    4. js-controller 5.0.x jetzt für alle User im STABLE!
      liv-in-sky @Thomas Braun last edited by
      so ist jetzt der stand:
                          v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 12 (bookworm)
      Kernel:                 6.2.16-6-pve
      Installation:           lxc
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                             /usr/bin/node           v18.17.1
                             /usr/bin/npm            9.6.7
                             /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:             11G        7.6G        2.4G        1.8M        1.8G        4.2G
      Swap:           2.1G          0B        2.1G
      Total:           13G        7.6G        4.5G
      Active iob-Instances:   72
      Active repo(s): beta
      ioBroker Core:          js-controller           5.0.12
                             admin                   6.10.1
      Objects type: jsonl
      States  type: redis
      + system.adapter.admin.0                  : admin                 : iobroker59                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : iobroker59                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
       system.adapter.admin.2                  : admin                 : iobroker59                               - disabled, port: 8089, bind: 0.0.0.0, run as: admin
       system.adapter.admin.3                  : admin                 : iobroker59                               - disabled, port: 8071, bind: 0.0.0.0, run as: admin
       system.adapter.web-speedy.0             : web-speedy            : iobroker59                               - disabled
      + system.adapter.web.0                    : web                   : iobroker59                               -  enabled, port: 8082, bind: 192.168.178.59, run as: admin
      + system.adapter.web.1                    : web                   : iobroker59                               -  enabled, port: 8072, bind: 192.168.178.59, run as: admin
       system.adapter.web.2                    : web                   : iobroker59                               - disabled, port: 8098, bind: 0.0.0.0, run as: admin
       system.adapter.web.3                    : web                   : iobroker59                               - disabled, port: 8074, bind: 0.0.0.0, run as: admin
       system.adapter.web.4                    : web                   : iobroker59                               - disabled, port: 8075, bind: 0.0.0.0, run as: admin
      + system.adapter.web.5                    : web                   : iobroker59                               -  enabled, port: 8076, bind: 0.0.0.0, run as: admin
       system.adapter.web.6                    : web                   : iobroker59                               - disabled, port: 8077, bind: 0.0.0.0, run as: admin
       system.adapter.web.7                    : web                   : iobroker59                               - disabled, port: 8078, bind: 0.0.0.0, run as: admin
      + system.adapter.webcal.0                 : webcal                : iobroker59                               -  enabled
      + system.adapter.webcal.1                 : webcal                : iobroker59                               -  enabled
      + system.adapter.webcal.2                 : webcal                : iobroker59                               -  enabled
      Objects:                71282
      States:                 78322
      Size of iob-Database:
      84M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/states.jsonl
      den einen adapter kann ich nicht updaten, da die neue version davon nicht geht - ist traccar - sollte hier kein thema sein
      kein root user 🙂
        Thomas Braun Most Active @liv-in-sky last edited by Thomas Braun
        @liv-in-sky sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
        kein root user
        räusper
        User-ID: 0
        Edit:
        Okay, geändert im aktuellen Output...
          liv-in-sky @foxriver76 last edited by
          @foxriver76
          @Thomas-Braun
          habe leider keine zeit nehr - gehe wieder auf altes system zurück - evtl kann ich am WE nochmal testen
          erstmal danke
            apollon77 @JohGre last edited by
            @johgre da muss mehr im log stehen bei normalen logleveln.
            JohGre 1 Reply Last reply Reply Quote 0
            • JohGre
              JohGre @apollon77 last edited by
              @apollon77 Hallo, hat sich erledigt.
              Einmal Adapter löschen, wieder installieren, Module neu hinzufügen, konfigurieren und schon tuts wieder.
              Hab das vorher in einem neuen Container probiert und da es da geklappt hat gleich am Produktivsystem.
              • surfer09
                surfer09 @JohGre last edited by
                Bei mir hat auch alles funktioniert. Danke! 😉
                • mcm1957
                  mcm1957 @mcm1957 last edited by mcm1957
                  This post is deleted!
                    Thomas Braun Most Active @mcm1957 last edited by
                    @mcm57
                    Dann kannst du ja den Eintrag dazu ändern:
                    ⚪ enigma2 - required: none - not at stable yet
                    • mcm1957
                      mcm1957 @foxriver76 last edited by
                      @foxriver76 said in js-controller 5.0.x jetzt für alle User im STABLE!:
                      @liv-in-sky Im Endeffekt iwo ein binding in vis, welches mist macht. Aber ich denke wir sollten noch eine neue Web Adapter Version machen weil ist eigentlich gefixt in socket classes aber dafür müsste web Adapter neu installiert oder geupdated werden.
                      Ab morgen sollte eine neue Release von web / ws / socketio im stable angeboten werden, die dieses Problem (invalid bindings in vis) fixed. Danke an @foxriver76 für die schnelle Release.
                      Krisiun 1 Reply Last reply Reply Quote 1
                      • O
                        oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by oFbEQnpoLKKl6mbY5e13
                        @foxriver76
                        MQTT-Client crashed wegen eines falschen Zeichens.
                        2023-09-14 23:26:08.910  - info: host.iobroker instance system.adapter.mqtt-client.0 started with pid 3149
                        2023-09-14 23:26:11.236  - info: mqtt-client.0 (3149) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-09-14 23:26:11.348  - info: mqtt-client.0 (3149) starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v18.16.0, js-controller: 5.0.12
                        2023-09-14 23:26:12.408  - info: mqtt-client.0 (3149) Try to connect to mqtt://admin:*******************@192.168.0.6:1883?clientId=mqtt-client.0.iobroker
                        2023-09-14 23:26:12.625  - error: mqtt-client.0 (3149) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-09-14 23:26:12.631  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] connected with secret 1694726772485_8486
                        2023-09-14 23:26:12.626  - error: mqtt-client.0 (3149) unhandled promise rejection: The pattern "io.mqtt-client.0.stat.� 0� stat.tasmota_95F" is not a valid ID pattern
                        2023-09-14 23:26:12.628  - error: mqtt-client.0 (3149) Error: The pattern "io.mqtt-client.0.stat.� 0� stat.tasmota_95F" is not a valid ID pattern
                            at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2186:15)
                            at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:865:100)
                            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                        2023-09-14 23:26:12.628  - error: mqtt-client.0 (3149) The pattern "io.mqtt-client.0.stat.� 0� stat.tasmota_95F" is not a valid ID pattern
                        2023-09-14 23:26:12.654  - info: mqtt-client.0 (3149) connected to broker
                        2023-09-14 23:26:12.745  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] subscribes on "mqtt.0.tele.tasmota_85D39A.STATE"
                        2023-09-14 23:26:13.199  - info: mqtt-client.0 (3149) terminating
                        2023-09-14 23:26:13.202  - warn: mqtt-client.0 (3149) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2023-09-14 23:26:14.110  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] publishOnSubscribe send all known states
                        2023-09-14 23:26:14.158  - info: mqtt.0 (456) Client [mqtt-client.0.iobroker] connection closed: disconnected
                        2023-09-14 23:26:14.366  - info: mqtt-client.0 (3149) terminating with timeout
                        2023-09-14 23:26:14.934  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_341527.LWT: DB closed
                        2023-09-14 23:26:14.935  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_A36501.STATUS6: DB closed
                        2023-09-14 23:26:14.936  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_9E62C6.STATUS: DB closed
                        2023-09-14 23:26:14.936  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_56D73B.INFO3: DB closed
                        2023-09-14 23:26:14.937  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_A36501.LWT: DB closed
                        2023-09-14 23:26:14.938  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_3F8AD6.LWT: DB closed
                        2023-09-14 23:26:14.938  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_85CD09.STATUS: DB closed
                        2023-09-14 23:26:14.939  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_A36501.POWER2: DB closed
                        2023-09-14 23:26:14.940  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_95FE9E.STATE: DB closed
                        2023-09-14 23:26:14.941  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_7E7404.STATUS4: DB closed
                        2023-09-14 23:26:14.942  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_990526.UPGRADE: DB closed
                        2023-09-14 23:26:14.942  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_4CC022.STATUS4: DB closed
                        2023-09-14 23:26:14.943  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_63E60D.RESULT: DB closed
                        2023-09-14 23:26:14.944  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_4E489B.STATUS11: DB closed
                        2023-09-14 23:26:14.944  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_53EAB0.STATUS6: DB closed
                        2023-09-14 23:26:14.945  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_4E4778.STATUS4: DB closed
                        2023-09-14 23:26:14.945  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_9E62C6.INFO2: DB closed
                        2023-09-14 23:26:14.946  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tasmota.discovery.840D8E5E4526.config: DB closed
                        2023-09-14 23:26:14.947  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_BB868C.STATUS3: DB closed
                        2023-09-14 23:26:14.948  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_990210.INFO3: DB closed
                        2023-09-14 23:26:14.948  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_BEB72E.STATUS4: DB closed
                        2023-09-14 23:26:14.949  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_A36501.STATE: DB closed
                        2023-09-14 23:26:14.949  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_FD2178.STATE: DB closed
                        2023-09-14 23:26:14.950  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_5E4526.STATUS4: DB closed
                        2023-09-14 23:26:14.951  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.tele.tasmota_3F8AD6.SENSOR: DB closed
                        2023-09-14 23:26:14.952  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_95FE9E.STATUS4: DB closed
                        2023-09-14 23:26:14.953  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_53EAB0.STATUS1: DB closed
                        2023-09-14 23:26:14.953  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_41CB86.POWER: DB closed
                        2023-09-14 23:26:14.954  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_59618E.STATUS7: DB closed
                        2023-09-14 23:26:14.954  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_3F8C42.RESULT: DB closed
                        2023-09-14 23:26:14.955  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_3F8C42.STATUS6: DB closed
                        2023-09-14 23:26:14.955  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_990576.STATUS4: DB closed
                        2023-09-14 23:26:14.956  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_3F8AD6.UPGRADE: DB closed
                        2023-09-14 23:26:14.956  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_95F446.STATUS4: DB closed
                        2023-09-14 23:26:14.957  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_41CB86.STATUS2: DB closed
                        2023-09-14 23:26:14.958  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_53EAB0.UPGRADE: DB closed
                        2023-09-14 23:26:14.963  - warn: mqtt-client.0 (3149) DB closed
                        2023-09-14 23:26:14.964  - warn: mqtt-client.0 (3149) Could not perform strict object check of state mqtt-client.0.stat.tasmota_98FD5F.STATUS10: DB closed
                        2023-09-14 23:26:15.262  - error: mqtt-client.0 (3149) Cannot check object existence of "mqtt-client.0.info.connection": Connection is closed.
                        2023-09-14 23:26:15.271  - info: mqtt-client.0 (3149) terminating
                        2023-09-14 23:26:15.393  - error: host.iobroker Caught by controller[0]: [ioredis] Unhandled error event: Error: write EPIPE
                        2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at afterWriteDispatched (node:internal/stream_base_commons:160:15)
                        2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at writeGeneric (node:internal/stream_base_commons:151:3)
                        2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at Socket._writeGeneric (node:net:930:11)
                        2023-09-14 23:26:15.394  - error: host.iobroker Caught by controller[0]:     at Socket._write (node:net:942:8)
                        2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at writeOrBuffer (node:internal/streams/writable:392:12)
                        2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at _write (node:internal/streams/writable:333:10)
                        2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at Writable.write (node:internal/streams/writable:337:10)
                        2023-09-14 23:26:15.395  - error: host.iobroker Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:679:33)
                        2023-09-14 23:26:15.396  - error: host.iobroker Caught by controller[0]:     at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                        2023-09-14 23:26:15.396  - error: host.iobroker Caught by controller[0]:     at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:610:35)
                        2023-09-14 23:26:15.396  - error: host.iobroker instance system.adapter.mqtt-client.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2023-09-14 23:26:15.396  - info: host.iobroker Restart adapter system.adapter.mqtt-client.0 because enabled
                        • foxriver76
                          foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
                          @ofbeqnpolkkl6mby5e13 müssen wir im adapter fixen
                          O 3 Replies Last reply Reply Quote 0
                          • O
                            @foxriver76
                            Soll ich Issue erstellen?
                            foxriver76 Krisiun 2 Replies Last reply Reply Quote 0
                            • foxriver76
                              @ofbeqnpolkkl6mby5e13 ja sehr gerne
                              • O
                                @foxriver76
                                https://github.com/iobroker-community-adapters/ioBroker.mqtt-client/issues/233
                                RP70DP created this issue in iobroker-community-adapters/ioBroker.mqtt-client
                                closed JS-Controller 5.0.12: Adapter is crashing because of a wrong pattern #233
                                • Krisiun
                                  Krisiun @oFbEQnpoLKKl6mbY5e13 last edited by
                                  Ja bitte wobei ich weiß nicht was ich damit anfangen soll. Irgend wie will mir niemand das ganze hier erklären obwohl ich möchte das alles verstehen. Vielen Dank.
                                    Thomas Braun Most Active @Krisiun last edited by
                                    @krisiun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                    In diesem Thread geht es um Auffälligkeiten/Probleme/Beobachtungen im Rahmen der Veröffentlichung des js-controller 5 als Stabile Version.
                                    @oFbEQnpoLKKl6mbY5e13 hat offenbar da was mit dem Adaper mqtt-client gefunden und das hier vermerkt.
                                    Hat mit deiner veralteten Beta-Version, die nicht auf js-controller angepasst war, nichts zu tun.
                                    Krisiun 1 Reply Last reply Reply Quote 0
                                    • Krisiun
                                      Krisiun @Thomas Braun last edited by
                                      Das klingt jetzt bestimmt komisch weil viele das selber immer schreiben aber da bin ich der nächste der einfach nur sagt : VIELEN DANK
                                      • O
                                        @foxriver76
                                        Scheint im MQTT-Adapter selbst auch nicht komplett abgefangen zu werden:
                                        2023-09-15 00:37:44.321  - error: mqtt.0 (456) Client [DVES_990210] Cannot parse "stat/tasmota_990210/STATUS11": {"StatusSTS":{"Time":"2023-09-14T23:37:34","Uptime":"100T16:49:22","UptimeSec":8700562,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":24,"POWER":"OFF","Wifi":{"AP":1,"SSId":"***","BSSId":"***","Channel":1,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":8,"Downtime":"0T00� stat/t
                                        Krisiun O 2 Replies Last reply Reply Quote 0
                                        • Krisiun
                                          hmm? keine ahnung aber bis jetzt geht alles. Vielen vielen Dank.
                                          • Fabio
                                            Fabio @foxriver76 last edited by Fabio
                                            @foxriver76 ich habe seit heute morgen das Problem das ich keine Skripte exportieren kann.
                                            host.nuc
                                            2023-09-15 07:46:19.842	warn	Saving in binary state "system.host.nuc.zip.2023-09-15-scripts.zip" is deprecated. Please add the "fileStorageNamespace" attribute to request (with e.g. "admin.0" value) to save ZIP in file as "zip/2023-09-15-scripts.zip"
                                            System ist auf dem neusten Stand.
                                            Fabio
                                            Walter White 1 Reply Last reply Reply Quote 1
                                            1.0k
                                            js-controller stable upgrade
                                            82
                                            509
                                            130687
