    4. Test Adapter Plex v1.1.x
      ticaki Developer last edited by ticaki
      v.1.1.1 demnächst im latest
      nur Fehlerbehebungen, kaum geändertes Verhalten.
      Ich weiß noch nciht ob ich die Metadata.*.Media.url Datenpunkte lassen oder entfernen soll. Unter Music ist er definiert und ein Link auf den abgespielten Inhalt. Das gibts auch für alles andere. Drin lassen und definieren (dann ist es eine url) oder raus werfen?
        liv-in-sky @ticaki last edited by
        @ticaki
        hi- habe auf neuen js-controller upgedatet - bekomme nun das
        host.iobroker59
        	2023-09-16 20:13:41.032	warn	Do not restart adapter system.adapter.plex.0 because restart loop detected
        host.iobroker59
        	2023-09-16 20:13:41.032	error	instance system.adapter.plex.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        plex.0
        	2023-09-16 20:13:40.355	error	400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
        plex.0
        	2023-09-16 20:13:40.355	error	StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:514:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:514:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:628:28) at IncomingMessage.emit (node:events:526:35) at endReadableNT (node:internal/streams/readable:1359:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        plex.0
        	2023-09-16 20:13:40.355	error	unhandled promise rejection: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
        plex.0
        	2023-09-16 20:13:40.355	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        plex.0
        	2023-09-16 20:13:40.341	error	400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
        plex.0
        	2023-09-16 20:13:40.341	error	StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:514:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:514:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:628:28) at IncomingMessage.emit (node:events:526:35) at endReadableNT (node:internal/streams/readable:1359:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        plex.0
        	2023-09-16 20:13:40.340	error	unhandled promise rejection: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
        plex.0
        	2023-09-16 20:13:40.340	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        plex.0
        	2023-09-16 20:13:40.311	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        plex.0
        	2023-09-16 20:13:40.310	info	terminating
        den api key habe ich neu eingerichtet und es kam auch kein fehler
        hast du eine ahnung, was da sein könnte
          ticaki Developer @liv-in-sky last edited by
          @liv-in-sky
          Noch nicht 🙂
          Hab gerade einen neue Token abgerufen und es läuft bei mir. (dev-server) Kannst du das mal mit Debuglog wiederholen?
            @ticaki
            hast du den neuen js-controller ?
            host.iobroker59
               2023-09-16 20:44:43.541	warn	Do not restart adapter system.adapter.plex.0 because restart loop detected
            host.iobroker59
               2023-09-16 20:44:43.540	error	instance system.adapter.plex.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            plex.0
               2023-09-16 20:44:42.878	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            plex.0
               2023-09-16 20:44:42.878	info	terminating
            plex.0
               2023-09-16 20:44:42.878	info	Plex Adapter stopped und unloaded.
            plex.0
               2023-09-16 20:44:42.877	error	400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
               2023-09-16 20:44:42.877	error	StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:514:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:514:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:628:28) at IncomingMessage.emit (node:events:526:35) at endReadableNT (node:internal/streams/readable:1359:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            plex.0
               2023-09-16 20:44:42.877	error	unhandled promise rejection: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
               2023-09-16 20:44:42.877	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            plex.0
               2023-09-16 20:44:42.876	error	400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
               2023-09-16 20:44:42.876	error	StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:514:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:514:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:628:28) at IncomingMessage.emit (node:events:526:35) at endReadableNT (node:internal/streams/readable:1359:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            plex.0
               2023-09-16 20:44:42.876	error	unhandled promise rejection: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
               2023-09-16 20:44:42.876	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            plex.0
            plex.0
            plex.0
            plex.0
            plex.0
            plex.0
               2023-09-16 20:44:42.875	error	StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}} at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15) at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33) at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) at self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (node:events:514:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (node:events:514:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (node:events:628:28) at IncomingMessage.emit (node:events:526:35) at endReadableNT (node:internal/streams/readable:1359:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            plex.0
               2023-09-16 20:44:42.875	error	unhandled promise rejection: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
               2023-09-16 20:44:42.875	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            plex.0
               2023-09-16 20:44:42.875	error	400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
            plex.0
            plex.0
               2023-09-16 20:44:42.874	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            plex.0
               2023-09-16 20:44:42.841	debug	Retrieved Settings from Plex.
            plex.0
               2023-09-16 20:44:42.824	debug	Retrieved Playlists from Plex.
            plex.0
               2023-09-16 20:44:42.811	debug	Retrieved Libraries from Plex.
            plex.0
               2023-09-16 20:44:42.791	debug	StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}}
            plex.0
               2023-09-16 20:44:42.791	debug	Could not retrieve Users from Tautulli!
            plex.0
               2023-09-16 20:44:42.777	debug	Start getting client details _playing.aftr-f7c8166be109b676-com-plexapp-android - timeline,playback,mirror,playqueues,provider-playback - 192.168.178.202 - 32500
            plex.0
               2023-09-16 20:44:42.775	debug	setClientData config object from player _playing.aftr-f7c8166be109b676-com-plexapp-android is {"name":"AFTR","host":"192.168.178.202","address":"192.168.178.202","port":32500,"machineIdentifier":"f7c8166be109b676-com-plexapp-android","version":"9.30.0.3604","protocol":"plex","product":"Plex for Android (TV)","deviceClass":"mobile","protocolVersion":"1","protocolCapabilities":"timeline,playback,mirror,playqueues,provider-playback"}
            plex.0
               2023-09-16 20:44:42.775	debug	Create player with prefix "_playing.aftr-f7c8166be109b676-com-plexapp-android", localAddress "192.168.178.202" and port "32500"
            plex.0
               2023-09-16 20:44:42.773	debug	Retrieved Players from Plex. JSON: {"MediaContainer":{"size":1,"Server":[{"name":"AFTR","host":"192.168.178.202","address":"192.168.178.202","port":32500,"machineIdentifier":"f7c8166be109b676-com-plexapp-android","version":"9.30.0.3604","protocol":"plex","product":"Plex for Android (TV)","deviceClass":"mobile","protocolVersion":"1","protocolCapabilities":"timeline,playback,mirror,playqueues,provider-playback"}]}}
            plex.0
               2023-09-16 20:44:42.770	debug	Retrieved Servers from Plex.
            plex.0
               2023-09-16 20:44:41.720	debug	Retrieved playing now from plex server: {"size":0}
            plex.0
               2023-09-16 20:44:41.513	info	Establishing insecure connection to Plex Media Server...
            plex.0
               2023-09-16 20:44:41.474	info	starting. Version 1.1.1 (non-npm: iobroker-community-adapters/ioBroker.plex#2ef8ff88552fecba6bd199dc30349b9e8c4359c1) in /opt/iobroker/node_modules/iobroker.plex, node: v18.17.1, js-controller: 5.0.12
              @ticaki
              ok - habe mal alles mit tautulli rausgenommen - der adapter funktioniert jetzt
              das scheint mein problem zu sein - muss mich damit nochmal rihtig beschäftigen
                @liv-in-sky sagte in Test Adapter Plex v1.1.x:
                debug StatusCodeError: 400 - {"response":{"result":"error","message":"Invalid apikey","data":{}}} plex.0
                adapter.log.debug('Could not retrieve Users from Tautulli!');
                adapter.log.debug(err);
                Der Tautulli Api-key ist falsch. Dann trag ich den auch mal falsch ein und suche wo der absturz ist 🙂
                  @ticaki hatte ich eigentlich auch neu gemacht - ich versuch es nochmal
                    @ticaki
                    habe es nochmal neu eingerichtet - jetzt ist eine verbindung da - das war irgendwie mein eingestellter mist ! sorry
                      @liv-in-sky
                      2023-09-16 21:17:42.017  - error: plex.0 (127081) Tautulli configuration data are incorrect. IP: http://192.168.179.16 Port:  Api-Key: sddsaafadsass Error: RequestError: Error: getaddrinfo ENOTFOUND http
                      ab version 1.1.2
                      Nix zu sorryien 😄 , das war ein Fehler(seit 4 Jahren), ein Adapter sollte niemals abstürzen.
                        v1.1.2 ist auf dem Weg
                          sigi234 Forum Testing Most Active @ticaki last edited by sigi234
                          @ticaki sagte in Test Adapter Plex v1.1.x:
                          plex.0
                          2023-09-17 11:49:11.876	warn	Object of state "plex.0.events.Player" is missing the required property "common.type"
                          RAW:
                            "common": {
                              "name": "Player Information",
                              "write": false
                            "type": "channel",
                            "native": {},
                            "from": "system.adapter.plex.0",
                            "user": "system.user.admin",
                            "ts": 1694428241214,
                            "_id": "plex.0.events.Player",
                            "acl": {
                              "object": 1636,
                              "owner": "system.user.admin",
                            ticaki Developer @sigi234 last edited by
                            @sigi234
                            Hm dachte nur ich hätte diese Warnung... ok muß mal schauen wo das nun wieder her kommt.
                              @sigi234
                              Lösche mal die Ordner unter event, oder event gleich ganz. Das gehört da nicht mehr hin.
                                @sigi234
                                Läuft einwandfrei.👍
                                  Die Version 1.1.3 ist auf dem Weg ins stable, wenn keine Fehler gefunden werden.
                                  ca. 1 Woche
                                    @ticaki
                                    könntest du mir evtl helfen - was besagt diese fehlermeldung?
                                    plex.0
                                    2023-11-04 19:04:26.125	warn	catch() 122: {"message":"connect ECONNREFUSED 192.168.178.202:32500","name":"Error","stack":"Error: connect ECONNREFUSED 192.168.178.202:32500\n at AxiosError.from (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:837:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:3016:25)\n at RedirectableRequest.emit (node:events:526:35)\n at eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)\n at ClientRequest.emit (node:events:514:28)\n at Socket.socketErrorListener (node:_http_client:501:9)\n at Socket.emit (node:events:514:28)\n at emitErrorNT (node:internal/streams/destroy:151:8)\n at emitErrorCloseNT (node:internal/streams/destroy:116:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":700,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Plex-Token":"MB-e_x5Gu1AnqxTxHrGQ","X-Plex-Target-Client-Identifier":"f7c8166be109b676-com-plexapp-android","X-Plex-Client-Identifier":"5cc42810-6dc0-44b1-8c70-747152d4f7f9","X-Plex-Device-Name":"AFTR","User-Agent":"axios/1.5.1","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.202:32500/player/timeline/poll?wait=0&commandID=251"},"code":"ECONNREFUSED","status":null}
                                    die 202 ist der firetv cube - die meldung kommt eine zeit lang, dann verschwindet sie
                                    in welche richtung wird da was refused ?
                                      catch() 122
                                      Wenn du von den States nichts logs, lösche mal den Unterzweig zu diesem Player und starte den Adapter neu. Irgendwer hat mir doch erzählt das man das firetv nicht kontrollieren kann.
                                      Und schaue mal was du du hier für eine Antwort bekommst:
                                        da kommt keine verbindung möglich
                                        das löschn der dp und dann der start des adapters bringt keine fehler im moment
                                        ich muss aber mal morgen nochmal nachsehen, den das ganze kommt, wenn ich die server (plex,tautulli) und den tv( mit fire cube) alle gleichzeitig einschalte - evtl muss ich da eine rehenfolge beachten - geht gerade nicht 😞
                                          ticaki Developer @liv-in-sky last edited by ticaki
                                          @liv-in-sky
                                          Erstmal der Fehler ist egal, wird abgefangen und behandelt nervt nur im log. Aber durch das löschen der States ist entweder die ip oder der port verschwunden(weiß net mehr was es genau war) und damit weiß der Adapter das der Player das nicht unterstützt und versuchts erst garnicht.
                                          liv-in-sky 1 Reply Last reply Reply Quote 1
                                            @ticaki
                                            schau mal - ist wieder da - ic schalt mal das log der instanz auf "error" 🙂
                                               catch() 122: {"message":"connect ECONNREFUSED 192.168.178.202:32500","name":"Error","stack":"Error: connect ECONNREFUSED 192.168.178.202:32500\n at AxiosError.from (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:837:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:3016:25)\n at RedirectableRequest.emit (node:events:526:35)\n at eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)\n at ClientRequest.emit (node:events:514:28)\n at Socket.socketErrorListener (node:_http_client:501:9)\n at Socket.emit (node:events:514:28)\n at emitErrorNT (node:internal/streams/destroy:151:8)\n at emitErrorCloseNT (node:internal/streams/destroy:116:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":700,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Plex-Token":"MB-e_x5Gu1AnqxTxHrGQ","X-Plex-Target-Client-Identifier":"f7c8166be109b676-com-plexapp-android","X-Plex-Client-Identifier":"5cc42810-6dc0-44b1-8c70-747152d4f7f9","X-Plex-Device-Name":"AFTR","User-Agent":"axios/1.5.1","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.202:32500/player/timeline/poll?wait=0&commandID=128"},"code":"ECONNREFUSED","status":null}
                                            adapter plex tautulli
                                            25711
