    4. js-controller 5.0.x jetzt für alle User im STABLE!
    • FredF
      FredF Most Active Forum Testing @sigi234 last edited by
      @sigi234 Deswegen wird es Zeit dass das mal aktualisiert wird
      • Fabio
        Fabio @foxriver76 last edited by
        @foxriver76 vielen vielen Dank für eure Mühen. 👍 Update hat problemlos geklappt.
        Fabio
          myssv last edited by
          Auch bei mir problemlos vollzogen
            liv-in-sky @foxriver76 last edited by
            @foxriver76
            hast du da eine idee - ansonsten lief alles ganz gut
            vis geht im moment nicht, da ws.5 genutzt wird
            host.iobroker59
            2023-09-14 18:27:02.983	warn	Do not restart adapter system.adapter.ws.5 because restart loop detected
            host.iobroker59
            2023-09-14 18:27:02.983	error	instance system.adapter.ws.5 terminated with code 6 (UNCAUGHT_EXCEPTION)
            host.iobroker59
            2023-09-14 18:27:02.983	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
            host.iobroker59
            2023-09-14 18:27:02.983	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
            host.iobroker59
            2023-09-14 18:27:02.983	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
            host.iobroker59
            2023-09-14 18:27:02.983	error	Caught by controller[1]: Error: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
            host.iobroker59
            2023-09-14 18:27:02.983	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            ws.5
            2023-09-14 18:27:02.310	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            ws.5
            2023-09-14 18:27:02.290	error	The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
            ws.5
            2023-09-14 18:27:02.289	error	Error: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
            ws.5
            2023-09-14 18:27:02.186	error	unhandled promise rejection: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
            ws.5
            2023-09-14 18:27:02.185	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            ws.5
            2023-09-14 18:27:02.179	error	Invalid pattern on subscribe: The pattern " scale(1, 1)" is not a valid ID pattern
            ws.5
            2023-09-14 18:27:02.178	error	Invalid pattern on subscribe: The pattern "0% { transform: scale(1, 1)" is not a valid ID pattern
            ws.5
            2023-09-14 18:26:58.656	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
            host.iobroker59
            2023-09-14 18:26:27.342	error	instance system.adapter.ws.5 terminated with code 6 (UNCAUGHT_EXCEPTION)
            UND sayit
            beim start versuch
            Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 93. This version of Node.js requires NODE_MODULE_VERSION 108. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
              @foxriver76
              also sayit hat sich erledigt - neu installiert und jetzt kommt kein fehler
              das mit ws.5 ist etwas seltsam - habe nur ws.0 und ws.1 aktiv und ws.5 - habe jetzt ws5 abgeschaltet und in ws.2 definiert - dann startet alles ohne fehler und die vis ist wieder da
              diese ganzen ws.x hatte ich mal installiert und getestet, ob meine tablets die vis stabiler anzeigen, wenn jedes tablet eigene instanzen hat
              bleibt n nur noch diese warnung:
                liv-in-sky @foxriver76 last edited by liv-in-sky
                @foxriver76
                zu früh gefreut - egal, was ich in der web.x instanz einstelle (integriert, ws oder socket - alles stürzt ab) diesmal dieser fehler
                also keine vis 😞
                host.iobroker59
                2023-09-14 18:53:17.401	error	instance system.adapter.web.5 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.iobroker59
                2023-09-14 18:53:17.401	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                host.iobroker59
                2023-09-14 18:53:17.401	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
                host.iobroker59
                2023-09-14 18:53:17.401	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
                host.iobroker59
                2023-09-14 18:53:17.401	error	Caught by controller[1]: Error: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
                host.iobroker59
                2023-09-14 18:53:17.401	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                web.5
                2023-09-14 18:53:16.746	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee2mqtt.0.0x540f57fffef3f8cf.current_heating_setpoint, sourceObj={"type":"state","common":{"id":"current_heating_setpoint","prop":"current_heating_setpoint","name":"Temperature setpoint","role":"level.temperature","write":true,"read":true,"type":"number","min":5,"max":30,"unit":"°C","def":5},"native":{},"from":"system.adapter.zigbee2mqtt.0","user":"system.user.admin","ts":1694708659978,"_id":"zigbee2mqtt.0.0x540f57fffef3f8cf.current_heating_setpoint","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                web.5
                2023-09-14 18:53:16.746	error	Alias subscription error. Please check your alias definitions: sourceId=zigbee2mqtt.0.0x84ba20fffe2dca6b.current_heating_setpoint, sourceObj={"type":"state","common":{"id":"current_heating_setpoint","prop":"current_heating_setpoint","name":"Temperature setpoint","role":"level.temperature","write":true,"read":true,"type":"number","min":5,"max":30,"unit":"°C","def":5},"native":{},"from":"system.adapter.zigbee2mqtt.0","user":"system.user.admin","ts":1694708659054,"_id":"zigbee2mqtt.0.0x84ba20fffe2dca6b.current_heating_setpoint","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                web.5
                2023-09-14 18:53:16.746	error	Alias subscription error. Please check your alias definitions: sourceId=fritzdect.0.DECT_119610737080.tsoll, sourceObj={"type":"state","common":{"name":"Setpoint Temperature","type":"number","min":0,"max":32,"unit":"°C","read":true,"write":true,"role":"value.temperature","desc":"Setpoint Temperature"},"native":{},"from":"system.adapter.fritzdect.0","user":"system.user.admin","ts":1611662566181,"_id":"fritzdect.0.DECT_119610737080.tsoll","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                web.5
                2023-09-14 18:53:16.696	error	The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
                web.5
                2023-09-14 18:53:16.695	error	Error: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                web.5
                2023-09-14 18:53:16.647	error	unhandled promise rejection: The pattern "io. scale(1.3, 1.3)" is not a valid ID pattern
                web.5
                2023-09-14 18:53:16.647	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                web.5
                2023-09-14 18:53:16.642	error	Invalid pattern on subscribe: The pattern " scale(1, 1)" is not a valid ID pattern
                web.5
                2023-09-14 18:53:16.641	error	Invalid pattern on subscribe: The pattern "0% { transform: scale(1, 1)" is not a valid ID pattern
                iob diag:
                Copy text starting here:
                                    v.2023-04-16
                Operatingsystem:        Debian GNU/Linux 12 (bookworm)
                Kernel:                 6.2.16-6-pve
                Installation:           lxc
                Timezone:               Europe/Berlin (CEST, +0200)
                User-ID:                0
                X-Server:               false
                Boot Target:            graphical.target
                Pending OS-Updates:     10
                Pending iob updates:    3
                Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                       /usr/bin/node           v18.17.1
                                       /usr/bin/npm            9.6.7
                                       /usr/bin/npx            9.6.7
                Recommended versions are nodejs 18.x.y and npm 9.x.y
                MEMORY:
                Mem:             11G        8.0G        438M        1.8M        3.3G        3.8G
                Swap:           2.1G          0B        2.1G
                Total:           13G        8.0G        2.6G
                Active iob-Instances:   74
                Active repo(s): beta
                ioBroker Core:          js-controller           5.0.12
                                       admin                   6.10.1
                Objects type: jsonl
                States  type: redis
                + system.adapter.admin.0                  : admin                 : iobroker59                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.admin.1                  : admin                 : iobroker59                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                 system.adapter.admin.2                  : admin                 : iobroker59                               - disabled, port: 8089, bind: 0.0.0.0, run as: admin
                 system.adapter.admin.3                  : admin                 : iobroker59                               - disabled, port: 8071, bind: 0.0.0.0, run as: admin
                 system.adapter.web-speedy.0             : web-speedy            : iobroker59                               - disabled
                + system.adapter.web.0                    : web                   : iobroker59                               -  enabled, port: 8082, bind: 192.168.178.59, run as: admin
                + system.adapter.web.1                    : web                   : iobroker59                               -  enabled, port: 8072, bind: 192.168.178.59, run as: admin
                 system.adapter.web.2                    : web                   : iobroker59                               - disabled, port: 8098, bind: 0.0.0.0, run as: admin
                 system.adapter.web.3                    : web                   : iobroker59                               - disabled, port: 8074, bind: 0.0.0.0, run as: admin
                 system.adapter.web.4                    : web                   : iobroker59                               - disabled, port: 8075, bind: 0.0.0.0, run as: admin
                + system.adapter.web.5                    : web                   : iobroker59                               -  enabled, port: 8076, bind: 0.0.0.0, run as: admin
                 system.adapter.web.6                    : web                   : iobroker59                               - disabled, port: 8077, bind: 0.0.0.0, run as: admin
                 system.adapter.web.7                    : web                   : iobroker59                               - disabled, port: 8078, bind: 0.0.0.0, run as: admin
                + system.adapter.webcal.0                 : webcal                : iobroker59                               -  enabled
                + system.adapter.webcal.1                 : webcal                : iobroker59                               -  enabled
                + system.adapter.webcal.2                 : webcal                : iobroker59                               -  enabled
                Objects:                71340
                States:                 78158
                Size of iob-Database:
                163M    /opt/iobroker/iobroker-data/objects.jsonl
                26M     /opt/iobroker/iobroker-data/states.jsonl
                Installed ioBroker-Instances
                Used repository: beta
                Adapter    "admin"        : 6.10.1   , installed 6.10.1
                Adapter    "alexa-timer-vis": 0.2.0  , installed 0.2.0
                Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                Adapter    "calendar"     : 1.2.0    , installed 1.2.0
                Adapter    "contact"      : 1.1.3    , installed 1.1.3
                Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "device-reminder": 2.0.1  , installed 1.2.9  [Updatable]
                Adapter    "email"        : 1.2.0    , installed 1.2.0
                Adapter    "esphome"      : 0.2.4    , installed 0.2.4
                Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                Adapter    "fuelpricemonitor": 0.3.6 , installed 0.3.6-alpha.0 [Updatable]
                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                Adapter    "gotify"       : 0.2.0    , installed 0.2.0
                Adapter    "history"      : 2.2.6    , installed 2.2.6
                Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "imap"         : 0.1.1    , installed 0.1.1
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                Adapter    "meross"       : 1.15.1   , installed 1.15.1
                Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mpd"          : 1.1.1    , installed 1.1.1
                Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                Adapter    "odl"          : 2.0.5    , installed 2.0.5
                Adapter    "openweathermap": 0.4.3   , installed 0.4.3
                Adapter    "parcel"       : 0.1.2    , installed 0.1.2
                Adapter    "parser"       : 2.0.5    , installed 2.0.5
                Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                Adapter    "pixelit"      : 1.1.1    , installed 1.1.1
                Adapter    "plex"         : 1.1.0    , installed 1.1.0
                Adapter    "proxmox"      : 2.0.2    , installed 2.0.2
                Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
                Adapter    "pushbullet"   : 1.0.1    , installed 1.0.1
                Adapter    "pushover"     : 3.0.4    , installed 3.0.4
                Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
                Adapter    "socketio"     : 6.5.3    , installed 6.5.3
                Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                Adapter    "telegram-menu": 0.6.7    , installed 0.6.7
                Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                Adapter    "traccar"      : 1.1.2    , installed 0.0.12 [Updatable]
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
                Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "web"          : 6.1.1    , installed 6.1.1
                Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "windows-control": 0.1.5  , installed 0.1.5
                Adapter    "wled"         : 0.7.0    , installed 0.7.0
                Adapter    "ws"           : 2.5.4    , installed 2.5.4
                Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
                Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                • mcm1957
                  mcm1957 @mcm1957 last edited by
                  @mcm57 said in js-controller 5.0.x jetzt für alle User im STABLE!:
                  @foxriver76
                  Ok
                  Wenn ihr keine Zeit habt kann ich am Abend release versuchen
                  Ok, der botvac hat weder release script noch github tests - Museumsstand was die Infrastruktur betrifft. Ich werd dann mal anfangen, kann aber auch noch nen Tag dauern bis ne saubere Release entsteht.
                  Wer will, kann zwischenzeitlich die GITHUB Version versuchen (übliches Disclaimer - at own risk + Backup). Der Code sollte an js-controller 5 angepasst sein. Er enthält allerdings auch ein paar weitere Änderungen die nicht ins README gefunden haben, da muss ich erst mal schaun ob da ne Info was geändert wurde extrahieren kann.
                  JohGre 2 Replies Last reply Reply Quote 1
                    Thomas Braun Most Active @liv-in-sky last edited by
                    @liv-in-sky sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                    User-ID:                0
                    Das würde ich zunächst in Angriff nehmen. Also user anlegen und nicht als root herummachen und die Updates einspielen. Auf der Basis kann man dann weiter schauen.
                    • JohGre
                      JohGre @mcm1957 last edited by
                      @mcm57 Danke schon mal für deine Hilfe beim Botvac Adapter.
                      Aber viel wichtiger wäre mir Hilfe bei der Lösung des Problems mit dem ham-modul homebridge-balboa-spa@2.2.6, das brauch ich wirklich da ich damit unsere Whirlpool steuere.
                      Mehr spukt das log dazu nicht aus.
                      2023-09-14 14:40:20.837  - error: ham.0 (35321) Error: Library homebridge-balboa-spa@2.2.6 not installed after 3 attempts
                      mcm1957 apollon77 2 Replies Last reply Reply Quote 0
                      • foxriver76
                        foxriver76 Developer @liv-in-sky last edited by
                        @liv-in-sky Im Endeffekt iwo ein binding in vis, welches mist macht. Aber ich denke wir sollten noch eine neue Web Adapter Version machen weil ist eigentlich gefixt in socket classes aber dafür müsste web Adapter neu installiert oder geupdated werden.
                        liv-in-sky mcm1957 3 Replies Last reply Reply Quote 0
                          @foxriver76 du meinst ich soll den web adapter deinstallieren und neu installieren ?
                          • mcm1957
                            mcm1957 @JohGre last edited by
                            @johgre said in js-controller 5.0.x jetzt für alle User im STABLE!:
                            Sorry, da kann ich nix beitragen.
                            @foxriver76
                            @apollon77
                            Könnt ihr da was dazu sagen oder jemand triggern der sich das ansehen kann?
                              liv-in-sky @Thomas Braun last edited by
                              so ist jetzt der stand:
                                                  v.2023-04-16
                              Installation:           lxc
                              User-ID:                1000
                              X-Server:               false
                              Pending OS-Updates:     0
                              Pending iob updates:    1
                                                     /usr/bin/npm            9.6.7
                                                     /usr/bin/npx            9.6.7
                              MEMORY:
                              Mem:             11G        7.6G        2.4G        1.8M        1.8G        4.2G
                              Swap:           2.1G          0B        2.1G
                              Total:           13G        7.6G        4.5G
                              Active iob-Instances:   72
                                                     admin                   6.10.1
                              Objects type: jsonl
                              States  type: redis
                              Objects:                71282
                              States:                 78322
                              84M     /opt/iobroker/iobroker-data/objects.jsonl
                              den einen adapter kann ich nicht updaten, da die neue version davon nicht geht - ist traccar - sollte hier kein thema sein
                              kein root user 🙂
                                Thomas Braun Most Active @liv-in-sky last edited by Thomas Braun
                                kein root user
                                räusper
                                User-ID: 0
                                Edit:
                                Okay, geändert im aktuellen Output...
                                  @foxriver76
                                  @Thomas-Braun
                                  habe leider keine zeit nehr - gehe wieder auf altes system zurück - evtl kann ich am WE nochmal testen
                                  erstmal danke
                                    apollon77 @JohGre last edited by
                                    @johgre da muss mehr im log stehen bei normalen logleveln.
                                    JohGre 1 Reply Last reply Reply Quote 0
                                    • JohGre
                                      JohGre @apollon77 last edited by
                                      @apollon77 Hallo, hat sich erledigt.
                                      Einmal Adapter löschen, wieder installieren, Module neu hinzufügen, konfigurieren und schon tuts wieder.
                                      Hab das vorher in einem neuen Container probiert und da es da geklappt hat gleich am Produktivsystem.
                                      • surfer09
                                        surfer09 @JohGre last edited by
                                        Bei mir hat auch alles funktioniert. Danke! 😉
                                        • mcm1957
                                          mcm1957 @mcm1957 last edited by mcm1957
                                          This post is deleted!
                                            Thomas Braun Most Active @mcm1957 last edited by
                                            @mcm57
                                            Dann kannst du ja den Eintrag dazu ändern:
                                            ⚪ enigma2 - required: none - not at stable yet
                                            js-controller stable upgrade
                                            82
                                            509
                                            130717
