    4. wie Enigma2 Update f. js-Controller 5
    • Krisiun
      Krisiun @foxriver76 last edited by
      @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
      iob upgrade enigma2@2.0.3
      iobroker start
      pi@raspberrypi4-iob:~ $ iob upgrade enigma2@2.0.3
      Adapter "enigma2" is not in the repository and cannot be updated.
      • Krisiun
        Krisiun last edited by
        host.raspberrypi4-iob
        	2023-09-14 23:10:10.047	error	instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        	2023-09-14 23:10:10.047	error	Caught by controller[0]: Node.js v18.17.1
        	2023-09-14 23:10:10.047	error	Caught by controller[0]: }
        	2023-09-14 23:10:10.047	error	Caught by controller[0]: ]
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: requireStack: [
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        	2023-09-14 23:10:10.046	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
        	2023-09-14 23:10:10.045	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
        	2023-09-14 23:10:10.044	error	Caught by controller[0]: Require stack:
        	2023-09-14 23:10:10.044	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        	2023-09-14 23:10:10.044	error	Caught by controller[0]: ^
        	2023-09-14 23:10:10.044	error	Caught by controller[0]: throw err;
        	2023-09-14 23:10:10.043	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
        	2023-09-14 23:09:24.537	error	instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        	2023-09-14 23:09:24.537	error	Caught by controller[0]: Node.js v18.17.1
        	2023-09-14 23:09:24.536	error	Caught by controller[0]: }
        	2023-09-14 23:09:24.536	error	Caught by controller[0]: ]
        	2023-09-14 23:09:24.535	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
        	2023-09-14 23:09:24.535	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
        	2023-09-14 23:09:24.534	error	Caught by controller[0]: requireStack: [
        	2023-09-14 23:09:24.534	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        	2023-09-14 23:09:24.534	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
        	2023-09-14 23:09:24.533	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        	2023-09-14 23:09:24.533	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        	2023-09-14 23:09:24.532	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        	2023-09-14 23:09:24.532	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        	2023-09-14 23:09:24.531	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
        	2023-09-14 23:09:24.530	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
        	2023-09-14 23:09:24.530	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        	2023-09-14 23:09:24.529	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
        	2023-09-14 23:09:24.529	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        	2023-09-14 23:09:24.529	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
        	2023-09-14 23:09:24.528	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
        	2023-09-14 23:09:24.528	error	Caught by controller[0]: Require stack:
        	2023-09-14 23:09:24.527	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        	2023-09-14 23:09:24.527	error	Caught by controller[0]: ^
        	2023-09-14 23:09:24.526	error	Caught by controller[0]: throw err;
        	2023-09-14 23:09:24.525	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
        parcel.0
        	2023-09-14 23:08:14.783	error	Error: read ETIMEDOUT
        parcel.0
        	2023-09-14 23:08:14.782	error	https://www.dhl.de/int-verfolgen/data/search?piececode=&noRedirect=true&language=de&cid=app
        	2023-09-14 23:07:35.937	error	instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        	2023-09-14 23:07:35.937	error	Caught by controller[1]: Node.js v18.17.1
        	2023-09-14 23:07:35.937	error	Caught by controller[0]: }
        	2023-09-14 23:07:35.937	error	Caught by controller[0]: ]
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: requireStack: [
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        	2023-09-14 23:07:35.936	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
        	2023-09-14 23:07:35.935	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
        	2023-09-14 23:07:35.934	error	Caught by controller[0]: Require stack:
        	2023-09-14 23:07:35.934	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        	2023-09-14 23:07:35.934	error	Caught by controller[0]: ^
        	2023-09-14 23:07:35.934	error	Caught by controller[0]: throw err;
        	2023-09-14 23:07:35.934	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
        	2023-09-14 23:07:13.101	error	instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        	2023-09-14 23:07:13.101	error	Caught by controller[1]: Node.js v18.17.1
        	2023-09-14 23:07:13.101	error	Caught by controller[0]: }
        	2023-09-14 23:07:13.101	error	Caught by controller[0]: ]
        	2023-09-14 23:07:13.101	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
        	2023-09-14 23:07:13.101	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
        	2023-09-14 23:07:13.100	error	Caught by controller[0]: requireStack: [
        	2023-09-14 23:07:13.100	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        	2023-09-14 23:07:13.100	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
        	2023-09-14 23:07:13.100	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
        	2023-09-14 23:07:13.100	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
        	2023-09-14 23:07:13.099	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        	2023-09-14 23:07:13.099	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
        	2023-09-14 23:07:13.099	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
        	2023-09-14 23:07:13.098	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
        	2023-09-14 23:07:13.098	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
        	2023-09-14 23:07:13.098	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
        	2023-09-14 23:07:13.098	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        	2023-09-14 23:07:13.097	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
        	2023-09-14 23:07:13.097	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
        	2023-09-14 23:07:13.097	error	Caught by controller[0]: Require stack:
        	2023-09-14 23:07:13.096	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
        	2023-09-14 23:07:13.096	error	Caught by controller[0]: ^
        	2023-09-14 23:07:13.095	error	Caught by controller[0]: throw err;
        	2023-09-14 23:07:13.094	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
        • Krisiun
          Da sind nur Fehler drin
            Thomas Braun Most Active @Krisiun last edited by
            @krisiun
            Du kurvst ja auch noch mit der alten Version herum...
            Mach einen neuen Thread dazu auf, das hat mit dem js-controller5 ja nix zu tun.
            Krisiun 1 Reply Last reply Reply Quote 0
            • Krisiun
              Krisiun @Thomas Braun last edited by
              @thomas-braun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
              js-controller5
              Aber seid ich den js-controller5 installiert habe geht enigma2 nicht mehr
                @krisiun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                Mooooooaaarrrrr....
                Neuen Thread...
                • Krisiun
                  @thomas-braun wenn man nicht weißt wie das geht? Danke für deine Hilfe
                  • foxriver76
                    foxriver76 Developer @Krisiun last edited by
                    @krisiun dann iob url iobroker.enigma2@2.0.3 und wenn das nicht geht bitte wirklich eignen thread hat nix mit dem Thema hier zu tun. Irgendwie hast du den Adapter ja mal aus Beta installiert
                      Einen separaten Thread für sein Individual-Problem eröffnen?
                      • Negalein
                        Negalein Global Moderator @Krisiun last edited by Negalein
                        @krisiun
                        hier gehts jetzt mit deinem Problem weiter!!
                        • Krisiun
                          @foxriver76
                          Vielen Dank. Das hat´s was gebracht. Jetzt ist die Instanz endlich wieder grün. Super 👍
                          3200
