Tasmota Aktualisierung nach ca. 3min mit MQTT/Sonoff Adapter
@wendy2702 sagte in Allgemeine Frage zu Shelly Produkten:
MINIMAL firmware please upgrade
Dazu konnte ich mittlerweile was finden.
Habe aber immer noch das Problem das Sensor Werte erst nach ca. 4 minuten aktualisiert werden
Hier mal ein Log vom MQTT, da kann man das ein/ausschalten sehen und später dann die aktualisierung der Sensor Werte
2023-09-15 21:13:41.047 - debug: mqtt.0 (3318) stateChange mqtt.0.info.connection: {"val":"DVES_836EE2","ack":true,"ts":1694805221045,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805221045} 2023-09-15 21:13:51.099 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:13:59.096 - debug: mqtt.0 (3318) stateChange mqtt.0.stat.tasmota_836EE2.RESULT: {"val":"{\"POWER\":\"ON\"}","ack":true,"ts":1694805239093,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805239093} 2023-09-15 21:13:59.098 - debug: mqtt.0 (3318) stateChange mqtt.0.stat.tasmota_836EE2.POWER: {"val":"ON","ack":true,"ts":1694805239093,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805239093} 2023-09-15 21:14:21.180 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:14:51.295 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:15:04.506 - debug: mqtt.0 (3318) stateChange mqtt.0.stat.tasmota_836EE2.RESULT: {"val":"{\"POWER\":\"OFF\"}","ack":true,"ts":1694805304502,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805304502} 2023-09-15 21:15:04.510 - debug: mqtt.0 (3318) stateChange mqtt.0.stat.tasmota_836EE2.POWER: {"val":"OFF","ack":true,"ts":1694805304502,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805304502} 2023-09-15 21:15:21.397 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:15:52.708 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:16:21.474 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:16:51.506 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:17:21.561 - debug: mqtt.0 (3318) Client [DVES_836EE2] pingreq 2023-09-15 21:17:24.017 - debug: mqtt.0 (3318) stateChange mqtt.0.tele.tasmota_836EE2.STATE: {"val":"{\"Time\":\"2023-09-15T21:17:23\",\"Uptime\":\"0T00:10:12\",\"UptimeSec\":612,\"Heap\":24,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":3,\"POWER\":\"OFF\",\"Wifi\":{\"AP\":1,\"SSId\":\"WANOSOHO\",\"BSSId\":\"6A:D7:9A:18:CE:BB\",\"Channel\":11,\"Mode\":\"11n\",\"RSSI\":76,\"Signal\":-62,\"LinkCount\":1,\"Downtime\":\"0T00:00:06\"}}","ack":true,"ts":1694805444015,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805444015} 2023-09-15 21:17:24.019 - debug: mqtt.0 (3318) stateChange mqtt.0.tele.tasmota_836EE2.SENSOR: {"val":"{\"Time\":\"2023-09-15T21:17:23\",\"ENERGY\":{\"TotalStartTime\":\"2023-09-15T15:26:07\",\"Total\":0.151,\"Yesterday\":0.000,\"Today\":0.151,\"Period\":3,\"Power\":0,\"ApparentPower\":0,\"ReactivePower\":0,\"Factor\":0.00,\"Voltage\":0,\"Current\":0.000}}","ack":true,"ts":1694805444015,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1694805444015}EDIT: Glaube ich habe es gefunden:
Welchen Wert habt ihr da so sinnvoller weise drin stehen?
Der aktuelle Sonoff-Adapter 2.5.7 hat ein Passwort Problem, man muss über Github die Version 3.0.2 installieren.
Ja @wendy2702 du hast es gefunden unter 10 geht nicht. -
@wendy2702 sagte in Tasmota Aktualisierung nach ca. 3min mit MQTT/Sonoff Adapter:
Was bedeutet das eigentlich: MINIMAL firmware please upgrade
Das bedeutet das die minimalste Firmware geflasht ist und der größte Speicher frei ist um eine normale Tasmota Firmware zu flashen.
Braucht man zum Bleistift um eine ESP-01S mit 512k zu flashen. -
@wendy2702 da wird das gut erklärt:
https://nous.technology/product/a1t/template.html -
warum das Template welches aktuell in meinem Nous ist ein anderes ist welches im Dokument erwähnt wird.
@wendy2702 wenn's nicht klappt, Werksreset und neu versuchen.
Wobei mir Rätsel, warum da nur minimal drauf ist. Laut Beschreibung sollte die fix fertig sein... -
@da_woody @wendy2702 ,
bei den neuen Tasmotaversionen wird beim OTA-Firmware-Update automatisch erst die Minimal-Version geladen und danach erst die angeforderte Firmware z.B. http://ota.tasmota.com/tasmota/release/tasmota-DE.bin.gz, wenn der Speicher zu klein ist.
Man muss ca. 2-3min warten, da 2 mal die Firmware geflasht wird, evtl. ist da was schief gelaufen.
Einfach die http://ota.tasmota.com/tasmota/release/tasmota-DE.bin.gz über OTA neu flashen. -
@wal schon OK. Nur bei einer neuen Dose sollte eigentlich keine minimal drauf sein...
sorry für die verzögerte Rückmeldung aber ich war mit anderen Dingen beschäftigt.
@Wal Das habe ich dank Google und deiner Erklärung jetzt verstanden und es sogar hingekommen die Deutsche FW zu flashen.
@da_Woody : da war keine Minimal drauf. Das kam halt nachdem ich einen Upgrade gestartet habe.
Der erste Plug läuft jetzt dank eurer aller Hilfe.
Eins noch,
Was muss ich in Tasmota ändern damit die Plugs einen eingängigen Namen im Router haben und was damit ein eingängiger Name in iobroker erscheint?
@wendy2702
zumindest bei mir so... -
@da_woody danke.
Werde ich nächstes Wochenende testen. Bin jetzt auf Dienstreise
