    4. Performance Probleme durch Shelly Adapter?
      Schtallone @Schtallone last edited by
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
      Hardware Vendor :
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.1.0
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       12:41:54 up 22:06,  0 users,  load average: 8.64, 8.88, 8.33
      CPU threads: 2
      *** Time and Time Zones ***
      Sat Sep 16 10:41:54 UTC 2023
      Sat Sep 16 12:41:54 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            7.8G        5.2G        1.1G        238M        1.5G        1.9G
      Swap:            23G        1.7G         21G
      Total:           31G        6.8G         22G
               7792 M total memory
               5170 M used memory
               2476 M active memory
               2644 M inactive memory
               1076 M free memory
                512 M buffer memory
               1032 M swap cache
              23447 M total swap
               1659 M used swap
              21787 M free swap
      *** FILESYSTEM ***
      Filesystem            Type     Size  Used Avail Use% Mounted on
      overlay               overlay  2.6T  1.6T  1.1T  61% /
      tmpfs                 tmpfs     64M     0   64M   0% /dev
      tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/fs/cgroup
      shm                   tmpfs     64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev1 ext4     2.6T  1.6T  1.1T  61% /opt/iobroker
      tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/asound
      tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/acpi
      tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/scsi
      tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/firmware
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems (real ones only):
      TARGET           SOURCE        FSTYPE OPTIONS
      /opt/iobroker    /dev/mapper/cachedev1[/Docker/iobroker]        ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/resolv.conf] ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hostname]    ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hosts]       ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      987M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      639M    /opt/iobroker/iobroker-data/
      415M    /opt/iobroker/iobroker-data/files
      132M    /opt/iobroker/iobroker-data/files/javascript.admin
      129M    /opt/iobroker/iobroker-data/files/devices.admin/static
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.f95354b8.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.meross.0                 : meross                : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 192.168.1.10
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.10
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
        system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 192.168.1.10, run as: admin
      + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "device-watcher": 2.9.3   , installed 2.9.3
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "meross"       : 1.15.1   , installed 1.15.1
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "pushover"     : 3.0.4    , installed 3.0.4
      Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
      Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "snmp"         : 2.4.11   , installed 2.4.11
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "vw-connect"   : 0.1.2    , installed 0.1.2
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Objects and States
      Objects:        10441
      States:         8960
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       5569456    -
      tcp        0      0 192.168.1.10:1880       0.0.0.0:*               LISTEN      1000       9092066    -
      tcp        0      0 192.168.1.10:1882       0.0.0.0:*               LISTEN      1000       9247890    -
      tcp        0      0 127.0.0.11:44959        0.0.0.0:*               LISTEN      0          5407964    -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5422351    -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5422233    -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5425094    -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5536059    -
      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       5535121    -
      udp        0      0 0.0.0.0:38695           0.0.0.0:*                           1000       5552420    -
      udp        0      0 127.0.0.11:60125        0.0.0.0:*                           0          5407963    -
      udp        0      0 0.0.0.0:46182           0.0.0.0:*                           1000       5552419    -
      2023-09-15 00:37:02.337  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032ab94e10 / shellyplus1pm#a8032ab94e10#1) (false)
      2023-09-15 00:37:03.121  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a876248"
      2023-09-15 00:37:04.440  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e5f74" connected!
      2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8b94fc"
      2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d970"
      2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8bf730"
      2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
      2023-09-15 00:37:05.295  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a863524 / shellyplus2pm#b8d61a863524#1) (false)
      2023-09-15 00:37:05.587  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-3c610579bd34 / shellyplus1pm#3c610579bd34#1) (false)
      2023-09-15 00:37:06.868  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a863524"
      2023-09-15 00:37:07.457  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-3c610579bd34"
      2023-09-15 00:37:07.722  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-4022d8da969c / shellyplus2pm#4022d8da969c#1) (false)
      2023-09-15 00:37:07.785  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-7c87ce65d794 / shellyplus1pm#7c87ce65d794#1) (false)
      2023-09-15 00:37:11.460  - info: modbus.0 (411) Connected to slave 192.168.1.47
      2023-09-15 00:37:12.224  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23ecce4" connected!
      2023-09-15 00:37:14.432  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23e5f74 / shellyplus2pm#5443b23e5f74#1) (false)
      2023-09-15 00:37:22.217  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23ecce4 / shellyplus2pm#5443b23ecce4#1) (false)
      2023-09-15 00:37:25.564  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23fd3dc" connected!
      2023-09-15 00:37:27.320  - info: modbus.0 (411) Disconnected from slave 192.168.1.47
      2023-09-15 00:37:29.078  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1pm-a8032abc230c" connected!
      2023-09-15 00:37:30.096  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e1a90" connected!
      2023-09-15 00:37:35.564  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23fd3dc / shellyplus2pm#5443b23fd3dc#1) (false)
      2023-09-15 00:37:36.407  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-4022d8dbe474" connected!
      2023-09-15 00:37:38.493  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1-441793a820f4" connected!
      2023-09-15 00:37:38.853  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032abc230c / shellyplus1pm#a8032abc230c#1) (false)
      iob diag has finished.
        Thomas Braun Most Active @Schtallone last edited by
        @schtallone
        CPU threads: 2
        Dürfte was wenig sein. Und dann scheint da abgesehen vom iobroker noch anderes rechenintensives Zeug auf der Kiste zu laufen.
          Homoran Global Moderator Administrators @Schtallone last edited by
          @schtallone sagte in Performance Probleme durch Shelly Adapter?:
          model name : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
          wenn das ein Rechner wäre, auf dem nur ioBroker liefe, wäre diese CPUBdurchaus zu gebrauchen
          Ein NAS hat natürlich noch weitere Aufgaben.
          Was sagt denn in dessen GUI die CPU-Auslastung?
          Was läuft da sonst noch?
            Homoran Global Moderator Administrators @Homoran last edited by
            @homoran sagte in Performance Probleme durch Shelly Adapter?:
            was ist das denn für ein NAS?
            wenn schon der Docker
            Mem: 7.8G
            zur Verfügung hat müsste das NAS ja deutlich mehr haben.
            Davon gibt es nicht viele.
            Schon gar nicht mit Celeron J4005.
              Schtallone @Thomas Braun last edited by
              ist nen QNAP TS251D mit 8gb RAM.
              Hier aktuelle Performance-Monitor Daten:
              Homoran ? 3 Replies Last reply Reply Quote 0
                vom NAS selbst?
                  Schtallone @Homoran last edited by
                  ja vom NAS. hier nochmals in größer
                    @schtallone
                    Da wanken auch drei Zombies durch das System.
                    Starte das mal alles sauber durch.
                      was ist daran größer?
                      die Schrift jedenfalls nicht
                        hier nochhmals ohne diesen balken....
                          Homoran Global Moderator Administrators @Schtallone last edited by Homoran
                          @schtallone was ist passiert?
                          nur noch 22%CPU statt vorher 66?
                          der js controller auf vernünftigen 3.18, statt 20
                            nichts, es schwankt hin und her. Ich habe durchschittlich ca. 70% CPU Auslastung gehabt. Ich starte das NAS einmal komplett neu. Bis gleich
                            • Glasfaser
                              Glasfaser @Schtallone last edited by Glasfaser
                              486 iobroker 20 0 1063652 151672 9988 S 0,3 1,9 3:27.47 io.admin.0
                              499 iobroker 20 0 866856 76112 8560 S 0,0 1,0 1:46.15 io.admin.1
                              Warum hast du 2 x Admin
                              und was ich mich auch schon im anderen Thread gefragt habe
                              warum bist du BETA Tester ... hat das ein Grund !?
                              EDIT :
                              Wegen admin.1 , das war noch von gestern eine Test wegen dem Port , den kannst du deinstallieren
                              https://forum.iobroker.net/post/1044331
                                A Former User @Schtallone last edited by
                                Moin,
                                kenne QNAP nicht, aber wenn Dein Docker und die darin enthaltenen Container schon ein Großteil des Memory auffressen, dann bleibt für das Basisbetriebssystem nicht mehr viel, man sieht auch, dass das Betriebssystem schon mal gut 1.7 GB in den Swap verschoben hat.
                                Der Tipp kam ja schon, einmal sauber neu starten, dann mal alles auf der QNAP anhalten, was Du definitiv nicht brauchst.
                                Bei mir auf der Synology sieht das mit 17 Containern und 8 GB so aus,
                                VG
                                Bernd
                                • Glasfaser
                                  @schtallone
                                  Da du im anderen Thread auch ein Binding beim Admin falsch hattest ,
                                  zeige mal
                                  iob list instances | grep port
                                    Schtallone @Glasfaser last edited by
                                    @glasfaser
                                    Admin.1 ist bereits deinstalliert.
                                    Ich bin kein BETA tester, eher BETA User 😉
                                    Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      @schtallone
                                      Kommt die Ausgabe vom Befehl noch ...
                                      oder war es das gewesen , damit kann ich/wir nichts anfangen!?
                                      ich bin kein BETA tester, eher BETA User 😉
                                        • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
                                        und das ganze nochmal mit mqtt.1
                                        warum?
                                          Schtallone @Glasfaser last edited by Schtallone
                                          @glasfaser
                                          root@iobroker:/opt/iobroker# iob list instances | grep port
                                          Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
                                              at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
                                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                            Das ist in sich ein Widerspruch.
                                            256
                                            40536
