    4. Iobroker Admin Webseite nicht erreichbar
      fastfoot @Schtallone last edited by
      @schtallone sieht top aus. ein allerletzter versuch:
      iob add admin.1 --port 4711
      danach http://192.168.1.10:4711
        Schtallone @fastfoot last edited by
        @fastfoot said in Iobroker Admin Webseite nicht erreichbar:
        root@iobroker:/opt/iobroker# iob add admin.1 --port 4711
        host.iobroker create instance admin
        host.iobroker object system.adapter.admin.1.alive created
        host.iobroker object system.adapter.admin.1.connected created
        host.iobroker object system.adapter.admin.1.compactMode created
        host.iobroker object system.adapter.admin.1.cpu created
        host.iobroker object system.adapter.admin.1.cputime created
        host.iobroker object system.adapter.admin.1.memHeapUsed created
        host.iobroker object system.adapter.admin.1.memHeapTotal created
        host.iobroker object system.adapter.admin.1.memRss created
        host.iobroker object system.adapter.admin.1.uptime created
        host.iobroker object system.adapter.admin.1.inputCount created
        host.iobroker object system.adapter.admin.1.outputCount created
        host.iobroker object system.adapter.admin.1.eventLoopLag created
        host.iobroker object system.adapter.admin.1.sigKill created
        host.iobroker object system.adapter.admin.1.logLevel created
        host.iobroker object system.adapter.admin.upload created
        host.iobroker object admin.1.info created
        host.iobroker object admin.1 created
        host.iobroker object admin.1.info.connected created
        host.iobroker object admin.1.info.connection created
        host.iobroker object admin.1.info.newsFeed created
        host.iobroker object admin.1.info.newsETag created
        host.iobroker object admin.1.info.newsLastId created
        host.iobroker object admin.1.info.updatesList created
        host.iobroker Set default value of admin.1.info.connected:
        host.iobroker Set default value of admin.1.info.connection: false
        host.iobroker Set default value of admin.1.info.updatesList:
        host.iobroker object system.adapter.admin.1 created
        aber kein Zugriff
        • Glasfaser
          Glasfaser @Schtallone last edited by
          @schtallone sagte in Iobroker Admin Webseite nicht erreichbar:
          @glasfaser
          Firefox im privaten Modus mit der genannten IP http://192.168.1.10:8081 geht nicht
          Nimm mal einen Browser mit dem du noch nie ioBroker aufgerufen hast !
            aber kein Zugriff
            also jetzt bin ich wirklich am Ende meines Wissens. Alle Einstellungen scheinen zu stimmen, du rufst richtig mit http:// auf, das Start Log sieht super aus
            wenn du aus windows auf die 192.168.1.10 pingst, geht das?
              192.168.1.10
              ja, keine Paketverluste
                Schtallone @Glasfaser last edited by
                @glasfaser
                Edge wäre der Browser gewesen, aber geht auch nicht
                • Glasfaser
                  @schtallone
                  Was hast du sonst noch ...
                  Firewall
                  Pi-Hole
                  Adblocker
                    @schtallone
                    mit Handy?
                    Hast du einen Ad-Blocker am Laufen(der private Mode sollte den eig. ausgeschaltet haben)
                      @fastfoot
                      Ad-blocker ist deaktiviert. Mit HAndy auch probiert, kein Zugriff. WIndows Firewall läuft
                      Glasfaser F 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        Glasfaser @Schtallone last edited by Glasfaser
                        @schtallone
                        Nur mal zum mitschreiben ...
                        du hast ein Probleme gehabt mit deinem bestehenden Container / iobroker
                        Neuen Container mit ioBroker erstellt inkl. der neuen IP 192.168.1.10
                        dann gestartet und per backitup dein Backup eingespielt
                        Nach der Restore danach kein zugriff mehr über die IP 192.168.1.10
                        F S 2 Replies Last reply Reply Quote 0
                          @schtallone du solltest eig. auch ein qnet-dhcp-eth0-79e6cc Netzwerk haben, kannst das im Portainer auswählen?
                          • Glasfaser
                            @fastfoot
                            Hat er
                            @glasfaser
                              fastfoot @Glasfaser last edited by
                              @glasfaser sagte in Iobroker Admin Webseite nicht erreichbar:
                              es ist nicht der hostname, iob l a hat das gezeigt und auch das Start-Log
                                Hat er
                                nein, das gezeigte ist statisch bei dem man die IP Adresse vorgibt, das dhcp holt sich die IP vom Router
                                  @glasfaser
                                  ja, ich habe den Container neu aufgesetzt und dann mit backup restore im Webfenster die wiederherstellung gemacht. Dies hat dann nicht funktioniert und dann kam ich auch nicht mehr auf den iobroker drauf. Dann habe ich mehrere male den Container erneuert und per console das restore gemacht.
                                  Letzenendes habe ich den persistenten Ordner aus einen Backup wiederhhergestellt und versucht, den iobroker damit wieder zzu starten (also so wie er vorgestern war) Das ist das Datum des Backups.
                                  Un da bin ich jetzt
                                    Schtallone @Schtallone last edited by
                                    So, ich habe mir nochmals die gemappten Ordner angeschaut im Portainer.
                                    So sah das aus:
                                    Ich habe nun die beiden komischen Einträge gelöscht und nur noch das binding von /opt/iobroker gelassen. Nachdem der Container neu aufgesetzt war, komme ich auf den iobroker drauf.
                                      ich frage michh nur, was das mit dem Zugriff zu tun haben soll.
                                        @schtallone du hast verschiedene iobroker installationen durch das mapping vorgegeben, das kann nicht funktionieren.
                                        dass du dieses Mapping verändert hast hattest du aber nicht erwähnt!!
                                          @fastfoot
                                          Ich hatte es auch nicht verändert. Das habe ichh so von dem vorher funktionierenden Container übernommen.
                                          Ich habe mir aber paralell zu unseren Diskussionen hier auch nochmals von Buanet die Tutorials durchgelesen und da war nur von dem einen Binding die Rede.
                                            Nichts desto Trotz: Sehr sehr vielen DANK! Für Eure Hilfe hier und Eure Ausdauer zu dieser unnchristlichen Zeit.
                                            Ich starte gerade alle Adapter und es sieht sehr gut aus bisher. Morgen geht es weiter. Gute Nacht und nochmals vielen DANK an Euch.
                                            115
                                            18583
