 0.0.0.0?
                wie kommst du darauf?
                • I
                  Das gab es noch zur Auswahl. Nur nur damit hat es letztendlich geklappt.
                    dann hast du irgendwas mit deinem Netzwerk.
                    Die hier eingestellte IP wird der Ccu mitgeteilt damit sie von sich aus jede Änderung da hinschickt.
                    An eine 0.0.0.0 kann sie nichts schicken.
                    Das klappt nur, weil du jetzt zusätzlich eine Callback Adresse vergeben hast, die der CCU als Adresse mitgeteilt wird.
                    Das ist aber nur bei speziellen Netzwerkkonfigugrationen (z.B. Docker) notwendig.
                    In normalen Netzen muss es mit den früheren Einstellungen funktionieren
                    • Codierknecht
                      Codierknecht Developer Most Active @Homoran last edited by
                      @homoran sagte in Hmip-broll in Iobroker einpflegen:
                      Ich glaube (hoffe) er meint das hier:
                        iobroker teilt der CCU [.31:2010] mit Änderungen an die [.64:2010] zu schicken und das intern mit iobroker:hm-rpc.1.... zu dokumentieren
                          Homoran Global Moderator Administrators @Codierknecht last edited by
                          @codierknecht klar meint er das.
                          aber dort muss eine "von extern erreichbare IP" eingetragen werden, da diese von der CCU aufgerufen werden muss.
                          • Codierknecht
                            Ist bei mir genau so eingestellt. 0.0.0.0 heißt doch "alle"
                              @codierknecht sagte in Hmip-broll in Iobroker einpflegen:
                              nicht in dem Falle.
                              du dann auch
                              • Codierknecht
                                du dann auch
                                Genau.
                                Adapter-Adresse auf 0.0.0.0 und dafür die passende Callback-Adresse (die des Docker-Host) eingetragen.
                                  die des Docker-Host
                                  Dann muss das so.
                                  • Codierknecht
                                    Docker ist halt nicht normal 😁 😁 😁
                                    • I
                                      Infinity 0 @Codierknecht last edited by
                                      @codierknecht so ich habe jetzt alle broll drin. Auch mit der richtigen IP hat es geklappt. Allerdings musste ich jeden broll einzeln einpflegen. Alle auf einmal hat er nicht gemacht. Aber egal... Hauptsache jetzt klappt es. Viele vielen Dank.
                                      1.4k
                                      2673
