    4. Plenticore Adapter startet nicht nach Aktualisierung
      Hendrik @Thomas Braun last edited by
      @thomas-braun zur Info IoBroker läuft auf einer Synology nas
        Homoran Global Moderator Administrators @Hendrik last edited by
        @hendrik sagte in Plenticore Adapter startet nicht nach Aktualisierung:
        @thomas-braun Erstmal Danke für Deine schnelle Rückmeldung. Kannst Du mich bei diesem Problem unterstützen?
        beantworte doch erst einmal die Frage(n).
        im Moment weiss man zu wenig
          einfach so?
          • nativ?
          • Virtualization station?
          • Docker?
            Thomas Braun Most Active @Hendrik last edited by
            iob diag
            sagt?
            Die Langfassung.
              Hendrik @Thomas Braun last edited by Homoran
              2023-09-15 11:28:00.656 Error instance system.adapter.plenticore.0 was terminated with code 6 (UNCAUGHT_EXCEPTION)
              plenticore.0
              2023-09-15 11:28:00.032 warn Terminated (UNCAUGHT_EXCEPTION): without reason
              plenticore.0
              2023-09-15 11:27:59.037 Error Exception code: ERR_INVALID_ARG_TYPE: The "path" argument must be of type "string" or an instance of "buffer" or "URL". Received undefined
              plenticore.0
              2023-09-15 11:27:59.037 Error TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type "string" or an instance of "buffer" or "URL". Undefined received at Object.openSync (node:fs:595:10) at Object.writeFileSync (node:fs:2324:35) at Object.unload (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore. js: 773:5) at AdapterClass.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore/main.js:40:14) at AdapterClass.emit (node:events:514:28) at AdapterClass. _stop (/opt /iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1369:26) at AdapterClass._ExceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build /lib/adapter/adapter.js:9113:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
              plenticore.0
              09/15/2023 11:27:59.033 Error Unhandled promise rejection: the "path" argument must be of type "string" or an instance of "buffer" or "URL". Received undefined
              Translated with www.DeepL.com/Translator (free version)
                Hendrik @Homoran last edited by Homoran
                @homoran In einem Docker Plattform
                docker
                Betriebssystem
                linux
                Architektur
                x64
                CPUs
                Geschwindigkeit
                2001 MHz
                Modell
                Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
                RAM
                9.58 GB
                System-Betriebszeit
                81 T. 08:40:32
                Node.js
                v18.17.1
                time
                1694770424015
                timeOffset
                -120
                NPM
                9.6.7
                Anzahl der Adapter
                496
                dockerInformation
                [object Object]
                Datenträgergröße
                3.49 TB
                freier Festplattenspeicher
                3.24 TB
                Aktive Instanzen
                27
                Weg
                /opt/iobroker/
                Betriebszeit
                00:27:00
                Hostname
                buanet-iobrokerv8latest
                MOD-EDIT:Code in code-tags gesetzt!
                • mcm1957
                  mcm1957 @Hendrik last edited by mcm1957
                  @hendrik
                  Welche Adapterversion verwendest du?
                  Wenn ich es richtig lese 2.2.0. Aber bitte bei JEDEM Problem die Releases der beteiligten Adapter angeben. Verlängert die Lebensdauer unserer Glaskugeln 🙂
                  Das Problem sollte lt. Code Check spätestens ab 2.2.2 (aktuell im Latest ist 2.3.0) behoben sein.
                  Leider hat der Dev bisher keinen Update des Adapters im stable repository angefordert. Es scheint heir ein Missverständnis gegeben zu haben.(https://github.com/pixcept/ioBroker.plenticore/issues/78).
                  Ich versuche das zu klären.
                  Zum Test kannst du die Version 2.3.0 von latest installieren. Aber wie immer LATEST = BETA = AT-OWN-RISK - also nur mit Backup
                    @homoran Ich konnte das Problem erstmal lösen.in dem ich auf die alte Version zurückgegangen bin.
                    Trotzdem stellt sich die Frage, warum es bei der neusten Version vom JS Controller nicht funktioniert beim Plenticore Adapter
                    • mcm1957
                      @hendrik said in Plenticore Adapter startet nicht nach Aktualisierung:
                      Ich vermute damit meinst du Rückstieg auf js-controller 4.x.x. Warum hast du nicht Plentiocor 2.3.0 getestet?
                      Es funktioniert nicht weil der Plenticore Adapter in v2.2.0 eine nicht mehr unterstützte Methode zum Zugriff auf Daten verwendet. Dies wurde auch im Adapter schon gefixed. Mit Adapterversion 2.3.0 sollte es funktionieren.
                      Sollte bei dir Plenticore 2.3.0 in Verbindung mit js-controlelr 5 nicht funktionieren, dann bitte
                      -) ein Issue beim Aapter eröffen
                      -) vollständigen log ahängen
                      -) und gern hier verlinken
                      mcm1957
                        Hendrik @mcm1957 last edited by
                        @mcm57 danke für den guten Hinweis ! mit der v2.3.0 hat es auch nicht funktioniert .
                          @mcm57 Danke
                          • mcm1957
                            @hendrik
                            Da eine Fehlerbehebung nur mit einem Issue zu erwarten ist, habe ich eines (für dich und andere User) geöffnet:
                            https://github.com/pixcept/ioBroker.plenticore/issues/84
                            Falls du logs der Probleme mit Version 2.3.0 beisteuern kannst, bitte häng sie an das Issue an.
                            H S 2 Replies Last reply Reply Quote 1
                              @mcm57 Danke im Voraus für Deine Unterstützung! Bezogen auf Deine Frage von Version 2.3.0, kann ich nur sagen, dass das gleiche Fehlerbild anstand d.h. der Adapter startet und bricht wieder ab.
                              • mcm1957
                                @hendrik
                                pixcept hat eine neue Version 2.3.1 erstellt. In den Releasenotes steht zwar nichts zu js-controlelr 5, aber bitte ev. doch testen. Und wenn es Probleme gibt im Adapter Repos isse erstellen oder aktualisieren.
                                DANKE
                                  @mcm57 erstmal danke für die Rückmeldung..! Kann mein System erst am Samstag aktualisieren.
                                    @mcm57 Hallo mit der Version 2.3.1 sind die Probleme gleich geblieben.
                                    Wie bereits von Dir geschrieben ist auch kein Hinweis im Änderungsprotokoll auf Version 5.
                                    2.3.1
                                    Weitere Option zur Steuerung des Batteriemanagements hinzugefügt [PastCoder]
                                    • mcm1957
                                      @hendrik
                                      Danke für Info
                                      Und sorry f Probleme
                                        @mcm57 Hallo, mein produktives System iob läuft auf einer Synology nas .
                                        Ich habe jetzt den Adapter mit meinem Testsystem Proxmox getestet was auch mit der Version 2.2.2 mit js-controller 5 funktioniert hat.
                                        Sollte ich es nochmal auf meiner Nas probieren ?
                                        Danke im Voraus für die Rückmeldung !
                                          Spidermike @mcm1957 last edited by
                                          @mcm57
                                          Möchte das Thema nochmal aufgreifen.
                                          Habe auch den Plenticore Adapter auf 2.3.1
                                          gibt es dafür eine Lösung?
                                          • mcm1957
                                            @spidermike
                                            Da ich den Adapter nicht entwickelt habe oder warten kann muss ich dich mit der Frage an den Maintainer bzw ein issue im Repo verweisen:
                                            Ob pixcept hier im Forum mitliest / tätig ist weiß ich leider nicht.
                                            aktualisierung js controller 5.0.12 plenticore
                                            1602
