    4. js-controller 5.0.x jetzt für alle User im STABLE!
      sunny9999 @wendy2702 last edited by
      @wendy2702 @x4N70 @Latzi
      bei mir leider nicht mehr haut folgende Fehler raus :
      host.IOBROKER-MASTER
      2023-09-15 16:16:45.354	info	Restart adapter system.adapter.linux-control.0 because enabled
      2023-09-15 16:16:45.354	error	instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-09-15 16:16:45.354	error	Caught by controller[22]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.354	error	Caught by controller[22]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.354	error	Caught by controller[22]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.354	error	Caught by controller[22]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.354	error	Caught by controller[22]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.354	error	Caught by controller[21]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.354	error	Caught by controller[21]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.354	error	Caught by controller[21]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.354	error	Caught by controller[21]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.354	error	Caught by controller[20]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.354	error	Caught by controller[19]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.354	error	Caught by controller[19]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.354	error	Caught by controller[19]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.354	error	Caught by controller[19]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.354	error	Caught by controller[19]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.354	error	Caught by controller[18]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.354	error	Caught by controller[18]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.354	error	Caught by controller[18]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.354	error	Caught by controller[18]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.354	error	Caught by controller[18]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.354	error	Caught by controller[17]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.354	error	Caught by controller[17]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.353	error	Caught by controller[17]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.353	error	Caught by controller[17]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.353	error	Caught by controller[17]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.353	error	Caught by controller[16]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.353	error	Caught by controller[16]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.353	error	Caught by controller[16]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.353	error	Caught by controller[16]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.353	error	Caught by controller[15]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.353	error	Caught by controller[14]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.353	error	Caught by controller[14]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.353	error	Caught by controller[14]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.353	error	Caught by controller[14]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.353	error	Caught by controller[13]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.353	error	Caught by controller[12]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.353	error	Caught by controller[12]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.353	error	Caught by controller[12]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.353	error	Caught by controller[12]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.350	error	Caught by controller[11]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.350	error	Caught by controller[10]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.350	error	Caught by controller[10]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.350	error	Caught by controller[10]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.350	error	Caught by controller[10]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.350	error	Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[9]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[9]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[9]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[9]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[8]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[8]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[8]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[8]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[7]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[7]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[7]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[7]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[7]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[6]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[6]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[6]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[6]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[5]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[5]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[5]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[5]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[4]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[4]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[4]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[3]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[3]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.349	error	Caught by controller[3]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.349	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.349	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.349	error	Caught by controller[2]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.349	error	Caught by controller[2]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.348	error	Caught by controller[2]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.348	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.348	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.348	error	Caught by controller[1]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.348	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.348	error	Caught by controller[1]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      2023-09-15 16:16:45.348	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-09-15 16:16:45.348	error	Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-15 16:16:45.348	error	Caught by controller[0]: at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27)
      2023-09-15 16:16:45.348	error	Caught by controller[0]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15)
      2023-09-15 16:16:45.348	error	Caught by controller[0]: Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      2023-09-15 16:16:45.348	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      linux-control.0
      2023-09-15 16:16:44.899	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.899	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.899	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.898	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.897	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.897	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.896	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.896	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.888	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.888	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.888	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.887	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.885	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.885	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.885	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.885	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.875	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.875	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.875	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.874	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.872	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.872	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.872	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.872	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.857	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.857	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.857	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.854	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.854	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.854	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.854	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.795	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.795	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.794	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.794	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.792	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.792	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.791	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.773	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.772	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.772	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.772	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.770	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.770	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.769	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.769	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.677	error	The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.677	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.677	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.start" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.677	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.670	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.670	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.670	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.669	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.667	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.667	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.666	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.666	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.636	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.635	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.635	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.635	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.633	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.632	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.632	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.632	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.611	error	The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.611	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.610	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.stop" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.610	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:44.576	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      linux-control.0
      2023-09-15 16:16:44.575	info	terminating
      linux-control.0
      2023-09-15 16:16:44.575	info	cleaned everything up...
      linux-control.0
      2023-09-15 16:16:44.558	error	The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.558	error	Error: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
      linux-control.0
      2023-09-15 16:16:44.481	error	unhandled promise rejection: The pattern "io.linux-control.0.Monitor-PI.services.●.restart" is not a valid ID pattern
      linux-control.0
      2023-09-15 16:16:44.480	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      linux-control.0
      2023-09-15 16:16:38.470	info	getting data from Monitor-PI (192.168.10.25:22, Adapter start)
      linux-control.0
      2023-09-15 16:16:38.469	info	getting data from IO-SLAVE (192.168.10.17:22, Adapter start)
      linux-control.0
      2023-09-15 16:16:38.469	info	getting data from RDP-PI (192.168.10.65:22, Adapter start)
      linux-control.0
      2023-09-15 16:16:38.468	info	getting data from LABEL-PI (192.168.10.66:22, Adapter start)
      linux-control.0
      2023-09-15 16:16:38.431	info	starting. Version 1.1.6 (non-npm: Scrounger/ioBroker.linux-control#59f578f3402850684ba8767a24a9ff288b05a3f0) in /opt/iobroker/node_modules/iobroker.linux-control, node: v18.16.1, js-controller: 5.0.12
      Schon deinstalliert und neu installiert.
      Hab auch noch Probleme mit email und samsung_tizen adaptern..... Rest rennt
      Jemand noch nen Tip ?
      Sunny
      mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @sunny9999 last edited by
        Es gab da ein issue beim linux control
        https://github.com/Scrounger/ioBroker.linux-control/issues/49
        Keine Ahnung ob relevant für dein Problem. Abercschau mal rein.
        Strobelix80 created this issue in Scrounger/ioBroker.linux-control
        closed Error with js-controller 5.x #49
          Thomas Braun Most Active @sunny9999 last edited by
          @sunny9999 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
          ices.●.rest
          Dürfte ein illegales Zeichen an der Stelle sein.
          • Fabio
            Fabio @foxriver76 last edited by Fabio
            @foxriver76 @Bluefox eben kam das Update vom Javasript 7.1.4
            Das Exportieren der Scripte funktioniert wieder. Vielen Dank euch.....👍
            Fabio
            • MartinP
              MartinP @liv-in-sky last edited by
              @liv-in-sky said in js-controller 5.0.x jetzt für alle User im STABLE!:
              @foxriver76
              also sayit hat sich erledigt - neu installiert und jetzt kommt kein fehler
              das mit ws.5 ist etwas seltsam - habe nur ws.0 und ws.1 aktiv und ws.5 - habe jetzt ws5 abgeschaltet und in ws.2 definiert - dann startet alles ohne fehler und die vis ist wieder da
              diese ganzen ws.x hatte ich mal installiert und getestet, ob meine tablets die vis stabiler anzeigen, wenn jedes tablet eigene instanzen hat
              bleibt n nur noch diese warnung:
              	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
              Diese Warnung habe ich auch von simple-api.0 ... keine Antwort auf Deine Frage im Thread gefunden
              liv-in-sky foxriver76 mcm1957 3 Replies Last reply Reply Quote 0
                A Former User @mcm1957 last edited by
                @mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                Aktualisierung der Liste erforderlicher Adapterupdates:
                Weitere Adapter mit Problemen:
                • Adapter FITBIT-FITNESS ist mit js-controlelr 5 inkompatibel. Dev hat auf Issue aus April bisher nicht reagiert.
                  https://forum.iobroker.net/topic/68328/fitbit-app-läuft-mit-js-controller-5-0-12-nicht-mehr
                Das war bei mir am Anfang mit den Alpha 5.x, seit der 5.0.10 läuft der Fitbit Adapter einwandfrei.
                Node 18.17.0, NPM 9.6, Debian bookworm im lxc.
                • Duffy
                  Duffy @Thomas Braun last edited by
                  @thomas-braun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                  @duffy
                  Die Befehle, aber ohne sudo vorweg.
                  Danke dir vielmals.
                  Liebe Grüsse Duffy
                  • FredF
                    FredF Most Active Forum Testing last edited by
                    Master im Docker Container, sowie 2 Slaves ohne Probleme aktualisiert 👍
                    Danke für euren unermüdlichen Einsatz
                      liv-in-sky @MartinP last edited by
                      @martinp das liegt daran, dass ich auch keine antwort habe 😞
                      • foxriver76
                        foxriver76 Developer @MartinP last edited by
                        @martinp ist nur ne Warnung, gerne issues beim adapter erstellen
                        • mcm1957
                          mcm1957 @MartinP last edited by mcm1957
                          @martinp said in js-controller 5.0.x jetzt für alle User im STABLE!:
                          Siehe offenes Issue https://github.com/ioBroker/ioBroker.simple-api/issues/168
                          @foxriver76 FYI
                          Madaraxa created this issue in ioBroker/ioBroker.simple-api
                          closed Warning Lets Encrypt with JS Controller 5.x #168
                            emil70 last edited by emil70
                            Habe gerade upgedatet und bekomme bei Aufruf von iobrocker Info unter Übersicht im Webif von iobroker folgende Fehlermeldung
                            im Konsolenlog steht das
                            Error: Minified React error #31; visit https://reactjs.org/docs/error-decoder.html?invariant=31&args[]=object%20with%20keys%20%7BisDocker%2C%20isOfficial%2C%20officialVersion%7D for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
                                React 17
                                value IntroCard.jsx:289
                                onClick IntroCard.jsx:411
                                React 11
                                o helpers.ts:98
                            instrument.ts:132
                            Bin auf Github nicht angemeldet, daher poste ich das mal hier
                            Wo liegt da der Fehler??
                            Edit:
                            Skript v.2023-05-28-4
                            *** BASE SYSTEM ***
                            Hardware Vendor : Synology
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v7.0.0
                            model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                            Virtualization  : Unknown (buanet/Synology?)
                            Kernel          : x86_64
                            Userland        : amd64
                            Systemuptime and Load:
                             20:56:17 up 4 days,  4:25,  0 users,  load average: 2.23, 1.44, 1.02
                            CPU threads: 4
                            *** Time and Time Zones ***
                            Fri Sep 15 18:56:17 UTC 2023
                            Fri Sep 15 20:56:17 CEST 2023
                            CEST +0200
                            Etc/UTC
                            *** User and Groups ***
                            root
                            /root
                            root
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:             11G        3.0G        2.3G        154M        6.5G        8.2G
                            Swap:           9.1G         12M        9.1G
                            Total:           20G        3.1G         11G
                                    11822 M total memory
                                     3041 M used memory
                                     4722 M active memory
                                     2930 M inactive memory
                                     2315 M free memory
                                      891 M buffer memory
                                     5573 M swap cache
                                     9143 M total swap
                                       12 M used swap
                                     9131 M free swap
                            *** FILESYSTEM ***
                            Filesystem             Type   Size  Used Avail Use% Mounted on
                            /dev/mapper/cachedev_1 btrfs  3.5T  1.3T  2.3T  36% /
                            tmpfs                  tmpfs   64M     0   64M   0% /dev
                            tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
                            shm                    tmpfs   64M     0   64M   0% /dev/shm
                            /dev/mapper/cachedev_1 btrfs  3.5T  1.3T  2.3T  36% /opt/iobroker
                            /dev/mapper/cachedev_1 btrfs  3.5T  1.3T  2.3T  36% /etc/hosts
                            tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
                            tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
                            tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
                            Show mounted filesystems (real ones only):
                            TARGET  SOURCE        FSTYPE OPTIONS
                            /       /dev/mapper/cachedev_1[/@syno/@docker/btrfs/subvolumes/c9399b5c2c4c3ea75f19f1b7ac5a4265f4d5f18b3ada27d2f19bd08e781cf109]
                            |        btrfs  rw,node
                            |-/opt/iobroker
                            |       /dev/mapper/cachedev_1[/@syno/docker/iobroker_data]        btrfs  rw,node
                            |-/etc/resolv.conf
                            |       /dev/mapper/cachedev_1[/@syno/@docker/containers/5ea90685692b9aca72f0ab85e42da8cde040aae7fd4746bc1ffeb9c0ef253114/resolv.conf]
                            |        btrfs  rw,node
                            |-/etc/hostname
                            |       /dev/mapper/cachedev_1[/@syno/@docker/containers/5ea90685692b9aca72f0ab85e42da8cde040aae7fd4746bc1ffeb9c0ef253114/hostname]
                            |        btrfs  rw,node
                            `-/etc/hosts
                                    /dev/mapper/cachedev_1[/@syno/@docker/containers/5ea90685692b9aca72f0ab85e42da8cde040aae7fd4746bc1ffeb9c0ef253114/hosts]
        btrfs  rw,node
                            /var:
                            16M     /var/
                            13M     /var/lib/dpkg/info
                            13M     /var/lib/dpkg
                            13M     /var/lib
                            1.9M    /var/cache/debconf
                            /opt/iobroker/backups:
                            106M    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            1.1G    /opt/iobroker/iobroker-data/
                            986M    /opt/iobroker/iobroker-data/files
                            231M    /opt/iobroker/iobroker-data/files/vis-2-beta
                            143M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
                            142M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
                            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            31M     /opt/iobroker/iobroker-data/states.jsonl
                            24M     /opt/iobroker/iobroker-data/objects.jsonl
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                            20M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.eafc8c95.js.map
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Installed: 18.17.1-1nodesource1
                              Candidate: 18.17.1-1nodesource1
                              Version table:
                             *** 18.17.1-1nodesource1 100
                                    100 /var/lib/dpkg/status
                            No problems detected
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            No configuration change needed.
                            Multihost discovery server: disabled
                            Discovery authentication:   enabled
                            Persistent activation:      disabled
                            Objects:                    jsonl on 127.0.0.1
                            States:                     jsonl on 127.0.0.1
                            Core adapters versions
                            admin:          6.8.0
                            javascript:     7.1.4
                            Adapters from github:   15
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                              system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                            + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                              system.adapter.devices.0                : devices               : iobroker                                 - disabled
                            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                            + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                            + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
                              system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                              system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : iobroker                                 - disabled
                            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                            + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                              system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 80
                              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                            + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 125.123.8.49
                              system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
                            + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 -  enabled
                              system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                              system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled
                              system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 - disabled
                              system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                              system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                              system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                              system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                              system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            + system.adapter.vr200.0                  : vr200                 : iobroker                                 -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.weishaupt-wem.0          : weishaupt-wem         : iobroker                                 -  enabled
                            + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                            + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              system.adapter.yr.0                     : yr                    : iobroker                                 - disabled
                            + instance is alive
                            ioBroker-Repositories
                            Stable (default): http://download.iobroker.net/sources-dist.json
                            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                            Active repo(s): Stable (default)
                            Installed ioBroker-Instances
                            Used repository: Stable (default)
                            Adapter    "admin"        : 6.8.0    , installed 6.8.0
                            Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                            Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
                            Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                            Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
                            Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                            Adapter    "denon"        : 1.15.4   , installed 1.15.4
                            Adapter    "device-watcher": 2.9.3   , installed 2.9.3
                            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                            Adapter    "egigeozone"   : 0.1.2    , installed 0.1.2
                            Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                            Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                            Adapter    "hue"          : 3.9.5    , installed 3.9.5
                            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                            Adapter    "info"         : 1.9.26   , installed 1.9.26
                            Adapter    "iot"          : 1.14.5   , installed 1.14.5
                            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                            Controller "js-controller": 5.0.12   , installed 5.0.12
                            Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
                            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                            Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                            Adapter    "panasonic-comfort-cloud": 2.2.0, installed 2.2.0
                            Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                            Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
                            Adapter    "snmp"         : 2.4.11   , installed 2.4.11
                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                            Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                            Adapter    "synology"     : 2.1.13   , installed 2.1.13
                            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                            Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
                            Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                            Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                            Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                            Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                            Adapter    "vr200"        : 1.0.0    , installed 1.1.0
                            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                            Adapter    "web"          : 6.1.2    , installed 6.1.2
                            Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.16
                            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                            Adapter    "worx"         : 2.3.2    , installed 2.3.2
                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                            Adapter    "yahoo-stock-market": 0.0.5, installed 0.0.5
                            Adapter    "yr"           : 5.3.0    , installed 5.3.0
                            Objects and States
                            Objects:        24150
                            States:         28305
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Reading package lists... Done
                            Pending Updates: 9
                            *** Listening Ports ***
                            tcp        0      0 125.123.8.49:2010       0.0.0.0:*               LISTEN      1000       62065376   -
                            tcp        0      0 125.123.8.49:1883       0.0.0.0:*               LISTEN      1000       62067513   -
                            tcp        0      0 125.123.8.49:1884       0.0.0.0:*               LISTEN      1000       62067514   -
                            tcp        0      0 125.123.8.49:8701       0.0.0.0:*               LISTEN      1000       62065148   -
                            tcp        0      0 127.0.0.11:35749        0.0.0.0:*               LISTEN      0          47415874   -
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       62059118   -
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       62059105   -
                            tcp        0      0 125.123.8.49:9292       0.0.0.0:*               LISTEN      1000       62067785   -
                            tcp        0      0 125.123.8.49:2001       0.0.0.0:*               LISTEN      1000       62066798   -
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       62062684   -
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       62078963   -
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       62081022   -
                            udp        0      0 127.0.0.11:37225        0.0.0.0:*                           0          47415873   -
                            2023-09-15 20:55:39.783  - info: worx.0 (10532) Start MQTT connection
                            2023-09-15 20:55:40.290  - info: worx.0 (10532) MQTT connected to: iot.eu-west-1.worxlandroid.com
                            2023-09-15 20:55:40.355  - info: worx.0 (10532) Request Counter: 1
                            2023-09-15 20:55:40.490  - info: host.iobroker instance system.adapter.iqontrol.0 started with pid 10693
                            2023-09-15 20:55:43.343  - info: iqontrol.0 (10693) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2023-09-15 20:55:43.377  - info: iqontrol.0 (10693) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v18.17.1, js-controller: 5.0.12
                            2023-09-15 20:55:43.504  - info: iqontrol.0 (10693) systemLanguage = de
                            2023-09-15 20:55:43.506  - info: iqontrol.0 (10693) Creating Passphrase...
                            2023-09-15 20:55:43.565  - info: iqontrol.0 (10693) Creating Popup States...
                            2023-09-15 20:55:44.433  - info: iqontrol.0 (10693) Creating Widget States...
                            2023-09-15 20:55:44.434  - info: iqontrol.0 (10693) Lists deactivated.
                            2023-09-15 20:55:44.434  - info: iqontrol.0 (10693) Deleting unused Objects...
                            2023-09-15 20:55:44.436  - info: iqontrol.0 (10693) Subscribing to states...
                            2023-09-15 20:55:44.439  - info: iqontrol.0 (10693) iQontrol ready.
                            2023-09-15 20:55:44.488  - info: web.0 (10374) ==> Connected system.user.admin from ::ffff:125.123.8.88
                            2023-09-15 20:55:47.120  - info: vis-google-fonts.0 (10745) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.17.1, js-controller: 5.0.12
                            2023-09-15 20:55:47.825  - info: vis-google-fonts.0 (10745) Terminated (NO_ERROR): Without reason
                            2023-09-15 20:55:48.140  - info: host.iobroker instance system.adapter.fully-tablet-control.0 started with pid 10837
                            2023-09-15 20:55:48.630  - info: host.iobroker instance system.adapter.vis-google-fonts.0 terminated while should be started once
                            2023-09-15 20:55:50.864  - info: fully-tablet-control.0 (10837) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2023-09-15 20:55:51.124  - info: fully-tablet-control.0 (10837) starting. Version 0.3.8 (non-npm: xXBJXx/ioBroker.fully-tablet-control#af138797fc2ddeb067b46b3248da63083d4b5a46) in /opt/iobroker/node_modules/iobroker.fully-tablet-control, node: v18.17.1, js-controller: 5.0.12
                            2023-09-15 20:55:57.250  - info: mqtt.0 (9561) Client [] connection closed: disconnected
                            2023-09-15 20:55:57.504  - info: mqtt.0 (9561) Client [] connected with secret 1694804157503_5368
                            2023-09-15 20:56:55.601  - info: mqtt.0 (9561) Client [] connection closed: disconnected
                            2023-09-15 20:56:57.867  - info: mqtt.0 (9561) Client [] connected with secret 1694804217866_6830
                                                 v.2023-05-28-4
                            Kernel          : x86_64
                            Userland        : amd64
                            Docker          : v7.0.0
                            Installation:           Docker
                            Kernel:                 x86_64
                            Userland:               amd64
                            Timezone:               Etc/UTC
                            User-ID:                0
                            X-Server:               false
                            Pending OS-Updates:     9
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                            MEMORY:
                            Mem:             11G        3.0G        2.4G        154M        6.5G        8.3G
                            Swap:           9.1G         12M        9.1G
                            Total:           20G        3.0G         11G
                            Active iob-Instances:   30
                            ioBroker Core:          js-controller           5.0.12
                                                    admin                   6.8.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                24150
                            States:                 28305
                            Size of iob-Database:
                            32M     /opt/iobroker/iobroker-data/states.jsonl
                            • Walter White
                              Walter White last edited by Walter White
                              Heute waren ja auch Updates für JS Adapter und so, und seitdem hat mich der Fritzbox Präsenz Adapter zusammen mit meiner Frau schon das zweite Mal abgemeldet, und meldet uns nicht wieder an.
                              Jetzt verfolgt uns die sicherheitskamera hier die ganze Zeit, weil die natürlich bei Abwesenheit scharf schaltet.
                              fb-checkpresence.0
                              2023-09-15 20:39:11.708 info newActive HeisenbergHandy false
                              Steht in den log files, unsere Handys sind selbstverständlich die ganze Zeit zu Hause und im WLAN.
                              Betrifft anscheinend aber nur die Handys welche direkt an der 7590 sind, kinderhandys sind weiterhin eingebucht aber sind jedoch auch am AVM 3000 welcher hier als Access Point läuft.
                              PS: WLAN im Handy aus und wieder anmachen meldet uns wieder an, aber ich habe in den logs auch keine rote oder gelbe Meldung dazu.
                              • mcm1957
                                mcm1957 @Walter White last edited by mcm1957
                                @walter-white said in js-controller 5.0.x jetzt für alle User im STABLE!:
                                fb-checkpresence.0
                                Sorry, aber mit den Infos können wir nur plaudern ...
                                Bitte um
                                • Versionen der betreffenden Adapter
                                • Fehler im Logfile bzw. Log Auszug
                                Warum ein Update des "und so" Adapters oder des "js" Adapters etwas am Adapter fb-presence bewirken soll, kann ich nicht sagen. Prüfe mal die logs des fb-presence adapters um den es offensichtlich geht. Falls kein erkennbarere oder zumindest zu vermutender Zusammenhang mit js-controller 5 existiert, itte neues Topic eröffnen und dort diskutieren.
                                Und natürlich - bitte adie Versionen der beteiligten Adapter angeben-
                                DANKE
                                • mcm1957
                                  mcm1957 @JohGre last edited by
                                  @johgre said in js-controller 5.0.x jetzt für alle User im STABLE!:
                                  @mcm57 Zur Info
                                  Habe gerade einen fork des community-Adapters gefunden der funktioniert. Vielleicht könnt ihr das zusammenlegen.
                                  https://github.com/PeterVoronov/ioBroker.botvac/tree/patch-1
                                  zugehöriger Thread:
                                  https://forum.iobroker.net/topic/44822/neato-botvac-adapter-further-development/45?_=1694772899628
                                  Ich habe nun die Infrastruktur des Adapter s so halbwegs auf den aktuellen Stand gebracht und ALPHA Version eingezogen. (2.0.0.alpha.1) Diese enthält auch den PR von PeterVoronov.
                                  Diese alpha Version ist vi github und via npm installierbar aber nicht in den Repositories gelistet.
                                  Über Feedback würde ich mich freuen.
                                  Um dieses Topic zu entpasten bitte die Diskussion incl. Feedback im oben genannten botvac topic https://forum.iobroker.net/topic/44822/neato-botvac-adapter-further-development/45?_=1694772899628 fortführen. Hier würde ich nur eine Notiz posten sobald eine offozielle mit js-controller 5 kompatible Version im Repository verfügbar ist.
                                  • Ben1983
                                    Ben1983 last edited by
                                    habe auf den 5.0.12 geupdatet.
                                    Bei Start des ioBrokers kam das hier: (Habe leider nur den Screenshot)
                                    dann habe ich noch:
                                    erst erschien immer dies hier:
                                    fitbit-fitness.0 2023-09-15 15:07:19.211	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    fitbit-fitness.0 2023-09-15 15:07:19.206	error	undefined is not a valid state value
                                    fitbit-fitness.0 2023-09-15 15:07:19.205	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9) at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
                                    fitbit-fitness.0 2023-09-15 15:07:19.199	error	unhandled promise rejection: undefined is not a valid state value
                                    fitbit-fitness.0 2023-09-15 15:07:19.197	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    seit heute morgen erscheint bei Adapterstart das hier:
                                    fitbit-fitness.0
                                    2023-09-16 07:43:24.360	error	Adapter Connection: Error: Error: Request failed with status code 401
                                    Samson71 mcm1957 2 Replies Last reply Reply Quote 0
                                    • Samson71
                                      Samson71 Global Moderator @Ben1983 last edited by
                                      @ben1983
                                      Warum hier jetzt nochmal? Gibt doch bereits einen eigenen Beitrag von Dir dazu. Auf den wird sogar im Laufe dieses Fadens hier verwiesen (glaube bei Post 73 oder so).
                                      • O
                                        oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by oFbEQnpoLKKl6mbY5e13
                                        @foxriver76
                                        Während in der ersten Nacht nach dem Upgrade auf 5.0.12 das Backup mit dem Backitup-Adapter einwandfrei lief, nun das in der zweiten Nacht:
                                        2023-09-16 01:31:59.954  - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                                        2023-09-16 01:31:59.955  - error: host.iobroker Caught by controller[0]: [907:0x68fdde0] 95686994 ms: Mark-sweep 3077.9 (4143.8) -> 3077.5 (4143.7) MB, 315.9 / 0.0 ms  (average mu = 0.734, current mu = 0.110) allocation failure; GC in old space requested
                                        2023-09-16 01:31:59.956  - error: host.iobroker Caught by controller[0]: [907:0x68fdde0] 95687315 ms: Mark-sweep 3078.1 (4144.1) -> 3077.8 (4144.1) MB, 302.1 / 0.0 ms  (average mu = 0.592, current mu = 0.059) allocation failure; scavenge might not succeed
                                        2023-09-16 01:31:59.956  - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
                                        2023-09-16 01:31:59.956  - error: host.iobroker Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                        2023-09-16 01:31:59.957  - error: host.iobroker Caught by controller[1]:  1: 0xb7a940 node::Abort() [io.backitup.0]
                                        2023-09-16 01:31:59.957  - error: host.iobroker Caught by controller[2]:  2: 0xa8e823  [io.backitup.0]
                                        2023-09-16 01:31:59.958  - error: host.iobroker Caught by controller[3]:  3: 0xd5c940 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.backitup.0]
                                        2023-09-16 01:31:59.958  - error: host.iobroker Caught by controller[4]:  4: 0xd5cce7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.backitup.0]
                                        2023-09-16 01:31:59.958  - error: host.iobroker Caught by controller[5]:  5: 0xf3a3e5  [io.backitup.0]
                                        2023-09-16 01:31:59.960  - error: host.iobroker Caught by controller[6]:  6: 0xf4c8cd v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.backitup.0]
                                        2023-09-16 01:31:59.960  - error: host.iobroker Caught by controller[7]:  7: 0xf26fce v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.backitup.0]
                                        2023-09-16 01:31:59.961  - error: host.iobroker Caught by controller[8]:  8: 0xf28397 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.backitup.0]
                                        2023-09-16 01:31:59.961  - error: host.iobroker Caught by controller[9]:  9: 0xf088e0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.backitup.0]
                                        2023-09-16 01:31:59.961  - error: host.iobroker Caught by controller[10]: 10: 0xf00354 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.backitup.0]
                                        2023-09-16 01:31:59.962  - error: host.iobroker Caught by controller[11]: 11: 0xf026e8 v8::internal::FactoryBase<v8::internal::Factory>::NewRawTwoByteString(int, v8::internal::AllocationType) [io.backitup.0]
                                        2023-09-16 01:31:59.962  - error: host.iobroker Caught by controller[12]: 12: 0x11dfc15 v8::internal::String::SlowFlatten(v8::internal::Isolate*, v8::internal::Handle<v8::internal::ConsString>, v8::internal::AllocationType) [io.backitup.0]
                                        2023-09-16 01:31:59.963  - error: host.iobroker Caught by controller[13]: 13: 0xd6874c v8::String::Utf8Length(v8::Isolate*) const [io.backitup.0]
                                        2023-09-16 01:31:59.963  - error: host.iobroker Caught by controller[14]: 14: 0xc64a91 node::StringBytes::Size(v8::Isolate*, v8::Local<v8::Value>, node::encoding) [io.backitup.0]
                                        2023-09-16 01:31:59.964  - error: host.iobroker Caught by controller[15]: 15: 0xc5ef28 int node::StreamBase::WriteString<(node::encoding)1>(v8::FunctionCallbackInfo<v8::Value> const&) [io.backitup.0]
                                        2023-09-16 01:31:59.964  - error: host.iobroker Caught by controller[16]: 16: 0xc5f985 void node::StreamBase::JSMethod<&(int node::StreamBase::WriteString<(node::encoding)1>(v8::FunctionCallbackInfo<v8::Value> const&))>(v8::FunctionCallbackInfo<v8::Value> const&) [io.backitup.0]
                                        2023-09-16 01:31:59.965  - error: host.iobroker Caught by controller[17]: 17: 0xdbaa30  [io.backitup.0]
                                        2023-09-16 01:31:59.965  - error: host.iobroker Caught by controller[18]: 18: 0xdbbf6f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.backitup.0]
                                        2023-09-16 01:31:59.965  - error: host.iobroker Caught by controller[19]: 19: 0x16fb7b9  [io.backitup.0]
                                        2023-09-16 01:31:59.966  - warn: host.iobroker instance system.adapter.backitup.0 terminated due to SIGABRT
                                        Mein NAS hat 16GB RAM.
                                        foxriver76 ? 2 Replies Last reply Reply Quote 0
                                          babl last edited by babl
                                          Gelöscht, da mein Fehler
                                            liv-in-sky last edited by liv-in-sky
                                            habe nochmal das update durchgeführt - vorher die neuen ws, web, und socket updates - und nun sieht es besser aus - bisher keine fehler beim anzeigen der vis
                                            dieser fehler wurde noch angezeigt
                                            ws.2
                                            2023-09-16 09:19:05.317	error	Invalid pattern on subscribe: The pattern " scale(1, 1)" is not a valid ID pattern
                                            ws.2
                                            2023-09-16 09:19:05.317	error	Invalid pattern on subscribe: The pattern "0% { transform: scale(1, 1)" is not a valid ID pattern
                                            konnte jedoch das widget mit einem falschen html code entdecken und ändern - daher ist auch diese fehlermeldung weg 🙂
                                            werd jetzt mal weiter beobachten, ob noch fehler kommen
                                            etwas mehr cpu load wird erzeugt - die lücke ist die update zeit
                                            sigi234 Dr. Bakterius 2 Replies Last reply Reply Quote 0
                                            js-controller stable upgrade
                                            82
                                            509
                                            130812
