    3. Einsteigerfragen
    4. Installation
    5. Hilfe! js-controller und javascript Problem
    • I
      ioNewbie @Thomas Braun last edited by
      @thomas-braun said in Hilfe! js-controller und javascript Problem:
      sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
      sieht nach demselben Fehler aus:
      pi@iobroker:/etc/apt/sources.list.d $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
      Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
      Executing: /tmp/apt-key-gpghome.KIQN2h7mCD/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
      gpg: key DC30D7C23CBBABEE: public key "Debian Archive Automatic Signing Key (10/buster) <ftpmaster@debian.org>" imported
      gpg: Total number processed: 1
      gpg:               imported: 1
      pi@iobroker:/etc/apt/sources.list.d $ sudo apt update
      Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
      Reading package lists... Done
      W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
      E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      pi@iobroker:/etc/apt/sources.list.d $ sudo apt -t bullseye-proposed-updates install udev
      E: The value 'bullseye-proposed-updates' is invalid for APT::Default-Release as such a release is not available in the sources
        Thomas Braun Most Active @ioNewbie last edited by
        @ionewbie sagte in Hilfe! js-controller und javascript Problem:
        6ED0E7B82643E131
        Transferleistung gefragt...
        Der fehlende Key heißt 6ED0E7B82643E131...
        • I
          6ED0E7B82643E131
          omg, ja verstehe. habe nur die 314 Postings in dem von dir verlinkten Thread gesehen und Textsuche auf keys gemacht und als ich nichts gefunden habe, bin ich ausgestiegen, weil Wald und Bäume und so...
          Also der Schlüssel ist jetzt drin, und sudo apt update ergab folgendes Ergebnis:
          Get:5 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages [152 kB]
          Get:6 http://deb.debian.org/debian bullseye-proposed-updates/main Translation-en [94.8 kB]
          Fetched 247 kB in 1s (212 kB/s)
          Building dependency tree... Done
          23 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@iobroker:/etc/apt/sources.list.d $ apt list --upgradable
          Ich nehme an, die 23 Pakete ziehe ich jetzt mal mit dem dort angegebenen Befehl herein?
            Nein, nur das udev-Paket.
            Und dann löschst du die gerade angelegte .list-Datei auch wieder.
            • I
              ok, das udev war wohl vorher schon drin? und die bullseye Datei darf ich nicht löschen.
              udev is already the newest version (247.3-7+rpi1+deb11u2).
              The following package was automatically installed and is no longer required:
                raspinfo
              Use 'sudo apt autoremove' to remove it.
              0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
              pi@iobroker:/etc/apt/sources.list.d $ ls
              bullseye-proposed-updates.list  nodesource.list  raspi.list
              pi@iobroker:/etc/apt/sources.list.d $ rm bullseye-proposed-updates.list
              rm: remove write-protected regular file 'bullseye-proposed-updates.list'? y
              rm: cannot remove 'bullseye-proposed-updates.list': Permission denied
                @ionewbie
                sudo apt update
                apt policy udev
                • I
                  @thomas-braun es bleibt bei u2
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  pi@iobroker:/etc/apt/sources.list.d $ apt policy udev
                  udev:
                    Installed: 247.3-7+rpi1+deb11u2
                    Candidate: 247.3-7+rpi1+deb11u2
                    Version table:
                   *** 247.3-7+rpi1+deb11u2 500
                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                          100 /var/lib/dpkg/status
                       247.3-7+deb11u4 500
                          500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
                    @ionewbie
                    Dann wie in der Anleitung beschrieben:
                    sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                    sudo apt-mark hold udev
                    sudo rm /etc/apt/sources.list.d/bullseye-proposed-updates.list
                    sudo apt update
                    • I
                      das kam jetzt dabei heraus:
                      pi@iobroker:~ $ sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                        raspinfo
                      The following packages will be REMOVED:
                        libudev-dev
                      The following held packages will be changed:
                        udev
                      The following packages will be DOWNGRADED:
                        libudev1 udev
                      0 upgraded, 0 newly installed, 2 downgraded, 1 to remove and 23 not upgraded.
                      Need to get 1,602 kB of archives.
                      After this operation, 573 kB disk space will be freed.
                      Do you want to continue? [Y/n] y
                      Get:1 http://deb.debian.org/debian bullseye-proposed-updates/main armhf udev armhf 247.3-7+deb11u4 [1,440 kB]
                      Get:2 http://deb.debian.org/debian bullseye-proposed-updates/main armhf libudev1 armhf 247.3-7+deb11u4 [162 kB]
                      Fetched 1,602 kB in 0s (9,808 kB/s)
                      (Reading database ... 55082 files and directories currently installed.)
                      Removing libudev-dev:armhf (247.3-7+rpi1+deb11u2) ...
                      dpkg: warning: downgrading udev from 247.3-7+rpi1+deb11u2 to 247.3-7+deb11u4
                      (Reading database ... 55007 files and directories currently installed.)
                      Preparing to unpack .../udev_247.3-7+deb11u4_armhf.deb ...
                      Unpacking udev (247.3-7+deb11u4) over (247.3-7+rpi1+deb11u2) ...
                      dpkg: warning: downgrading libudev1:armhf from 247.3-7+rpi1+deb11u2 to 247.3-7+deb11u4
                      Preparing to unpack .../libudev1_247.3-7+deb11u4_armhf.deb ...
                      Unpacking libudev1:armhf (247.3-7+deb11u4) over (247.3-7+rpi1+deb11u2) ...
                      Setting up libudev1:armhf (247.3-7+deb11u4) ...
                      Setting up udev (247.3-7+deb11u4) ...
                      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      Processing triggers for initramfs-tools (0.140) ...
                      pi@iobroker:~ $ sudo apt-mark hold udev
                      udev set on hold.
                      pi@iobroker:~ $ sudo rm /etc/apt/sources.list.d/bullseye-proposed-updates.list
                      pi@iobroker:~ $ sudo apt update
                      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                      2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                      pi@iobroker:~ $ apt policy udev
                      udev:
                        Installed: 247.3-7+deb11u4
                        Version table:
                       *** **247.3-7+deb11u4** 100
                        @ionewbie
                        Jetzt passt es.
                        • I
                          ioNewbie @Thomas Braun last edited by ioNewbie
                          @thomas-braun und diese Schritte als nächstes? der JSController ist ja immer noch der alte
                          Diese hier?
                          cd /opt/iobroker/
                          sudo iobroker stop
                          sudo iobroker update
                          sudo iobroker upgrade self
                          sudo iobroker start
                            @ionewbie
                            NEIN!
                            iobroker wird NIE mit sudo angepackt.
                            • I
                              @thomas-braun sorry. Also diese hier:
                              iobroker stop
                              iobroker update
                              iobroker fix oder wenn das nicht funktioniert: curl -sL https://iobroker.net/fix.sh | bash -
                              iobroker start
                                @ionewbie
                                Gib mir nochmal die aktuelle Langfassung vom
                                iob diag
                                • I
                                  @thomas-braun hier:
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                           Icon name: computer
                                          Machine ID: 68716f4ecfa5426ea966c195a9cf7def
                                             Boot ID: 6aefc086b627460e8ca1c41a04001228
                                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 6.1.21-v8+
                                        Architecture: arm64
                                  Model           : Raspberry Pi 4 Model B Rev 1.2
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : armhf
                                  Systemuptime and Load:
                                   14:34:11 up 10 min,  2 users,  load average: 0.12, 0.48, 0.45
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  Other values than 0x0 hint to temperature/voltage problems
                                  temp=42.8'C
                                  volt=0.8625V
                                  *** Time and Time Zones ***
                                                 Local time: Sun 2023-09-17 14:34:11 CEST
                                             Universal time: Sun 2023-09-17 12:34:11 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            3.8G        441M        2.8G        0.0K        524M        3.3G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        441M        2.9G
                                           3794 M total memory
                                            441 M used memory
                                            519 M active memory
                                            327 M inactive memory
                                           2828 M free memory
                                             54 M buffer memory
                                            470 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       59G  7.0G   49G  13% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                  tmpfs          tmpfs     759M  836K  759M   1% /run
                                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                  /dev/sda1      exfat     118G  9.3M  118G   1% /media/usbstick
                                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                  [Sun Sep 17 14:23:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F8:36:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f61f07b-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Sun Sep 17 14:23:32 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Sun Sep 17 14:23:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Sun Sep 17 14:23:35 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  Show mounted filesystems (real ones only):
                                  TARGET            SOURCE         FSTYPE OPTIONS
                                  /                 /dev/mmcblk0p2 ext4   rw,noatime,nodiratime
                                  |-/boot           /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                  `-/media/usbstick /dev/sda1      exfat  rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,iocharset=utf8,errors=remount-ro
                                  /var:
                                  2.4G    /var/
                                  1.8G    /var/log/journal/68716f4ecfa5426ea966c195a9cf7def
                                  1.8G    /var/log
                                  323M    /var/cache
                                  Archived and active journals take up 1.7G in the file system.
                                  /opt/iobroker/backups:
                                  87M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  1.9G    /opt/iobroker/iobroker-data/
                                  1.7G    /opt/iobroker/iobroker-data/history
                                  126M    /opt/iobroker/iobroker-data/files
                                  52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  44M     /opt/iobroker/iobroker-data/backup-objects
                                  7.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                  7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                  5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                                  5.3M    /opt/iobroker/iobroker-data/files/knx.admin/static/js/2.00871907.chunk.js.map
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v18.17.1
                                  /usr/bin/node           v18.17.1
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Installed: 18.17.1-deb-1nodesource1
                                    Candidate: 18.17.1-deb-1nodesource1
                                    Version table:
                                   *** 18.17.1-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                       12.22.12~dfsg-1~deb11u4 500
                                  No problems detected
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
                                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-09-17T12_34_24_403Z-debug-0.log
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  No configuration change needed.
                                  Multihost discovery server: disabled
                                  Discovery authentication:   enabled
                                  Persistent activation:      disabled
                                  Objects:                    jsonl on 127.0.0.1
                                  States:                     jsonl on 127.0.0.1
                                  Core adapters versions
                                  js-controller:  4.0.24
                                  admin:          6.3.5
                                  javascript:     7.1.4
                                  Adapters from github:   0
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                    system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 - disabled
                                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                    system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                                    system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                    system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                    system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.10.190
                                    system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                                    system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                    system.adapter.powerfox2.0              : powerfox2             : iobroker                                 -  enabled
                                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
                                    system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
                                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                    system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                    system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                                    system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                                  Adapter    "alexa2"       : 3.24.1   , installed 3.23.2 [Updatable]
                                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                  Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                  Adapter    "daikin-cloud" : 0.3.0    , installed 0.2.3  [Updatable]
                                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                  Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
                                  Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                  Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
                                  Adapter    "knx"          : 2.0.22   , installed 2.0.17 [Updatable]
                                  Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                  Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
                                  Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                  Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
                                  Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                                  Adapter    "synology"     : 2.1.13   , installed 2.1.13
                                  Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                  Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
                                  Objects and States
                                  Objects:        2461
                                  States:         1869
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1872       482/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13925      482/iobroker.js-con
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       14238      834/io.shelly.0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13899      519/sshd: /usr/sbin
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14173      598/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17582      1027/io.web.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13901      519/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:46199           0.0.0.0:*                           108        1774       393/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1772       393/avahi-daemon: r
                                  udp        0      0 192.168.10.190:52781    0.0.0.0:*                           1001       16090      1296/io.knx.0
                                  udp        0      0 192.168.10.190:56912    0.0.0.0:*                           1001       23788      1296/io.knx.0
                                  udp        0      0 192.168.10.190:50885    0.0.0.0:*                           1001       16873      1296/io.knx.0
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15138      701/dhcpcd
                                  udp6       0      0 :::47730                :::*                                108        1775       393/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                108        1773       393/avahi-daemon: r
                                  2023-09-17 14:29:06.350  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  2023-09-17 14:30:00.117  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3666
                                  2023-09-17 14:30:02.100  - info: powerfox2.0 (3666) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-17 14:30:05.431  - info: powerfox2.0 (3666) Terminated (NO_ERROR): Without reason
                                  2023-09-17 14:30:05.987  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  2023-09-17 14:31:00.148  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3683
                                  2023-09-17 14:31:02.155  - info: powerfox2.0 (3683) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-17 14:31:05.186  - info: powerfox2.0 (3683) Terminated (NO_ERROR): Without reason
                                  2023-09-17 14:31:05.763  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  2023-09-17 14:32:00.093  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3700
                                  2023-09-17 14:32:02.065  - info: powerfox2.0 (3700) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-17 14:32:05.411  - info: powerfox2.0 (3700) Terminated (NO_ERROR): Without reason
                                  2023-09-17 14:32:05.943  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  2023-09-17 14:33:00.123  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3715
                                  2023-09-17 14:33:02.072  - info: powerfox2.0 (3715) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-17 14:33:06.034  - info: powerfox2.0 (3715) Terminated (NO_ERROR): Without reason
                                  2023-09-17 14:33:06.565  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  2023-09-17 14:34:00.133  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 3733
                                  2023-09-17 14:34:02.101  - info: powerfox2.0 (3733) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-17 14:34:05.015  - info: powerfox2.0 (3733) Terminated (NO_ERROR): Without reason
                                  2023-09-17 14:34:05.576  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  2023-09-17 14:35:00.112  - info: host.iobroker instance system.adapter.powerfox2.0 started with pid 4007
                                  2023-09-17 14:35:02.218  - info: powerfox2.0 (4007) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v18.17.1, js-controller: 4.0.24
                                  2023-09-17 14:35:06.498  - info: powerfox2.0 (4007) Terminated (NO_ERROR): Without reason
                                  2023-09-17 14:35:07.028  - info: host.iobroker instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
                                  • I
                                    ioNewbie @ioNewbie last edited by
                                    @ionewbie
                                    was ist mit den npm Errors, muss das gefixt werden und wie?
                                      Ja. Ich weiß nur noch nicht wie genau.
                                      iob update
                                      iob upgrade all
                                      sagt?
                                      • I
                                        @thomas-braun iob update bringt das hier.
                                        pi@iobroker:~ $ iob update
                                        ich gehe gerade den zweiten Befehl durch (upgrade all), muss bei jedem Paket einzeln bestätigen (y).
                                        Thomas Braun I 2 Replies Last reply Reply Quote 0
                                          So soll das sein.
                                          • I
                                            @ionewbie ok, die sind jetzt alle durch, ohne Fehler, wenn ich das richtig verfolgt habe.
                                            Willst du den kompletten output von Putty dazu?
                                            5923
