    4. Huawei Sun2000 & ioBroker via JS script funktioniert
    • bahnuhr
      bahnuhr Forum Testing Most Active @Chris_B last edited by
      @chris_b
      @baerengraben
      So, habe nun folgendes eingestellt:
      Bekomme nun sehr viele DP gefüllt.
      var currentinverter = 2;
      Const ModBusIDs = [16,1];
      const PowerMeterID = 0;
      const BatteryUnits = [[3, 0], [0, 0]];
      Bei diesen DP:
      // These register spaces need to be read
      const RegToRead =
      [ [32000, 116],   // inverter status -                            read fast
        [37000, 68],    // battery information -                        read fast
        [37100, 114],   // meter info -                                 read fast
        [37700, 100],   // battery information -                        read fast
        [38200, 100],   // additional battery information -             read fast
        [30000, 81],    // model info, SN, max Power (static info) -    read slow
        [37800, 100],   // additional battery information -             read slow
        [38300, 100],   // additional battery information -             read slow
        [38400, 100],   // additional battery information -             read slow
        [47081, 8]      // additional battery information -             read slow
      //[35300, 40]     // inverter power adjustments -                 do not read
      kommen Fehler im log:
      javascript.0
      2023-09-08 16:20:57.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 37700 from id: 1 with error: undefined
      javascript.0
      2023-09-08 16:20:52.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 37100 from id: 1 with error: undefined
      javascript.0
      2023-09-08 16:20:47.914	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 37000 from id: 1 with error: undefined
      javascript.0
      2023-09-08 16:20:42.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 32000 from id: 1 with error: undefined
      javascript.0
      2023-09-08 16:20:37.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 47081 from id: 16 with error: undefined
      javascript.0
      2023-09-08 16:20:32.914	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 38400 from id: 16 with error: undefined
      javascript.0
      2023-09-08 16:20:27.915	warn	script.js.Scripte.Geraete.Huawei_geändert: Error received reading address 38300 from id: 16 with error: undefined
      javascript.0
      2023-09-08 16:20:27.883	warn	script.js.Scripte.Geraete.Huawei_Original_V4: Error received reading address 37700 from id: 16 with error: Slave device busy (retry request again later)
      Soll/kann ich die einfach auskommentieren.
      mfg
        jokerjo1000 last edited by
        ich hoffe ich darf das hier einmal schreiben?
        Ich habe laienhafte Kenntnisse von der ganzen Materie, jedoch nicht ausreichend um hier mitzukommen.
        Habe auch eine Huawei PV Anlage mit Wechselrichter Speicher und Power Meter. Auch ein Raspi mit Iobroker ist am laufen. Daten hole ich mir u.a. von Influx und evcc. Gerne würde ich die Modbus Daten in den Iobroker bekommen. Hier hört aber mein Wissenstand auf. Ihr schreibt hier viel was für Kenner etwas ist aber leider nicht für "Anfänger". Es wäre echt klasse wenn jemand vielleicht einmal Lust hat uns Laien etwas mitzunehmen. Habe versucht das Skript von Chris im Iobroker zu installieren, jedoch ohne Erfolg. Es haut lediglich nur Fehlermeldungen raus. Das liegt sicherlich an mir und ich würde mich freuen das auch einmal hin zu bekommen. Es wäre also schön wenn jemand uns Newbies etwas itnehmen könnte.
        DANKE !!!
          palantin @bahnuhr last edited by
          @bahnuhr hast du Daten unter "Meter"
          • bahnuhr
            bahnuhr Forum Testing Most Active @palantin last edited by
            @palantin sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
            ja, hat aber gedauert.
              @bahnuhr
              welche Kommunikationsid steht bei dir in der SolarApp von Huawei vom SmartMeter?
              • bahnuhr
                @bahnuhr
                keine Ahnung was du meinst bzw. wo ich sowas finde
                  hussi @jokerjo1000 last edited by
                  @jokerjo1000 Ich habe auch von Null angefangen. Evtl. kann ich dir Helfen.
                  Der erste Schritt ist, dass du unter Instanzen in den Einstellungen von Javascript das NPM Modul "modbus-serial" hinzufügst. Dazu vorher:
                  https://www.npmjs.com/package/modbus-serial
                  Anschließend gehst du zu den Scripten und legst dir ein neues Javascript mit dem Inhalt von Chris´ github:
                  https://github.com/ChrisBCH/SunLuna2000_iobroker
                  Dann müssen in dem Script die Daten deiner PV Anlage eingegeben werden. IP, etc.
                  Nun solltest du die Daten in den Objekten unter javascript > 0 > Solarpower sehen.
                  • 0
                    0815_Peter @badsnoopy667 last edited by
                    @badsnoopy667
                    Hallo in die Runde,
                    vielleicht hab ich was überlesen bei den 395 Antworten, wenn ja bitte entschuldigt.
                    Das schreiben der U32 Zahl (Maximum Charge and Discharge Power) funktioniert mit den Flow vom badsnoopy667 hab vielen dank.
                    Wenn ich die % Werte der SOC Charge Cutoff und Discharge Cutoff einstellen will muss ich eine U16 Zahl schicken zum WR.
                    Ich werde aus der Beschreibung für die Funktion im Flow nicht so richtig schlau.
                    https://stevesnoderedguide.com/modbus-writing-data
                    Das mit den GAIN habe ich schon beachtet --> eine 100 sind 10% --> trotzdem will der WR meine Werte nicht 😞 also sollte es auch der Funktion liegen die den String aufarbeitet.
                    Kann mir bitte jemand helfen wie die Funktion im Flow aussehen muss, damit der WR die % Werte annimmt die geschickt werden.
                      badsnoopy667 @0815_Peter last edited by
                      @0815_peter
                      Ich glaube Du hast in den falschen Thread gepostet.
                      Aber versuch's mal hiermit:
                      var fc = 16;
                      var sa = 50;
                      var addresses = 2;
                      var buf = Buffer.alloc(2); // create a buffer with 2 bytes for UINT16
                      buf.writeUInt16BE(msg.payload); // write UINT16 value to the buffer
                      var value = buf.readUInt16BE(); // read the UINT16 value from the buffer
                      msg.slave_ip = "192.168.1.76";
                      msg.payload = value;
                      return msg;
                      • 0
                        @badsnoopy667
                        Danke für deine Antwort
                        okay ich hab hier geantwortet, da du am Anfang von diesen Thread gezeigt hast wie du auf die Register schreibst.
                        Leider klappt deine Funktion nicht...der WR nimmt die Werte nicht 😞
                        ich hab meinen Flow mal hier angehangen vielleicht sieht du ja gleich den Fehler.
                        flows.json
                        • bahnuhr
                          bekomme immer mal wieder eine solche Meldung im log:
                          Error received reading address 37000 from id: 16 with error: Slave device busy (retry request again later)
                          Kann man da irgendwo was einstellen ?
                            R4 @bahnuhr last edited by
                            @bahnuhr
                            Die Zahl am Ende der Funktion setInterval() - also die Intervalldauer - erhöhen hilft die Anzahl dieser Meldungen zu verringern.
                            (Die Fehlermeldung kommt bei mir mit 4000ms auch immer wieder, macht aber nix, da wird dann halt mal ein Registerbereich nicht aktualisiert.)
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @R4 last edited by
                              @r4
                              Danke für die Info.
                              Stand bei mir schon auf 5000.
                              Habs jetzt mal auf 10000 gesetzt.
                              Mal schauen.
                                R4 @bahnuhr last edited by R4
                                @bahnuhr
                                Außer einem "schöneren" Log hast du damit aber nichts gewonnen:
                                Die Daten (alle) werden dann nur noch alle 10*RegFast Sekunden, also 50s bei Standardwerten, statt alle 25s aktualisiert.
                                Die Fehlermeldung wird wohl dennoch hin und wieder auftauchen, und so musst du eben auf diesen Teil der Daten 100s warten, statt 50s bei der ursprünglichen Einstellung.
                                Huawei ist hier ein bisschen (arg) langsam, damit muss man offenbar leben *). Den Fehler kann man aber ignorieren, du hast dann lediglich kurzzeitig ein wenig veraltete Daten.
                                *) Mit Aufwand zu umgehen
                                  @palantin said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                  PowerMeter id auf 0
                                  bin ich der Einzige, bei dem das Powermeter nichts liefert? Was habt ihr bei PowerMeterID eintetragen, wenn es bei 0 nicht funktioniert.
                                    juggi1962 @palantin last edited by
                                    @palantin Ich habe 0 beim PowerMeter und ich bekomme Daten.
                                    P A 2 Replies Last reply Reply Quote 0
                                      palantin @juggi1962 last edited by
                                      @juggi1962 bei mir ist leider noch immer nichts. Noch habe ich keine Lösung gefunden - die anderen Datenpunkte auf WR 1 und WR 2 in der Kaskade funktionieren problemlos.
                                        R4 @palantin last edited by
                                        @palantin
                                        An welchem WR ist denn der Powermeter angeschlossen?
                                        Schon mal "1" getestet?
                                        S P 2 Replies Last reply Reply Quote 0
                                          Skydream @R4 last edited by
                                          Moin,
                                          ein ganz dolles Danke für diese Script, ich habe es heute installiert und nach anfänglichem totstellen des Modbus sind dann auch daten gekommen 😊
                                          Inzwischen habe ich auch die auskommentierten Zeilen für den zweiten String gefunden....sehr schön. Man ist je etwas erschlagen von der fülle an daten, aber besser haben und nicht brauchen wie brauchen und nicht haben.
                                          Ist es normal das die Werte nicht 100% zu denen im Webportal passen?
                                          Sind die dort geglättet?
                                          SUN2000-8KTL-M1 mit zwei Strings, 5KW Batterie, Dongle per Wifi angebunden.
                                            palantin @R4 last edited by
                                            @r4 Ja, leider kein Effekt - hier erhalte ich die selben Fehler wie bei "11"
                                            477
                                            90523
