    4. Performance Probleme durch Shelly Adapter?
      Schtallone @Homoran last edited by Schtallone
      @Homoran
      Copy text starting here:
                           v.2023-06-20
      model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.1.0
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.8G        5.3G        854M        238M        1.6G        1.6G
      Swap:            23G        1.7G         21G
      Total:           31G        7.0G         22G
      Active iob-Instances:   23
      Active repo(s): beta
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                10441
      States:                 8960
      Size of iob-Database:
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      16M     /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      S Homoran 2 Replies Last reply Reply Quote 0
        Schtallone @Schtallone last edited by
        Skript v.2023-06-20
        *** BASE SYSTEM ***
        cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
        Hardware Vendor :
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.1.0
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         12:41:54 up 22:06,  0 users,  load average: 8.64, 8.88, 8.33
        CPU threads: 2
        *** Time and Time Zones ***
        Sat Sep 16 10:41:54 UTC 2023
        Sat Sep 16 12:41:54 CEST 2023
        CEST +0200
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            7.8G        5.2G        1.1G        238M        1.5G        1.9G
        Swap:            23G        1.7G         21G
        Total:           31G        6.8G         22G
                 7792 M total memory
                 5170 M used memory
                 2476 M active memory
                 2644 M inactive memory
                 1076 M free memory
                  512 M buffer memory
                 1032 M swap cache
                23447 M total swap
                 1659 M used swap
                21787 M free swap
        *** FILESYSTEM ***
        Filesystem            Type     Size  Used Avail Use% Mounted on
        overlay               overlay  2.6T  1.6T  1.1T  61% /
        tmpfs                 tmpfs     64M     0   64M   0% /dev
        tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/fs/cgroup
        shm                   tmpfs     64M     0   64M   0% /dev/shm
        /dev/mapper/cachedev1 ext4     2.6T  1.6T  1.1T  61% /opt/iobroker
        tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/asound
        tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/acpi
        tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/scsi
        tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/firmware
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems (real ones only):
        TARGET           SOURCE        FSTYPE OPTIONS
        /opt/iobroker    /dev/mapper/cachedev1[/Docker/iobroker]        ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
        /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/resolv.conf] ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
        /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hostname]    ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
        /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hosts]       ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
        /var:
        33M     /var/
        31M     /var/lib
        18M     /var/lib/apt/lists
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        987M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        639M    /opt/iobroker/iobroker-data/
        415M    /opt/iobroker/iobroker-data/files
        132M    /opt/iobroker/iobroker-data/files/javascript.admin
        129M    /opt/iobroker/iobroker-data/files/devices.admin/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.f95354b8.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        *** NodeJS-Installation ***
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    jsonl on 127.0.0.1
        States:                     jsonl on 127.0.0.1
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.10.1
        javascript:     7.1.4
        Adapters from github:   1
        Adapter State
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 - disabled
          system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.meross.0                 : meross                : iobroker                                 - disabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 192.168.1.10
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.10
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
          system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 192.168.1.10, run as: admin
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "device-watcher": 2.9.3   , installed 2.9.3
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "pushover"     : 3.0.4    , installed 3.0.4
        Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
        Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "snmp"         : 2.4.11   , installed 2.4.11
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "vw-connect"   : 0.1.2    , installed 0.1.2
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Objects:        10441
        States:         8960
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       5569456    -
        tcp        0      0 192.168.1.10:1880       0.0.0.0:*               LISTEN      1000       9092066    -
        tcp        0      0 192.168.1.10:1882       0.0.0.0:*               LISTEN      1000       9247890    -
        tcp        0      0 127.0.0.11:44959        0.0.0.0:*               LISTEN      0          5407964    -
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5422351    -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5422233    -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5425094    -
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5536059    -
        tcp6       0      0 :::8088                 :::*                    LISTEN      1000       5535121    -
        udp        0      0 0.0.0.0:38695           0.0.0.0:*                           1000       5552420    -
        udp        0      0 127.0.0.11:60125        0.0.0.0:*                           0          5407963    -
        udp        0      0 0.0.0.0:46182           0.0.0.0:*                           1000       5552419    -
        2023-09-15 00:37:02.337  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032ab94e10 / shellyplus1pm#a8032ab94e10#1) (false)
        2023-09-15 00:37:03.121  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a876248"
        2023-09-15 00:37:04.440  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e5f74" connected!
        2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8b94fc"
        2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d970"
        2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8bf730"
        2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
        2023-09-15 00:37:05.295  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a863524 / shellyplus2pm#b8d61a863524#1) (false)
        2023-09-15 00:37:05.587  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-3c610579bd34 / shellyplus1pm#3c610579bd34#1) (false)
        2023-09-15 00:37:06.868  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a863524"
        2023-09-15 00:37:07.457  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-3c610579bd34"
        2023-09-15 00:37:07.722  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-4022d8da969c / shellyplus2pm#4022d8da969c#1) (false)
        2023-09-15 00:37:07.785  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-7c87ce65d794 / shellyplus1pm#7c87ce65d794#1) (false)
        2023-09-15 00:37:11.460  - info: modbus.0 (411) Connected to slave 192.168.1.47
        2023-09-15 00:37:12.224  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23ecce4" connected!
        2023-09-15 00:37:14.432  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23e5f74 / shellyplus2pm#5443b23e5f74#1) (false)
        2023-09-15 00:37:22.217  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23ecce4 / shellyplus2pm#5443b23ecce4#1) (false)
        2023-09-15 00:37:25.564  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23fd3dc" connected!
        2023-09-15 00:37:27.320  - info: modbus.0 (411) Disconnected from slave 192.168.1.47
        2023-09-15 00:37:29.078  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1pm-a8032abc230c" connected!
        2023-09-15 00:37:30.096  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e1a90" connected!
        2023-09-15 00:37:35.564  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23fd3dc / shellyplus2pm#5443b23fd3dc#1) (false)
        2023-09-15 00:37:36.407  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-4022d8dbe474" connected!
        2023-09-15 00:37:38.493  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1-441793a820f4" connected!
        2023-09-15 00:37:38.853  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032abc230c / shellyplus1pm#a8032abc230c#1) (false)
        iob diag has finished.
          Thomas Braun Most Active @Schtallone last edited by
          @schtallone
          CPU threads: 2
          Dürfte was wenig sein. Und dann scheint da abgesehen vom iobroker noch anderes rechenintensives Zeug auf der Kiste zu laufen.
            Homoran Global Moderator Administrators @Schtallone last edited by
            @schtallone sagte in Performance Probleme durch Shelly Adapter?:
            wenn das ein Rechner wäre, auf dem nur ioBroker liefe, wäre diese CPUBdurchaus zu gebrauchen
            Ein NAS hat natürlich noch weitere Aufgaben.
            Was sagt denn in dessen GUI die CPU-Auslastung?
            Was läuft da sonst noch?
              Homoran Global Moderator Administrators @Homoran last edited by
              @homoran sagte in Performance Probleme durch Shelly Adapter?:
              was ist das denn für ein NAS?
              wenn schon der Docker
              Mem: 7.8G
              zur Verfügung hat müsste das NAS ja deutlich mehr haben.
              Davon gibt es nicht viele.
              Schon gar nicht mit Celeron J4005.
                Schtallone @Thomas Braun last edited by
                ist nen QNAP TS251D mit 8gb RAM.
                Hier aktuelle Performance-Monitor Daten:
                Homoran ? 3 Replies Last reply Reply Quote 0
                  vom NAS selbst?
                    ja vom NAS. hier nochmals in größer
                      @schtallone
                      Da wanken auch drei Zombies durch das System.
                      Starte das mal alles sauber durch.
                        was ist daran größer?
                        die Schrift jedenfalls nicht
                          hier nochhmals ohne diesen balken....
                            Homoran Global Moderator Administrators @Schtallone last edited by Homoran
                            @schtallone was ist passiert?
                            nur noch 22%CPU statt vorher 66?
                            der js controller auf vernünftigen 3.18, statt 20
                              nichts, es schwankt hin und her. Ich habe durchschittlich ca. 70% CPU Auslastung gehabt. Ich starte das NAS einmal komplett neu. Bis gleich
                              • Glasfaser
                                Glasfaser @Schtallone last edited by Glasfaser
                                486 iobroker 20 0 1063652 151672 9988 S 0,3 1,9 3:27.47 io.admin.0
                                499 iobroker 20 0 866856 76112 8560 S 0,0 1,0 1:46.15 io.admin.1
                                Warum hast du 2 x Admin
                                und was ich mich auch schon im anderen Thread gefragt habe
                                warum bist du BETA Tester ... hat das ein Grund !?
                                EDIT :
                                Wegen admin.1 , das war noch von gestern eine Test wegen dem Port , den kannst du deinstallieren
                                https://forum.iobroker.net/post/1044331
                                  A Former User @Schtallone last edited by
                                  Moin,
                                  kenne QNAP nicht, aber wenn Dein Docker und die darin enthaltenen Container schon ein Großteil des Memory auffressen, dann bleibt für das Basisbetriebssystem nicht mehr viel, man sieht auch, dass das Betriebssystem schon mal gut 1.7 GB in den Swap verschoben hat.
                                  Der Tipp kam ja schon, einmal sauber neu starten, dann mal alles auf der QNAP anhalten, was Du definitiv nicht brauchst.
                                  Bei mir auf der Synology sieht das mit 17 Containern und 8 GB so aus,
                                  VG
                                  Bernd
                                  • Glasfaser
                                    @schtallone
                                    Da du im anderen Thread auch ein Binding beim Admin falsch hattest ,
                                    zeige mal
                                    iob list instances | grep port
                                      Schtallone @Glasfaser last edited by
                                      @glasfaser
                                      Admin.1 ist bereits deinstalliert.
                                      Ich bin kein BETA tester, eher BETA User 😉
                                      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • Glasfaser
                                        @schtallone
                                        Kommt die Ausgabe vom Befehl noch ...
                                        oder war es das gewesen , damit kann ich/wir nichts anfangen!?
                                        ich bin kein BETA tester, eher BETA User 😉
                                          • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
                                          und das ganze nochmal mit mqtt.1
                                          warum?
                                            Schtallone @Glasfaser last edited by Schtallone
                                            @glasfaser
                                            root@iobroker:/opt/iobroker# iob list instances | grep port
                                            Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
                                                at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
                                                at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                            256
                                            40618
