    4. Test Adapter Ford 0.0.x
    • massenbach
      massenbach @tombox last edited by
      @tombox Dann werde ich mal auf die 0.0.9 gehen und in ein paar Tagen berichten. Danke
      • massenbach
        massenbach @tombox last edited by Negalein
        @tombox oder ich berichte schon mal gleich:
        ford.0	2022-02-27 21:45:22.063	error	(2617) {"statusCode":404,"message":"Resource not found"}
        ford.0	2022-02-27 21:45:22.062	error	(2617) Error: Request failed with status code 404
        ford.0	2022-02-27 21:42:21.369	error	(2617) {"statusCode":404,"message":"Resource not found"}
        ford.0	2022-02-27 21:42:21.368	error	(2617) Error: Request failed with status code 404
        ford.0	2022-02-27 21:42:20.560	error	(2617) {"statusCode":404,"message":"Resource not found"}
        ford.0	2022-02-27 21:42:20.560	error	(2617) Error: Request failed with status code 404
        ford.0	2022-02-27 21:42:20.053	error	(2617) {"statusCode":404,"message":"Resource not found"}
        ford.0	2022-02-27 21:42:20.052	error	(2617) Error: Request failed with status code 404
        ford.0	2022-02-27 21:40:21.670	info	(2617) Login successful
        ford.0	2022-02-27 21:40:20.643	info	(2617) starting. Version 0.0.9 (non-npm: TA2k/ioBroker.ford#670f33792745af01a4badc266895809593fbf816) in /opt/iobroker/node_modules/iobroker.ford, node: v14.19.0, js-controller: 4.0.15
          tombox @massenbach last edited by
          @massenbach Vielleicht könntest du nochma via github installieren da müssten mehr details kommen
          massenbach 1 Reply Last reply Reply Quote 0
          • massenbach
            @tombox Moin, hoffe das hilft Dir.
            ford.0	2022-02-28 06:27:21.716	error	(13422) {"statusCode":404,"message":"Resource not found"}
            ford.0	2022-02-28 06:27:21.714	error	(13422) Error: Request failed with status code 404
            ford.0	2022-02-28 06:27:20.704	error	(13422) {"statusCode":404,"message":"Resource not found"}
            ford.0	2022-02-28 06:27:20.703	error	(13422) Error: Request failed with status code 404
            ford.0	2022-02-28 06:27:16.874	error	(13422) {"statusCode":404,"message":"Resource not found"}
            ford.0	2022-02-28 06:27:16.872	error	(13422) Error: Request failed with status code 404
            ford.0	2022-02-28 06:25:39.514	info	(13422) 2 vehicles found
            ford.0	2022-02-28 06:25:37.636	info	(13422) Login successful
            ford.0	2022-02-28 06:25:36.899	info	(13422) starting. Version 0.0.9 (non-npm: TA2k/ioBroker.ford#master) in /opt/iobroker/node_modules/iobroker.ford, node: v14.19.0, js-controller: 4.0.15
            host.raspberrypi	2022-02-28 06:25:25.789	info	Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
            host.raspberrypi	2022-02-28 06:25:24.407	info	instance system.adapter.ford.0 started with pid 13422
            host.raspberrypi	2022-02-28 06:25:20.368	info	iobroker exit 0
            host.raspberrypi	2022-02-28 06:25:20.178	info	instance system.adapter.ford.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            host.raspberrypi	2022-02-28 06:25:19.352	info	stopInstance system.adapter.ford.0 send kill signal
            ford.0	2022-02-28 06:25:19.313	info	(2617) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            ford.0	2022-02-28 06:25:19.311	info	(2617) terminating
            ford.0	2022-02-28 06:25:19.293	info	(2617) Got terminate signal TERMINATE_YOURSELF
            host.raspberrypi	2022-02-28 06:25:19.280	info	stopInstance system.adapter.ford.0 (force=false, process=true)
            host.raspberrypi	2022-02-28 06:25:19.251	info	iobroker Update "system.adapter.ford.0"
            host.raspberrypi	2022-02-28 06:25:19.168	info	iobroker upload [0] ford.admin /opt/iobroker/node_modules/iobroker.ford/admin/words.js words.js application/javascript
            host.raspberrypi	2022-02-28 06:25:19.158	info	iobroker upload [1] ford.admin /opt/iobroker/node_modules/iobroker.ford/admin/style.css style.css text/css
            host.raspberrypi	2022-02-28 06:25:19.146	info	iobroker upload [2] ford.admin /opt/iobroker/node_modules/iobroker.ford/admin/index_m.html index_m.html text/html
            host.raspberrypi	2022-02-28 06:25:19.134	info	iobroker upload [3] ford.admin /opt/iobroker/node_modules/iobroker.ford/admin/ford.png ford.png image/png
            host.raspberrypi	2022-02-28 06:25:18.949	info	iobroker upload [4] ford.admin /opt/iobroker/node_modules/iobroker.ford/admin/admin.d.ts admin.d.ts video/mp2t
            host.raspberrypi	2022-02-28 06:25:18.845	info	iobroker 177 packages are looking for funding run `npm fund` for details
            host.raspberrypi	2022-02-28 06:25:04.442	info	iobroker + iobroker.ford@0.0.9removed 3 packages and updated 1 package in 60.849s
            host.raspberrypi	2022-02-28 06:25:04.437	info	iobroker npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            host.raspberrypi	2022-02-28 06:25:04.435	info	iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
            host.raspberrypi	2022-02-28 06:25:04.391	info	iobroker npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            host.raspberrypi	2022-02-28 06:25:04.389	info	iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
            host.raspberrypi	2022-02-28 06:25:04.337	info	iobroker npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            host.raspberrypi	2022-02-28 06:25:04.336	info	iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
            host.raspberrypi	2022-02-28 06:25:04.291	info	iobroker npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            host.raspberrypi	2022-02-28 06:25:04.290	info	iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
            host.raspberrypi	2022-02-28 06:25:04.253	info	iobroker npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            host.raspberrypi	2022-02-28 06:25:04.252	info	iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
            host.raspberrypi	2022-02-28 06:25:04.202	info	iobroker npm WARN rifm@0.7.0 requires a peer of react@>=16.8 but none is installed. You must install peer dependencies yourself.
            host.raspberrypi	2022-02-28 06:25:04.150	info	iobroker npm WARN react-transition-group@4.4.2 requires a peer of react-dom@>=16.6.0 but none is installed. You must install peer dependencies yourself.
            host.raspberrypi	2022-02-28 06:25:04.101	info	iobroker npm WARN react-transition-group@4.4.2 requires a peer of react@>=16.6.0 but none is installed. You must install peer dependencies yourself.
            host.raspberrypi	2022-02-28 06:25:04.054	info	iobroker npm WARN @material-ui/pickers@3.3.10 requires a peer of react-dom@^16.8.0 || ^17.0.0 but none is installed. You must install peer dependencies yourself.
            host.raspberrypi	2022-02-28 06:25:04.006	info	iobroker npm WARN @material-ui/pickers@3.3.10 requires a peer of react@^16.8.0 || ^17.0.0 but none is installed. You must install peer dependencies yourself.
            host.raspberrypi	2022-02-28 06:25:03.968	info	iobroker npm WARN @material-ui/pickers@3.3.10 requires a peer of @material-ui/core@^4.0.0 but none is installed. You must install peer dependencies yourself.
              ps-neotrace last edited by
              @tombox Zuerst einmal möchte ich für den hervorragenden Adapter meinen Dank aussprechen. Verwende Ihn seit Anfang diesen Jahres. Seit wir unsereren Tourneo Custom. Das Teil läuft! Tatsächlich zu gut für einen Leien wie mich, was dazu führte das ich ganz am Anfang den Updateintervall auf 1sec runterstellte um dann nach 3 Tagen mit total tiefenentladenen Batterien beim Händler zu stehen 🙂 ADAC sei dank... Der fragte sich natürlich wie das sein kann, da wir das Auto gerade 14 Tage auf dem Hof hatten... an die App und den IO-Broker hat natürlich zu dem Zeitpunkt keiner gedacht.
              Nun habe ich seit dem die Zeit fürs Update auf Stunden raufgesetzt und würde gern wissen wollen ob ich das auch tatsächlich umstellen kann, ggf. durch ein Script, das er nur abfragt wenn er läuft oder eine Art der Batterieschonung.
              Ansonsten läuft der Adapter tatsächlich bei mir seit dem ersten Tag Störungsfrei und ich war positiv überrascht wieviele Infos ich aus dem System auslesen kann im Verhältnis zur App.
              Wenn möglich gern mal ein Script für die Abfrage mitteilen... Habe heute auf Version 0.0.12 geupdatet.
              Vielen Dank auf jeden Fall für deine/eure mühen. Für mich als nur Nutzer ist das Ding Gold wert!
              LG Patrik
                tombox @ps-neotrace last edited by
                @ps-neotrace Das ist natürlich ärgerlich dass sich das Fahrzeug nicht dagegen schützt. Kann ja auch mit der App passieren.
                Und Minimum Intervall sind auch 30 Sekunden
                Du kannst die interval zeit auf 24h und mit remote.refresh jederzeit manuell updaten
                  dadsche last edited by Negalein
                  Hallo Zusammen,
                  ich habe feststellen müssen, dass das Auto aufgrund des Adapters die 12v Batterie komplett entläd und dann gar nichts mehr geht. Bei unserem Auto hat es auch dazu geführt, dass das entsprechende Modul getauscht werden musste.
                  In den Einstellungen des Adapters hatte ich die Intervallzeit auf 1 Minute heruntergesetzt und den Haken bei "Update bei jedem Intervall anfordern" gesetzt. Mir war nicht klar (und ich meine, ich habe es auch nirgends gelesen), dass dadurch jedes Mal eine Anfrage an die Ford Server und von dort an das Auto gesendet wird und dadurch das Auto quasi dauerhaft "wach" bleibt und Daten sendet.
                  Ich habe nun die Intervallzeit auf 5 Minuten gesetzt (wie standardmäßig eingestellt) und den Haken entfernt. Da, wenn ich es richtig verstehe, es somit nur zur Anfrage bei den Ford Servern kommt und diese letzten Werte übermitteln und keine explizite Anfrage zum Auto senden. Ist dies korrekt?
                  Ein Problem was sich jetzt aber auftut, ist dass mein Log mit lauter Fehlermeldungen des Ford Adapters gefüllt wird.
                  ford.0 2023-09-15 12:12:31.382 error {"statusCode":403,"message":"Forbidden"}
                  ford.0 2023-09-15 12:12:31.381 error AxiosError: Request failed with status code 403
                  ford.0 2023-09-15 12:12:31.381 error https://usapi.cv.ford.com/api/vehicles/v4/XX/status
                  ford.0 2023-09-15 12:12:31.371 error {"statusCode":403,"message":"Forbidden"}
                  ford.0 2023-09-15 12:12:31.371 error AxiosError: Request failed with status code 403
                  ford.0 2023-09-15 12:12:31.371 error https://usapi.cv.ford.com/api/vehicles/v2/XX/status
                  Da irgendein Zugang nicht gewährt wird, ist die Frage welcher und wie ich ihn bekomme. Die Zugangsdaten von Ford stimmen, auf der Ford Homepage kann ich mich damit anmelden.
                  Vielleicht kann sich einer der Sache mal annehmen, da ich nicht glaube, dass ich der einzige mit diesem Problem bin...
                  Viele Grüße
                  Dadsche
                  F P 2 Replies Last reply Reply Quote 0
                    falkomfs @dadsche last edited by
                    @dadsche sagte in Test Adapter Ford 0.0.x:
                    bei mir sind zur Zeit auch Fehlermeldungen seit gestern. Ich hatte auf 5 Minuten und ohne Haken, somit wird bei Ford etwas geändert worden sein. Da ich von dort nur die Reichweite und den SOC benutze war es mir erstmal nicht so wichtig und ich habe den Adapter auf Pause gestellt. Eventuell hat ja auch nur Ford gerade Probleme.
                    Falko
                      babl @falkomfs last edited by
                      @falkomfs Nein, Issue ist bereits bei github und TA2k ist bereits dran, weiß aktuell nur nicht was er meint mit der github version runterladen, habe auf github und expertenmodus gestellt bleib aber immer noch auf v 0.0.14
                        falkomfs @babl last edited by
                        @babl sagte in Test Adapter Ford 0.0.x:
                        Ok, wahrscheinlich bin ich bei solchen Sachen zu geduldig, wenn es nicht benötigt wird zum Leben kann ich warten und sehe nur hier im Forum unter neuen Einträgen nach. Aber schön zu wissen das daran gearbeitet wird.
                          tombox @falkomfs last edited by
                          @MiKKey sind denn alle Ford Nutzer betroffen?
                          Oder geht bei manchen noch die alte Version?
                          Ging der Adapter vorher mit den Fahrzeugen?
                          T M 2 Replies Last reply Reply Quote 0
                            tombox @tombox last edited by
                            v0.1.1 hat ein neuen status fetch und eine 12v Überwachung bei unter 12.2 stellt sich der adapter ab.
                            die neue API liefert enorm viele Daten
                              falkomfs @tombox last edited by
                              @tombox
                              Moin, also der Adapter ging vorher. Aber auch die v0.1.1 liefert keine Daten. In der App ist alles da.
                              Gruß Falko
                                @falkomfs ja bei mir auch, und die Log Datei kann man auch nicht runterladen, hier wird sofort zu Ford weitergeleitet.
                                  MiKKey @tombox last edited by MiKKey
                                  @tombox ich hab die Version 0.1.3 gerade einmal gecheckt. Kommt eine Menge an Infos mit.
                                  Muss gestehen hab länger nicht geschaut gehabt.
                                  Mir ist nicht aufgefallen, das die 0.0.14 nicht mehr ging…..
                                    ps-neotrace @dadsche last edited by
                                    @dadsche said in Test Adapter Ford 0.0.x:
                                    Moin, das Problem hatten wir anfangs auch. Das sich die Batterie leer saugt weil ich zu oft update. Ich habe da mal einen Gedankenansatz. Für mich ist es uninteressant wenn das Auto aus ist wie der Status ist, da der sich ja nicht mehr ändert. Wir haben hinten in unserem Tourneo Custom eine Seperate 12V Steckdose. Dort sitzt verbaut ein im Stecker montierter Shelly Uni, welcher lediglich die Spannung überwacht. Da unser Fahrzeug zudem mit einem Wifi ausgestattet ist, wird immer dann wenn die Spannung höher ist die Daten per MQTT (in unserem Fall über VPN) an meinen IOB weitergegeben. Somit ist sicher gestellt das das Auto läuft. Ich frage somit im Sekundentakt (kann auch Minutentakt sein) mein Auto ab, sobald die Bedingung erfüllt ist das das Fahrzeug läuft. Damit wird bei mir sicher verhindert das die Batterien leer gesaugt sind. Das Problem trat bei mit spannenderweise auch bereits 3 Tagen nach Kauf auf. Da ich einen Mild Hybrid fahre, soviel mal aus der Technik war es zudem so das wirklich alle Batterien im Auto leer waren! Also weder die Starter noch eine Andere Batterie hatte genug Spannung.
                                    Vieleicht hilft mein Lösungsansazt auch wenn er nicht unbedingt der Originale Weg ist 🙂
                                      @ps-neotrace die neuen Daten liefern den 12V Stand und der Adapter schaltet sich bei unter 12.2 V ab
                                        ps-neotrace @tombox last edited by
                                        @tombox Auch ne schöne Idee... Dann schau ich doch gleich mal wie der so läuft.
                                        • massenbach
                                          @tombox Hi, der Adapter wird bei mir nicht mehr grün. Ich verwende die 0.2.0. Ich bekomme keine Fehlermeldung, nur ein "Warn": "\r\n\r\n\r\n
                                            @massenbach Kann ich so nicht nachvollziehen sagt der log noch mehr oder auch mal username Passwort überprüft
                                            massenbach 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            101
                                            9350
