    4. Backup InfluxDB ioBroker
    • Marc Berg
      Marc Berg Most Active @danwir last edited by Marc Berg
      @danwir sagte in Backup InfluxDB ioBroker:
      Aber ich cheke das mal gegen und öffne mal die gepackten Dateien.
      Und am besten mal alles Mögliche hier als Screenshot oder Text in Code-Tags zeigen, dann kann man vielleicht was sehen.
        danwir @Marc Berg last edited by
        @marc-berg SO beide Maschinen nutzen den gleichen FritzBox Zugang und haben daher gleiche und alle Berechtigungen bzgl. lesen/schreiben.
        Backup auf Maschine (ALT, PI3)
        Started iobroker ...
        [DEBUG] [mount] - noserverino option: true
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.1/fritz.nas/ext_Festplatte/PI3+4_Backup /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - host.raspberrypi 10290 states saved
        [DEBUG] [iobroker] - host.raspberrypi 10997 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_17-13_51_05_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [influxDB] - InfluxDB-Backup for influxdb.0 is started ...
        [DEBUG] [influxDB] - Start InfluxDB Backup ...
        [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
        [DEBUG] [influxDB] - Packed 0MB so far...
        [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_17-13_51_37_influxdb.0_backupiobroker.tar.gz
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_17-13_51_37_influxdb.0_backupiobroker"
        [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_17-13_51_37_influxdb.0_backupiobroker" successfully deleted
        [DEBUG] [influxDB] - InfluxDB-Backup for influxdb.0 is finish
        [DEBUG] [influxDB] - InfluxDB-Backup for influxdb.1 is started ...
        [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_17-13_52_07_influxdb.1_backupiobroker.tar.gz
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_17-13_52_07_influxdb.1_backupiobroker"
        [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_17-13_52_07_influxdb.1_backupiobroker" successfully deleted
        [DEBUG] [influxDB] - InfluxDB-Backup for influxdb.1 is finish
        [DEBUG] [influxDB] - done
        [DEBUG] [cifs] - used copy path: /fritz.nas/ext_Festplatte/PI3+4_Backup
        [DEBUG] [cifs] - done
        [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
        [DEBUG] [clean] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        RESTORE auf neuer Maschine: (PI4)
        Fehler beim REstore:
          danwir @Marc Berg last edited by danwir
          @marc-berg kann das der Fehler sein ? bisschen klein die Dateien oder ? dafür das da 3 Monate dutzende Daten reinlaufen.
          Marc Berg 2 Replies Last reply Reply Quote 0
          • Marc Berg
            Ja, viel zu klein. Da läuft beim Backup schon was schief.
            • Marc Berg
              Ich habe dunkel in Erinnerung, dass auch @Thomas-Braun mit dem Mount auf der Fritzbox Probleme hatte. Vielleicht könnte er helfen? Da bin ich nicht fit genug, um sinnvoll helfen zu können. Aber zumindest haben wir die Ursache schon eingekreist.
                @marc-berg ich glaub ich hab ne Idee... 24ba82f6-bb9b-48e2-a972-3be99a6023ed-image.png
                ggf falsch herum .. teste
                korrektur .. war egal geht trotzdem nicht
                  @marc-berg ich könnte auch versuchen auf nen Stick am PI direkt .. aber keine Ahnung wie ich den als Ordner einrichten im iOBrocker Backup
                  • Marc Berg
                    Heißen die Buckets in der InfluxDB so wie unter "Name der Datenbank" angegeben?
                      Thomas Braun Most Active @Marc Berg last edited by
                      @marc-berg sagte in Backup InfluxDB ioBroker:
                      Richtig. Betrifft bei mir aber nur Backitup-Backups unter nodejs@20 auf einem per CIFS in /opt/iobroker/backup gemounteten ext4-Dateisystem eines FritzNAS. Alle anderen Konstellationen sind nicht betroffen.
                      • Marc Berg
                        Marc Berg Most Active @Thomas Braun last edited by Marc Berg
                        @thomas-braun sagte in Backup InfluxDB ioBroker:
                        Okay, danke! Scheinbar haben wir es hier doch noch mit einem anderen Problem zu tun.
                          @marc-berg ja Buckets heissen gleich
                          merkwürdig ist ja er macht ja das BAckup nur irgendwie ohne Inhalt. Das Backup läuft ja auch sauber im Log durch.
                          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_09_17-14_13_39_backupiobroker.tar.gz
                          [DEBUG] [influxDB] - InfluxDB-Backup for KNX is started ...
                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_17-14_13_57_KNX_backupiobroker.tar.gz
                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_17-14_13_57_KNX_backupiobroker"
                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_17-14_13_57_KNX_backupiobroker" successfully deleted
                          [DEBUG] [influxDB] - InfluxDB-Backup for KNX is finish
                          [DEBUG] [influxDB] - InfluxDB-Backup for IR_Lesekopf_Zaehler is started ...
                          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_09_17-14_13_57_IR_Lesekopf_Zaehler_backupiobroker.tar.gz
                          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_09_17-14_13_57_IR_Lesekopf_Zaehler_backupiobroker"
                          [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_09_17-14_13_57_IR_Lesekopf_Zaehler_backupiobroker" successfully deleted
                          [DEBUG] [influxDB] - InfluxDB-Backup for IR_Lesekopf_Zaehler is finish
                          [EXIT] 0
                          Marc Berg simatec 2 Replies Last reply Reply Quote 0
                          • Marc Berg
                            Ja, aber auch das eigentliche ioBroker Backup ist viel zu klein. Ich glaube weiterhin, dass da durch den Mount was verhunzt wird. Kannst du das Ganze mal ohne SMB Mount online bringen?
                              @marc-berg verrate mir wie ? was soll ich machen
                              • Marc Berg
                                Im Backitup Adapter alle "Storage locations" abschalten. Dann wird das Backup lokal unter /opt/iobroker/backups abgelegt. Da mal schauen, wie die Größen aussehen.
                                  @marc-berg okay interessant ..
                                  ca 3MB groß ... man was für ein dreck
                                  ahh moment influx vergessen mit zunhemen
                                  auch nur 10KB groß
                                  • Marc Berg
                                    auch nur 10KB groß
                                    Aber lässt sich die Datei nun öffnen?
                                    • simatec
                                      simatec Developer Most Active @danwir last edited by
                                      Stelle bitte für die Fritzbox smb auf 3.1.1.
                                      Sollte dies nicht funktionieren, erstelle erstmal ein lokales Backup, um zu schauen, ob es am Mount liegt.
                                      1570
