    3. Off Topic
    4. Homekit-controller lässt sich nicht installieren
      SirDrinsAlot last edited by
      Wenn ich wüsste was das wäre... Linux ist nicht mein Gebiet.
        Thomas Braun Most Active @SirDrinsAlot last edited by
        @sirdrinsalot
        Lass mal sehen wie du da womit unterwegs bist.
        iob diag
        Langfassung.
          SirDrinsAlot last edited by Homoran
          Ohje, is ne Menge.
           *** BASE SYSTEM ***
           Static hostname: iobrokerNUC
                 Icon name: computer-desktop
                   Chassis: desktop 🖥️
                Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d
                   Boot ID: 200f822a21c448e884941fd698e54ca1
                    Kernel: Linux 6.1.0-12-amd64
              Architecture: x86-64
           Hardware Vendor: Default string
            Hardware Model: Default string
          Firmware Version: 5.27
          model name      : Intel(R) N95
          Docker          : false
          Virtualization  : none
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           16:48:21 up  3:32,  3 users,  load average: 0.43, 0.35, 0.26
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Fri 2023-09-15 16:48:21 CEST
                     Universal time: Fri 2023-09-15 14:48:21 UTC
                           RTC time: Fri 2023-09-15 14:48:21
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          root
          /root
          root
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             16G        5.5G        4.6G        210M        7.0G         11G
          Swap:           1.0G          0B        1.0G
          Total:           17G        5.5G        5.6G
                  15767 M total memory
                   5258 M used memory
                   1133 M active memory
                   9391 M inactive memory
                   4349 M free memory
                    242 M buffer memory
                   6451 M swap cache
                    975 M total swap
                      0 M used swap
                    975 M free swap
          *** FILESYSTEM ***
          udev           devtmpfs  7.7G     0  7.7G   0% /dev
          tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
          /dev/sda2      ext4      467G  9.8G  434G   3% /
          tmpfs          tmpfs     7.7G  792K  7.7G   1% /dev/shm
          tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
          /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
          tmpfs          tmpfs     1.6G  3.7M  1.6G   1% /run/user/1000
          [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET               SOURCE    FSTYPE      OPTIONS
          /                    /dev/sda2 ext4        rw,relatime,errors=remount-ro
          |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot/efi          /dev/sda1 vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
          /var:
          503M    /var/
          231M    /var/cache
          221M    /var/cache/apt
          216M    /var/lib
          145M    /var/cache/apt/archives
          Archived and active journals take up 32.0M in the file system.
          /opt/iobroker/backups:
          71M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          784M    /opt/iobroker/iobroker-data/
          698M    /opt/iobroker/iobroker-data/files
          119M    /opt/iobroker/iobroker-data/files/vis-2
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          71M     /opt/iobroker/iobroker-data/files/vis-2/static
          73M     /opt/iobroker/iobroker-data/objects.jsonl
          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          No configuration change needed.
          Multihost discovery server: disabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    jsonl on 127.0.0.1
          States:                     jsonl on 127.0.0.1
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.10.1
          javascript:     7.1.4
          Adapters from github:   5
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobrokerNUC                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.admin.1                  : admin                 : iobrokerNUC                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                 : alexa2                : iobrokerNUC                              - disabled
          + system.adapter.backitup.0               : backitup              : iobrokerNUC                              -  enabled
            system.adapter.ble.0                    : ble                   : iobrokerNUC                              - disabled
            system.adapter.broadlink2.0             : broadlink2            : iobrokerNUC                              - disabled
            system.adapter.cameras.0                : cameras               : iobrokerNUC                              - disabled, port: 8200, bind: 0.0.0.0
            system.adapter.chromecast.0             : chromecast            : iobrokerNUC                              - disabled
            system.adapter.cloud.0                  : cloud                 : iobrokerNUC                              - disabled
            system.adapter.daswetter.0              : daswetter             : iobrokerNUC                              - disabled
            system.adapter.devices.0                : devices               : iobrokerNUC                              - disabled
            system.adapter.discovery.0              : discovery             : iobrokerNUC                              - disabled
            system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : iobrokerNUC                              - disabled
            system.adapter.ecovacs-deebot.3         : ecovacs-deebot        : iobrokerNUC                              - disabled
            system.adapter.ecovacs-deebot.4         : ecovacs-deebot        : iobrokerNUC                              - disabled
            system.adapter.energiefluss.0           : energiefluss          : iobrokerNUC                              - disabled
            system.adapter.eusec.0                  : eusec                 : iobrokerNUC                              - disabled
            system.adapter.feiertage.0              : feiertage             : iobrokerNUC                              - disabled
            system.adapter.flot.0                   : flot                  : iobrokerNUC                              - disabled
            system.adapter.fritzbox.0               : fritzbox              : iobrokerNUC                              - disabled
            system.adapter.fritzdect.0              : fritzdect             : iobrokerNUC                              - disabled
            system.adapter.fullcalendar.0           : fullcalendar          : iobrokerNUC                              - disabled
            system.adapter.fullybrowser.0           : fullybrowser          : iobrokerNUC                              - disabled
            system.adapter.govee-app.0              : govee-app             : iobrokerNUC                              - disabled
            system.adapter.habpanel.0               : habpanel              : iobrokerNUC                              - disabled
            system.adapter.history.0                : history               : iobrokerNUC                              - disabled
            system.adapter.hm-rega.0                : hm-rega               : iobrokerNUC                              - disabled
            system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
            system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
            system.adapter.homeconnect.0            : homeconnect           : iobrokerNUC                              - disabled
            system.adapter.homekit-controller.0     : homekit-controller    : iobrokerNUC                              - disabled
            system.adapter.homepilot20.0            : homepilot20           : iobrokerNUC                              - disabled
            system.adapter.hue-extended.0           : hue-extended          : iobrokerNUC                              - disabled
            system.adapter.hue.0                    : hue                   : iobrokerNUC                              - disabled, port: 443
            system.adapter.ical.0                   : ical                  : iobrokerNUC                              - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerNUC                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerNUC                              - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC                              - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerNUC                              - disabled
            system.adapter.influxdb.0               : influxdb              : iobrokerNUC                              - disabled, port: 8090
            system.adapter.info.0                   : info                  : iobrokerNUC                              - disabled
            system.adapter.iot.0                    : iot                   : iobrokerNUC                              - disabled
            system.adapter.javascript.0             : javascript            : iobrokerNUC                              - disabled
            system.adapter.linux-control.0          : linux-control         : iobrokerNUC                              - disabled
            system.adapter.material.0               : material              : iobrokerNUC                              - disabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerNUC                              - disabled, port: 54321
            system.adapter.mihome.0                 : mihome                : iobrokerNUC                              - disabled, port: 9898, bind: 0.0.0.0
            system.adapter.mobile.0                 : mobile                : iobrokerNUC                              - disabled
            system.adapter.mqtt.0                   : mqtt                  : iobrokerNUC                              - disabled, port: 1888, bind: 0.0.0.0
            system.adapter.musiccast.0              : musiccast             : iobrokerNUC                              - disabled
            system.adapter.net-tools.0              : net-tools             : iobrokerNUC                              - disabled
            system.adapter.netatmo.0                : netatmo               : iobrokerNUC                              - disabled
            system.adapter.netatmo.1                : netatmo               : iobrokerNUC                              - disabled
            system.adapter.node-red.0               : node-red              : iobrokerNUC                              - disabled, port: 1880, bind: 192.168.178.143
            system.adapter.radar2.0                 : radar2                : iobrokerNUC                              - disabled
            system.adapter.sayit.0                  : sayit                 : iobrokerNUC                              - disabled
            system.adapter.scenes.0                 : scenes                : iobrokerNUC                              - disabled
            system.adapter.shelly.0                 : shelly                : iobrokerNUC                              - disabled, port: 1886, bind: 0.0.0.0
            system.adapter.simple-api.0             : simple-api            : iobrokerNUC                              - disabled, port: 8087, bind: 192.168.178.143, run as: admin
            system.adapter.slideshow.0              : slideshow             : iobrokerNUC                              - disabled
            system.adapter.smartthings.0            : smartthings           : iobrokerNUC                              - disabled
            system.adapter.socketio.0               : socketio              : iobrokerNUC                              - disabled, port: 8085, bind: 0.0.0.0, run as: admin
            system.adapter.sonoff.0                 : sonoff                : iobrokerNUC                              - disabled, port: 1883, bind: 192.168.178.143
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokerNUC                              - disabled
            system.adapter.synology.0               : synology              : iobrokerNUC                              - disabled, port: 5000
            system.adapter.telegram.0               : telegram              : iobrokerNUC                              - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.terminal.0               : terminal              : iobrokerNUC                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
            system.adapter.text2command.0           : text2command          : iobrokerNUC                              - disabled
            system.adapter.tileboard.0              : tileboard             : iobrokerNUC                              - disabled
            system.adapter.tr-064.0                 : tr-064                : iobrokerNUC                              - disabled
            system.adapter.tuya.0                   : tuya                  : iobrokerNUC                              - disabled
            system.adapter.vis-2.0                  : vis-2                 : iobrokerNUC                              - disabled
            system.adapter.vis-bars.0               : vis-bars              : iobrokerNUC                              - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerNUC                              - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerNUC                              - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerNUC                              - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerNUC                              - disabled
            system.adapter.vis-history.0            : vis-history           : iobrokerNUC                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerNUC                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerNUC                              - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerNUC                              - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerNUC                              - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobrokerNUC                              - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokerNUC                              - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobrokerNUC                              - disabled
            system.adapter.vis-map.0                : vis-map               : iobrokerNUC                              - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerNUC                              - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerNUC                              - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobrokerNUC                              - disabled
            system.adapter.vis-players.0            : vis-players           : iobrokerNUC                              - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobrokerNUC                              - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerNUC                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerNUC                              - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobrokerNUC                              - disabled
            system.adapter.vis.0                    : vis                   : iobrokerNUC                              - disabled
            system.adapter.web.0                    : web                   : iobrokerNUC                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerNUC                              - disabled
            system.adapter.wifilight.0              : wifilight             : iobrokerNUC                              - disabled
            system.adapter.yeelight-2.0             : yeelight-2            : iobrokerNUC                              - disabled
            system.adapter.yr.0                     : yr                    : iobrokerNUC                              - disabled
            system.adapter.zigbee.0                 : zigbee                : iobrokerNUC                              - disabled, port: /dev/ttyUSB0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobrokerNUC                              - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.8.0    , installed 6.10.1
          Adapter    "alexa2"       : 3.24.1   , installed 3.25.2
          Adapter    "backitup"     : 2.6.23   , installed 2.8.1
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "discovery"    : 3.1.0    , installed 4.0.0
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
          Adapter    "eusec"        : 1.1.2    , installed 1.1.2
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
          Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "fullcalendar" : 1.2.0    , installed 2.2.6
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "history"      : 2.2.6    , installed 2.2.6
          Adapter    "hm-rega"      : 3.0.47   , installed 4.0.0
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
          Adapter    "hue"          : 3.9.5    , installed 3.10.0
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 2.0.0
          Adapter    "iot"          : 1.14.5   , installed 2.0.11
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "radar2"       : 2.0.7    , installed 2.0.7
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
          Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
          Adapter    "synology"     : 2.1.13   , installed 3.0.0
          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "text2command" : 3.0.2    , installed 3.0.2
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
          Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
          Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
          Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
          Objects and States
          Objects:        37997
          States:         31034
          W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:4 http://deb.anydesk.com all InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:37838           0.0.0.0:*               LISTEN      0          188418     28229/anydesk
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21612      662/cupsd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       212660     43636/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       211792     43636/iobroker.js-c
          tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          145110     28229/anydesk
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          166031     33594/sshd: /usr/sb
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          135901     1/init
          tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          21672      544/brltty
          tcp6       0      0 ::1:4101                :::*                    LISTEN      0          17962      544/brltty
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       211857     43667/io.admin.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21611      662/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          166033     33594/sshd: /usr/sb
          tcp6       0      0 :::111                  :::*                    LISTEN      0          136579     1/init
          udp        0      0 0.0.0.0:56190           0.0.0.0:*                           103        17893      594/avahi-daemon: r
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137387     1/init
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23634      907/cups-browsed
          udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          146842     28229/anydesk
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        17891      594/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          136581     1/init
          udp6       0      0 :::52127                :::*                                103        17894      594/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                103        17892      594/avahi-daemon: r
          2023-09-15 15:18:57.566  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
          2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log
          2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
          2023-09-15 15:19:43.092  - info: host.iobrokerNUC iobroker exit 25
          2023-09-15 15:23:58.531  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
          2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
          2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
          2023-09-15 15:24:04.010  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log
          2023-09-15 15:24:04.011  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
          2023-09-15 15:24:05.036  - info: host.iobrokerNUC iobroker exit 25
          2023-09-15 15:34:53.572  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
          2023-09-15 15:34:54.600  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
          2023-09-15 15:34:54.601  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
          2023-09-15 15:35:04.442  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
          2023-09-15 15:35:04.443  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
          2023-09-15 15:35:05.468  - info: host.iobrokerNUC iobroker exit 25
          2023-09-15 16:34:59.946  - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105
          2023-09-15 16:35:01.497  - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2023-09-15 16:39:44.533  - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105
          2023-09-15 16:39:53.534  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
          2023-09-15 16:39:54.568  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
          2023-09-15 16:39:54.569  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
          2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log
          2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
          2023-09-15 16:40:04.857  - info: host.iobrokerNUC iobroker exit 25
                               v.2023-06-20
                   Chassis: desktop 🖥️
          Installation:           native
          Kernel:                 x86_64
          Userland:               amd64
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                0
          X-Server:               true
          Boot Target:            graphical.target
          Pending OS-Updates:     0
            @sirdrinsalot
            Statt spoiler die codetags verwenden.
              HAt nicht funktioniert, kam Forbidden, sry.
                @sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
                User-ID: 0
                X-Server: true
                Root und Desktop...
                'nuff seen.
                Schalt den Krampf aus und agier da als Standard-User.
                  @thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
                  @sirdrinsalot
                  habs gefixt
                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                    @homoran sagte in Homekit-controller lässt sich nicht installieren:
                    habs gefixt
                    Den Desktop und den root? Respekt!
                      habs gefixt
                      Natürlich!
                      ist jetzt forbidden!
                        Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
                        Ohne root hats eben auch nicht funktioniert.
                          Ja, das ohnehin. AnyDesk ist auch verboten.
                            Homoran Global Moderator Administrators @SirDrinsAlot last edited by Homoran
                            @sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
                            dann nimm jetzt den root und gib deinem user roottechte.
                            melde dich dann als user an und mach
                            iob stop
                            iob fix
                            iob start
                              Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
                                Auf dem raspberry hat alles immer genauso funktioniert, deswegen dacht ich das es so auch geht.
                                Wie schaltet man den ab?
                                  @sirdrinsalot
                                  sudo systemctl set-default multi-user.target
                                  sudo systemctl isolate multi-user.target
                                    ich glaub ich schieb das mal ins offtopic.
                                    Probleme mit der Homekit controller Installation ist mit Sicherheit kein Bug von ioBroker!
                                      Danke erstmal für die schnelle Hilfe, kann es erst morgen weiter testen.
                                      Bin halt leider ein kompletter linux DAU. Wenn man die Zeit hätte sich mehr damit zu beschäftigen.
                                      Naja, vielen Dank erstmal.
                                        Moin
                                        Habe jetzt nochmal alles platt gemacht und wieder iobroker auf Windows installiert.
                                        Kam der selbe Fehler. Habe dann die python pfade angepasst und Visual Studio 2017 installiert statt 22, mit dem funktionierte es nicht und jetzt läuft alles.
                                        Danke nochmals.
                                        D H 2 Replies Last reply Reply Quote 0
                                          drdolittle @SirDrinsAlot last edited by
                                          @sirdrinsalot kannst du genau beschreiben, was du gemacht hast, damit das klappt?
                                          Bei mir kommt auch Error 25 unter Windows mit:
                                          Installing iobroker.homekit-controller@0.5.9... (System call)
                                          npm ERR! code 1npm ERR! path C:\ioBroker\node_modules@abandonware\noblenpm ERR! command failednpm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp-buildnpm ERR!
                                          usw.
                                          Den Noble Ordner gibt es nicht in @abandonware
                                            BastiBerlin last edited by
                                            @SirDrinsAlot ich habe ähnliche Probleme unter Windows.
                                            wie hast du es letztendlich doch zum laufen bekommen?
                                            Basti
                                            2106
