    3. Off Topic
    4. Homekit-controller lässt sich nicht installieren
      Thomas Braun Most Active @SirDrinsAlot last edited by
      @sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
      /home/iobroker/.npm/_logs/2023-09-15T13_00_49_922Z-debug-0.log
      Was steht da drin?
        Der Error 25 Befehl ändert leider nix und das /home/iobroker/ Verzeichnis ist leer.
          Nein, ist es nicht.
          Dateien und Verzeichnisse, die mit einem Punkt beginnen sind ausgeblendet.
          ls -lAh /home/iobroker
          zeigt auch diese Dateien.
            Stimmt, sry bin eher windows user.
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@9.6.7
            2 info using node@v18.17.1
            3 timing npm:load:whichnode Completed in 1ms
            4 timing config:load:defaults Completed in 1ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
            6 timing config:load:builtin Completed in 0ms
            7 timing config:load:cli Completed in 2ms
            8 timing config:load:env Completed in 0ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
            10 timing config:load:project Completed in 2ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
            12 timing config:load:user Completed in 0ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 0ms
            15 timing config:load:setEnvs Completed in 1ms
            16 timing config:load Completed in 8ms
            17 timing npm:load:configload Completed in 8ms
            18 timing npm:load:mkdirpcache Completed in 1ms
            19 timing npm:load:mkdirplogs Completed in 0ms
            20 verbose title npm install iobroker.homekit-controller@0.5.8
            21 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.homekit-controller@0.5.8"
            22 timing npm:load:setTitle Completed in 1ms
            23 timing config:load:flatten Completed in 2ms
            24 timing npm:load:display Completed in 3ms
            25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-
            26 verbose logfile /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
            27 timing npm:load:logFile Completed in 7ms
            28 timing npm:load:timers Completed in 0ms
            29 timing npm:load:configScope Completed in 0ms
            30 timing npm:load Completed in 21ms
            31 timing arborist:ctor Completed in 0ms
            32 silly logfile start cleaning logs, removing 2 files
            33 silly logfile done cleaning log files
            34 timing idealTree:init Completed in 1269ms
            35 timing idealTree:userRequests Completed in 2ms
            36 silly idealTree buildDeps
            37 silly fetch manifest iobroker.homekit-controller@0.5.8
            38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            39 http fetch GET 200 https://registry.npmjs.org/iobroker.homekit-controller 1537ms (cache revalidated)
            40 silly placeDep ROOT iobroker.homekit-controller@0.5.8 OK for: iobroker.inst@3.0.0 want: 0.5.8
            41 silly fetch manifest @iobroker/adapter-core@^2.6.7
            42 silly fetch manifest debug@^4.3.4
            43 silly fetch manifest hap-controller@^0.9.3
            44 silly fetch manifest @esm2cjs/p-queue@^7.3.0
            45 http fetch GET 200 https://registry.npmjs.org/debug 101ms (cache revalidated)
            46 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 596ms (cache revalidated)
            47 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-queue 1428ms (cache revalidated)
            48 http fetch GET 200 https://registry.npmjs.org/hap-controller 1609ms (cache revalidated)
            49 timing idealTree:#root Completed in 3167ms
            50 silly placeDep ROOT @esm2cjs/p-queue@7.3.0 OK for: iobroker.homekit-controller@0.5.8 want: ^7.3.0
            51 silly fetch manifest @esm2cjs/p-timeout@^5.0.2
            52 silly fetch manifest eventemitter3@^4.0.7
            53 silly placeDep node_modules/iobroker.homekit-controller @iobroker/adapter-core@2.6.8 OK for: iobroker.homekit-controller@0.5.8 want: ^2.6.7
            54 silly placeDep node_modules/iobroker.homekit-controller debug@4.3.4 OK for: iobroker.homekit-controller@0.5.8 want: ^4.3.4
            55 silly fetch manifest ms@2.1.2
            56 silly placeDep ROOT hap-controller@0.9.3 OK for: iobroker.homekit-controller@0.5.8 want: ^0.9.3
            57 silly fetch manifest @abandonware/noble@1.9.2-20
            58 silly fetch manifest dnssd@^0.4.1
            59 silly fetch manifest fast-srp-hap@^2.0.4
            60 silly fetch manifest http-parser-js@^0.5.8
            61 silly fetch manifest libsodium-wrappers@^0.7.11
            62 silly fetch manifest node-hkdf-sync@^1.0.0
            63 http fetch GET 200 https://registry.npmjs.org/http-parser-js 90ms (cache revalidated)
            64 http fetch GET 200 https://registry.npmjs.org/eventemitter3 407ms (cache revalidated)
            65 http fetch GET 200 https://registry.npmjs.org/ms 606ms (cache revalidated)
            66 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fnoble 603ms (cache revalidated)
            67 http fetch GET 200 https://registry.npmjs.org/libsodium-wrappers 778ms (cache revalidated)
            68 http fetch GET 200 https://registry.npmjs.org/node-hkdf-sync 1094ms (cache revalidated)
            69 http fetch GET 200 https://registry.npmjs.org/fast-srp-hap 1214ms (cache revalidated)
            70 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-timeout 1532ms (cache revalidated)
            71 http fetch GET 200 https://registry.npmjs.org/dnssd 1934ms (cache revalidated)
            72 timing idealTree:node_modules/iobroker.homekit-controller Completed in 1950ms
            73 silly placeDep ROOT @esm2cjs/p-timeout@5.1.0 OK for: @esm2cjs/p-queue@7.3.0 want: ^5.0.2
            74 silly placeDep node_modules/@esm2cjs/p-queue eventemitter3@4.0.7 OK for: @esm2cjs/p-queue@7.3.0 want: ^4.0.7
            75 timing idealTree:node_modules/@esm2cjs/p-queue Completed in 9ms
            76 timing idealTree:node_modules/@esm2cjs/p-timeout Completed in 0ms
            77 silly placeDep node_modules/hap-controller @abandonware/noble@1.9.2-20 OK for: hap-controller@0.9.3 want: 1.9.2-20
            78 silly fetch manifest node-addon-api@^4.3.0
            79 silly placeDep node_modules/hap-controller debug@4.3.4 OK for: hap-controller@0.9.3 want: ^4.3.4
            80 silly placeDep ROOT dnssd@0.4.1 OK for: hap-controller@0.9.3 want: ^0.4.1
            81 silly placeDep ROOT fast-srp-hap@2.0.4 OK for: hap-controller@0.9.3 want: ^2.0.4
            82 silly placeDep ROOT http-parser-js@0.5.8 OK for: hap-controller@0.9.3 want: ^0.5.8
            83 silly placeDep ROOT libsodium-wrappers@0.7.13 OK for: hap-controller@0.9.3 want: ^0.7.11
            84 silly fetch manifest libsodium@^0.7.13
            85 silly placeDep ROOT node-hkdf-sync@1.0.0 OK for: hap-controller@0.9.3 want: ^1.0.0
            86 silly fetch manifest vows@0.5.13
            87 http fetch GET 200 https://registry.npmjs.org/node-addon-api 88ms (cache revalidated)
            88 http fetch GET 200 https://registry.npmjs.org/libsodium 398ms (cache revalidated)
            89 http fetch GET 200 https://registry.npmjs.org/vows 1387ms (cache revalidated)
            90 timing idealTree:node_modules/hap-controller Completed in 1405ms
            91 timing idealTree:node_modules/dnssd Completed in 0ms
            92 timing idealTree:node_modules/fast-srp-hap Completed in 0ms
            93 timing idealTree:node_modules/http-parser-js Completed in 0ms
            94 silly placeDep ROOT libsodium@0.7.13 OK for: libsodium-wrappers@0.7.13 want: ^0.7.13
            95 timing idealTree:node_modules/libsodium-wrappers Completed in 4ms
            96 timing idealTree:node_modules/libsodium Completed in 0ms
            97 silly placeDep ROOT vows@0.5.13 OK for: node-hkdf-sync@1.0.0 want: 0.5.13
            98 timing idealTree:node_modules/node-hkdf-sync Completed in 4ms
            99 timing idealTree:node_modules/vows Completed in 0ms
            100 timing idealTree:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 0ms
            101 silly placeDep node_modules/hap-controller node-addon-api@4.3.0 OK for: @abandonware/noble@1.9.2-20 want: ^4.3.0
            102 timing idealTree:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 3ms
            103 silly placeDep node_modules/hap-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
            104 timing idealTree:node_modules/hap-controller/node_modules/debug Completed in 1ms
            105 timing idealTree:node_modules/hap-controller/node_modules/ms Completed in 0ms
            106 timing idealTree:node_modules/hap-controller/node_modules/node-addon-api Completed in 0ms
            107 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 0ms
            108 silly placeDep node_modules/iobroker.homekit-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
            109 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 1ms
            110 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 0ms
            111 timing idealTree:buildDeps Completed in 6549ms
            112 timing idealTree:fixDepFlags Completed in 13ms
            113 timing idealTree Completed in 7847ms
            114 timing reify:loadTrees Completed in 7848ms
            115 timing reify:diffTrees Completed in 40ms
            116 silly reify moves {}
            117 timing reify:retireShallow Completed in 0ms
            118 timing reify:createSparse Completed in 2ms
            119 timing reify:loadBundles Completed in 0ms
            120 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
            121 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
            122 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
            123 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
            124 timing reifyNode:node_modules/osx-temperature-sensor Completed in 9ms
            125 timing reifyNode:node_modules/fsevents Completed in 10ms
            126 timing reifyNode:node_modules/mdns/node_modules/bindings Completed in 168ms
            127 timing reifyNode:node_modules/authenticate-pam Completed in 168ms
            128 timing reifyNode:node_modules/hap-controller/node_modules/ms Completed in 170ms
            129 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 170ms
            130 timing reifyNode:node_modules/node-gyp/node_modules/strip-ansi Completed in 170ms
            131 timing reifyNode:node_modules/node-gyp/node_modules/string-width Completed in 170ms
            132 timing reifyNode:node_modules/node-gyp/node_modules/is-fullwidth-code-point Completed in 171ms
            133 timing reifyNode:node_modules/node-gyp/node_modules/brace-expansion Completed in 171ms
            134 timing reifyNode:node_modules/node-gyp/node_modules/ansi-regex Completed in 171ms
            135 timing reifyNode:node_modules/node-gyp/node_modules/aproba Completed in 171ms
            136 timing reifyNode:node_modules/@abandonware/noble/node_modules/ms Completed in 171ms
            137 timing reifyNode:node_modules/http-parser-js Completed in 173ms
            138 timing reifyNode:node_modules/node-gyp/node_modules/string_decoder Completed in 177ms
            139 timing reifyNode:node_modules/node-gyp/node_modules/npmlog Completed in 177ms
            140 timing reifyNode:node_modules/node-gyp/node_modules/minimatch Completed in 178ms
            141 timing reifyNode:node_modules/hap-controller/node_modules/debug Completed in 181ms
            142 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 180ms
            143 timing reifyNode:node_modules/@abandonware/noble/node_modules/debug Completed in 180ms
            144 timing reifyNode:node_modules/node-hkdf-sync Completed in 182ms
            145 timing reifyNode:node_modules/usocket Completed in 182ms
            146 timing reifyNode:node_modules/node-gyp/node_modules/are-we-there-yet Completed in 183ms
            147 timing reifyNode:node_modules/node-gyp/node_modules/glob Completed in 184ms
            148 timing reifyNode:node_modules/libsodium-wrappers Completed in 186ms
            149 timing reifyNode:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 188ms
            150 timing reifyNode:node_modules/@esm2cjs/p-timeout Completed in 188ms
            151 timing reifyNode:node_modules/napi-thread-safe-callback Completed in 188ms
            152 timing reifyNode:node_modules/net-ping Completed in 195ms
            153 timing reifyNode:node_modules/buildcheck Completed in 195ms
            154 timing reifyNode:node_modules/raw-socket Completed in 201ms
            155 timing reifyNode:node_modules/node-gyp/node_modules/gauge Completed in 201ms
            156 timing reifyNode:node_modules/fast-srp-hap Completed in 203ms
            157 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 207ms
            158 timing reifyNode:node_modules/node-gyp/node_modules/readable-stream Completed in 211ms
            159 timing reifyNode:node_modules/libsodium Completed in 212ms
            160 timing reifyNode:node_modules/@esm2cjs/p-queue Completed in 214ms
            161 timing reifyNode:node_modules/hap-controller/node_modules/node-addon-api Completed in 222ms
            162 timing reifyNode:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 221ms
            163 timing reifyNode:node_modules/vows Completed in 231ms
            164 timing reifyNode:node_modules/raw-socket/node_modules/nan Completed in 248ms
            165 timing reifyNode:node_modules/mdns Completed in 253ms
            166 timing reifyNode:node_modules/hap-controller Completed in 282ms
            167 timing reifyNode:node_modules/cpu-features Completed in 300ms
            168 timing reifyNode:node_modules/dnssd Completed in 302ms
            169 timing reifyNode:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 302ms
            170 timing reifyNode:node_modules/@abandonware/noble Completed in 300ms
            171 timing reifyNode:node_modules/node-gyp Completed in 307ms
            172 timing reifyNode:node_modules/iobroker.homekit-controller Completed in 329ms
            173 timing reify:unpack Completed in 331ms
            174 timing reify:unretire Completed in 0ms
            175 timing build:queue Completed in 3ms
            176 timing build:link:node_modules/dnssd Completed in 1ms
            177 timing build:link:node_modules/node-gyp Completed in 0ms
            178 timing build:link:node_modules/vows Completed in 0ms
            179 timing build:link Completed in 1ms
            180 info run @abandonware/noble@1.9.2-19 install node_modules/@abandonware/noble node-gyp-build
            181 info run authenticate-pam@1.0.5 install node_modules/authenticate-pam node-gyp rebuild
            182 info run cpu-features@0.0.9 install node_modules/cpu-features node buildcheck.js > buildcheck.gypi && node-gyp rebuild
            183 info run mdns@2.7.2 install node_modules/mdns node-gyp rebuild
            184 info run mdns@2.7.2 install { code: 1, signal: null }
            185 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns
            186 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns' ]
            187 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns/node_modules/bindings
            188 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns/node_modules/bindings' ]
            189 timing build:run:install:node_modules/mdns Completed in 551ms
            190 info run raw-socket@1.7.0 install node_modules/raw-socket node-gyp rebuild
            191 info run authenticate-pam@1.0.5 install { code: 1, signal: null }
            192 verbose reify failed optional dependency /opt/iobroker/node_modules/authenticate-pam
            193 silly reify mark deleted [ '/opt/iobroker/node_modules/authenticate-pam' ]
            194 timing build:run:install:node_modules/authenticate-pam Completed in 590ms
            195 info run usocket@0.3.0 install node_modules/usocket node-gyp rebuild
            196 info run cpu-features@0.0.9 install { code: 1, signal: null }
            197 verbose reify failed optional dependency /opt/iobroker/node_modules/cpu-features
            198 silly reify mark deleted [ '/opt/iobroker/node_modules/cpu-features' ]
            199 verbose reify failed optional dependency /opt/iobroker/node_modules/buildcheck
            200 silly reify mark deleted [ '/opt/iobroker/node_modules/buildcheck' ]
            201 timing build:run:install:node_modules/cpu-features Completed in 648ms
            202 info run @abandonware/noble@1.9.2-20 install node_modules/hap-controller/node_modules/@abandonware/noble node-gyp-build
            203 info run @abandonware/noble@1.9.2-19 install { code: 1, signal: null }
            204 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble
            205 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble' ]
            206 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/debug
            207 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/debug' ]
            208 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api
            209 silly reify mark deleted [
            209 silly reify   '/opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api'
            209 silly reify ]
            210 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/ms
            211 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/ms' ]
            212 timing build:run:install:node_modules/@abandonware/noble Completed in 685ms
            213 info run raw-socket@1.7.0 install { code: 1, signal: null }
            214 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket
            215 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket' ]
            216 verbose reify failed optional dependency /opt/iobroker/node_modules/net-ping
            217 silly reify mark deleted [ '/opt/iobroker/node_modules/net-ping' ]
            218 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket/node_modules/nan
            219 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket/node_modules/nan' ]
            220 timing build:run:install:node_modules/raw-socket Completed in 433ms
            221 info run usocket@0.3.0 install { code: 1, signal: null }
            222 verbose reify failed optional dependency /opt/iobroker/node_modules/usocket
            223 silly reify mark deleted [ '/opt/iobroker/node_modules/usocket' ]
            224 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp
            225 silly reify mark deleted [
            225 silly reify   '/opt/iobroker/node_modules/node-gyp',
            225 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp'
            225 silly reify ]
            226 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/glob
            227 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/glob' ]
            228 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/npmlog
            229 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
            230 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/minimatch
            231 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/minimatch' ]
            232 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet
            233 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
            234 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/gauge
            235 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
            236 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion
            237 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion' ]
            238 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/readable-stream
            239 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
            240 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/aproba
            241 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/aproba' ]
            242 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string-width
            243 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
            244 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi
            245 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
            246 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string_decoder
            247 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string_decoder' ]
            248 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point
            249 silly reify mark deleted [
            249 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
            249 silly reify ]
            250 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex
            251 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
            252 timing build:run:install:node_modules/usocket Completed in 435ms
            253 info run @abandonware/noble@1.9.2-20 install { code: 1, signal: null }
            254 timing reify:rollback:createSparse Completed in 51ms
            255 timing reify:rollback:retireShallow Completed in 0ms
            256 timing command:install Completed in 9458ms
            257 verbose stack Error: command failed
            257 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
            257 verbose stack     at ChildProcess.emit (node:events:514:28)
            257 verbose stack     at maybeClose (node:internal/child_process:1091:16)
            257 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
            258 verbose pkgid @abandonware/noble@1.9.2-20
            259 verbose cwd /opt/iobroker
            260 verbose Linux 6.1.0-12-amd64
            261 verbose node v18.17.1
            262 verbose npm  v9.6.7
            263 error code 1
            264 error path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
            265 error command failed
            266 error command sh -c node-gyp-build
            267 error (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
            267 error (Use `node --trace-deprecation ...` to show where the warning was created)
            267 error Traceback (most recent call last):
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
            267 error     sys.exit(gyp.script_main())
            267 error              ^^^^^^^^^^^^^^^^^
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
            267 error     return main(sys.argv[1:])
            267 error            ^^^^^^^^^^^^^^^^^^
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
            267 error     return gyp_main(args)
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
            267 error     [generator, flat_list, targets, data] = Load(
            267 error                                             ^^^^^
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
            267 error     result = gyp.input.Load(
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
            267 error     LoadTargetBuildFile(
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
            267 error     build_file_data = LoadOneBuildFile(
            267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
            267 error     build_file_contents = open(build_file_path, "rU").read()
            267 error                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
            267 error ValueError: invalid mode: 'rU' while trying to load binding.gyp
            267 error gyp ERR! configure error
            267 error gyp ERR! stack Error: `gyp` failed with exit code: 1
            267 error gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
            267 error gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
            267 error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
            267 error gyp ERR! System Linux 6.1.0-12-amd64
            267 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            267 error gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
            267 error gyp ERR! node -v v18.17.1
            267 error gyp ERR! node-gyp -v v7.1.2
            267 error gyp ERR! not ok
            268 verbose exit 1
            269 timing npm Completed in 9617ms
            270 verbose unfinished npm timer reify 1694784894962
            271 verbose unfinished npm timer reify:build 1694784903192
            272 verbose unfinished npm timer build 1694784903193
            273 verbose unfinished npm timer build:deps 1694784903193
            274 verbose unfinished npm timer build:run:install 1694784903197
            275 verbose unfinished npm timer build:run:install:node_modules/hap-controller/node_modules/@abandonware/noble 1694784903869
            276 verbose code 1
            277 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
              @abandonware/noble
              Da kann @abandonware/noble nicht gebaut werden.
              build-environment am Start?
                Wenn ich wüsste was das wäre... Linux ist nicht mein Gebiet.
                  @sirdrinsalot
                  Lass mal sehen wie du da womit unterwegs bist.
                  iob diag
                  Langfassung.
                    SirDrinsAlot last edited by Homoran
                    Ohje, is ne Menge.
                     *** BASE SYSTEM ***
                     Static hostname: iobrokerNUC
                           Icon name: computer-desktop
                             Chassis: desktop 🖥️
                          Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d
                             Boot ID: 200f822a21c448e884941fd698e54ca1
                              Kernel: Linux 6.1.0-12-amd64
                        Architecture: x86-64
                     Hardware Vendor: Default string
                      Hardware Model: Default string
                    Firmware Version: 5.27
                    model name      : Intel(R) N95
                    Docker          : false
                    Virtualization  : none
                    Kernel          : x86_64
                    Userland        : amd64
                    Systemuptime and Load:
                     16:48:21 up  3:32,  3 users,  load average: 0.43, 0.35, 0.26
                    CPU threads: 4
                    *** Time and Time Zones ***
                                   Local time: Fri 2023-09-15 16:48:21 CEST
                               Universal time: Fri 2023-09-15 14:48:21 UTC
                                     RTC time: Fri 2023-09-15 14:48:21
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    root
                    /root
                    root
                    *** X-Server-Setup ***
                    X-Server:       true
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:             16G        5.5G        4.6G        210M        7.0G         11G
                    Swap:           1.0G          0B        1.0G
                    Total:           17G        5.5G        5.6G
                            15767 M total memory
                             5258 M used memory
                             1133 M active memory
                             9391 M inactive memory
                             4349 M free memory
                              242 M buffer memory
                             6451 M swap cache
                              975 M total swap
                                0 M used swap
                              975 M free swap
                    *** FILESYSTEM ***
                    udev           devtmpfs  7.7G     0  7.7G   0% /dev
                    tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
                    /dev/sda2      ext4      467G  9.8G  434G   3% /
                    tmpfs          tmpfs     7.7G  792K  7.7G   1% /dev/shm
                    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                    /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                    tmpfs          tmpfs     1.6G  3.7M  1.6G   1% /run/user/1000
                    [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    Show mounted filesystems (real ones only):
                    TARGET               SOURCE    FSTYPE      OPTIONS
                    /                    /dev/sda2 ext4        rw,relatime,errors=remount-ro
                    |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                    `-/boot/efi          /dev/sda1 vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                    /var:
                    503M    /var/
                    231M    /var/cache
                    221M    /var/cache/apt
                    216M    /var/lib
                    145M    /var/cache/apt/archives
                    Archived and active journals take up 32.0M in the file system.
                    /opt/iobroker/backups:
                    71M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    784M    /opt/iobroker/iobroker-data/
                    698M    /opt/iobroker/iobroker-data/files
                    119M    /opt/iobroker/iobroker-data/files/vis-2
                    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                    71M     /opt/iobroker/iobroker-data/files/vis-2/static
                    73M     /opt/iobroker/iobroker-data/objects.jsonl
                    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.17.1
                    /usr/bin/node           v18.17.1
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Installed: 18.17.1-deb-1nodesource1
                      Candidate: 18.17.1-deb-1nodesource1
                      Version table:
                     *** 18.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                            100 /var/lib/dpkg/status
                         18.13.0+dfsg1-1 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    No configuration change needed.
                    Multihost discovery server: disabled
                    Discovery authentication:   enabled
                    Persistent activation:      disabled
                    Objects:                    jsonl on 127.0.0.1
                    States:                     jsonl on 127.0.0.1
                    Core adapters versions
                    js-controller:  5.0.12
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapters from github:   5
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobrokerNUC                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      system.adapter.admin.1                  : admin                 : iobrokerNUC                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.alexa2.0                 : alexa2                : iobrokerNUC                              - disabled
                    + system.adapter.backitup.0               : backitup              : iobrokerNUC                              -  enabled
                      system.adapter.ble.0                    : ble                   : iobrokerNUC                              - disabled
                      system.adapter.broadlink2.0             : broadlink2            : iobrokerNUC                              - disabled
                      system.adapter.cameras.0                : cameras               : iobrokerNUC                              - disabled, port: 8200, bind: 0.0.0.0
                      system.adapter.chromecast.0             : chromecast            : iobrokerNUC                              - disabled
                      system.adapter.cloud.0                  : cloud                 : iobrokerNUC                              - disabled
                      system.adapter.daswetter.0              : daswetter             : iobrokerNUC                              - disabled
                      system.adapter.devices.0                : devices               : iobrokerNUC                              - disabled
                      system.adapter.discovery.0              : discovery             : iobrokerNUC                              - disabled
                      system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : iobrokerNUC                              - disabled
                      system.adapter.ecovacs-deebot.3         : ecovacs-deebot        : iobrokerNUC                              - disabled
                      system.adapter.ecovacs-deebot.4         : ecovacs-deebot        : iobrokerNUC                              - disabled
                      system.adapter.energiefluss.0           : energiefluss          : iobrokerNUC                              - disabled
                      system.adapter.eusec.0                  : eusec                 : iobrokerNUC                              - disabled
                      system.adapter.feiertage.0              : feiertage             : iobrokerNUC                              - disabled
                      system.adapter.flot.0                   : flot                  : iobrokerNUC                              - disabled
                      system.adapter.fritzbox.0               : fritzbox              : iobrokerNUC                              - disabled
                      system.adapter.fritzdect.0              : fritzdect             : iobrokerNUC                              - disabled
                      system.adapter.fullcalendar.0           : fullcalendar          : iobrokerNUC                              - disabled
                      system.adapter.fullybrowser.0           : fullybrowser          : iobrokerNUC                              - disabled
                      system.adapter.govee-app.0              : govee-app             : iobrokerNUC                              - disabled
                      system.adapter.habpanel.0               : habpanel              : iobrokerNUC                              - disabled
                      system.adapter.history.0                : history               : iobrokerNUC                              - disabled
                      system.adapter.hm-rega.0                : hm-rega               : iobrokerNUC                              - disabled
                      system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                      system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                      system.adapter.homeconnect.0            : homeconnect           : iobrokerNUC                              - disabled
                      system.adapter.homekit-controller.0     : homekit-controller    : iobrokerNUC                              - disabled
                      system.adapter.homepilot20.0            : homepilot20           : iobrokerNUC                              - disabled
                      system.adapter.hue-extended.0           : hue-extended          : iobrokerNUC                              - disabled
                      system.adapter.hue.0                    : hue                   : iobrokerNUC                              - disabled, port: 443
                      system.adapter.ical.0                   : ical                  : iobrokerNUC                              - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerNUC                              - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerNUC                              - disabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC                              - disabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerNUC                              - disabled
                      system.adapter.influxdb.0               : influxdb              : iobrokerNUC                              - disabled, port: 8090
                      system.adapter.info.0                   : info                  : iobrokerNUC                              - disabled
                      system.adapter.iot.0                    : iot                   : iobrokerNUC                              - disabled
                      system.adapter.javascript.0             : javascript            : iobrokerNUC                              - disabled
                      system.adapter.linux-control.0          : linux-control         : iobrokerNUC                              - disabled
                      system.adapter.material.0               : material              : iobrokerNUC                              - disabled
                      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerNUC                              - disabled, port: 54321
                      system.adapter.mihome.0                 : mihome                : iobrokerNUC                              - disabled, port: 9898, bind: 0.0.0.0
                      system.adapter.mobile.0                 : mobile                : iobrokerNUC                              - disabled
                      system.adapter.mqtt.0                   : mqtt                  : iobrokerNUC                              - disabled, port: 1888, bind: 0.0.0.0
                      system.adapter.musiccast.0              : musiccast             : iobrokerNUC                              - disabled
                      system.adapter.net-tools.0              : net-tools             : iobrokerNUC                              - disabled
                      system.adapter.netatmo.0                : netatmo               : iobrokerNUC                              - disabled
                      system.adapter.netatmo.1                : netatmo               : iobrokerNUC                              - disabled
                      system.adapter.node-red.0               : node-red              : iobrokerNUC                              - disabled, port: 1880, bind: 192.168.178.143
                      system.adapter.radar2.0                 : radar2                : iobrokerNUC                              - disabled
                      system.adapter.sayit.0                  : sayit                 : iobrokerNUC                              - disabled
                      system.adapter.scenes.0                 : scenes                : iobrokerNUC                              - disabled
                      system.adapter.shelly.0                 : shelly                : iobrokerNUC                              - disabled, port: 1886, bind: 0.0.0.0
                      system.adapter.simple-api.0             : simple-api            : iobrokerNUC                              - disabled, port: 8087, bind: 192.168.178.143, run as: admin
                      system.adapter.slideshow.0              : slideshow             : iobrokerNUC                              - disabled
                      system.adapter.smartthings.0            : smartthings           : iobrokerNUC                              - disabled
                      system.adapter.socketio.0               : socketio              : iobrokerNUC                              - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                      system.adapter.sonoff.0                 : sonoff                : iobrokerNUC                              - disabled, port: 1883, bind: 192.168.178.143
                      system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokerNUC                              - disabled
                      system.adapter.synology.0               : synology              : iobrokerNUC                              - disabled, port: 5000
                      system.adapter.telegram.0               : telegram              : iobrokerNUC                              - disabled, port: 8443, bind: 0.0.0.0
                      system.adapter.terminal.0               : terminal              : iobrokerNUC                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                      system.adapter.text2command.0           : text2command          : iobrokerNUC                              - disabled
                      system.adapter.tileboard.0              : tileboard             : iobrokerNUC                              - disabled
                      system.adapter.tr-064.0                 : tr-064                : iobrokerNUC                              - disabled
                      system.adapter.tuya.0                   : tuya                  : iobrokerNUC                              - disabled
                      system.adapter.vis-2.0                  : vis-2                 : iobrokerNUC                              - disabled
                      system.adapter.vis-bars.0               : vis-bars              : iobrokerNUC                              - disabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerNUC                              - disabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerNUC                              - disabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerNUC                              - disabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerNUC                              - disabled
                      system.adapter.vis-history.0            : vis-history           : iobrokerNUC                              - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerNUC                              - disabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerNUC                              - disabled
                      system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerNUC                              - disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerNUC                              - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobrokerNUC                              - disabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokerNUC                              - disabled
                      system.adapter.vis-lcars.0              : vis-lcars             : iobrokerNUC                              - disabled
                      system.adapter.vis-map.0                : vis-map               : iobrokerNUC                              - disabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerNUC                              - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerNUC                              - disabled
                      system.adapter.vis-metro.0              : vis-metro             : iobrokerNUC                              - disabled
                      system.adapter.vis-players.0            : vis-players           : iobrokerNUC                              - disabled
                      system.adapter.vis-plumb.0              : vis-plumb             : iobrokerNUC                              - disabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerNUC                              - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerNUC                              - disabled
                      system.adapter.vis-weather.0            : vis-weather           : iobrokerNUC                              - disabled
                      system.adapter.vis.0                    : vis                   : iobrokerNUC                              - disabled
                      system.adapter.web.0                    : web                   : iobrokerNUC                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerNUC                              - disabled
                      system.adapter.wifilight.0              : wifilight             : iobrokerNUC                              - disabled
                      system.adapter.yeelight-2.0             : yeelight-2            : iobrokerNUC                              - disabled
                      system.adapter.yr.0                     : yr                    : iobrokerNUC                              - disabled
                      system.adapter.zigbee.0                 : zigbee                : iobrokerNUC                              - disabled, port: /dev/ttyUSB0
                      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobrokerNUC                              - disabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 6.8.0    , installed 6.10.1
                    Adapter    "alexa2"       : 3.24.1   , installed 3.25.2
                    Adapter    "backitup"     : 2.6.23   , installed 2.8.1
                    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                    Adapter    "discovery"    : 3.1.0    , installed 4.0.0
                    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                    Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
                    Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                    Adapter    "fullcalendar" : 1.2.0    , installed 2.2.6
                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "history"      : 2.2.6    , installed 2.2.6
                    Adapter    "hm-rega"      : 3.0.47   , installed 4.0.0
                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                    Adapter    "hue"          : 3.9.5    , installed 3.10.0
                    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "info"         : 1.9.26   , installed 2.0.0
                    Adapter    "iot"          : 1.14.5   , installed 2.0.11
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "material"     : 1.3.1    , installed 1.3.1
                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                    Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
                    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                    Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                    Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
                    Adapter    "synology"     : 2.1.13   , installed 3.0.0
                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "text2command" : 3.0.2    , installed 3.0.2
                    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.4
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
                    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                    Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
                    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                    Adapter    "yr"           : 5.3.0    , installed 5.3.0
                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
                    Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
                    Objects and States
                    Objects:        37997
                    States:         31034
                    W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                    Hit:4 http://deb.anydesk.com all InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:37838           0.0.0.0:*               LISTEN      0          188418     28229/anydesk
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21612      662/cupsd
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       212660     43636/iobroker.js-c
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       211792     43636/iobroker.js-c
                    tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          145110     28229/anydesk
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          166031     33594/sshd: /usr/sb
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          135901     1/init
                    tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          21672      544/brltty
                    tcp6       0      0 ::1:4101                :::*                    LISTEN      0          17962      544/brltty
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       211857     43667/io.admin.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21611      662/cupsd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          166033     33594/sshd: /usr/sb
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          136579     1/init
                    udp        0      0 0.0.0.0:56190           0.0.0.0:*                           103        17893      594/avahi-daemon: r
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137387     1/init
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23634      907/cups-browsed
                    udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          146842     28229/anydesk
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        17891      594/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          136581     1/init
                    udp6       0      0 :::52127                :::*                                103        17894      594/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                103        17892      594/avahi-daemon: r
                    2023-09-15 15:18:57.566  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                    2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log
                    2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                    2023-09-15 15:19:43.092  - info: host.iobrokerNUC iobroker exit 25
                    2023-09-15 15:23:58.531  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                    2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                    2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                    2023-09-15 15:24:04.010  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log
                    2023-09-15 15:24:04.011  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                    2023-09-15 15:24:05.036  - info: host.iobrokerNUC iobroker exit 25
                    2023-09-15 15:34:53.572  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                    2023-09-15 15:34:54.600  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                    2023-09-15 15:34:54.601  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                    2023-09-15 15:35:04.442  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
                    2023-09-15 15:35:04.443  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                    2023-09-15 15:35:05.468  - info: host.iobrokerNUC iobroker exit 25
                    2023-09-15 16:34:59.946  - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105
                    2023-09-15 16:35:01.497  - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2023-09-15 16:39:44.533  - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105
                    2023-09-15 16:39:53.534  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                    2023-09-15 16:39:54.568  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                    2023-09-15 16:39:54.569  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                    2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log
                    2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                    2023-09-15 16:40:04.857  - info: host.iobrokerNUC iobroker exit 25
                                         v.2023-06-20
                             Chassis: desktop 🖥️
                    Installation:           native
                    Kernel:                 x86_64
                    Userland:               amd64
                    Timezone:               Europe/Berlin (CEST, +0200)
                    User-ID:                0
                    X-Server:               true
                    Boot Target:            graphical.target
                    Pending OS-Updates:     0
                      @sirdrinsalot
                      Statt spoiler die codetags verwenden.
                        HAt nicht funktioniert, kam Forbidden, sry.
                          User-ID: 0
                          X-Server: true
                          Root und Desktop...
                          'nuff seen.
                          Schalt den Krampf aus und agier da als Standard-User.
                            @thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
                            @sirdrinsalot
                            habs gefixt
                              Thomas Braun Most Active @Homoran last edited by Thomas Braun
                              @homoran sagte in Homekit-controller lässt sich nicht installieren:
                              habs gefixt
                              Den Desktop und den root? Respekt!
                                habs gefixt
                                Natürlich!
                                ist jetzt forbidden!
                                  Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
                                  Ohne root hats eben auch nicht funktioniert.
                                    Ja, das ohnehin. AnyDesk ist auch verboten.
                                      Homoran Global Moderator Administrators @SirDrinsAlot last edited by Homoran
                                      @sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
                                      dann nimm jetzt den root und gib deinem user roottechte.
                                      melde dich dann als user an und mach
                                      iob stop
                                      iob fix
                                      iob start
                                        Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
                                          Auf dem raspberry hat alles immer genauso funktioniert, deswegen dacht ich das es so auch geht.
                                          Wie schaltet man den ab?
                                            @sirdrinsalot
                                            sudo systemctl set-default multi-user.target
                                            sudo systemctl isolate multi-user.target
                                            2106
