    3. Off Topic
    4. Homekit-controller lässt sich nicht installieren
      Thomas Braun Most Active @SirDrinsAlot last edited by
      @sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
      /home/iobroker/ Verzeichnis ist leer.
      Nein, ist es nicht.
      Dateien und Verzeichnisse, die mit einem Punkt beginnen sind ausgeblendet.
      ls -lAh /home/iobroker
      zeigt auch diese Dateien.
        Stimmt, sry bin eher windows user.
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@9.6.7
        2 info using node@v18.17.1
        3 timing npm:load:whichnode Completed in 1ms
        4 timing config:load:defaults Completed in 1ms
        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
        6 timing config:load:builtin Completed in 0ms
        7 timing config:load:cli Completed in 2ms
        8 timing config:load:env Completed in 0ms
        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
        10 timing config:load:project Completed in 2ms
        11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
        12 timing config:load:user Completed in 0ms
        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
        14 timing config:load:global Completed in 0ms
        15 timing config:load:setEnvs Completed in 1ms
        16 timing config:load Completed in 8ms
        17 timing npm:load:configload Completed in 8ms
        18 timing npm:load:mkdirpcache Completed in 1ms
        19 timing npm:load:mkdirplogs Completed in 0ms
        20 verbose title npm install iobroker.homekit-controller@0.5.8
        21 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.homekit-controller@0.5.8"
        22 timing npm:load:setTitle Completed in 1ms
        23 timing config:load:flatten Completed in 2ms
        24 timing npm:load:display Completed in 3ms
        25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-
        26 verbose logfile /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
        27 timing npm:load:logFile Completed in 7ms
        28 timing npm:load:timers Completed in 0ms
        29 timing npm:load:configScope Completed in 0ms
        30 timing npm:load Completed in 21ms
        31 timing arborist:ctor Completed in 0ms
        32 silly logfile start cleaning logs, removing 2 files
        33 silly logfile done cleaning log files
        34 timing idealTree:init Completed in 1269ms
        35 timing idealTree:userRequests Completed in 2ms
        36 silly idealTree buildDeps
        37 silly fetch manifest iobroker.homekit-controller@0.5.8
        38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
        39 http fetch GET 200 https://registry.npmjs.org/iobroker.homekit-controller 1537ms (cache revalidated)
        40 silly placeDep ROOT iobroker.homekit-controller@0.5.8 OK for: iobroker.inst@3.0.0 want: 0.5.8
        41 silly fetch manifest @iobroker/adapter-core@^2.6.7
        42 silly fetch manifest debug@^4.3.4
        43 silly fetch manifest hap-controller@^0.9.3
        44 silly fetch manifest @esm2cjs/p-queue@^7.3.0
        45 http fetch GET 200 https://registry.npmjs.org/debug 101ms (cache revalidated)
        46 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 596ms (cache revalidated)
        47 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-queue 1428ms (cache revalidated)
        48 http fetch GET 200 https://registry.npmjs.org/hap-controller 1609ms (cache revalidated)
        49 timing idealTree:#root Completed in 3167ms
        50 silly placeDep ROOT @esm2cjs/p-queue@7.3.0 OK for: iobroker.homekit-controller@0.5.8 want: ^7.3.0
        51 silly fetch manifest @esm2cjs/p-timeout@^5.0.2
        52 silly fetch manifest eventemitter3@^4.0.7
        53 silly placeDep node_modules/iobroker.homekit-controller @iobroker/adapter-core@2.6.8 OK for: iobroker.homekit-controller@0.5.8 want: ^2.6.7
        54 silly placeDep node_modules/iobroker.homekit-controller debug@4.3.4 OK for: iobroker.homekit-controller@0.5.8 want: ^4.3.4
        55 silly fetch manifest ms@2.1.2
        56 silly placeDep ROOT hap-controller@0.9.3 OK for: iobroker.homekit-controller@0.5.8 want: ^0.9.3
        57 silly fetch manifest @abandonware/noble@1.9.2-20
        58 silly fetch manifest dnssd@^0.4.1
        59 silly fetch manifest fast-srp-hap@^2.0.4
        60 silly fetch manifest http-parser-js@^0.5.8
        61 silly fetch manifest libsodium-wrappers@^0.7.11
        62 silly fetch manifest node-hkdf-sync@^1.0.0
        63 http fetch GET 200 https://registry.npmjs.org/http-parser-js 90ms (cache revalidated)
        64 http fetch GET 200 https://registry.npmjs.org/eventemitter3 407ms (cache revalidated)
        65 http fetch GET 200 https://registry.npmjs.org/ms 606ms (cache revalidated)
        66 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fnoble 603ms (cache revalidated)
        67 http fetch GET 200 https://registry.npmjs.org/libsodium-wrappers 778ms (cache revalidated)
        68 http fetch GET 200 https://registry.npmjs.org/node-hkdf-sync 1094ms (cache revalidated)
        69 http fetch GET 200 https://registry.npmjs.org/fast-srp-hap 1214ms (cache revalidated)
        70 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-timeout 1532ms (cache revalidated)
        71 http fetch GET 200 https://registry.npmjs.org/dnssd 1934ms (cache revalidated)
        72 timing idealTree:node_modules/iobroker.homekit-controller Completed in 1950ms
        73 silly placeDep ROOT @esm2cjs/p-timeout@5.1.0 OK for: @esm2cjs/p-queue@7.3.0 want: ^5.0.2
        74 silly placeDep node_modules/@esm2cjs/p-queue eventemitter3@4.0.7 OK for: @esm2cjs/p-queue@7.3.0 want: ^4.0.7
        75 timing idealTree:node_modules/@esm2cjs/p-queue Completed in 9ms
        76 timing idealTree:node_modules/@esm2cjs/p-timeout Completed in 0ms
        77 silly placeDep node_modules/hap-controller @abandonware/noble@1.9.2-20 OK for: hap-controller@0.9.3 want: 1.9.2-20
        78 silly fetch manifest node-addon-api@^4.3.0
        79 silly placeDep node_modules/hap-controller debug@4.3.4 OK for: hap-controller@0.9.3 want: ^4.3.4
        80 silly placeDep ROOT dnssd@0.4.1 OK for: hap-controller@0.9.3 want: ^0.4.1
        81 silly placeDep ROOT fast-srp-hap@2.0.4 OK for: hap-controller@0.9.3 want: ^2.0.4
        82 silly placeDep ROOT http-parser-js@0.5.8 OK for: hap-controller@0.9.3 want: ^0.5.8
        83 silly placeDep ROOT libsodium-wrappers@0.7.13 OK for: hap-controller@0.9.3 want: ^0.7.11
        84 silly fetch manifest libsodium@^0.7.13
        85 silly placeDep ROOT node-hkdf-sync@1.0.0 OK for: hap-controller@0.9.3 want: ^1.0.0
        86 silly fetch manifest vows@0.5.13
        87 http fetch GET 200 https://registry.npmjs.org/node-addon-api 88ms (cache revalidated)
        88 http fetch GET 200 https://registry.npmjs.org/libsodium 398ms (cache revalidated)
        89 http fetch GET 200 https://registry.npmjs.org/vows 1387ms (cache revalidated)
        90 timing idealTree:node_modules/hap-controller Completed in 1405ms
        91 timing idealTree:node_modules/dnssd Completed in 0ms
        92 timing idealTree:node_modules/fast-srp-hap Completed in 0ms
        93 timing idealTree:node_modules/http-parser-js Completed in 0ms
        94 silly placeDep ROOT libsodium@0.7.13 OK for: libsodium-wrappers@0.7.13 want: ^0.7.13
        95 timing idealTree:node_modules/libsodium-wrappers Completed in 4ms
        96 timing idealTree:node_modules/libsodium Completed in 0ms
        97 silly placeDep ROOT vows@0.5.13 OK for: node-hkdf-sync@1.0.0 want: 0.5.13
        98 timing idealTree:node_modules/node-hkdf-sync Completed in 4ms
        99 timing idealTree:node_modules/vows Completed in 0ms
        100 timing idealTree:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 0ms
        101 silly placeDep node_modules/hap-controller node-addon-api@4.3.0 OK for: @abandonware/noble@1.9.2-20 want: ^4.3.0
        102 timing idealTree:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 3ms
        103 silly placeDep node_modules/hap-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
        104 timing idealTree:node_modules/hap-controller/node_modules/debug Completed in 1ms
        105 timing idealTree:node_modules/hap-controller/node_modules/ms Completed in 0ms
        106 timing idealTree:node_modules/hap-controller/node_modules/node-addon-api Completed in 0ms
        107 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 0ms
        108 silly placeDep node_modules/iobroker.homekit-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
        109 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 1ms
        110 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 0ms
        111 timing idealTree:buildDeps Completed in 6549ms
        112 timing idealTree:fixDepFlags Completed in 13ms
        113 timing idealTree Completed in 7847ms
        114 timing reify:loadTrees Completed in 7848ms
        115 timing reify:diffTrees Completed in 40ms
        116 silly reify moves {}
        117 timing reify:retireShallow Completed in 0ms
        118 timing reify:createSparse Completed in 2ms
        119 timing reify:loadBundles Completed in 0ms
        120 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
        121 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
        122 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
        123 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
        124 timing reifyNode:node_modules/osx-temperature-sensor Completed in 9ms
        125 timing reifyNode:node_modules/fsevents Completed in 10ms
        126 timing reifyNode:node_modules/mdns/node_modules/bindings Completed in 168ms
        127 timing reifyNode:node_modules/authenticate-pam Completed in 168ms
        128 timing reifyNode:node_modules/hap-controller/node_modules/ms Completed in 170ms
        129 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 170ms
        130 timing reifyNode:node_modules/node-gyp/node_modules/strip-ansi Completed in 170ms
        131 timing reifyNode:node_modules/node-gyp/node_modules/string-width Completed in 170ms
        132 timing reifyNode:node_modules/node-gyp/node_modules/is-fullwidth-code-point Completed in 171ms
        133 timing reifyNode:node_modules/node-gyp/node_modules/brace-expansion Completed in 171ms
        134 timing reifyNode:node_modules/node-gyp/node_modules/ansi-regex Completed in 171ms
        135 timing reifyNode:node_modules/node-gyp/node_modules/aproba Completed in 171ms
        136 timing reifyNode:node_modules/@abandonware/noble/node_modules/ms Completed in 171ms
        137 timing reifyNode:node_modules/http-parser-js Completed in 173ms
        138 timing reifyNode:node_modules/node-gyp/node_modules/string_decoder Completed in 177ms
        139 timing reifyNode:node_modules/node-gyp/node_modules/npmlog Completed in 177ms
        140 timing reifyNode:node_modules/node-gyp/node_modules/minimatch Completed in 178ms
        141 timing reifyNode:node_modules/hap-controller/node_modules/debug Completed in 181ms
        142 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 180ms
        143 timing reifyNode:node_modules/@abandonware/noble/node_modules/debug Completed in 180ms
        144 timing reifyNode:node_modules/node-hkdf-sync Completed in 182ms
        145 timing reifyNode:node_modules/usocket Completed in 182ms
        146 timing reifyNode:node_modules/node-gyp/node_modules/are-we-there-yet Completed in 183ms
        147 timing reifyNode:node_modules/node-gyp/node_modules/glob Completed in 184ms
        148 timing reifyNode:node_modules/libsodium-wrappers Completed in 186ms
        149 timing reifyNode:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 188ms
        150 timing reifyNode:node_modules/@esm2cjs/p-timeout Completed in 188ms
        151 timing reifyNode:node_modules/napi-thread-safe-callback Completed in 188ms
        152 timing reifyNode:node_modules/net-ping Completed in 195ms
        153 timing reifyNode:node_modules/buildcheck Completed in 195ms
        154 timing reifyNode:node_modules/raw-socket Completed in 201ms
        155 timing reifyNode:node_modules/node-gyp/node_modules/gauge Completed in 201ms
        156 timing reifyNode:node_modules/fast-srp-hap Completed in 203ms
        157 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 207ms
        158 timing reifyNode:node_modules/node-gyp/node_modules/readable-stream Completed in 211ms
        159 timing reifyNode:node_modules/libsodium Completed in 212ms
        160 timing reifyNode:node_modules/@esm2cjs/p-queue Completed in 214ms
        161 timing reifyNode:node_modules/hap-controller/node_modules/node-addon-api Completed in 222ms
        162 timing reifyNode:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 221ms
        163 timing reifyNode:node_modules/vows Completed in 231ms
        164 timing reifyNode:node_modules/raw-socket/node_modules/nan Completed in 248ms
        165 timing reifyNode:node_modules/mdns Completed in 253ms
        166 timing reifyNode:node_modules/hap-controller Completed in 282ms
        167 timing reifyNode:node_modules/cpu-features Completed in 300ms
        168 timing reifyNode:node_modules/dnssd Completed in 302ms
        169 timing reifyNode:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 302ms
        170 timing reifyNode:node_modules/@abandonware/noble Completed in 300ms
        171 timing reifyNode:node_modules/node-gyp Completed in 307ms
        172 timing reifyNode:node_modules/iobroker.homekit-controller Completed in 329ms
        173 timing reify:unpack Completed in 331ms
        174 timing reify:unretire Completed in 0ms
        175 timing build:queue Completed in 3ms
        176 timing build:link:node_modules/dnssd Completed in 1ms
        177 timing build:link:node_modules/node-gyp Completed in 0ms
        178 timing build:link:node_modules/vows Completed in 0ms
        179 timing build:link Completed in 1ms
        180 info run @abandonware/noble@1.9.2-19 install node_modules/@abandonware/noble node-gyp-build
        181 info run authenticate-pam@1.0.5 install node_modules/authenticate-pam node-gyp rebuild
        182 info run cpu-features@0.0.9 install node_modules/cpu-features node buildcheck.js > buildcheck.gypi && node-gyp rebuild
        183 info run mdns@2.7.2 install node_modules/mdns node-gyp rebuild
        184 info run mdns@2.7.2 install { code: 1, signal: null }
        185 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns
        186 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns' ]
        187 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns/node_modules/bindings
        188 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns/node_modules/bindings' ]
        189 timing build:run:install:node_modules/mdns Completed in 551ms
        190 info run raw-socket@1.7.0 install node_modules/raw-socket node-gyp rebuild
        191 info run authenticate-pam@1.0.5 install { code: 1, signal: null }
        192 verbose reify failed optional dependency /opt/iobroker/node_modules/authenticate-pam
        193 silly reify mark deleted [ '/opt/iobroker/node_modules/authenticate-pam' ]
        194 timing build:run:install:node_modules/authenticate-pam Completed in 590ms
        195 info run usocket@0.3.0 install node_modules/usocket node-gyp rebuild
        196 info run cpu-features@0.0.9 install { code: 1, signal: null }
        197 verbose reify failed optional dependency /opt/iobroker/node_modules/cpu-features
        198 silly reify mark deleted [ '/opt/iobroker/node_modules/cpu-features' ]
        199 verbose reify failed optional dependency /opt/iobroker/node_modules/buildcheck
        200 silly reify mark deleted [ '/opt/iobroker/node_modules/buildcheck' ]
        201 timing build:run:install:node_modules/cpu-features Completed in 648ms
        202 info run @abandonware/noble@1.9.2-20 install node_modules/hap-controller/node_modules/@abandonware/noble node-gyp-build
        203 info run @abandonware/noble@1.9.2-19 install { code: 1, signal: null }
        204 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble
        205 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble' ]
        206 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/debug
        207 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/debug' ]
        208 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api
        209 silly reify mark deleted [
        209 silly reify   '/opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api'
        209 silly reify ]
        210 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/ms
        211 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/ms' ]
        212 timing build:run:install:node_modules/@abandonware/noble Completed in 685ms
        213 info run raw-socket@1.7.0 install { code: 1, signal: null }
        214 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket
        215 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket' ]
        216 verbose reify failed optional dependency /opt/iobroker/node_modules/net-ping
        217 silly reify mark deleted [ '/opt/iobroker/node_modules/net-ping' ]
        218 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket/node_modules/nan
        219 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket/node_modules/nan' ]
        220 timing build:run:install:node_modules/raw-socket Completed in 433ms
        221 info run usocket@0.3.0 install { code: 1, signal: null }
        222 verbose reify failed optional dependency /opt/iobroker/node_modules/usocket
        223 silly reify mark deleted [ '/opt/iobroker/node_modules/usocket' ]
        224 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp
        225 silly reify mark deleted [
        225 silly reify   '/opt/iobroker/node_modules/node-gyp',
        225 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp'
        225 silly reify ]
        226 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/glob
        227 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/glob' ]
        228 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/npmlog
        229 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
        230 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/minimatch
        231 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/minimatch' ]
        232 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet
        233 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
        234 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/gauge
        235 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
        236 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion
        237 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion' ]
        238 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/readable-stream
        239 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
        240 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/aproba
        241 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/aproba' ]
        242 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string-width
        243 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
        244 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi
        245 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
        246 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string_decoder
        247 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string_decoder' ]
        248 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point
        249 silly reify mark deleted [
        249 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
        249 silly reify ]
        250 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex
        251 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
        252 timing build:run:install:node_modules/usocket Completed in 435ms
        253 info run @abandonware/noble@1.9.2-20 install { code: 1, signal: null }
        254 timing reify:rollback:createSparse Completed in 51ms
        255 timing reify:rollback:retireShallow Completed in 0ms
        256 timing command:install Completed in 9458ms
        257 verbose stack Error: command failed
        257 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
        257 verbose stack     at ChildProcess.emit (node:events:514:28)
        257 verbose stack     at maybeClose (node:internal/child_process:1091:16)
        257 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
        258 verbose pkgid @abandonware/noble@1.9.2-20
        259 verbose cwd /opt/iobroker
        260 verbose Linux 6.1.0-12-amd64
        261 verbose node v18.17.1
        262 verbose npm  v9.6.7
        263 error code 1
        264 error path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
        265 error command failed
        266 error command sh -c node-gyp-build
        267 error (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
        267 error (Use `node --trace-deprecation ...` to show where the warning was created)
        267 error Traceback (most recent call last):
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
        267 error     sys.exit(gyp.script_main())
        267 error              ^^^^^^^^^^^^^^^^^
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
        267 error     return main(sys.argv[1:])
        267 error            ^^^^^^^^^^^^^^^^^^
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
        267 error     return gyp_main(args)
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
        267 error     [generator, flat_list, targets, data] = Load(
        267 error                                             ^^^^^
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
        267 error     result = gyp.input.Load(
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
        267 error     LoadTargetBuildFile(
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
        267 error     build_file_data = LoadOneBuildFile(
        267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
        267 error     build_file_contents = open(build_file_path, "rU").read()
        267 error                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
        267 error ValueError: invalid mode: 'rU' while trying to load binding.gyp
        267 error gyp ERR! configure error
        267 error gyp ERR! stack Error: `gyp` failed with exit code: 1
        267 error gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
        267 error gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
        267 error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
        267 error gyp ERR! System Linux 6.1.0-12-amd64
        267 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        267 error gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
        267 error gyp ERR! node -v v18.17.1
        267 error gyp ERR! node-gyp -v v7.1.2
        267 error gyp ERR! not ok
        268 verbose exit 1
        269 timing npm Completed in 9617ms
        270 verbose unfinished npm timer reify 1694784894962
        271 verbose unfinished npm timer reify:build 1694784903192
        272 verbose unfinished npm timer build 1694784903193
        273 verbose unfinished npm timer build:deps 1694784903193
        274 verbose unfinished npm timer build:run:install 1694784903197
        275 verbose unfinished npm timer build:run:install:node_modules/hap-controller/node_modules/@abandonware/noble 1694784903869
        276 verbose code 1
        277 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
          @abandonware/noble
          Da kann @abandonware/noble nicht gebaut werden.
          build-environment am Start?
            Wenn ich wüsste was das wäre... Linux ist nicht mein Gebiet.
              @sirdrinsalot
              Lass mal sehen wie du da womit unterwegs bist.
              iob diag
              Langfassung.
                SirDrinsAlot last edited by Homoran
                Ohje, is ne Menge.
                 *** BASE SYSTEM ***
                 Static hostname: iobrokerNUC
                       Icon name: computer-desktop
                         Chassis: desktop 🖥️
                      Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d
                         Boot ID: 200f822a21c448e884941fd698e54ca1
                          Kernel: Linux 6.1.0-12-amd64
                    Architecture: x86-64
                 Hardware Vendor: Default string
                  Hardware Model: Default string
                Firmware Version: 5.27
                model name      : Intel(R) N95
                Docker          : false
                Virtualization  : none
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 16:48:21 up  3:32,  3 users,  load average: 0.43, 0.35, 0.26
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Fri 2023-09-15 16:48:21 CEST
                           Universal time: Fri 2023-09-15 14:48:21 UTC
                                 RTC time: Fri 2023-09-15 14:48:21
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                root
                /root
                root
                *** X-Server-Setup ***
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             16G        5.5G        4.6G        210M        7.0G         11G
                Swap:           1.0G          0B        1.0G
                Total:           17G        5.5G        5.6G
                        15767 M total memory
                         5258 M used memory
                         1133 M active memory
                         9391 M inactive memory
                         4349 M free memory
                          242 M buffer memory
                         6451 M swap cache
                          975 M total swap
                            0 M used swap
                          975 M free swap
                *** FILESYSTEM ***
                udev           devtmpfs  7.7G     0  7.7G   0% /dev
                tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
                /dev/sda2      ext4      467G  9.8G  434G   3% /
                tmpfs          tmpfs     7.7G  792K  7.7G   1% /dev/shm
                tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                tmpfs          tmpfs     1.6G  3.7M  1.6G   1% /run/user/1000
                [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                Show mounted filesystems (real ones only):
                TARGET               SOURCE    FSTYPE      OPTIONS
                /                    /dev/sda2 ext4        rw,relatime,errors=remount-ro
                |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                `-/boot/efi          /dev/sda1 vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                /var:
                503M    /var/
                231M    /var/cache
                221M    /var/cache/apt
                216M    /var/lib
                145M    /var/cache/apt/archives
                Archived and active journals take up 32.0M in the file system.
                /opt/iobroker/backups:
                71M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                784M    /opt/iobroker/iobroker-data/
                698M    /opt/iobroker/iobroker-data/files
                119M    /opt/iobroker/iobroker-data/files/vis-2
                78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                71M     /opt/iobroker/iobroker-data/files/vis-2/static
                73M     /opt/iobroker/iobroker-data/objects.jsonl
                41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.17.1
                /usr/bin/node           v18.17.1
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                        100 /var/lib/dpkg/status
                     18.13.0+dfsg1-1 500
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                No configuration change needed.
                Multihost discovery server: disabled
                Discovery authentication:   enabled
                Persistent activation:      disabled
                Objects:                    jsonl on 127.0.0.1
                States:                     jsonl on 127.0.0.1
                Core adapters versions
                js-controller:  5.0.12
                admin:          6.10.1
                javascript:     7.1.4
                Adapters from github:   5
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobrokerNUC                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.admin.1                  : admin                 : iobrokerNUC                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alexa2.0                 : alexa2                : iobrokerNUC                              - disabled
                + system.adapter.backitup.0               : backitup              : iobrokerNUC                              -  enabled
                  system.adapter.ble.0                    : ble                   : iobrokerNUC                              - disabled
                  system.adapter.broadlink2.0             : broadlink2            : iobrokerNUC                              - disabled
                  system.adapter.cameras.0                : cameras               : iobrokerNUC                              - disabled, port: 8200, bind: 0.0.0.0
                  system.adapter.chromecast.0             : chromecast            : iobrokerNUC                              - disabled
                  system.adapter.cloud.0                  : cloud                 : iobrokerNUC                              - disabled
                  system.adapter.daswetter.0              : daswetter             : iobrokerNUC                              - disabled
                  system.adapter.devices.0                : devices               : iobrokerNUC                              - disabled
                  system.adapter.discovery.0              : discovery             : iobrokerNUC                              - disabled
                  system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : iobrokerNUC                              - disabled
                  system.adapter.ecovacs-deebot.3         : ecovacs-deebot        : iobrokerNUC                              - disabled
                  system.adapter.ecovacs-deebot.4         : ecovacs-deebot        : iobrokerNUC                              - disabled
                  system.adapter.energiefluss.0           : energiefluss          : iobrokerNUC                              - disabled
                  system.adapter.eusec.0                  : eusec                 : iobrokerNUC                              - disabled
                  system.adapter.feiertage.0              : feiertage             : iobrokerNUC                              - disabled
                  system.adapter.flot.0                   : flot                  : iobrokerNUC                              - disabled
                  system.adapter.fritzbox.0               : fritzbox              : iobrokerNUC                              - disabled
                  system.adapter.fritzdect.0              : fritzdect             : iobrokerNUC                              - disabled
                  system.adapter.fullcalendar.0           : fullcalendar          : iobrokerNUC                              - disabled
                  system.adapter.fullybrowser.0           : fullybrowser          : iobrokerNUC                              - disabled
                  system.adapter.govee-app.0              : govee-app             : iobrokerNUC                              - disabled
                  system.adapter.habpanel.0               : habpanel              : iobrokerNUC                              - disabled
                  system.adapter.history.0                : history               : iobrokerNUC                              - disabled
                  system.adapter.hm-rega.0                : hm-rega               : iobrokerNUC                              - disabled
                  system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                  system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                  system.adapter.homeconnect.0            : homeconnect           : iobrokerNUC                              - disabled
                  system.adapter.homekit-controller.0     : homekit-controller    : iobrokerNUC                              - disabled
                  system.adapter.homepilot20.0            : homepilot20           : iobrokerNUC                              - disabled
                  system.adapter.hue-extended.0           : hue-extended          : iobrokerNUC                              - disabled
                  system.adapter.hue.0                    : hue                   : iobrokerNUC                              - disabled, port: 443
                  system.adapter.ical.0                   : ical                  : iobrokerNUC                              - disabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerNUC                              - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerNUC                              - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC                              - disabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerNUC                              - disabled
                  system.adapter.influxdb.0               : influxdb              : iobrokerNUC                              - disabled, port: 8090
                  system.adapter.info.0                   : info                  : iobrokerNUC                              - disabled
                  system.adapter.iot.0                    : iot                   : iobrokerNUC                              - disabled
                  system.adapter.javascript.0             : javascript            : iobrokerNUC                              - disabled
                  system.adapter.linux-control.0          : linux-control         : iobrokerNUC                              - disabled
                  system.adapter.material.0               : material              : iobrokerNUC                              - disabled
                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerNUC                              - disabled, port: 54321
                  system.adapter.mihome.0                 : mihome                : iobrokerNUC                              - disabled, port: 9898, bind: 0.0.0.0
                  system.adapter.mobile.0                 : mobile                : iobrokerNUC                              - disabled
                  system.adapter.mqtt.0                   : mqtt                  : iobrokerNUC                              - disabled, port: 1888, bind: 0.0.0.0
                  system.adapter.musiccast.0              : musiccast             : iobrokerNUC                              - disabled
                  system.adapter.net-tools.0              : net-tools             : iobrokerNUC                              - disabled
                  system.adapter.netatmo.0                : netatmo               : iobrokerNUC                              - disabled
                  system.adapter.netatmo.1                : netatmo               : iobrokerNUC                              - disabled
                  system.adapter.node-red.0               : node-red              : iobrokerNUC                              - disabled, port: 1880, bind: 192.168.178.143
                  system.adapter.radar2.0                 : radar2                : iobrokerNUC                              - disabled
                  system.adapter.sayit.0                  : sayit                 : iobrokerNUC                              - disabled
                  system.adapter.scenes.0                 : scenes                : iobrokerNUC                              - disabled
                  system.adapter.shelly.0                 : shelly                : iobrokerNUC                              - disabled, port: 1886, bind: 0.0.0.0
                  system.adapter.simple-api.0             : simple-api            : iobrokerNUC                              - disabled, port: 8087, bind: 192.168.178.143, run as: admin
                  system.adapter.slideshow.0              : slideshow             : iobrokerNUC                              - disabled
                  system.adapter.smartthings.0            : smartthings           : iobrokerNUC                              - disabled
                  system.adapter.socketio.0               : socketio              : iobrokerNUC                              - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                  system.adapter.sonoff.0                 : sonoff                : iobrokerNUC                              - disabled, port: 1883, bind: 192.168.178.143
                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokerNUC                              - disabled
                  system.adapter.synology.0               : synology              : iobrokerNUC                              - disabled, port: 5000
                  system.adapter.telegram.0               : telegram              : iobrokerNUC                              - disabled, port: 8443, bind: 0.0.0.0
                  system.adapter.terminal.0               : terminal              : iobrokerNUC                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                  system.adapter.text2command.0           : text2command          : iobrokerNUC                              - disabled
                  system.adapter.tileboard.0              : tileboard             : iobrokerNUC                              - disabled
                  system.adapter.tr-064.0                 : tr-064                : iobrokerNUC                              - disabled
                  system.adapter.tuya.0                   : tuya                  : iobrokerNUC                              - disabled
                  system.adapter.vis-2.0                  : vis-2                 : iobrokerNUC                              - disabled
                  system.adapter.vis-bars.0               : vis-bars              : iobrokerNUC                              - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerNUC                              - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerNUC                              - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerNUC                              - disabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerNUC                              - disabled
                  system.adapter.vis-history.0            : vis-history           : iobrokerNUC                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerNUC                              - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerNUC                              - disabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerNUC                              - disabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerNUC                              - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : iobrokerNUC                              - disabled
                  system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokerNUC                              - disabled
                  system.adapter.vis-lcars.0              : vis-lcars             : iobrokerNUC                              - disabled
                  system.adapter.vis-map.0                : vis-map               : iobrokerNUC                              - disabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerNUC                              - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerNUC                              - disabled
                  system.adapter.vis-metro.0              : vis-metro             : iobrokerNUC                              - disabled
                  system.adapter.vis-players.0            : vis-players           : iobrokerNUC                              - disabled
                  system.adapter.vis-plumb.0              : vis-plumb             : iobrokerNUC                              - disabled
                  system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerNUC                              - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerNUC                              - disabled
                  system.adapter.vis-weather.0            : vis-weather           : iobrokerNUC                              - disabled
                  system.adapter.vis.0                    : vis                   : iobrokerNUC                              - disabled
                  system.adapter.web.0                    : web                   : iobrokerNUC                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerNUC                              - disabled
                  system.adapter.wifilight.0              : wifilight             : iobrokerNUC                              - disabled
                  system.adapter.yeelight-2.0             : yeelight-2            : iobrokerNUC                              - disabled
                  system.adapter.yr.0                     : yr                    : iobrokerNUC                              - disabled
                  system.adapter.zigbee.0                 : zigbee                : iobrokerNUC                              - disabled, port: /dev/ttyUSB0
                  system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobrokerNUC                              - disabled
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.8.0    , installed 6.10.1
                Adapter    "alexa2"       : 3.24.1   , installed 3.25.2
                Adapter    "backitup"     : 2.6.23   , installed 2.8.1
                Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "discovery"    : 3.1.0    , installed 4.0.0
                Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
                Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                Adapter    "fullcalendar" : 1.2.0    , installed 2.2.6
                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Adapter    "history"      : 2.2.6    , installed 2.2.6
                Adapter    "hm-rega"      : 3.0.47   , installed 4.0.0
                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                Adapter    "hue"          : 3.9.5    , installed 3.10.0
                Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "info"         : 1.9.26   , installed 2.0.0
                Adapter    "iot"          : 1.14.5   , installed 2.0.11
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                Adapter    "material"     : 1.3.1    , installed 1.3.1
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
                Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
                Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
                Adapter    "synology"     : 2.1.13   , installed 3.0.0
                Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                Adapter    "text2command" : 3.0.2    , installed 3.0.2
                Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.4
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
                Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
                Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
                Objects and States
                Objects:        37997
                States:         31034
                W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                Hit:4 http://deb.anydesk.com all InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:37838           0.0.0.0:*               LISTEN      0          188418     28229/anydesk
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21612      662/cupsd
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       212660     43636/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       211792     43636/iobroker.js-c
                tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          145110     28229/anydesk
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          166031     33594/sshd: /usr/sb
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          135901     1/init
                tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          21672      544/brltty
                tcp6       0      0 ::1:4101                :::*                    LISTEN      0          17962      544/brltty
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       211857     43667/io.admin.0
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21611      662/cupsd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          166033     33594/sshd: /usr/sb
                tcp6       0      0 :::111                  :::*                    LISTEN      0          136579     1/init
                udp        0      0 0.0.0.0:56190           0.0.0.0:*                           103        17893      594/avahi-daemon: r
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137387     1/init
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23634      907/cups-browsed
                udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          146842     28229/anydesk
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        17891      594/avahi-daemon: r
                udp6       0      0 :::111                  :::*                                0          136581     1/init
                udp6       0      0 :::52127                :::*                                103        17894      594/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                103        17892      594/avahi-daemon: r
                2023-09-15 15:18:57.566  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log
                2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                2023-09-15 15:19:43.092  - info: host.iobrokerNUC iobroker exit 25
                2023-09-15 15:23:58.531  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                2023-09-15 15:24:04.010  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log
                2023-09-15 15:24:04.011  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                2023-09-15 15:24:05.036  - info: host.iobrokerNUC iobroker exit 25
                2023-09-15 15:34:53.572  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                2023-09-15 15:34:54.600  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                2023-09-15 15:34:54.601  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                2023-09-15 15:35:04.442  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
                2023-09-15 15:35:04.443  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                2023-09-15 15:35:05.468  - info: host.iobrokerNUC iobroker exit 25
                2023-09-15 16:34:59.946  - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105
                2023-09-15 16:35:01.497  - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2023-09-15 16:39:44.533  - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105
                2023-09-15 16:39:53.534  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                2023-09-15 16:39:54.568  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                2023-09-15 16:39:54.569  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log
                2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                2023-09-15 16:40:04.857  - info: host.iobrokerNUC iobroker exit 25
                                     v.2023-06-20
                         Chassis: desktop 🖥️
                Installation:           native
                Kernel:                 x86_64
                Userland:               amd64
                Timezone:               Europe/Berlin (CEST, +0200)
                User-ID:                0
                X-Server:               true
                Boot Target:            graphical.target
                Pending OS-Updates:     0
                  @sirdrinsalot
                  Statt spoiler die codetags verwenden.
                    HAt nicht funktioniert, kam Forbidden, sry.
                      User-ID: 0
                      X-Server: true
                      Root und Desktop...
                      'nuff seen.
                      Schalt den Krampf aus und agier da als Standard-User.
                        @thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
                        @sirdrinsalot
                        habs gefixt
                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                          @homoran sagte in Homekit-controller lässt sich nicht installieren:
                          habs gefixt
                          Den Desktop und den root? Respekt!
                            habs gefixt
                            Natürlich!
                            ist jetzt forbidden!
                              Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
                              Ohne root hats eben auch nicht funktioniert.
                                Ja, das ohnehin. AnyDesk ist auch verboten.
                                  Homoran Global Moderator Administrators @SirDrinsAlot last edited by Homoran
                                  @sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
                                  dann nimm jetzt den root und gib deinem user roottechte.
                                  melde dich dann als user an und mach
                                  iob stop
                                  iob fix
                                  iob start
                                    Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
                                      Auf dem raspberry hat alles immer genauso funktioniert, deswegen dacht ich das es so auch geht.
                                      Wie schaltet man den ab?
                                        @sirdrinsalot
                                        sudo systemctl set-default multi-user.target
                                        sudo systemctl isolate multi-user.target
                                          ich glaub ich schieb das mal ins offtopic.
                                          Probleme mit der Homekit controller Installation ist mit Sicherheit kein Bug von ioBroker!
                                            Danke erstmal für die schnelle Hilfe, kann es erst morgen weiter testen.
                                            Bin halt leider ein kompletter linux DAU. Wenn man die Zeit hätte sich mehr damit zu beschäftigen.
                                            Naja, vielen Dank erstmal.
                                            2106
