    4. Speicherprobleme - Absturz?
      Schandmann @Homoran last edited by
      iob diag:
      root@iobroker:/opt/iobroker# iob diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
        iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
        iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      top:
        Homoran Global Moderator Administrators @Schandmann last edited by
        @schandmann sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
        iob diag
        da ist aber einiges faul
        iob stop
        iob fix
        iob start
        iob diag
        top:
        redis ist IMHO auch hyperaktiv
        Mach mal den fix und den diag, ich glieder das hier aus
          Schandmann @Schandmann last edited by
          @Homoran
          Hat jetzt mit iob diag geklappt...
                              v.2023-04-16
          Operatingsystem:        Ubuntu 20.04.4 LTS
          Kernel:                 5.4.0-162-generic
          Installation:           microsoft
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                0
          X-Server:               false
          Boot Target:            graphical.target
          Pending OS-Updates:     95
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v16.20.1
                                 /usr/bin/node           v16.20.1
                                 /usr/bin/npm            8.19.4
                                 /usr/bin/npx            8.19.4
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:           3.9G        3.5G        259M        0.0K        170M        223M
          Swap:          3.3G        738M        2.5G
          Total:         7.2G        4.2G        2.8G
          Active iob-Instances:   38
          Active repo(s): Stable (default)
          ioBroker Core:          js-controller           4.0.24
                                 admin                   6.6.1
          /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                 throw e;
          Error: Connection is closed.
             at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
             at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
             at Object.onceWrapper (node:events:628:26)
             at Socket.emit (node:events:513:28)
             at TCP.<anonymous> (node:net:301:12)
          Emitted 'error' event on ScanStream instance at:
             at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
             at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
             at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
             at processTicksAndRejections (node:internal/process/task_queues:96:5)
          ioBroker Status:
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                28968
          States:                 24818
          Size of iob-Database:
          31M     /opt/iobroker/iobroker-data/objects.jsonl
          18M     /opt/iobroker/iobroker-data/objects.json.migrated
          18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          4.2M    /opt/iobroker/iobroker-data/states.json.bak
            Homoran Global Moderator Administrators @Schandmann last edited by Homoran
            @schandmann sagte in Speicherprobleme - Absturz?:
            ach du grüne Neune
            und das bei Windows??
            oder wie passt das Ganze zu Ubuntu?
            bitte
            @homoran sagte in Speicherprobleme - Absturz?:
            besser iob diag komplett
              das mit Microsoft könnte daran liegen, dass ich womöglich vor Jahren mal zu testzwecken dort gestartet bin. Bin ansonsten schon über einige Systeme gezogen (RockPI,RaspberryPi und nun Synology)
              Werde die Updates für Ubuntu mal fahren....
              diag komplett muss ich mal schauen wie das geht...
                dann hast du aber eine ganz krumme Installation.
                auch wenn @thomas-Braun sich ebenso wie ich nicht mit den Tiefen vom M$ aukennt, kann er diese Information vielleicht auflösen
                und Synology heisst womöglich auch noch Docker!???
                  auf der Synology läuft Ubuntu als VM und darauf dann Iobroker.
                  also nicht Docker.
                  Docker ist der Teufel. 🙂
                    Thomas Braun Most Active @Schandmann last edited by
                    @schandmann
                    Zu iob_diag:
                    Nie als root agieren. Leg dir einen user mit sudo-Recht an und spring damit durch das System.
                    Updates einspielen.
                       throw e;
                    Komischer Fehler.
                      Schandmann @Thomas Braun last edited by
                      Updates fahre ich noch. Muss gleich wieder zur Schicht. Melde mich!
                        Und dann immer stumpf Verzeichnisse hin- und herkopiert?
                        Das kann nicht vernünftig funktionieren.
                          habe immer Backups eingespielt. Habe nie stumpf Verzeichnisse kopiert.
                            dann ist da aber irgendwann ein Wurm mit den Backups reingekommen.
                              @schandmann
                              kommt auch aus der Betriebssystem-Ebene (genauer von systemd), nicht vom ioBroker.
                                @thomas-braun sagte in Speicherprobleme - Absturz?:
                                wäre es dann möglich dass
                                die anscheinend verwendete Virtualization Station (???) mit einem MS Produkt unter der Haube arbeitet?
                                leider hatte @Schandmann diese Aussage nicht näher spezifiziert wie due VM eingebunden ist.
                                  Keine Ahnung was da werkelt.
                                    Moin Leute,
                                    habe noch einige Versuche gestartet um herauszufinden, warum sich Iobroker immer übernommen hat.
                                    Fazit:
                                    -Ohne den aktiven Energieflussadapter lief das System stabil (trotz knappem RAM-Speicher).
                                    -habe der VM (auf der Iobroker läuft) noch 1,5 GB RAM extra freigegeben, keine Verbesserung.
                                    -habe dann auf der Vis vom Energieflussadapter angefangen alle Datenquellen in den Elementen rauszunehmen und auch die Datenquellen unter "verfügbare Datenquellen" zu löschen.
                                    -Dann bin ich darauf gestoßen, dass ich eine Datenquelle nicht löschen kann, da diese noch benutzt wird.
                                    -Habe dann alle Elemente durchgeklickt und tatsächlich ein Rechteck gefunden (mit der Datenquelle), dass mir visuell nicht angezeigt wurde, ebenfalls war die Datenquelle in dem Dropdownmenu der Elemente nicht ersichtlich. Das Rechteck habe ich dann gelöscht.
                                    -Schlussendlich habe ich wieder alle Datenquellen nach und nach angelegt und zwischendurch den Adapter neu gestartet um die Performance zu testen.
                                    -Es scheint, als sei das Problem behoben.
                                    Sollt es dennoch Probleme geben, würde ich mich wieder melden!
                                    Bis hierhin, vielen Dank an alle die geholfen haben!!!
                                    Habt ein schönes Wochenende!!!
                                    mfG
                                      @schandmann danke für das Feedback
                                      da hatte sich dann ggf. was verschluckt, möglicherweise als du viele Daten gespeichert hast.
                                      @skb hat das gerade gefixt
                                      1009
